Purge Geometry pointer aliases?
Martin Davis mtnclimb at gmail.com
Wed Jan 8 11:30:17 PST 2025
The GEOS codebase has several typedefs called GeometryPtr and GeomPtr.
They are aliases for a mixture of Geometry * and std::unique_Ptr<Geometry>.
I'm thinking it's a good thing to purge them from the codebase in favour of
explicit type signatures, because:
- it's highly confusing that they can be aliases for different things
- it's complicated that they are defined in multiple places
- it can be hard to see what they represent
- they don't save much typing in the case of Geometry*, and using auto can
simplify other uses
This was discussed a while back.  The general feeling was that it's better
to use explicit types.  Is this still the consensus?
Some notes on the process:
- I expect this will be done in multiple passes, to fit work schedules.
Will start with the least intrusive changes
- when this is done, it needs to be backported so that subsequent backports
don't collide with unchanged code.
- If older versions use the aliases in dead code, it may not be removed,
just patched to ensure it still compiles (i.e. by leaving the typedefs in
place)
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20250108/eb5bbe9f/attachment.htm>
