Curve support in GEOS C API
Even Rouault
even.rouault at spatialys.com
Wed Jan 7 07:31:58 PST 2026
Dan,
Just commenting on your last question. I don't think using function
pointers is feasible. I've vague memories of past times where I tried
this and I remember that at least on Windows, with shared libraries, the
address of a function inside the library is not the same as the address
an external user gets, due to how the dynamic loader works (typically
the address an external user gets is the one of some "trampoline"
function that then jumps to the actual address inside the library)
Even
Le 07/01/2026 à 16:06, Daniel Baston a écrit :
> Hi,
> I have been incrementally adding curve support in GEOS, for example in
> https://github.com/libgeos/geos/pull/1347. I've been thinking about
> the best way for applications such as QGIS/PostGIS/GDAL to integrate
> this functionality.
> Currently, these applications linearize all geometries before sending
> them to GEOS. That will not be necessary for GEOSNode and a list of
> functions that will likely increase over multiple GEOS releases. It
> seems cumbersome for applications to rely on GEOS version checks to
> know if linearization is needed, so I think GEOS should offer an
> ability to automatically linearize inputs and curvify outputs where
> needed. The parameters for this conversion (and whether to perform it
> all) could be held by the context handle, and controlled with
> functions like GEOSContext_setCurveToLine([ DISABLED / STEP_DEGREES /
> MAX_DEVIATION ]) and GEOSContext_setLineToCurve([ DISABLED /
> SOME_OTHER_TOLERANCE]). I would also expose a
> GEOSCurveToLine(GEOSGeometry*, params) and
> GEOSLineToCurve(GEOSGeometry*, params).
> If needed, we could also provide a capabilities function that would
> take a function name (or pointer?) and report whether the function
> supports curves in the current GEOS version.
> Does this seem like a reasonable approach?
> Dan
http://www.spatialys.com
