[GRASS-SVN] r29450 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Dec 16 12:54:37 EST 2007
Author: martinl
Date: 2007-12-16 12:54:36 -0500 (Sun, 16 Dec 2007)
New Revision: 29450
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
wxGUI: Dialog for setting default region extent and resolution improved (including 3D)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2007-12-16 11:52:29 UTC (rev 29449)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2007-12-16 17:54:36 UTC (rev 29450)
@@ -454,6 +454,10 @@
# do layout
self.__layout()
+ # self.SetMinSize(self.GetBestSize())
+ self.SetSize((680, 520))
+ self.SetMinSize(self.GetSize())
def __del__(self):
pass
# if self.qlayer and self.map:
@@ -880,10 +884,6 @@
# mainSizer.Fit(self) # problem connected to aui
self.Layout()
- # self.SetMinSize(self.GetBestSize())
- self.SetSize((680, 520))
- self.SetMinSize(self.GetSize())
def OnDataRightUp(self, event):
"""Table description area, context menu"""
if not hasattr(self, "popupDataID1"):
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2007-12-16 11:52:29 UTC (rev 29449)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2007-12-16 17:54:36 UTC (rev 29450)
@@ -76,9 +76,9 @@
return wx.TextCtrl(parent=self, id=wx.ID_ANY, value=text,
size=size, style=style)
- def MakeButton(self, text, size=(-1,-1)):
+ def MakeButton(self, text, id=wx.ID_ANY, size=(-1,-1)):
"""Generic button"""
- return wx.Button(parent=self, id=wx.ID_ANY, label=text,
+ return wx.Button(parent=self, id=id, label=text,
size=size)
class TitledPage(BaseClass, wiz.WizardPageSimple):
@@ -1352,13 +1352,16 @@
Page for setting default region extents and resolution
- def __init__(self,parent, id=wx.ID_ANY,
- title=_("Set default region values"), location=None):
+ def __init__(self, parent, id=wx.ID_ANY,
+ title=_("Set default region extent and resolution"), location=None):
wx.Frame.__init__(self, parent, id, title, size=(650,300))
self.parent = parent
self.location = location
+ # values
# 2D
self.north = 1.0
self.south = 0.0
@@ -1366,23 +1369,42 @@
self.west = 0.0
self.nsres = 1.0
self.ewres = 1.0
+ # 3D
+ self.top = 1.0
+ self.bottom = 0.0
+ # self.nsres3 = 1.0
+ # self.ewres3 = 1.0
+ self.tbres = 1.0
# inputs
- self.ttop = self.MakeTextCtrl(str(self.north), size=(150, -1))
- self.tbottom = self.MakeTextCtrl(str(self.south), size=(150, -1))
- self.tleft = self.MakeTextCtrl(str(self.west), size=(150, -1))
- self.tright = self.MakeTextCtrl(str(self.east), size=(150, -1))
- self.tres = self.MakeTextCtrl(str(self.res), size=(150, -1))
+ # 2D
+ self.tnorth = self.MakeTextCtrl(str(self.north), size=(150, -1))
+ self.tsouth = self.MakeTextCtrl(str(self.south), size=(150, -1))
+ self.twest = self.MakeTextCtrl(str(self.west), size=(150, -1))
+ self.teast = self.MakeTextCtrl(str(self.east), size=(150, -1))
+ self.tnsres = self.MakeTextCtrl(str(self.nsres), size=(150, -1))
+ self.tewres = self.MakeTextCtrl(str(self.ewres), size=(150, -1))
# labels
- # self.lmessage = self.MakeLabel(size=(300,50))
+ self.lrows = self.MakeLabel("")
+ self.lcols = self.MakeLabel("")
+ self.lcells = self.MakeLabel("")
# buttons
- self.bset = self.MakeButton(_("Set coordinates"), size=(150,-1))
