[geos-devel] [GEOS] #712: Single-sided buffer gives unexpected result
geos-trac at osgeo.org
Mon May 8 03:57:17 PDT 2023
Reporter: pmeems | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.6.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Resolution: wontfix
Keywords: |
Comment (by strk):
This case seems to be fixed with
https://github.com/libgeos/geos/pull/896#issuecomment-1538174226
Ticket URL: <https://trac.osgeo.org/geos/ticket/712#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
