3.15.0beta2
Daniel Baston dbaston at gmail.com
Wed Jul 15 06:36:02 PDT 2026
Hi Paul,
I've been gradually working my way through the XML overlay tests, making
curved versions and fixing issues as they come up. I haven't found anything
on the scale that would block a release. On the other hand, we have open
issues with 3.15 in some of our downstream projects:
https://github.com/shapely/shapely/issues/2467
https://github.com/r-spatial/sf/issues/2612
Nothing jumps out at me as likely to be serious, but it might be nice to
see some resolution on these before the release.
FWIW, the problems with GEOS 3.15 in GDAL were very minor and resolved with
https://github.com/OSGeo/gdal/pull/14927
Dan
On Tue, Jul 14, 2026 at 8:32 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Since Dan has been adding some commits, here's beta2. Dan, you are you
> getting closer to nirvana? When should we drop that solid 1-0? (that
> sounds more scatalogical than I intended).
> https://github.com/libgeos/geos/releases/tag/3.15.0beta2
> ATB,
> P
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20260715/a34b518d/attachment-0001.htm>