- self.bcancel = self.MakeButton(_("Cancel"), size=(150,-1))
+ self.bset = self.MakeButton(_("&Set region"), id=wx.ID_OK)
+ self.bcancel = self.MakeButton(_("Cancel"), id=wx.ID_CANCEL)
+ self.bset.SetDefault()
# set current working environment to PERMANENT mapset
# in selected location in order to set default region (WIND)
envval = {}
cmdlist = ['g.gisenv']
p = gcmd.Command(cmdlist)
@@ -1404,13 +1426,13 @@
dlg = wx.MessageBox(parent=self,
message=_('A valid location must be selected'),
caption=_("Error"), style=wx.ID_OK | wx.ICON_ERROR)
- dlg.ShowModal()
- dlg.Destroy()
return
# get current region settings
region = {}
- cmdlist = ['g.region', '-gp']
+ cmdlist = ['g.region', '-gp3']
if p.returncode == 0:
output = p.ReadStdOutput()
@@ -1421,131 +1443,363 @@
region[key] = float(val)
else:
- message=_('Invalid region'),
+ message=_("Invalid region"),
dlg.ShowModal()
dlg.Destroy()
return
+ # update values
+ # 2D
self.north = float(region['n'])
self.south = float(region['s'])
self.east = float(region['e'])
self.west = float(region['w'])
- self.res = float(region['ewres'])
+ self.nsres = float(region['nsres'])
+ self.ewres = float(region['ewres'])
+ self.rows = int(region['rows'])
+ self.cols = int(region['cols'])
+ self.cells = int(region['cells'])
+ # 3D
+ self.top = float(region['t'])
+ self.bottom = float(region['b'])
+ # self.nsres3 = float(region['nsres3'])
+ # self.ewres3 = float(region['ewres3'])
+ self.tbres = float(region['tbres'])
+ self.depth = int(region['depths'])
+ self.cells3 = int(region['3dcells'])
- # Insert current region settings into text controls
- self.ttop.SetValue(str(self.north))
- self.tbottom.SetValue(str(self.south))
- self.tleft.SetValue(str(self.west))
- self.tright.SetValue(str(self.east))
- self.tres.SetValue(str(self.res))
+ # 3D box collapsable
+ self.infoCollapseLabelExp = _("Click here to show 3D settings")
+ self.infoCollapseLabelCol = _("Click here to hide 3D settings")
+ self.settings3D = wx.CollapsiblePane(parent=self,
+ label=self.infoCollapseLabelExp,
+ style=wx.CP_DEFAULT_STYLE |
+ wx.CP_NO_TLW_RESIZE | wx.EXPAND)
+ self.MakeSettings3DPaneContent(self.settings3D.GetPane())
+ self.settings3D.Collapse(False)
+ self.Bind(wx.EVT_COLLAPSIBLEPANE_CHANGED, self.OnSettings3DPaneChanged, self.settings3D)
- # layout
- self.sizer = wx.GridBagSizer(vgap=0, hgap=0)
+ # set current region settings
+ self.tnorth.SetValue(str(self.north))
+ self.tsouth.SetValue(str(self.south))
+ self.twest.SetValue(str(self.west))
+ self.teast.SetValue(str(self.east))
+ self.tnsres.SetValue(str(self.nsres))
+ self.tewres.SetValue(str(self.ewres))
+ self.ttop.SetValue(str(self.top))
+ self.tbottom.SetValue(str(self.bottom))
+ # self.tnsres3.SetValue(str(self.nsres3))
+ # self.tewres3.SetValue(str(self.ewres3))
+ self.ttbres.SetValue(str(self.tbres))
+ self.lrows.SetLabel(_("Rows: %d" % self.rows))
+ self.lcols.SetLabel(_("Cols: %d" % self.cols))
+ self.lcells.SetLabel(_("Cells: %d" % self.cells))
- self.sizer.Add(item=self.MakeLabel(_("Region extents and resolution:")),
- flag=wx.ALIGN_RIGHT |
- wx.ALIGN_CENTER_VERTICAL |
- wx.ALL, border=10, pos=(0, 0), span=(1, 2))
+ # bindings
