geos-devel Digest, Vol 275, Issue 10
Jeroen Bloemscheer jeroen.bloemscheer at merkator.com
Sat Oct 31 06:35:26 PDT 2026
The amount of effort you had to make that comment is disproportionate to the amount I spent on that so called 100% generated message. Let's keep on topic please.
From: geos-devel-request at lists.osgeo.org <geos-devel-request at lists.osgeo.org>
Sent: Friday, 30 October 2026 20:29:38
To: geos-devel at lists.osgeo.org <geos-devel at lists.osgeo.org>
Subject: geos-devel Digest, Vol 275, Issue 10
Send geos-devel mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgeos-devel&data=05%7C02%7Cjeroen.bloemscheer%40merkator.com%7C1b2f7d047bff448335cb08df36bc2651%7Ca17ec843af694e17a6fc3e803a903e14%7C0%7C0%7C639289853887520737%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=vKUysy7mD9opRRHaw%2BsSxdluAPqKLBPG5f58C1dA65A%3D&reserved=0<https://lists.osgeo.org/mailman/listinfo/geos-devel>
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        geos-devel-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of geos-devel digest..."
Today's Topics:
   1. Re: Elliptical Curve, NURBS, Clothoid, Spiral Curve (Even Rouault)
Message: 1
Date: Fri, 30 Oct 2026 20:29:35 +0100
To: "geos-devel at lists.osgeo.org" <geos-devel at lists.osgeo.org>
Subject: Re: Elliptical Curve, NURBS, Clothoid, Spiral Curve
Message-ID: <01c24c47-0def-42bd-b78a-ce97026835c2 at spatialys.com>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Can an admin ban the account of the below bot ? Still a 100% AI
generated text...
Le 30/10/2026 ? 20:23, Jeroen Bloemscheer a ?crit?:
> Hi Dan,
> That's the distinction I should have made more clearly. I'm not
> arguing that GEOS should become a general-purpose
> computational-geometry or CAD kernel. If the requirement is arbitrary
> spline construction, surface modelling, exact constructions, meshing,
> or a broad catalogue of parametric curves, that belongs in something
> like CGAL, not GEOS.
> What I am proposing is a much narrower set: *the curve primitives that
> are useful as geometry values in the SQL/MM / GIS geometry model,
> together with the operations needed to move them safely through the
> GEOS ecosystem.* GEOS has already crossed that boundary with
> CircularString, CompoundCurve, CurvePolygon, MultiCurve and
> MultiSurface. The question is therefore where to complete that curve
> model, not whether GEOS should acquire a second computational-geometry
> framework.
> For me, a GEOS-specific scope would be:
>     CircularString / circular arcs ? already present.
>     CompoundCurve and CurvePolygon ? already present and provide the
>     composition model.
>     EllipticalCurve ? a bounded planar curve primitive that cannot in
>     general be preserved by the existing circular representation.
>     Clothoid ? the transition primitive used directly in road and rail
>     alignment, with a natural planar geometry representation and
>     deterministic linearisation.
>     SpiralCurve ? where required by the SQL/MM curve model, following
>     the same representation/I/O contract.
>     NURBS *only as the SQL/MM curve value needed for interchange*, not
>     as an invitation to add a CAD modelling system: no surfaces,
>     solids, trimming framework, constraint solver, or general CAGD
>     toolset.
>     And initially the common operation contract can remain
>     deliberately small: WKT/WKB round-trip, dimensionality/emptiness,
>     length, envelope, point evaluation where appropriate, and
>     tolerance-controlled linearisation. CompoundCurve can then carry
>     these sections without losing their type. Operations such as
>     predicates, distance, overlay and buffer should be added only
>     where there is a well-defined native implementation; until then
>     they should fail explicitly rather than silently change geometry.
>     That gives a fairly sharp boundary with CGAL. *GEOS owns
>     interoperable planar GIS geometry and spatial operations; CGAL
>     owns general computational-geometry machinery.* Supporting a
>     standardized curve as a GEOS geometry value doesn't imply
>     supporting every algorithm or every possible parametric curve any
>     more than supporting CircularString did.
