[GRASS-CVS] markus: grass6/vector/v.to.db areas.c, 1.9, 1.10 description.html, 1.24, 1.25 global.h, 1.9, 1.10 main.c, 1.21, 1.22 parse.c, 1.23, 1.24 update.c, 1.20, 1.21
grass at intevation.de grass at intevation.de
Sun Dec 2 08:01:48 EST 2007
Author: markus
Update of /grassrepository/grass6/vector/v.to.db
In directory doto:/tmp/cvs-serv9610
Modified Files:
	areas.c description.html global.h main.c parse.c update.c
Log Message:
Dylan Beaudette: added polygon's Fractal Dimension D
Index: areas.c
RCS file: /grassrepository/grass6/vector/v.to.db/areas.c,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- areas.c	23 Apr 2007 11:01:14 -0000	1.9
+++ areas.c	2 Dec 2007 13:01:46 -0000	1.10
@@ -25,10 +25,10 @@
 	area = 0;
 	perimeter = 0;
-	if ((options.option == O_COMPACT) || (options.option == O_AREA)) {
+	if ((options.option == O_COMPACT) || (options.option == O_FD) || (options.option == O_AREA)) {
 	    area = Vect_get_area_area(Map, area_num);
-	if ((options.option == O_COMPACT) || (options.option == O_PERIMETER)) {
+	if ((options.option == O_COMPACT) || (options.option == O_FD) || (options.option == O_PERIMETER)) {
 	    Vect_get_area_points(Map, area_num, Ppoints);
 	    perimeter = Vect_line_geodesic_length(Ppoints);
@@ -47,6 +47,9 @@
 			break;
 		    case O_COMPACT:
 			Values[idx].d1 = perimeter / (2.0 * sqrt(M_PI * area));
+			break;
+			case O_FD:
+			Values[idx].d1 = 2.0 * log(perimeter) / log(area) ;
 			break;
 		    found = 1;
Index: description.html
RCS file: /grassrepository/grass6/vector/v.to.db/description.html,v
retrieving revision 1.24
retrieving revision 1.25
diff -u -d -r1.24 -r1.25
--- description.html	19 Nov 2007 01:01:10 -0000	1.24
+++ description.html	2 Dec 2007 13:01:46 -0000	1.25
@@ -93,6 +93,25 @@
 v.db.select mysoils layer=2
 </pre></div>
+<p>
+Calculate polygon's Fractal Dimension D based on the formula:
+<br><tt>
+D = 2 * (log perimeter) / (log area):<br>
+</tt>
+<div class="code"><pre>
+g.copy vect=soils,mysoils
+v.db.addcol mysoils col="d double precision"
+v.to.db mysoils option=fd column="d"
+g.region vect=mysoils res=50
+v.to.rast in=mysoils out=soils_fd type=area use=attr column=d
+r.colors map=soils_fd color=gyr
+d.mon x0
+d.rast.leg soils_fd
+d.vect mysoils type=boundary
+</pre></div>
 <h3>Printing reports</h3>
 Report x,y,z coordinates of points in the input vector map:<br>
Index: global.h
RCS file: /grassrepository/grass6/vector/v.to.db/global.h,v
--- global.h	11 Dec 2006 17:47:03 -0000	1.9
+++ global.h	2 Dec 2007 13:01:46 -0000	1.10
@@ -61,12 +61,14 @@
 #define O_QUERY		6  /* Query database records linked by another field (qfield) */
 #define O_SIDES         7  /* Left and right area of boundary */
 #define O_COMPACT	8  /* Compactness of an area. Circle = 1.0 */
-#define O_PERIMETER	9  /* Compactness of an area. Circle = 1.0 */
+#define O_PERIMETER	9
 #define O_START        10  /* line/boundary starting point */
 #define O_END          11  /* line/boundary end point */
 #define O_SLOPE 	12 /* Line slope */
+#define O_FD		13 /* fractal dimension */
 #define U_ACRES		1
 #define U_HECTARES	2
Index: main.c
