[GRASS-CVS] [addons] r1249 - in trunk/grassaddons/gipe: . i.sattime
script_generator
grass-commit-addons at grass.itc.it
Thu Dec 6 07:29:12 EST 2007
Author: chemin
Date: 2007-12-06 13:28:44 +0100 (Thu, 06 Dec 2007)
New Revision: 1249
trunk/grassaddons/gipe/i.sattime/main.c
trunk/grassaddons/gipe/imagery_Makefile
trunk/grassaddons/gipe/script_generator/l7_in_read.c
Various bugs fixed
Modified: trunk/grassaddons/gipe/i.sattime/main.c
--- trunk/grassaddons/gipe/i.sattime/main.c 2007-12-05 13:13:53 UTC (rev 1248)
+++ trunk/grassaddons/gipe/i.sattime/main.c 2007-12-06 12:28:44 UTC (rev 1249)
@@ -83,7 +83,7 @@
input3->type = TYPE_STRING;
input3->required = YES;
input3->gisprompt =_("old,cell,raster") ;
- input3->description=_("Name of the latitude input map");
+ input3->description=_("Name of the longitude input map");
input3->answer =_("longitude");
input4 = G_define_option() ;
@@ -175,7 +175,8 @@
for (row = 0; row < nrows; row++)
DCELL d;
- DCELL d_da;
+ DCELL d_frac_year;
+ DCELL d_tc_wa;
DCELL d_delta;
DCELL d_Wa;
DCELL d_Wa1;
@@ -191,6 +192,8 @@
G_fatal_error(_("Could not read from <%s>"),doy);
if(G_get_raster_row(infd_lat,inrast_lat,row,data_type_lat)<0)
G_fatal_error(_("Could not read from <%s>"),lat);
+ if(G_get_raster_row(infd_lon,inrast_lon,row,data_type_lon)<0)
+ G_fatal_error(_("Could not read from <%s>"),lon);
if(G_get_raster_row(infd_phi,inrast_phi,row,data_type_phi)<0)
G_fatal_error(_("Could not read from <%s>"),phi);
for (col=0; col < ncols; col++)
@@ -217,6 +220,17 @@
d_lat = ((DCELL *) inrast_lat)[col];
break;
+ switch(data_type_lon){
+ case CELL_TYPE:
+ d_lon = (double) ((CELL *) inrast_lon)[col];
+ break;
+ case FCELL_TYPE:
+ d_lon = (double) ((FCELL *) inrast_lon)[col];
+ break;
+ case DCELL_TYPE:
+ d_lon = ((DCELL *) inrast_lon)[col];
+ break;
switch(data_type_phi){
case CELL_TYPE:
d_phi = (double) ((CELL *) inrast_phi)[col];
@@ -230,11 +244,15 @@
//d_da = 2 * PI * ( d_doy - 1 ) / 365.0;
//d_delta = 0.006918-0.399912*cos(d_da)+0.070257*sin(d_da)-0.006758*cos(2*d_da)+0.000907*sin(2*d_da)-0.002697*cos(3*d_da)+0.00148*sin(3*d_da);
- d_delta = 0.4093*sin((2.0*PI/365.0)*d_doy-1.39);
- d_Wa1=cos(d_phi*PI/180.0)-sin(d_delta)*sin(d_lat*PI/180.0);
- d_Wa2=cos(d_delta)*cos(d_lat*PI/180.0);
+ //d_delta = 0.4093*sin((2.0*PI/365.0)*d_doy-1.39);
+ d_frac_year = (360.0/365.25) * d_doy;
+ d_delta = 0.396372-22.91327*cos(d_frac_year*PI/180.0)+4.02543*sin(d_frac_year*PI/180.0)-0.387205*cos(2*d_frac_year*PI/180.0)+0.051967*sin(2*d_frac_year*PI/180.0)-0.154527*cos(3*d_frac_year*PI/180.0)+0.084798*sin(3*d_frac_year*PI/180.0);
+ d_tc_wa = 0.004297+0.107029*cos(d_frac_year*PI/180.0)-1.837877*sin(d_frac_year*PI/180.0)-0.837378*cos(2*d_frac_year*PI/180.0)-2.340475*sin(2*d_frac_year*PI/180.0);
+ d_Wa1=cos((90.0-d_phi)*PI/180.0)-sin(d_delta*PI/180.0)*sin(d_lat*PI/180.0);
+ d_Wa2=cos(d_delta*PI/180.0)*cos(d_lat*PI/180.0);
d_Wa=acos(d_Wa1/d_Wa2);
- d_time = 12.0*(d_Wa+1.0)/PI + d_lon*(24.0/360.0);