+ self.Bind(wx.EVT_BUTTON, self.OnSetButton, self.bset)
+ self.Bind(wx.EVT_BUTTON, self.OnCancel, self.bcancel)
+ self.tnorth.Bind(wx.EVT_TEXT, self.OnValue)
+ self.tsouth.Bind(wx.EVT_TEXT, self.OnValue)
+ self.teast.Bind(wx.EVT_TEXT, self.OnValue)
+ self.twest.Bind(wx.EVT_TEXT, self.OnValue)
+ self.tnsres.Bind(wx.EVT_TEXT, self.OnValue)
+ self.tewres.Bind(wx.EVT_TEXT, self.OnValue)
+ self.ttop.Bind(wx.EVT_TEXT, self.OnValue)
+ self.tbottom.Bind(wx.EVT_TEXT, self.OnValue)
+ # self.tnsres3.Bind(wx.EVT_TEXT, self.OnValue)
+ # self.tewres3.Bind(wx.EVT_TEXT, self.OnValue)
+ self.ttbres.Bind(wx.EVT_TEXT, self.OnValue)
- self.sizer.Add(item=self.MakeLabel(_("North")),
- flag=wx.ALIGN_CENTER_HORIZONTAL |
- wx.ALL, border=0, pos=(1, 2))
- self.sizer.Add(item=self.ttop,
- wx.ALL, border=5, pos=(2, 2))
+ self.__DoLayout()
+ self.SetMinSize(self.GetBestSize())
+ self.minWindowSize = self.GetMinSize()
- self.sizer.Add(item=self.MakeLabel(_("West")),
- wx.ALL, border=0, pos=(3, 0))
- self.sizer.Add(item=self.tleft,
- wx.ALL, border=5, pos=(3, 1))
+ def MakeSettings3DPaneContent(self, pane):
+ """Create 3D region settings pane"""
+ border = wx.BoxSizer(wx.VERTICAL)
+ gridSizer = wx.GridBagSizer(vgap=0, hgap=0)
- self.sizer.Add(item=self.tright,
- wx.ALL, border=5, pos=(3, 3))
- self.sizer.Add(item=self.MakeLabel("East"),
- flag=wx.ALIGN_LEFT |
- wx.ALL, border=0, pos=(3, 4))
+ # inputs
+ self.ttop = wx.TextCtrl(parent=pane, id=wx.ID_ANY, value=str(self.top),
+ size=(150, -1))
+ self.tbottom = wx.TextCtrl(parent=pane, id=wx.ID_ANY, value=str(self.bottom),
+ size=(150, -1))
+ self.ttbres = wx.TextCtrl(parent=pane, id=wx.ID_ANY, value=str(self.tbres),
+ size=(150, -1))
+ # self.tnsres3 = wx.TextCtrl(parent=pane, id=wx.ID_ANY, value=str(self.nsres3),
+ # size=(150, -1))
+ # self.tewres3 = wx.TextCtrl(parent=pane, id=wx.ID_ANY, value=str(self.ewres3),
+ # size=(150, -1))
- self.sizer.Add(item=self.tbottom,
- wx.ALL, border=5, pos=(4, 2))
- self.sizer.Add(item=self.MakeLabel("South"),
- wx.ALL, border=0, pos=(5, 2))
+ #labels
+ self.ldepth = wx.StaticText(parent=pane, label=_("Depth: %d") % self.depth)
+ self.lcells3 = wx.StaticText(parent=pane, label=_("3D Cells: %d") % self.cells3)
- self.sizer.Add(item=self.MakeLabel("Resolution"),
- wx.ALL, border=5, pos=(6, 1))
- self.sizer.Add(item=self.tres,
- wx.ALL, border=5, pos=(6, 2))
+ # top
+ gridSizer.Add(item=wx.StaticText(parent=pane, label=_("Top")),
+ flag=wx.ALIGN_CENTER |
+ wx.LEFT | wx.RIGHT | wx.TOP, border=5,
+ pos=(0, 1))
+ gridSizer.Add(item=self.ttop,
+ flag=wx.ALIGN_CENTER_HORIZONTAL |
+ wx.ALL, border=5, pos=(1, 1))
+ # bottom
+ gridSizer.Add(item=wx.StaticText(parent=pane, label=_("Bottom")),
+ pos=(0, 2))
+ gridSizer.Add(item=self.tbottom,
+ wx.ALL, border=5, pos=(1, 2))
+ # tbres
+ gridSizer.Add(item=wx.StaticText(parent=pane, label=_("T-B resolution")),
+ pos=(0, 3))
+ gridSizer.Add(item=self.ttbres,
+ wx.ALL, border=5, pos=(1, 3))
- self.sizer.Add(item=wx.StaticLine(self, -1),
- flag=wx.EXPAND|wx.ALL, border=0, pos=(7, 0),
- span=(1, 6))
+ # res
+ # gridSizer.Add(item=wx.StaticText(parent=pane, label=_("3D N-S resolution")),
+ # flag=wx.ALIGN_CENTER |
+ # wx.LEFT | wx.RIGHT | wx.TOP, border=5,
