Elliptical Curve, NURBS, Clothoid, Spiral Curve
Tom Payne twpayne at gmail.com
Fri Oct 30 06:52:34 PDT 2026
For what it's worth, I received a similar PR
<https://github.com/twpayne/go-geom/pull/277> for my go-geom library
<https://github.com/twpayne/go-geom> (think very basic GEOS in pure Go). In
my case I rejected the PR for several reasons:
* In my case, there was no evidence that the "contributor" was actually
using my library, i.e. this looked liked drive-by AI slop, not an
investment by a committed user.
* In my case, the "contributor" has opened 995 PRs in 560 different repos
this month, which further added to my suspicions.
* Code review is often more work than generating the code in the first
place, and the maintenance of said code is a long-term burden borne by the
project maintainers. If the "contributor" had a demonstrated history of
long term maintenance in other projects then I am more inclined to believe
that they will assist long term in my project.
As Dave Cheney so eloquently put it
<https://dave.cheney.net/2019/02/18/talk-then-code>: a pull request is for
life, not just for Christmas.
Regards,
Tom
On Fri, 30 Oct 2026 at 14:29, Daniel Baston <dbaston at gmail.com> wrote:
> The primary question for me is not about the quality or provenance of the
> PRs, but whether it makes sense for GEOS to handle these types at all.
> I'd rather not derail that discussion with an AI debate, although I can
> see that it will be probably be necessary under a separate thread.
> Dan
> On Fri, Oct 30, 2026 at 7:15 AM Jeroen Bloemscheer <
> jeroen.bloemscheer at merkator.com> wrote:
>> I think there are two separate discussions here: whether GEOS should have
>> a policy around LLM-assisted development, and whether this particular
>> contribution meets GEOS quality standards.
>> For the latter, the code is not being submitted on faith. The
>> implementation has been validated using proofs and working ArcGIS Pro
>> notebooks, and the results are reproducible and independently verifiable.
>> If there are concerns about the algorithm, implementation details,
>> performance, or maintainability, I'm happy to discuss those. But I don't
>> think "vibe coded" is an accurate characterization of the work.
>> Jeroen
>> <https://outlook.office.com/bookwithme/user/23c7633d14994a4bbdc50bf6aec0b485@merkator.com?anonymous&ep=bwmEmailSignature>
>> Book time to meet with me
>> *From:* Nyall Dawson <nyall.dawson at gmail.com>
>> *Sent:* Friday, October 30, 2026 3:30 AM
>> *To:* Daniel Baston <dbaston at gmail.com>
>> *Cc:* Jeroen Bloemscheer <jeroen.bloemscheer at merkator.com>;
>> geos-devel at lists.osgeo.org <geos-devel at lists.osgeo.org>
>> *Subject:* Re: Elliptical Curve, NURBS, Clothoid, Spiral Curve
>> [U ontvang niet vaak e-mail van nyall.dawson at gmail.com. Meer informatie
>> over waarom dit belangrijk is, vindt u op
>> https://aka.ms/LearnAboutSenderIdentification]
>> It's probably worth at least having some discussion about an LLM /
>> agent usage policy for GEOS too, as merging these PRs would basically
>> equate to GEOS becoming a "vibe coded" project.
>> Nyall
>> On Fri, 30 Oct 2026 at 11:25, Daniel Baston <dbaston at gmail.com> wrote:
>> > Jeroen,
>> > Perhaps the need has been evident to you for a long time, but I'm not
>> aware that it's ever been communicated to the project, so you may have to
>> educate us a bit. What software are these users working with that
>> interfaces with GEOS, and what operations do they expect GEOS to perform?
>> > Dan
>> > On Thu, Oct 29, 2026 at 3:06 AM Jeroen Bloemscheer <
>> >> Dan,
>> >> The impetus is simple. Engineers in rail, road design and flight-path
>> planning work with transition curves every day, and for about ten years
>> they've had to linearise them before GEOS could touch them. The need has
>> been evident for a long time. What was missing was someone to write the
>> code. GEOS is an OSGeo project, and OSGeo works as a do-ocracy. So I wrote
>> it.
>> >> ISO 13249-3 already defines these types, so GEOS doesn't have to
>> invent a model, only implement the standard. #1566 deliberately keeps the
>> scope small: I/O, length, envelope and linearisation for the clothoid.
>> Unsupported operations throw rather than guess, so nothing silently
>> produces the wrong answer.
>> >> On architecture, that's exactly why I raised the segment hierarchy
>> question before going further. I'd rather we agree the design now than bolt
>> types on later.
>> >> On maintenance, I'm not handing this over and walking away. I'll
>> maintain the curve code and respond to issues with it.
>> >> The three fixes (fix/arc-segment-distance, fix/arc-arc-distance,
>> fix/envelope-touching-distance) affect the existing CircularString code,
>> and I'll submit those as separate PRs regardless.
>> >> So I don't think the open question is whether there's a need. The need
>> predates the implementation by years. The useful question is what stands
>> between #1566 and acceptance: the design, the scope, or maintenance. If one
>> of those is the blocker, tell me which and I'll address it.
>> >> Thanks,
>> >> Jeroen
>> >> ________________________________
>> >> Jeroen Bloemscheer
>> >> Geo-IT Consultant
>> >> Zaltbommel
>> >> m: +31 (0)6 478 728 18
>> >> e:  jeroen.bloemscheer at merkator.com
>> >> Merkator BV
>> >> Hogeweg 137a
>> >> 5301 LL Zaltbommel(NL)
>> https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.merkator.com%2F&data=05%7C02%7Cjeroen.bloemscheer%40merkator.com%7Ca0427a027eba4756003708df362dccbb%7Ca17ec843af694e17a6fc3e803a903e14%7C0%7C0%7C639289242475755515%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=2tmmT%2FBIi%2Fo29xcYQ65y7Qtve9vXeIA5hyfoCNh9UcQ%3D&reserved=0
>> <http://www.merkator.com/>
>> >> This email (including any attachments to it) is confidential, legally
>> privileged, subject to copyright and is sent for the personal attention of
>> the intended recipient only. If you have received this email in error,
>> please advise us immediately and delete it. You are notified that
>> disclosing, copying, distributing or taking any action in reliance on the
>> contents of this information is strictly prohibited. Although we have taken
>> reasonable precautions to ensure no viruses are present in this email, we
>> cannot accept responsibility for any loss or damage arising from the
>> viruses in this email or attachments. We exclude any liability for the
>> content of this email, or for the consequences of any actions taken on the
>> basis of the information provided in this email or its attachments, unless
>> that information is subsequently confirmed in writing.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20261030/3a9fd3e3/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20261030/3a9fd3e3/attachment.png>
