[GRASS-SVN] r29442 - grass/trunk/raster/r.average
svn_grass at osgeo.org
Sat Dec 15 09:51:48 EST 2007
Author: epatton
Date: 2007-12-15 09:51:48 -0500 (Sat, 15 Dec 2007)
New Revision: 29442
grass/trunk/raster/r.average/description.html
Corrected typo; standardized section heading order
Modified: grass/trunk/raster/r.average/description.html
--- grass/trunk/raster/r.average/description.html 2007-12-15 10:55:35 UTC (rev 29441)
+++ grass/trunk/raster/r.average/description.html 2007-12-15 14:51:48 UTC (rev 29442)
@@ -29,10 +29,49 @@
value in the <EM>base</EM> map, the values assigned these cells in the
<EM>cover</EM> map will be averaged.
-The <B>cover</B> map is n existing raster map layer containing the values
+The <EM>cover</EM> map is an existing raster map layer containing the values
(in the form of cell category values or cell category labels) to be averaged
within each category of the <EM>base</EM> map.
+<H2>NOTES</H2>
+The <B>-c</B> option requires that the category label for
+each category in the <EM>cover</EM> map be a valid number,
+integer, or decimal. To be exact, if the first item in the
+label is numeric, then that value is used. Otherwise, zero
+is used. The following table covers all possible cases:
+<P>
+<PRE>
+ category value
+ label used by -c
+ ______________________
+ .12 .12
+ .80 KF .8
+ no data 0
+</PRE>
+<P>
+(This flag is very similar to the @ operator in
+<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>,
+and the user is encouraged to read the manual entry for
+to see how it works there.)
+<P>
+The user should use the results of <EM>r.average</EM> with
+care. Since this utility assigns a value to each cell
+which is based on global information (i.e., information at
+spatial locations other than just the location of the cell
+itself), the resultant map layer is only valid if the
+geographic region and mask settings are the same as they
+were at the time that the result map was created.
+<P>
+Results are affected by the current region settings and mask.
<H2>EXAMPLE</H2>
Assume that
@@ -81,45 +120,8 @@
7 .2345
</PRE>
-<H2>NOTES</H2>
-The <B>-c</B> option requires that the category label for
-each category in the <EM>cover</EM> map be a valid number,
-integer, or decimal. To be exact, if the first item in the
-label is numeric, then that value is used. Otherwise, zero
-is used. The following table covers all possible cases:
-<P>
-<PRE>
- category value
- label used by -c
- ______________________
- .12 .12
- .80 KF .8
- no data 0
-</PRE>
-<P>
-(This flag is very similar to the @ operator in
-<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>,
-and the user is encouraged to read the manual entry for
-to see how it works there.)
-<P>
-The user should use the results of <EM>r.average</EM> with
-care. Since this utility assigns a value to each cell
-which is based on global information (i.e., information at
-spatial locations other than just the location of the cell
-itself), the resultant map layer is only valid if the
-geographic region and mask settings are the same as they
-were at the time that the result map was created.
-<P>
-Results are affected by the current region settings and mask.
<H2>SEE ALSO</H2>
<EM><A HREF="g.region.html">g.region</A></EM>,
