Seeking feedback on RelateNG semantics for zero-length lines
Martin Davis mtnclimb at gmail.com
Tue Aug 6 10:27:38 PDT 2024
We're in the process of porting RelateNG [1] to GEOS [2].  It offers
benefits of performance, robustness, and increased functionality (e.g.
handling GeometryCollections).
RelateNG does have one slight change in semantics.  It treats a Zero-Length
Line to be topologically equal to a Point:
equalsTopo( LINESTRING(1 1, 1 1),  POINT(1 1) ) = TRUE
(the XML test for this is here:
https://github.com/libgeos/geos/blob/main/tests/xmltester/tests/validate/TestRelatePL.xml#L43
Note that RelateNG does fix some other issues with Zero-Length Lines, as
discussed in these issues:
https://github.com/locationtech/jts/issues/345
https://github.com/locationtech/jts/issues/1050
So the question is:  does anyone see any problems with allowing Zero-Length
Lines to test as equal to Points?
(Note: my opinion is that this is a beneficial change).
[1]
https://lin-ear-th-inking.blogspot.com/2024/05/jts-topological-relationships-next.html
[2] https://github.com/libgeos/geos/tree/main-relate-ng
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20240806/b5494c86/attachment.htm>
