[GRASS-CVS] [addons] r1253 - in trunk/grassaddons/gui: . display_driver
grass-commit-addons at grass.itc.it grass-commit-addons at grass.itc.it
Fri Dec 7 05:45:35 EST 2007
Author: landa
Date: 2007-12-07 11:45:34 +0100 (Fri, 07 Dec 2007)
New Revision: 1253
   trunk/grassaddons/gui/README
   trunk/grassaddons/gui/display_driver/Makefile
Cosmetics: simplify display driver compilation instructions
Modified: trunk/grassaddons/gui/README
--- trunk/grassaddons/gui/README	2007-12-07 10:27:46 UTC (rev 1252)
+++ trunk/grassaddons/gui/README	2007-12-07 10:45:34 UTC (rev 1253)
@@ -153,20 +153,14 @@
 To enable digitization tool you need to compile display driver located
 in directory 'display_driver'.
-Before compiling the driver go to the wxPython directory, e.g.
+$ cd $GISBASE/etc/wx/display_driver
-$ cd /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx
+Make symlink, e.g.
-Make symlink
+$ ln -s /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so libgdi.so
-sudo ln -s _gdi_.so libgdi.so
-Add /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx to
-LIBRARY_PATH or edit /etc/ld.so.conf file.
 Then you can compile the driver
-$ cd $GISBASE/etc/wx/display_driver
 $ make
 Note: You probably will need to modify the Makefile. This need to be
Modified: trunk/grassaddons/gui/display_driver/Makefile
--- trunk/grassaddons/gui/display_driver/Makefile	2007-12-07 10:27:46 UTC (rev 1252)
+++ trunk/grassaddons/gui/display_driver/Makefile	2007-12-07 10:45:34 UTC (rev 1253)
@@ -10,9 +10,9 @@
 SWIG=swig
-CFLAGS=-c -fpic -I/usr/include/python$(PYTHONVERSION) -I./ -I$(ARCH_DISTDIR)/include `wx-config --cxxflags`
+CFLAGS=-c -fpic -I/usr/include/python$(PYTHONVERSION) -I./ -I$(ARCH_DISTDIR)/include `wx-config --cxxflags` `gdal-config --cflags`
-LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) -lgrass_vect -lgrass_gis `wx-config --libs` -L/usr/lib/python$(PYTHONVERSION)/site-packages/wx-2.8-gtk2-unicode/wx -lgdi
+LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) -lgrass_vect -lgrass_gis `wx-config --libs` -L./ -lgdi
 default: grass6_wxdriver.so
