[GRASS-CVS] [grass-addons] r1234 - trunk/grassaddons/i.pr/doc
neteler at grass.itc.it
Mon Dec 3 09:29:00 EST 2007
Author: neteler
Date: 2007-12-03 15:29:00 +0100 (Mon, 03 Dec 2007)
New Revision: 1234
trunk/grassaddons/i.pr/doc/usage_EN.txt
test commit for email notification
Modified: trunk/grassaddons/i.pr/doc/usage_EN.txt
--- trunk/grassaddons/i.pr/doc/usage_EN.txt 2007-12-03 14:25:51 UTC (rev 1233)
+++ trunk/grassaddons/i.pr/doc/usage_EN.txt 2007-12-03 14:29:00 UTC (rev 1234)
@@ -6,7 +6,7 @@
Graphical interface for extracting data from training raster maps
GRASS. Given a list of maps (parameter map), where the first
Viewing will be used if not set the
-Parameter vismap, you select by clicking on the map
+parameter vismap, you select by clicking on the map
Examples of training that will dimension rows cols
(Parameters and rows cols respectively). The examples selected
Class will be assigned to input by choice (parameter
