[GRASS-CVS]
markus: grass6/scripts/db.out.ogr description.html, NONE,
1.1 db.out.ogr, NONE, 1.1 Makefile, NONE, 1.1
grass at intevation.de
Tue Dec 4 08:54:12 EST 2007
Author: markus
Update of /grassrepository/grass6/scripts/db.out.ogr
In directory doto:/tmp/cvs-serv30820
Added Files:
description.html db.out.ogr Makefile
Log Message:
new table exporter
--- NEW FILE: description.html ---
<h2>DESCRIPTION</h2>
<em>db.out.ogr</em> exports GRASS attribute tables into various formats as
supported by the OGR driver on the local system (CSV, DBF,
PostgreSQL, SQLite, MySQL, ODBC, etc.).
<h2>EXAMPLES</h2>
Export of GRASS table to a DBF table (default format):
<p>
<div class="code"><pre>
db.out.ogr points_tab dsn=/tmp/points_tab.dbf
</pre></div>
<p>
Export of GRASS table to a CSV table file:<br>
<p>
db.out.ogr points_tab dsn=points.csv format=CSV
</pre></div>
<p>
Export of GRASS table into a PostgreSQL table:
<p>
db.out.ogr points_tab dsn="PG:host=localhost dbname=postgres user=neteler" format=PostgreSQL
echo "SELECT * FROM points_tab" | psql postgres
</pre></div>
<h2>SEE ALSO</h2>
<em><a href="sql.html">GRASS SQL interface</a></em>
<h2>AUTHOR</h2>
Markus Neteler
<p><i>Last changed: $Date: 2007/12/04 13:54:09 $</i>
--- NEW FILE: db.out.ogr ---
#!/bin/sh -x
# MODULE: db.out.ogr
# AUTHOR(S): Markus Neteler
# PURPOSE: exports attribute tables into various formats
# COPYRIGHT: (C) 2007 by Markus Neteler and the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
#%Module
#% description: Exports attribute tables into various formats.
#% keywords: database, attribute table
#%End
#%option
#% key: input
#% type: string
#% key_desc : name
#% description: GRASS table name
#% required : yes
#%end
#%option
#% key: dsn
#% type: string
#% key_desc : name
#% gisprompt: new_file,file,input
#% description: Table file to be exported or DB connection string
#% required : yes
#%end
#%option
#% key: format
#% type: string
#% description: Table format
#% required : yes
#% options: CSV,DBF,GML,MySQL,PostgreSQL,SQLite
#% answer: DBF
#%end
#%option
#% key: db_table
#% type: string
#% key_desc : name
#% description: Name for output table
#% required : no
#%end
if [ -z "$GISBASE" ] ; then
echo "You must be in GRASS GIS to run this program." >&2
exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
fi
PROG=`basename $0`
# setting environment, so that awk works properly in all languages
unset LC_ALL
LC_NUMERIC=C
export LC_NUMERIC
# what to do in case of user break:
exitprocedure()
g.message -e 'User break!'
exit 1
# shell check for user break (signal list: trap -l)
trap "exitprocedure" 2 3 15
### setup enviro vars ###
eval `g.gisenv`
: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
if [ "$GIS_OPT_FORMAT" = "DBF" -o "$GIS_OPT_FORMAT" = "dbf" ] ; then
GIS_OPT_FORMAT="ESRI_Shapefile"
fi
if [ "$GIS_OPT_FORMAT" = "CSV" ] ; then
OLAYER="olayer=`basename $GIS_OPT_DSN .csv`"
fi
#is there a simpler way of testing for --overwrite?
if [ -e "$GIS_OPT_INPUT.dbf" ] ; then
if [ -z "$GRASS_OVERWRITE" ] || [ "$GRASS_OVERWRITE" -ne 1 ] ; then
g.message -e "File <$GIS_OPT_INPUT.dbf> already exists"
exit 1
fi
fi
v.out.ogr --q $GIS_OPT_INPUT dsn="$GIS_OPT_DSN" $OLAYER format=$GIS_OPT_FORMAT type=point
if [ $? -ne 0 ] ; then
exit 1
fi
if [ "$GIS_OPT_FORMAT" = "ESRI_Shapefile" ] ; then
echo "$GIS_OPT_DSN" | grep '\.dbf$' > /dev/null
if [ $? -eq 0 ] ; then
OUTNAME="`basename $GIS_OPT_DSN .dbf`"
rm -f $OUTNAME.shp
rm -f $OUTNAME.shx
rm -f $OUTNAME.prj
OUTNAME="$OUTNAME.dbf"
else
rm -f $GIS_OPT_DSN/$GIS_OPT_INPUT.shp
rm -f $GIS_OPT_DSN/$GIS_OPT_INPUT.shx
rm -f $GIS_OPT_DSN/$GIS_OPT_INPUT.prj
OUTNAME="$GIS_OPT_DSN/$GIS_OPT_INPUT.dbf"
fi
else
OUTNAME="$GIS_OPT_DSN".csv
else
OUTNAME="$GIS_OPT_INPUT"
fi
fi
g.message "Exported table <$OUTNAME>"
exit 0
--- NEW FILE: Makefile ---
MODULE_TOPDIR = ../..
PGM = db.out.ogr
include $(MODULE_TOPDIR)/include/Make/Script.make
default: script
