[GRASS-CVS] scott: grass6/scripts/r.regression.line r.regression.line, 1.18, 1.19
grass at intevation.de grass at intevation.de
Fri Dec 7 10:12:40 EST 2007
Author: scott
Update of /grassrepository/grass6/scripts/r.regression.line
In directory doto:/tmp/cvs-serv27425
Modified Files:
	r.regression.line
Log Message:
corrected description of medX medY - mean, not median
Index: r.regression.line
RCS file: /grassrepository/grass6/scripts/r.regression.line/r.regression.line,v
retrieving revision 1.18
retrieving revision 1.19
diff -u -d -r1.18 -r1.19
--- r.regression.line	4 Dec 2007 20:39:49 -0000	1.18
+++ r.regression.line	7 Dec 2007 15:12:37 -0000	1.19
@@ -115,7 +115,7 @@
            echo "   b: gain"
            echo "   R: sumXY - sumX*sumY/tot"
            echo "   N: number of elements"
-           echo "   medX, medY: Medians"
+           echo "   medX, medY: Means"
            echo "   sdX, sdY: Standard deviations"
            echo "a  b  R  N  F medX  sdX  medY  sdY"
 	   RESULTADO=`cat "$TMP"b`
@@ -130,7 +130,7 @@
            echo "   b: gain" >> "$TMP"c
            echo "   R: sumXY - sumX*sumY/tot" >> "$TMP"c
            echo "   N: number of elements" >> "$TMP"c
-           echo "   medX, medY: Medians" >> "$TMP"c
+           echo "   medX, medY: Means" >> "$TMP"c
            echo "   sdX, sdY: Standard deviations" >> "$TMP"c
            echo "a  b  R  N  F medX  sdX  medY  sdY" >> "$TMP"c
 	   cat "$TMP"b >> "$TMP"c
