[GEOS] #1141: Support 3D in GeoJSON reader/writer
GEOS geos-trac at osgeo.org
Fri May 2 13:35:51 PDT 2025
 Reporter:  caspervdw    |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  closed
 Priority:  minor        |   Milestone:  3.11.0
Component:  Default      |     Version:  main
 Severity:  Unassigned   |  Resolution:  fixed
 Keywords:               |
Comment (by dbaston):
 3D GeoJSON support comes from https://github.com/libgeos/geos/pull/1150,
 we're just seeing noise from GitHub and Trac having the same numbers for
 different things.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1141#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
