GEOS 3.13.0beta1 Available
Paul Ramsey pramsey at cleverelephant.ca
Fri Aug 23 12:49:21 PDT 2024
On Fri, Aug 16, 2024 at 4:57 PM Greg Troxel <gdt at lexort.com> wrote:
> Builds on NetBSD 10 amd64, and with it installed, passes self tests.
> I believe tests failing before installation is a longstanding issue, and
> I believe you might think it's a pkgsrc environment issue.   So If you
> think that you can have 3.12.2 or whatever installed, and build and test
> 3.13.0 pre-installation, that's fine.  If that doesn't work, then I
> think it's a bug.
> I rebuilt librttopo, libspatialite, gdal-lib, postgis (itself at
> 3.5.0alpha2 on my system, but at 3.4.2 in pkgsrc), and then qgis
> (3.34.9).  I started qgis and it seemed ok displayingusing layers from
> gpkg and postgis.  Not claiming this is the right test, but I needed to
> rebuild anyway.
> Here is an annotated list of the changes in installed files.  There are
> some things not explained in NEWS.   I don't mean to be super pedantic
> about NEWS; it's just that without a NEWS clue I can't sort out "this
> should have been listed in NEWS" vs "this shouldn't have been installed".
>   Index: PLIST
>   diff -u -p -U 1 -r1.27 PLIST
>   --- PLIST     5 Jun 2024 22:33:56 -0000       1.27
>   +++ PLIST     16 Aug 2024 23:15:42 -0000
>   @@ -10,2 +10,3 @@ include/geos/algorithm/CentralEndpointIn
>    include/geos/algorithm/Centroid.h
>   +include/geos/algorithm/CircularArcs.h
>    include/geos/algorithm/ConvexHull.h
> Seems part of "curved geometry types", but not listed.
I mean, it's part of curve support, and that's in News, where are you
thinking it could be listed?
>   @@ -33,2 +34,4 @@ include/geos/algorithm/RobustDeterminant
>    include/geos/algorithm/SimplePointInRing.h
>   +include/geos/algorithm/construct/IndexedDistanceToPoint.h
>   +include/geos/algorithm/construct/IndexedPointInPolygonsLocator.h
>    include/geos/algorithm/construct/LargestEmptyCircle.h
> Can't find this in the "new" section of NEWS.
Comes from:
Add LargestEmptyCircle handling of polygon obstacles (#939)
>   @@ -81,2 +89,3 @@ include/geos/geom/GeometryFactory.h
>    include/geos/geom/GeometryFilter.h
>   +include/geos/geom/GeometryTypeName.h
>    include/geos/geom/HeuristicOverlay.h
From
WKBReader: Support curved geometry types (#1106)
>   @@ -120,2 +134,3 @@ include/geos/geom/util/GeometryExtracter
>    include/geos/geom/util/GeometryFixer.h
>   +include/geos/geom/util/GeometryLister.h
>    include/geos/geom/util/GeometryMapper.h
>From RelateNG
>   @@ -126,2 +141,3 @@ include/geos/geom/util/PointExtracter.h
>    include/geos/geom/util/PolygonExtracter.h
>   +include/geos/geom/util/PolygonalExtracter.h
>    include/geos/geom/util/ShortCircuitedGeometryVisitor.h
From