+ # pos=(2, 1))
+ # gridSizer.Add(item=self.tnsres3,
+ # flag=wx.ALIGN_CENTER_HORIZONTAL |
+ # wx.ALL, border=5, pos=(3, 1))
+ # gridSizer.Add(item=wx.StaticText(parent=pane, label=_("3D E-W resolution")),
+ # pos=(2, 3))
+ # gridSizer.Add(item=self.tewres3,
+ # wx.ALL, border=5, pos=(3, 3))
- self.sizer.Add(item=self.bset,
- wx.ALL, border=5, pos=(8, 3))
+ # rows/cols/cells
+ gridSizer.Add(item=self.ldepth,
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER |
+ wx.ALL, border=5, pos=(2, 1))
- self.sizer.Add(item=self.bcancel,
- wx.ALL, border=5, pos=(8, 1))
+ gridSizer.Add(item=self.lcells3,
+ wx.ALL, border=5, pos=(2, 2))
+ border.Add(item=gridSizer, proportion=1,
+ flag=wx.ALL | wx.ALIGN_CENTER | wx.EXPAND, border=5)
- self.SetSizer(self.sizer)
+ pane.SetSizer(border)
+ border.Fit(pane)
+ def OnSettings3DPaneChanged(self, event):
+ """Collapse 3D settings box"""
+ if self.settings3D.IsExpanded():
+ self.settings3D.SetLabel(self.infoCollapseLabelCol)
+ self.Layout()
+ self.SetSize(self.GetBestSize())
+ else:
+ self.settings3D.SetLabel(self.infoCollapseLabelExp)
+ self.Layout()
+ self.SetSize(self.minWindowSize)
+ self.SetMinSize(self.minWindowSize)
+ self.SendSizeEvent()
+ def __DoLayout(self):
+ """Window layout"""
+ frameSizer = wx.BoxSizer(wx.VERTICAL)
+ settings3DSizer = wx.BoxSizer(wx.VERTICAL)
+ buttonSizer = wx.BoxSizer(wx.HORIZONTAL)
+ # north
+ gridSizer.Add(item=self.MakeLabel(_("North")),
+ flag=wx.ALIGN_BOTTOM | wx.ALIGN_CENTER_HORIZONTAL |
+ wx.TOP | wx.LEFT | wx.RIGHT, border=5, pos=(0, 2))
+ gridSizer.Add(item=self.tnorth,
+ wx.ALIGN_CENTER_VERTICAL |
+ # west
+ gridSizer.Add(item=self.MakeLabel(_("West")),
+ flag=wx.ALIGN_RIGHT |
+ wx.LEFT | wx.TOP | wx.BOTTOM, border=5, pos=(2, 0))
+ gridSizer.Add(item=self.twest,
+ gridSizer.Add(item=self.MakeLabel("+"),
+ # east
+ gridSizer.Add(item=self.teast,
+ wx.ALL, border=5, pos=(2, 3))
+ gridSizer.Add(item=self.MakeLabel(_("East")),
+ flag=wx.ALIGN_LEFT |
+ wx.RIGHT | wx.TOP | wx.BOTTOM, border=5, pos=(2, 4))
+ # south
+ gridSizer.Add(item=self.tsouth,
+ wx.ALL, border=5, pos=(3, 2))
+ gridSizer.Add(item=self.MakeLabel(_("South")),
+ flag=wx.ALIGN_TOP | wx.ALIGN_CENTER_HORIZONTAL |
+ wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5, pos=(4, 2))
+ # ns-res
+ gridSizer.Add(item=self.MakeLabel(_("N-S resolution")),
+ wx.TOP | wx.LEFT | wx.RIGHT, border=5, pos=(5, 1))
+ gridSizer.Add(item=self.tnsres,
+ wx.ALL, border=5, pos=(6, 1))
+ # ew-res
+ gridSizer.Add(item=self.MakeLabel(_("E-W resolution")),
+ wx.TOP | wx.LEFT | wx.RIGHT, border=5, pos=(5, 3))
+ gridSizer.Add(item=self.tewres,
+ wx.ALL, border=5, pos=(6, 3))
+ # rows/cols/cells
+ gridSizer.Add(item=self.lrows,
+ wx.ALL, border=5, pos=(7, 1))
+ gridSizer.Add(item=self.lcells,
+ wx.ALL, border=5, pos=(7, 2))
+ gridSizer.Add(item=self.lcols,
+ wx.ALL, border=5, pos=(7, 3))
+ # 3D
+ settings3DSizer.Add(item=self.settings3D,
+ flag=wx.ALL,
+ border=5)
+ # buttons
+ buttonSizer.Add(item=self.bcancel, proportion=1,
+ wx.ALL, border=10)
+ buttonSizer.Add(item=self.bset, proportion=1,
+ frameSizer.Add(item=gridSizer, proportion=1,
+ flag=wx.ALL | wx.ALIGN_CENTER, border=5)
