Elliptical Curve, NURBS, Clothoid, Spiral Curve
Jeroen Bloemscheer jeroen.bloemscheer at merkator.com
Thu Oct 29 00:05:46 PDT 2026
Dan,
The impetus is simple. Engineers in rail, road design and flight-path planning work with transition curves every day, and for about ten years they've had to linearise them before GEOS could touch them. The need has been evident for a long time. What was missing was someone to write the code. GEOS is an OSGeo project, and OSGeo works as a do-ocracy. So I wrote it.
ISO 13249-3 already defines these types, so GEOS doesn't have to invent a model, only implement the standard. #1566 deliberately keeps the scope small: I/O, length, envelope and linearisation for the clothoid. Unsupported operations throw rather than guess, so nothing silently produces the wrong answer.
On architecture, that's exactly why I raised the segment hierarchy question before going further. I'd rather we agree the design now than bolt types on later.
On maintenance, I'm not handing this over and walking away. I'll maintain the curve code and respond to issues with it.
The three fixes (fix/arc-segment-distance, fix/arc-arc-distance, fix/envelope-touching-distance) affect the existing CircularString code, and I'll submit those as separate PRs regardless.
So I don't think the open question is whether there's a need. The need predates the implementation by years. The useful question is what stands between #1566 and acceptance: the design, the scope, or maintenance. If one of those is the blocker, tell me which and I'll address it.
Thanks,
Jeroen
Jeroen Bloemscheer
Geo-IT Consultant
Zaltbommel
[Merkator]
m: +31 (0)6 478 728 18
e:  jeroen.bloemscheer at merkator.com
Merkator BV
Hogeweg 137a
5301 LL Zaltbommel(NL)
www.merkator.com<https://www.merkator.com/>     [LinkedIn] <https://www.linkedin.com/company/2400587>
This email (including any attachments to it) is confidential, legally privileged, subject to copyright and is sent for the personal attention of the intended recipient only. If you have received this email in error, please advise us immediately and delete it. You are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited. Although we have taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the viruses in this email or attachments. We exclude any liability for the content of this email, or for the consequences of any actions taken on the basis of the information provided in this email or its attachments, unless that information is subsequently confirmed in writing.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20261029/94266f99/attachment.htm>
