[geos-devel] Writing a wrapper around LibGEOS
Martin Davis
mtnclimb at gmail.com
Wed Mar 8 11:11:57 PST 2023
As others have said on this thread, adding curve support to GEOS is likely
to be a big effort.
My opinion is that to consider an extension of this magnitude, there needs
to be evidence that this initiative is feasible and sustainable over the
long term (at least 10 years). A good way to demonstrate this is a separate
project that extends GEOS with support for representing curves, and
implementing a *significant* set of *native* operations on curves. That
project should have at least two developers contributing algorithmic code
to it, to show that there is ability and desire to maintain such complex
code over the long term.
On Sun, Mar 5, 2023 at 2:38 PM Graham Toal <gtoal at gtoal.com> wrote:
> What I am currently working on is a hack to add curves to GEOS - I will
> flatten any curves from SVG paths on loading, work with the large
> straight-line paths using GEOS, but reconstitute and write out Bezier
> curves from the results as I save back to SVG files. (I've got
> proof-of-concept code for the re-constitution of Bezier curves from
> flattened paths but have not yet built that back into SVG data
> structures). My hope is that if I can get a demonstration working of a
> GEOS with curves by using this approximation, it might serve as a starting
> point for adding curves (and the corresponding operations) to GEOS properly
> within the data structure.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20230308/63f99bc2/attachment.htm>