>     On the concrete downstream question: GDAL/OGR already has an
>     SQL/MM-style curved geometry hierarchy and explicit
>     curve-to-linear conversion, while GEOS 3.13 added the
>     corresponding CircularString/CompoundCurve/CurvePolygon family.
>     That is exactly the seam I'm trying to close. A caller that
>     receives one of the additional standardized curve values should be
>     able to pass it through GEOS, inspect basic properties, compose it
>     in a CompoundCurve, and linearise it at a chosen tolerance without
>     first discarding the original curve representation outside GEOS.
>     For clothoids specifically, this isn't only representational.
>     Existing computational work gives practical algorithms for point
>     evaluation, length/parameter handling, bounding, linearisation and
>     intersection/distance as later increments; we don't need a generic
>     spline kernel to implement those. The first PR intentionally stops
>     well before the harder topology work.
>     So I would be happy to narrow the proposal explicitly around that
>     definition. If EllipticalCurve, Clothoid, SpiralCurve and
>     interchange-only NURBS are still considered outside GEOS under
>     that boundary, that's useful guidance. But I think that is a much
>     more specific design question than whether GEOS should grow into CGAL.
> *From:* Daniel Baston <dbaston at gmail.com>
> *Sent:* Friday, 30 October 2026 18:21:31
> *To:* Jeroen Bloemscheer <jeroen.bloemscheer at merkator.com>
> *Cc:* geos-devel at lists.osgeo.org <geos-devel at lists.osgeo.org>
> *Subject:* Re: Elliptical Curve, NURBS, Clothoid, Spiral Curve
> [U ontvang niet vaak e-mail van dbaston at gmail.com. Meer informatie
> over waarom dit belangrijk is, vindt u op
> https://aka.ms/LearnAboutSenderIdentification]
> It would be great if we could go back in time and have a common
> geometry representation that's used by everyone, but that's not how
> the ecosystem developed. The downstream projects I'm familiar with
> have their own geometry representations that are converted to GEOS to
> perform a particular spatial operation. In the absence of support for
> spatial operations on these types, a GEOS in-memory representation
> provides no real value. You say that "the usual answer is to linearise
> them before GEOS sees them" but you're not saying what software wants
> to use GEOS to work with these types, or what operations it wants to
> perform that currently require linearization.
> Dan
> On Fri, Oct 30, 2026 at 1:03?PM Jeroen Bloemscheer
> <jeroen.bloemscheer at merkator.com> wrote:
> > Hi Dan,
> > Thanks, that's a fair question.
> > I think the question is less whether these curves are "GIS" in the
> traditional sense, and more whether GEOS should be able to represent
> and operate on geometry that already exists in the systems built on
> top of it. PostGIS, Shapely, and QGIS all sit on GEOS, while rail,
> road, and similar engineering workflows already use these transition
> geometries. Today the usual answer is to linearise them before GEOS
> sees them.
> > That seems like the wrong boundary to me. SQL/MM already defines the
> geometry model, so GEOS does not need to invent one. If GEOS
> implements that model once, downstream projects can share the same
> representation and behaviour instead of each adding its own
> approximation or adapter.
> > I'm not proposing that every operation has to arrive at once. #1566
> is deliberately small: representation, I/O, length, envelope, and
> linearisation, with unsupported operations throwing rather than
> guessing. That gives downstream projects something they can build on
> without pretending GEOS already supports more than it does.
> > And on maintenance, I'm not proposing to drop this on the existing
> maintainers. I'll maintain the curve code and respond to issues with it.
> > So for me the useful question is: is representing these standardized
> curve types, and providing a path for downstream projects to use them
> without first destroying the curve information, within GEOS's scope? I
> think it is.
> > From: Daniel Baston <dbaston at gmail.com>
> > Sent: Friday, October 30, 2026 2:28 PM
> > To: Jeroen Bloemscheer <jeroen.bloemscheer at merkator.com>
> > Cc: Nyall Dawson <nyall.dawson at gmail.com>;
> > The primary question for me is not about the quality or provenance
> of the PRs, but whether it makes sense for GEOS to handle these types
> at all.
> > I'd rather not derail that discussion with an AI debate, although I
> can see that it will be probably be necessary under a separate thread.
