Exact circ×circ Hit on ExactCircularArc — keep CircularString as view?
Jeroen Bloemscheer
jeroen.bloemscheer at merkator.com
Tue Sep 15 16:37:11 PDT 2026
With curve types and CircularArcIntersector now in main, I’d like to propose a small, incremental addition—not an OverlayNG rewrite.
Proposal: introduce a closed‑form circular arc/arc intersection implemented on an algorithm‑side ExactCircularArc value type in geos::algorithm::exactcurve (not a new geos::geom type). When two circular 3‑control windows properly cross, intersection vertices are added on each arc at the intersection points. geom::CircularString remains the WKT/WKB representation; the operation does not take geom::CircularString as input.
No changes to the C API, ExactCurve, ArcNoder, or SegmentString.
Out of scope: circular‑arc/chord interior intersections, buffering, overlay operations, and CIRCLE as a separate SQL/MM type.
Refs: Discussion #1516; historical #1046 and #1382.
Would opening a GitHub issue for this specific slice be useful, or would you prefer that I keep the work on a fork until there’s a concrete PR? I’ll only open an issue if you consider it helpful.
Jeroen Bloemscheer
Merkator / OSGeo bloemscheer
Jeroen Bloemscheer
Geo-IT Consultant
Zaltbommel
[Merkator]
m: +31 (0)6 478 728 18
e: jeroen.bloemscheer at merkator.com
Merkator BV
Hogeweg 137a
5301 LL Zaltbommel(NL)
www.merkator.com<https://www.merkator.com/> [LinkedIn] <https://www.linkedin.com/company/2400587>
This email (including any attachments to it) is confidential, legally privileged, subject to copyright and is sent for the personal attention of the intended recipient only. If you have received this email in error, please advise us immediately and delete it. You are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited. Although we have taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the viruses in this email or attachments. We exclude any liability for the content of this email, or for the consequences of any actions taken on the basis of the information provided in this email or its attachments, unless that information is subsequently confirmed in writing.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20260915/3381a74d/attachment-0001.htm>
