Purge Geometry pointer aliases?
Daniel Baston
dbaston at gmail.com
Mon Jan 13 07:06:32 PST 2025
I'm not sure how this would work, since many aliases are defined as class
members (e.g. Geometry::Ptr). I would just leave the typdefs and
discontinue our (minimal) use of them.
Dan
On Mon, Jan 13, 2025 at 9:16 AM Howard Butler <howard at hobu.co> wrote:
> > On Jan 10, 2025, at 3:20 PM, Martin Davis <mtnclimb at gmail.com> wrote:
> > Given the desire to avoid changes to ABI for micro versions, it sounds
> like the path to removing pointer aliases is:
> > - remove aliases in src in main
> > - do not backport alias removal to previous versions (this may create
> some backporting pain, but since there are relatively few uses of alias in
> src hopefully this won't be too bad)
> > - remove aliases in test code as a lower priority, perhaps on an
> as-encountered basis
> Can we please stash the aliases in a header file that is still installed
> but nothing in the GEOS API actually uses? Then can we mark it all
> [[deprecated]]?
> This change is very likely to break people who have historical codebases
> that have tightly wrapped around GEOS. A special-for-them header to ease
> their transition would be a bit courteous, whereas an abrupt change of
> types in an a part of their codebase that is likely ancient is going to be
> very disorienting.
> Howard
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20250113/2d0a77a5/attachment.htm>
