Grid based intersection, what to expect ?
    Sandro Santilli
    strk at kbt.io
    Thu Apr 24 03:28:47 PDT 2025
On Mon, Apr 14, 2025 at 09:13:01PM -0700, Martin Davis wrote:
> One more option:  another approach used by OverlayNG to improve robustness
> is Snapped Noding.   This is different to Snap-Rounding.  Instead of
> rounding all coordinates to a precision grid, Snapping Noding uses a
> distance tolerance and snaps vertices to lines or vertices within the
> tolerance.  This improves robustness, but doesn't change vertices unless
> required. (Note it's still not *fully* robust - for that, full
> snap-rounding is required).
> This is implemented in GEOS, but is not expose in the C API (and hence not
> in PostGIS).  It could be exposed if required (with some coding, of course).
A stand-alone function to snap to segments would probably be useful, doing
`so should theoretically result in more intersections being found during
topology building.
--strk;
> On Mon, Apr 14, 2025 at 10:12 AM Martin Davis <mtnclimb at gmail.com> wrote:
> > Also, the input values have not been rounded to the requested precision.
> > In general this should be done to use the overlay precision ops correctly.
> > (The data will be rounded internally, but the results may not match what
> > might be expected from the original inputs).
> > The goal of the precision-based overlay ops is to support operations on a
> > dataset which is stored using a given precision.  The input data
> > should either be provided in the required precision, or reduced to it (e.g.
> > using GEOSGeom_setPrecision).  All operations on the geometry should be
> > done in a way which maintains that precision.  (One gap in the current API
> > is that the spatial predicates do not support a precision value.  I'm
> > hoping to provide that at some point).
> > On Mon, Apr 14, 2025 at 10:04 AM Martin Davis <mtnclimb at gmail.com> wrote:
> >> I suspect that the anomalies you're seeing are because the precision grid
> >> size is so small.  A precision of 1e-14 combined with input values which
> >> are on the order of 1e2 means that you are asking for 16 digits of decimal
> >> precision, which is at or over the precision that can be represented using
> >> double-precision FP.
> >> The precision-based overlay ops are only able to support "reasonable"
> >> precision for a given data magnitude.  I would say 14 digits of total
> >> precision is the very most that can be evaluated, and using 12 or even 10
> >> is safer.  Note that a precision of 10 digits allows representing earth
> >> coordinates to about 1 mm, which should be plenty for real-world cases.
> >> On Mon, Apr 14, 2025 at 9:01 AM Sandro Santilli <strk at kbt.io> wrote:
> >>> I'm evaluating the use of the GEOS "grid-based" overlay operations
> >>> available since version 3.9.0 as a way to reduce PostGIS Topology
> >>> states in which vertices of incoming lines end up being closer than
> >>> tolerance to segments of existing lines.
> >>> Example of such problematic states:
> >>>   - https://trac.osgeo.org/postgis/ticket/5862
> >>>   - https://trac.osgeo.org/postgis/ticket/5786
> >>> I thought using the "precise" overlay CAPI functions could reduce
> >>> this problem by always finding intersections when facets are within
> >>> the precision grid, so I tried the inputs of PostGIS ticket #5862:
> >>>   =# select ST_AsText(e1) e1, ST_AsText(e2) e2 from t5862_inputs;
> >>>   -[ RECORD 1
> >>>   e1 | LINESTRING(22.780107846871616
> >>> 70.70515928614921,22.779899976871615 70.7046262461492)
> >>>   e2 | LINESTRING(22.79217056687162 70.70247684614921,22.779969266871618
> >>> 70.70480392614921,22.780038556871617 70.7049816061492,22.796764346871615
> >>> 70.7044482361492)
> >>> Here you see how the internal points of the second line (e2) are at a
> >>> distance which is smaller than 1e-14:
> >>>   =# select n, ST_Distance(e1, ST_PointN(e2, n)) from t5862_inputs,
> >>> generate_series(1,4) n;
> >>>    n |      st_distance
> >>>    1 |   0.012357374241807065
> >>>    2 |  4.855711461806118e-16
> >>>    3 | 2.8243441995579915e-15
> >>>    4 |   0.016671670112874255
> >>>   (4 rows)
> >>> Asking GEOS 3.14.0dev-CAPI-1.20.0 to compute the intersection between
> >>> the two lines with a precision of 1e-13 correctly returns those 2
> >>> internal vertices:
> >>>   =# select ST_AsText( ST_Intersection(e1, e2, 1e-13) ) from
> >>> t5862_inputs;
> >>>                                       st_astext
> >>>    LINESTRING(22.7800385568716 70.7049816061492,22.7799692668716
> >>> 70.7048039261492)
> >>>   (1 row)
> >>> But when a precision grid of 1e-14 is used, only one of those two
> >>> internal points are returned (vertex 2, the closest). The other
> >>> vertex, which was ~2.8e-15 distant, is not included in the
> >>> intersection:
> >>>   =# select ST_AsText( ST_Intersection(e1, e2, 1e-14) ) from
> >>> t5862_inputs;
> >>>                    st_astext
> >>>    POINT(22.77996926687162 70.70480392614921)
> >>>   (1 row)
> >>> How can this be explained ?
> >>> --strk;
> >>>   Libre GIS consultant/developer 🎺
> >>>   https://strk.kbt.io/services.html
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20250424/d350a296/attachment.sig>