+ d_time = ((d_Wa-(d_lon*PI/180.0)-d_tc_wa)/15.0)+12.0;
+ //d_time = 12.0*(d_Wa+1.0)/PI + d_lon*(24.0/360.0);
((DCELL *) outrast1)[col] = d_time;
if (G_put_raster_row (outfd1, outrast1, data_type_output) < 0)
Modified: trunk/grassaddons/gipe/imagery_Makefile
--- trunk/grassaddons/gipe/imagery_Makefile 2007-12-05 13:13:53 UTC (rev 1248)
+++ trunk/grassaddons/gipe/imagery_Makefile 2007-12-06 12:28:44 UTC (rev 1249)
@@ -37,6 +37,7 @@
i.group \
i.his.rgb \
i.latitude \
+ i.longitude \
i.landsat.dehaze \
i.maxlik \
i.ortho.photo \
Modified: trunk/grassaddons/gipe/script_generator/l7_in_read.c
--- trunk/grassaddons/gipe/script_generator/l7_in_read.c 2007-12-05 13:13:53 UTC (rev 1248)
+++ trunk/grassaddons/gipe/script_generator/l7_in_read.c 2007-12-06 12:28:44 UTC (rev 1249)
@@ -600,7 +600,7 @@
/*Calculate ETPOT (and Rnetd for future ETa calculations)*/
system("echo \"\" >> temp.txt");
system("echo \"#ETPOT\" >> temp.txt");
- snprintf(sys_5,1000,"echo \"i.evapo.potrad -r -d albedo=%s.albedo tempk=%s.61 lat=%s.latitude doy=%s.doy tsw=%s.tsw slope=%s.slope aspect=%s.aspect etpot=%s.etpot rnetd=%s.rnetd --overwrite ; r.null map=%s.rnetd setnull=-999.99 \" >> temp.txt", basedate, basedate, basedate, basedate, basedate, basedate, basedate, basedate, basedate, basedate);
+ snprintf(sys_5,1000,"echo \"i.evapo.potrad -r albedo=%s.albedo tempk=%s.61 lat=%s.latitude doy=%s.doy tsw=%s.tsw etpot=%s.etpot rnetd=%s.rnetd --overwrite ; r.null map=%s.rnetd setnull=-999.99 \" >> temp.txt", basedate, basedate, basedate, basedate, basedate, basedate, basedate, basedate, basedate, basedate);
system(sys_5);
snprintf(sys_7,1000,"echo \"r.colors map=%s.etpot color=grey ; r.null map=%s.etpot setnull=-999.99\" >> temp.txt", basedate, basedate);
system(sys_7);
@@ -675,7 +675,7 @@
sprintf(sys_31,"echo \"i.eb.h_iter rohair=%s.rohair cp=1004.16 dtair=%s.delta tempk=%s.61 disp=%s.disp z0m=%s.z0m z0h=%s.z0h u2m=u2 h0=%s.h0 --overwrite; r.null map=%s.h0 setnull=-999.99 \" >> temp.txt",basedate,basedate,basedate,basedate,basedate,basedate,basedate,basedate);
system(sys_31);
- sprintf(sys_32,"echo \"i.eb.evapfr -m rnet=%s.rnet g0=%s.g0 h0=%s.h0 evapfr=%s.evapfr theta=%s.theta --overwrite ; r.null map=%s.evapfr setnull=-999.99 ; r.null map=%s.theta setnull=-999.99 \" >> temp.txt",basedate,basedate,basedate,basedate,basedate,basedate,basedate);
+ sprintf(sys_32,"echo \"i.eb.evapfr -m rnet=%s.rnet g0=%s.g0 h0=%s.h0 evapfr=%s.evapfr theta=%s.theta --overwrite ; r.null map=%s.evapfr setnull=-999.99 ; r.null map=%s.theta setnull=-999.99 ; r.colors map=%s.theta color=grey1.0 ; r.colors map=%s.evapfr color=grey1.0 \" >> temp.txt",basedate,basedate,basedate,basedate,basedate,basedate,basedate,basedate,basedate);
system(sys_32);
sprintf(sys_33,"echo \"i.eb.eta rnetday=%s.rnetd evapfr=%s.evapfr tempk=%s.61 eta=%s.eta --overwrite ; r.null map=%s.eta setnull=-999.99 \" >> temp.txt",basedate,basedate,basedate,basedate,basedate);
