[geos-devel] 3.12 release warning
Paul Ramsey pramsey at cleverelephant.ca
Tue Jun 20 09:18:25 PDT 2023
> On Jun 20, 2023, at 9:16 AM, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
> On 6/20/23 17:58, Paul Ramsey wrote:
>>> On Jun 20, 2023, at 8:55 AM, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
>>> On 6/20/23 00:04, Paul Ramsey wrote:
>>>> Please, test 3.12beta2 and let us know if you’re finding any issues, I am planning to release 3.12 at the end of the week, if there are no reports of issues with the last beta release.
>>> r-cran-rgeos 0.6-1 is failing its test suite with beta2:
>>> https://qa.debian.org/excuses.php?experimental=1&package=geos
>> Can you break this down for me? What GEOS function is failing on what inputs? I cannot do a lot with
>>> run-unit-test        FAIL non-zero exit status 1
>> Thanks!
> You need to scroll up for the output of the failing test:
> autopkgtest [23:08:41]: test run-unit-test: [-----------------------
> R version 4.3.1 (2023-06-16) -- "Beagle Scouts"
> Copyright (C) 2023 The R Foundation for Statistical Computing
> Platform: x86_64-pc-linux-gnu (64-bit)
> R is free software and comes with ABSOLUTELY NO WARRANTY.
> You are welcome to redistribute it under certain conditions.
> Type 'license()' or 'licence()' for distribution details.
> R is a collaborative project with many contributors.
> Type 'contributors()' for more information and
> 'citation()' on how to cite R or R packages in publications.
> Type 'demo()' for some demos, 'help()' for on-line help, or
> 'help.start()' for an HTML browser interface to help.
> Type 'q()' to quit R.
> > library(testthat)
> > library(rgeos)
> Loading required package: sp
> rgeos version: 0.6-1, (SVN revision 692)
> GEOS runtime version: 3.12.0beta2-CAPI-1.18.0
> Please note that rgeos will be retired during 2023,
> plan transition to sf functions using GEOS at your earliest convenience.
> GEOS using OverlayNG
> Linking to sp version: 1.5-1
> Polygon checking: TRUE
> Warning message:
> In fun(libname, pkgname) :
>  rgeos: versions of GEOS runtime 3.12.0beta2-CAPI-1.18.0
> and GEOS at installation 3.11.1-CAPI-1.17.1differ
> > set_do_poly_check(FALSE)
> > #test_dir(system.file("tests", package = "rgeos"), StopReporter)#SummaryByContextReporter)
> > #test_package("rgeos")
> > test_check("rgeos")
> [ FAIL 1 | WARN 28 | SKIP 0 | PASS 116 ]
> == Failed tests ================================================================
> -- Error ('test-misc.R:50'): gNearestPoints works with different geometries as inputs --
> Error: Unable to parse: MULTIPOLYGON(((34 54, 60 34, 60 54, 34 54),                          (50 50, 52 50, 52 48, 50 48, 50 50)),                     ((100 100, 150 100, 150 150, 100 150, 100 100),                           (120 120, 120 130, 130 130, 130 120, 120 120))))
> GEOS reported: "rgeos_readWKT: unable to read wkt"
There’s a typo in the test, there should only be three closing parens at the end. It is in fact invalid WKT.
P.
> Backtrace:
>    x
> 1. \-rgeos::readWKT("MULTIPOLYGON(((34 54, 60 34, 60 54, 34 54),\n                           (50 50, 52 50, 52 48, 50 48, 50 50)),\n                        ((100 100, 150 100, 150 150, 100 150, 100 100),\n                               (120 120, 120 130, 130 130, 130 120, 120 120))))") at test-misc.R:50:2
> 2.   \-base::tryCatch(...)
> 3.     \-base (local) tryCatchList(expr, classes, parentenv, handlers)
> 4.       \-base (local) tryCatchOne(expr, names, parentenv, handlers[[1L]])
> 5.         \-value[[3L]](cond)
> Error: Test failures
> Execution halted
> autopkgtest [23:08:43]: test run-unit-test: -----------------------]
> autopkgtest [23:08:43]: test run-unit-test:  - - - - - - - - - - results - - - - - - - - - -
> Kind Regards,
> Bas
> GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
