[geos-devel] [GEOS] #1064: Topology preserve simplify: unexpected behavior on similar polygons
geos-trac at osgeo.org
Fri Sep 22 05:41:19 PDT 2023
Reporter: uclaros | Owner: geos-devel@…
Type: defect | Status: closed
Priority: minor | Milestone: GEOS Fund Me
Component: Default | Version: main
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by uclaros):
This is not properly resolved, the following two cases still fail to
remove the 42,42 vertex:
QgsGeometry.fromWkt('Polygon ((0 42, 42 100, 100 42, 42 42, 0
42))').simplify(1)
QgsGeometry.fromWkt('Polygon ((100 42, 42 42, 0 42, 42 100, 100
42))').simplify(1)
Ticket URL: <https://trac.osgeo.org/geos/ticket/1064#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