> > Dan
> > On Fri, Oct 30, 2026 at 7:15 AM Jeroen Bloemscheer
> > I think there are two separate discussions here: whether GEOS should
> have a policy around LLM-assisted development, and whether this
> particular contribution meets GEOS quality standards.
> > For the latter, the code is not being submitted on faith. The
> implementation has been validated using proofs and working ArcGIS Pro
> notebooks, and the results are reproducible and independently verifiable.
> > If there are concerns about the algorithm, implementation details,
> performance, or maintainability, I'm happy to discuss those. But I
> don't think "vibe coded" is an accurate characterization of the work.
> > Jeroen
> > Jeroen Bloemscheer
> > Geo-IT Consultant
> > Zaltbommel
> > m: +31 (0)6 478 728 18
> > e: jeroen.bloemscheer at merkator.com
> > Merkator BV
> > Hogeweg 137a
> > 5301 LL Zaltbommel(NL)
> https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.merkator.com%2F&data=05%7C02%7Cjeroen.bloemscheer%40merkator.com%7C1b2f7d047bff448335cb08df36bc2651%7Ca17ec843af694e17a6fc3e803a903e14%7C0%7C0%7C639289853887541983%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=SQl%2BF7lJaYeUG3ZgYkRGzWu9IGLI5coOLP5Oca73KKk%3D&reserved=0<http://www.merkator.com/>
> <https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.merkator.com%2F&data=05%7C02%7Cjeroen.bloemscheer%40merkator.com%7C1b2f7d047bff448335cb08df36bc2651%7Ca17ec843af694e17a6fc3e803a903e14%7C0%7C0%7C639289853887555387%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=ltd9Sn4gwf64w4XbwMhhfb4gB%2BvOBznzRwIiW7716GE%3D&reserved=0<http://www.merkator.com/>>
> > This email (including any attachments to it) is confidential,
> legally privileged, subject to copyright and is sent for the personal
> attention of the intended recipient only. If you have received this
> email in error, please advise us immediately and delete it. You are
> notified that disclosing, copying, distributing or taking any action
> in reliance on the contents of this information is strictly
> prohibited. Although we have taken reasonable precautions to ensure no
> viruses are present in this email, we cannot accept responsibility for
> any loss or damage arising from the viruses in this email or
> attachments. We exclude any liability for the content of this email,
> or for the consequences of any actions taken on the basis of the
> information provided in this email or its attachments, unless that
> information is subsequently confirmed in writing.
https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.spatialys.com%2F&data=05%7C02%7Cjeroen.bloemscheer%40merkator.com%7C1b2f7d047bff448335cb08df36bc2651%7Ca17ec843af694e17a6fc3e803a903e14%7C0%7C0%7C639289853887568583%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=fbxcfmxZoR05%2Fu4fK9e3pwvwjodRbT8NDQtPkC%2BWfi4%3D&reserved=0<http://www.spatialys.com/>
LLMs contribute to global warming and brain rot.
Let's guillotine them! "Ah ! ?a ira, ?a ira, ?a ira !"
Initiator ofhttps://fuckaifoundation.org
URL: <https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fgeos-devel%2Fattachments%2F20261030%2Fd67c924b%2Fattachment.htm&data=05%7C02%7Cjeroen.bloemscheer%40merkator.com%7C1b2f7d047bff448335cb08df36bc2651%7Ca17ec843af694e17a6fc3e803a903e14%7C0%7C0%7C639289853887581704%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=IxTk%2FzIfl%2FC9NSlse4qkUw05NfWVD1Ba3yqAwWbz7HA%3D&reserved=0<http://lists.osgeo.org/pipermail/geos-devel/attachments/20261030/d67c924b/attachment.htm>>
Subject: Digest Footer
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgeos-devel&data=05%7C02%7Cjeroen.bloemscheer%40merkator.com%7C1b2f7d047bff448335cb08df36bc2651%7Ca17ec843af694e17a6fc3e803a903e14%7C0%7C0%7C639289853887600946%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=c2sped2bzLbJU9Yi27L77PWOh%2FZINRiwTb5G%2BUB7PJw%3D&reserved=0<https://lists.osgeo.org/mailman/listinfo/geos-devel>
End of geos-devel Digest, Vol 275, Issue 10
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20261031/d3efd989/attachment-0001.htm>