RCS file: /grassrepository/grass6/vector/v.to.db/main.c,v
retrieving revision 1.21
retrieving revision 1.22
diff -u -d -r1.21 -r1.22
--- main.c	16 Nov 2007 11:02:51 -0000	1.21
+++ main.c	2 Dec 2007 13:01:46 -0000	1.22
@@ -70,7 +70,7 @@
     if ( options.option == O_QUERY ){
 	query(&Map);
     } else if ( ( options.option == O_AREA ) || ( options.option == O_COMPACT ) ||
-		( options.option == O_PERIMETER ) ){
+		( options.option == O_PERIMETER ) || ( options.option == O_FD ) ){
 	read_areas(&Map);
     } else {
         read_lines(&Map);
Index: parse.c
RCS file: /grassrepository/grass6/vector/v.to.db/parse.c,v
retrieving revision 1.23
diff -u -d -r1.23 -r1.24
--- parse.c	12 Oct 2007 14:45:50 -0000	1.23
+++ parse.c	2 Dec 2007 13:01:46 -0000	1.24
@@ -47,13 +47,15 @@
     parms.option->type         = TYPE_STRING;
     parms.option->required     = YES;
     parms.option->multiple     = NO;
-    parms.option->options      = "cat,area,compact,perimeter,length,count,coor,start,end,sides,query,slope";
+    parms.option->options      = "cat,area,compact,fd,perimeter,length,count,coor,start,end,sides,query,slope";
     parms.option->description  = _("Value to upload");
     parms.option->descriptions  =
 		 "cat;insert new row for each category if doesn't exist yet;"
 		 "area;area size;"
-    		 "compact;compactness of an area, calculated as \n"
+    	 "compact;compactness of an area, calculated as \n"
 		 "              compactness = perimeter / (2 * sqrt(PI * area));"
+		 "fd;fractal dimension of an area, calculated as \n"
+		 "              fd = 2 * (log(perimeter) / log(area));"
 		 "perimeter;perimeter length of an area;"
 		 "length;line length;"
 		 "count;number of features for each category;"
@@ -135,7 +137,7 @@
     if (!options.print) {
 	if ( options.option == O_AREA || options.option == O_LENGTH || options.option == O_COUNT
-	     || options.option == O_QUERY || options.option == O_COMPACT
+	     || options.option == O_QUERY || options.option == O_COMPACT || options.option == O_FD
 	     || options.option == O_PERIMETER || options.option == O_SLOPE ) /* one column required */
 	    if ( ncols != 1) {
@@ -191,6 +193,7 @@
     else if (strcmp (s, "sides") == 0) x = O_SIDES;
     else if (strcmp (s, "query") == 0) x = O_QUERY;
     else if (strcmp (s, "compact") == 0) x = O_COMPACT;
+    else if (strcmp (s, "fd") == 0) x = O_FD;
     else if (strcmp (s, "perimeter") == 0) x = O_PERIMETER;
     else if (strcmp (s, "slope") == 0) x = O_SLOPE;
Index: update.c
RCS file: /grassrepository/grass6/vector/v.to.db/update.c,v
retrieving revision 1.20
diff -u -d -r1.20 -r1.21
--- update.c	19 Sep 2007 21:19:12 -0000	1.20
+++ update.c	2 Dec 2007 13:01:46 -0000	1.21
@@ -47,6 +47,7 @@
 	case O_AREA:
 	case O_QUERY:
 	case O_COMPACT:
+	case O_FD:
 	case O_PERIMETER:
         case O_SLOPE:
 	    sprintf (buf1, "update %s set %s =", Fi->table, options.col[0]);
@@ -78,6 +79,7 @@
     	    case O_LENGTH:
 	    case O_AREA:
 	    case O_COMPACT:
+	    case O_FD:
 	    case O_PERIMETER:
 	    case O_SLOPE:
     		sprintf (buf2, "%s %f where %s = %d", buf1, Values[i].d1, Fi->key,  Values[i].cat);
