[GRASS-CVS] [addons] r1242 - trunk/grassaddons/gui/gui_modules
grass-commit-addons at grass.itc.it
Wed Dec 5 05:16:28 EST 2007
Author: landa
Date: 2007-12-05 11:16:28 +0100 (Wed, 05 Dec 2007)
New Revision: 1242
trunk/grassaddons/gui/gui_modules/dbm.py
'Extract selected' enabled only when at least one item is selected
Modified: trunk/grassaddons/gui/gui_modules/dbm.py
--- trunk/grassaddons/gui/gui_modules/dbm.py 2007-12-05 09:39:57 UTC (rev 1241)
+++ trunk/grassaddons/gui/gui_modules/dbm.py 2007-12-05 10:16:28 UTC (rev 1242)
@@ -61,8 +61,8 @@
class VirtualAttributeList(wx.ListCtrl,
listmix.ListCtrlAutoWidthMixin,
- listmix.ColumnSorterMixin,
- listmix.TextEditMixin):
+ listmix.ColumnSorterMixin):
+ # listmix.TextEditMixin):
Support virtual list class
@@ -906,13 +906,16 @@
self.popupDataID5 = wx.NewId()
self.popupDataID6 = wx.NewId()
self.popupDataID7 = wx.NewId()
+ self.popupDataID8 = wx.NewId()
self.Bind(wx.EVT_MENU, self.OnDataItemEdit, id=self.popupDataID1)
self.Bind(wx.EVT_MENU, self.OnDataItemAdd, id=self.popupDataID2)
self.Bind(wx.EVT_MENU, self.OnDataItemDelete, id=self.popupDataID3)
self.Bind(wx.EVT_MENU, self.OnDataItemDeleteAll, id=self.popupDataID4)
self.Bind(wx.EVT_MENU, self.OnDataReload, id=self.popupDataID5)
- self.Bind(wx.EVT_MENU, self.OnDataDrawSelected, id=self.popupDataID6)
- self.Bind(wx.EVT_MENU, self.OnExtractSelected, id=self.popupDataID7)
+ self.Bind(wx.EVT_MENU, self.OnDataSelectAll, id=self.popupDataID6)
+ self.Bind(wx.EVT_MENU, self.OnDataDrawSelected, id=self.popupDataID7)
+ self.Bind(wx.EVT_MENU, self.OnExtractSelected, id=self.popupDataID8)
list = self.FindWindowById(self.layerPage[self.layer]['data'])
# generate popup-menu
@@ -921,21 +924,22 @@
selected = list.GetFirstSelected()
if selected == -1 or list.GetNextSelected(selected) != -1:
menu.Enable(self.popupDataID1, False)
- menu.AppendSeparator()
menu.Append(self.popupDataID2, _("Insert new record"))
menu.Append(self.popupDataID3, _("Delete selected record(s)"))
menu.Append(self.popupDataID4, _("Delete all records"))
- menu.Append(self.popupDataID5, _("Reload"))
+ menu.Append(self.popupDataID6, _("Select all"))
+ menu.Append(self.popupDataID6, _("Select none"))
- menu.Append(self.popupDataID6, _("Display selected"))
+ menu.Append(self.popupDataID7, _("Display selected"))
if not self.map:
- menu.Enable(self.popupDataID6, False)
- menu.Append(self.popupDataID7, _("Extract selected"))
+ menu.Enable(self.popupDataID7, False)
+ menu.Append(self.popupDataID8, _("Extract selected"))
if list.GetFirstSelected() == -1:
menu.Enable(self.popupDataID3, False)
- menu.Enable(self.popupDataID7, False)
+ menu.Enable(self.popupDataID8, False)
+ menu.AppendSeparator()
+ menu.Append(self.popupDataID5, _("Reload"))
self.PopupMenu(menu)
menu.Destroy()
@@ -1183,6 +1187,10 @@
self.OnApplySqlStatement(None)
self.listOfSQLStatements = []
+ def OnDataSelectAll(self, event):
+ """Select all items"""
+ pass
def OnTableChangeType(self, event):
"""Data type for new column changed. Enable or disable
data length widget"""
