[GRASS-CVS] [addons] r1248 - trunk/grassaddons/gui/gui_modules
grass-commit-addons at grass.itc.it
Wed Dec 5 08:13:54 EST 2007
Author: landa
Date: 2007-12-05 14:13:53 +0100 (Wed, 05 Dec 2007)
New Revision: 1248
trunk/grassaddons/gui/gui_modules/dbm.py
trunk/grassaddons/gui/gui_modules/gcmd.py
NewVectorDialog added (extract selected)
Modified: trunk/grassaddons/gui/gui_modules/dbm.py
--- trunk/grassaddons/gui/gui_modules/dbm.py 2007-12-05 12:21:24 UTC (rev 1247)
+++ trunk/grassaddons/gui/gui_modules/dbm.py 2007-12-05 13:13:53 UTC (rev 1248)
@@ -8,6 +8,7 @@
* DisplayAttributesDialog
* VectorDBInfo
* ModifyTableRecord
+ * NewVectorDialog
PURPOSE: GRASS attribute table manager
@@ -1665,38 +1666,31 @@
return False
else:
# dialog to get file name
- dlg = wx.TextEntryDialog(parent=self, caption=_('Extract selected'),
- message=_('Name of new vector map layer'))
+ # dlg = wx.TextEntryDialog(parent=self, caption=_('Extract selected'),
+ # message=_('Name of new vector map layer'))
+ dlg = NewVectorDialog(parent=self, id=wx.ID_ANY, title=_('Extract selected'))
- if dlg.ShowModal() == wx.ID_OK:
- outmap = dlg.GetValue()
- if outmap == '':
- dlgErr = wx.MessageDialog(self.parent,
- _("Unable to create new vector map layer.%s"
- "Name for map layer is missing.") % \
- (os.linesep),
- _("Error"), wx.OK | wx.ICON_ERROR)
- dlgErr.ShowModal()
- dlgErr.Destroy()
- dlg.Destroy()
- return False
+ if dlg.ShowModal() == wx.ID_OK:
+ outmap, overwrite = dlg.GetName()
- dlg.Destroy()
+ if outmap == '': # should not happen
+ return False
- #TODO - add overwrite option and vector map selector to dialog
- cmd = ["v.extract", "input=%s" % self.vectmap,
- "output=%s" % outmap,
- "list=%s" % utils.ListOfCatsToRange(cats),
- "--overwrite"]
+ cmd = ["v.extract",
+ "input=%s" % self.vectmap,
+ "output=%s" % outmap,
+ "list=%s" % utils.ListOfCatsToRange(cats)]
+ if overwrite is True:
+ cmd.append('--overwrite')
- p = gcmd.Command(cmd)
+ p = gcmd.Command(cmd)
- if p.returncode == 0:
- return True
- else:
- return False
+ if p.returncode == 0:
+ return True
+ return False
def UpdateSettings(self):
"""Update settings dict"""
self.settings['highlight']['color'] = self.hlColor.GetColour()
@@ -3135,6 +3129,8 @@
id += 1
self.__Layout()
+ self.SetMinSize(self.GetSize())
def __Layout(self):
"""Do layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
@@ -3181,6 +3177,72 @@
return valueList
+class NewVectorDialog(wx.Dialog):
+ """Create new vector map layer"""
+ def __init__(self, parent, id, title,
+ style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ wx.Dialog.__init__(self, parent, id, title, style=style)
+ self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
+ self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
+ self.btnOK = wx.Button(self.panel, wx.ID_OK)
+ self.btnOK.SetDefault()
+ self.btnOK.Enable(False)
+ self.label = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
+ label=_("Name for new vector map layer:"))
+ self.mapName = wx.TextCtrl(parent=self.panel, id=wx.ID_ANY,
+ value='', size=(250, -1),
+ style=wx.TE_PROCESS_ENTER)
+ self.mapName.Bind(wx.EVT_TEXT, self.OnMapName)
+ self.overwrite = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
+ label=_("Allow output files to overwrite existing files"))
+ self.__Layout()
+ def OnMapName(self, event):
+ """Name for vector map layer given"""
+ if len(event.GetString()) > 0:
+ self.btnOK.Enable(True)
+ else:
+ def __Layout(self):
+ """Do layout"""
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ dataSizer = wx.BoxSizer(wx.VERTICAL)
+ dataSizer.Add(self.label, proportion=0,
+ flag=wx.ALL, border=1)
+ dataSizer.Add(self.mapName, proportion=0,
+ flag=wx.EXPAND | wx.ALL, border=1)
+ dataSizer.Add(self.overwrite, proportion=0,
+ # buttons
+ btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(self.btnCancel)
+ btnSizer.AddButton(self.btnOK)
+ btnSizer.Realize()
+ sizer.Add(item=dataSizer, proportion=1,
+ flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ sizer.Add(item=btnSizer, proportion=0,
+ self.panel.SetSizer(sizer)
+ sizer.Fit(self)
+ def GetName(self):
+ """Return (mapName, overwrite)"""
+ return (self.mapName.GetValue(), self.overwrite.IsChecked())
def main(argv=None):
if argv is None:
argv = sys.argv
Modified: trunk/grassaddons/gui/gui_modules/gcmd.py
--- trunk/grassaddons/gui/gui_modules/gcmd.py 2007-12-05 12:21:24 UTC (rev 1247)
+++ trunk/grassaddons/gui/gui_modules/gcmd.py 2007-12-05 13:13:53 UTC (rev 1248)
@@ -184,11 +184,12 @@
# set verbosity level
verbose_orig = None
- if '--q' not in self.cmd and '--v' not in self.cmd:
+ if ('--q' not in self.cmd or '--quiet' not in self.cmd) and \
+ ('--v' not in self.cmd or '--verbose' not in self.cmd):
if verbose == 0:
- self.cmd.append('--q')
+ self.cmd.append('--quiet')
elif verbose == 3:
- self.cmd.append('--v')
+ self.cmd.append('--verbose')
else:
verbose_orig = os.getenv("GRASS_VERBOSE")
os.environ["GRASS_VERBOSE"] = str(verbose)
