Contexts and functions taking multiple geometries
    Tom Payne
    twpayne at gmail.com
    Wed Jan 15 16:16:40 PST 2025
Hi Daniel,
Thank you very much for this complete answer. It is extremely helpful and
very much appreciated!
I've updated go-geos to only lock the first context in
https://github.com/twpayne/go-geos/commit/05d44c727f8d75b5bb420a557b956a52de8fd538
Best regards,
Tom
On Thu, 9 Jan 2025 at 14:41, Daniel Baston <dbaston at gmail.com> wrote:
> Hi Tom,
> With the caveat that I did not develop the "_r" API, here's my
> understanding. The implementation of GEOS contexts is quite short and can
> be found near the top of geos_ts_c.cpp. From looking at the implementation
> we can see that a context has pretty limited functionality:
> - registering error and notice handlers
> - passing error messages to these handlers using a context-local buffer
> - storing properties of a global WKB writer
> - storing a single point that is mutated by a small set of functions such
> as GEOSPreparedContainsXY that want to avoid instantiating a point on each
> call
> The "_r" functions are a C API construct only and do not indicate anything
> about the thread-safety of the underlying algorithms. The parts of GEOS
> that actually _do_ things are implemented in C++ and have no notion of a
> "context."
> With regard to the situation you describe in your email:
> GEOSUnion_r(g.context.handle, g.geom, other.geom)
> GEOSUnion_r only accesses a context for the purpose of error reporting,
> and the only context it will access is the first argument. It does not
> matter whether "g" or "other" were created using this context, or whether
> "g" and "other" have the same context. If you were to call GEOSUnion_r
> simultaneously from multiple threads using the same first argument, AFAIK
> the worst thing that could happen is that simultaneously-emitted error
> messages generated would be garbled. But you can prevent that by locking
> the context provided in the first argument.
> If the context of "g" and "other" is irrelevant, can you use them safely
> from multiple threads? Not necessarily. The programming style used in GEOS
> lends itself to thread-safety (objects are generally immutable, etc.)
> although the use of lazy initialization sometimes gets in the way and the
> thread-safety of various operations is not well-documented or tested. The
> pattern you describe of locking the contexts of both "g" and "other" will
> protect against thread-safety issues but is unnecessarily broad; the same
> benefit could be achieved with locks scoped to the geometries themselves.
> Even this more limited locking is unnecessary for many operations, but
> unfortunately the GEOS docs don't give any guidance about which ones.
> Adding more tests and documentation around GEOS thread-safety would be a
> big improvement for the library.
> Dan
> PS
> There has been some discussion about giving contexts additional
> responsibility, such as managing interrupts:
> https://github.com/libgeos/geos/pull/803
> You might also find some useful discussion within the georust project, e.g.
> https://github.com/georust/geos/pull/164
> On Wed, Jan 8, 2025 at 9:36 PM Tom Payne <twpayne at gmail.com> wrote:
>> Gentle ping on this. I would really like to understand the requirements
>> for combining geometries from different GEOS contexts.
>> If my question is unclear, missing information, stupid, answered
>> elsewhere, or there is any other problem with it then please tell me. I
>> would really like to understand this.
>> Regards,
>> Tom
>> On Fri, 22 Nov 2024 at 10:50, Tom Payne <twpayne at gmail.com> wrote:
>>> Hi,
>>> tl;dr when calling a function which takes multiple geometries, like
>>> GEOSUnion_r
>>> <https://libgeos.org/doxygen/geos__c_8h.html#afd3d82a6d039ab5637e0a8a066694b7d>, where
>>> the two geometries are associated with different contexts, do I have to
>>> ensure that both geometries' contexts are used exclusively?
>>> Background:
>>> I maintain the Go bindings for GEOS <https://github.com/twpayne/go-geos>,
>>> which exclusively use the thread-safe *_r functions. Every created geometry
>>> is associated with a context. Every context has a mutex to ensure that it
>>> is only accessed from a single thread at time.
>>> For functions that take multiple geometries I check if the geometries
>>> are from different contexts, and if so, lock both mutexes. Here
>>> <https://github.com/twpayne/go-geos/blob/c9ed31526fa2ee3599ffe0fdf4556a6cf9c0b204/geommethods.go#L865-L875>
>>> is an example:
>>>     // Union returns the union of g and other.
>>>     func (g *Geom) Union(other *Geom) *Geom {
>>>         g.mustNotBeDestroyed()
>>>         g.context.Lock()
>>>         defer g.context.Unlock()
>>>         if other.context != g.context {
>>>             other.context.Lock()
>>>             defer other.context.Unlock()
>>>         return g.context.newGeom(C.GEOSUnion_r(g.context.handle, g.geom,
>>> other.geom), nil)
>>> However, there is a potential deadlock if there are two geometries A and
>>> B owned by different contexts and A.Union(B) and B.Union(A) are called
>>> simultaneously from different threads. In practice this pattern is unlikely
>>> to occur, but I would like to guard against it.
>>> I checked the documentation on GEOS's C API
>>> <https://libgeos.org/usage/c_api/>, the GEOS developer notes
>>> <https://github.com/libgeos/geos/blob/main/DEVELOPER-NOTES.md>, did a
>>> superficial search of the GitHub issues
>>> <https://github.com/search?q=repo%3Alibgeos%2Fgeos+context&type=issues>,
>>> and a superficial search of the geos-devel
>>> <https://www.google.com/search?q=site%3Alists.osgeo.org+%22%5Bgeos-devel%5D%22+context>
>>> archives, and could not find an answer to this question.
>>> Many thanks for any insight,
>>> Tom
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20250116/bd99178d/attachment.htm>
