[geos-devel] MacOS DYLD Fix
Regina Obe
lr at pcorp.us
Fri Nov 10 15:46:47 PST 2023
This isn’t an issue with other projects besides PostGIS that use GEOS?
Perhaps related, how much trouble would it be to get PostGIS to use pkgconfig for GEOS. I see that GEOS does ship pkgconfig files.
It’s always annoying when I try to do it that I have to explicitly specify the geos-config file in PostGIS when in other cases, we can read the pkg-config and have in fact standardized on that for other dependencies we use.
I’ve added PostGIS dev to this since well we seem to be talking about PostGIS now.
Sent: Friday, November 10, 2023 12:58 PM
To: Regina Obe <lr at pcorp.us>
Cc: GEOS Development List <geos-devel at lists.osgeo.org>
Subject: Re: [geos-devel] MacOS DYLD Fix
I’m on both sides of the argument now. The best/better practice might be to leave the install behaviour as-is and try to coerce PostGIS into ensuring the LD_RPATH on postgis.so, and other targets is set to the discovered locations of the dylib files in the ./configure.
P.
On Nov 9, 2023, at 6:38 PM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I’ll hold off on releasing until there is consensus on this issue.
From: geos-devel <geos-devel-bounces at lists.osgeo.org <mailto:geos-devel-bounces at lists.osgeo.org> > On Behalf Of Paul Ramsey via geos-devel
Sent: Thursday, November 9, 2023 4:47 PM
To: GEOS Development List <geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org> >
Cc: Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca> >
Subject: [geos-devel] MacOS DYLD Fix
>From XCode 15, the dyld linker no longer falls back to /usr/local/lib when resolving an @rpath, so installing libraries in /usr/local/lib and hoping that the linker finds them there is no longer workable. They need to be installed with LC_ID_DYLIB set to the install location, which in cmake world means installing them after setting the INSTALL_NAME_DIR property on the target.
https://github.com/libgeos/geos/commit/8cf761b4d77b1261e0f6673c6716adb2daee7eb1
I have committed this into main, and would like to pull it back a few stable braches too, since I need it to effectively work on postgis/geos on my Macbook, but I am going to hold off on the stable branches for a while, if anyone working on main finds that this change has broken something in *their* environment, please let me know.
P.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20231110/e3095df4/attachment.htm>