+ frameSizer.Add(item=settings3DSizer, proportion=0,
+ frameSizer.Add(item=buttonSizer, proportion=0,
+ flag=wx.ALL | wx.ALIGN_RIGHT, border=5)
self.SetAutoLayout(True)
+ self.SetSizer(frameSizer)
+ frameSizer.Fit(self)
self.Layout()
- self.Bind(wx.EVT_BUTTON, self.OnSetButton, self.bset)
- self.Bind(wx.EVT_BUTTON, self.OnCancel, self.bcancel)
- self.Bind(wx.EVT_TEXT, self.OnNorth, self.ttop)
- self.Bind(wx.EVT_TEXT, self.OnSouth, self.tbottom)
- self.Bind(wx.EVT_TEXT, self.OnEast, self.tright)
- self.Bind(wx.EVT_TEXT, self.OnWest, self.tleft)
- self.Bind(wx.EVT_TEXT, self.OnRes, self.tres)
+ def OnValue(self, event):
+ """Set given value"""
+ try:
+ if event.GetId() == self.tnorth.GetId():
+ self.north = float(event.GetString())
+ elif event.GetId() == self.tsouth.GetId():
+ self.south = float(event.GetString())
+ elif event.GetId() == self.teast.GetId():
+ self.east = float(event.GetString())
+ elif event.GetId() == self.twest.GetId():
+ self.west = float(event.GetString())
+ elif event.GetId() == self.tnsres.GetId():
+ self.nsres = float(event.GetString())
+ elif event.GetId() == self.tewres.GetId():
+ self.ewres = float(event.GetString())
+ elif event.GetId() == self.ttop.GetId():
+ self.top = float(event.GetString())
+ elif event.GetId() == self.tbottom.GetId():
+ self.bottom = float(event.GetString())
+ # elif event.GetId() == self.tnsres3.GetId():
+ # self.nsres3 = float(event.GetString())
+ # elif event.GetId() == self.tewres3.GetId():
+ # self.ewres3 = float(event.GetString())
+ elif event.GetId() == self.ttbres.GetId():
+ self.tbres = float(event.GetString())
- def OnNorth(self, event):
- self.north = event.GetString()
+ self.__UpdateInfo()
- def OnSouth(self, event):
- self.south = event.GetString()
+ except ValueError, e:
+ if len(event.GetString()) > 0 and event.GetString() != '-':
+ dlg = wx.MessageBox(parent=self,
+ message=_("Invalid value: %s") % e,
+ caption=_("Error"),
+ style=wx.OK | wx.ICON_ERROR)
+ # reset values
- def OnEast(self, event):
- self.east = event.GetString()
+ event.Skip()
- def OnWest(self, event):
- self.west = event.GetString()
+ def __UpdateInfo(self):
+ """Update number of rows/cols/cells"""
+ self.rows = int((self.north - self.south) / self.nsres)
+ self.cols = int((self.east - self.west) / self.ewres)
+ self.cells = self.rows * self.cols
- def OnRes(self, event):
- self.res = event.GetString()
+ self.depth = int((self.top - self.bottom) / self.tbres)
+ self.cells3 = self.rows * self.cols * self.depth
- def OnSetButton(self,event=None):
- cmdlist = ['g.region', '-sgpa', 'n=%s' % self.north, 's=%s' % self.south, \
- 'e=%s' % self.east, 'w=%s' % self.west, 'res=%s' % self.res]
+ # 2D
+ self.lrows.SetLabel(_("Rows: %d") % self.rows)
+ self.lcols.SetLabel(_("Cols: %d") % self.cols)
+ self.lcells.SetLabel(_("Cells: %d") % self.cells)
+ # 3D
+ self.ldepth.SetLabel(_("Depth: %d" % self.depth))
+ self.lcells3.SetLabel(_("3D Cells: %d" % self.cells3))
+ def OnSetButton(self, event=None):
+ """Set default region"""
+ cmdlist = ['g.region', '-sgpa',
+ 'n=%f' % self.north,
+ 's=%f' % self.south,
+ 'e=%f' % self.east,
+ 'w=%f' % self.west,
+ 'nsres=%f' % self.nsres,
+ 'ewres=%f' % self.ewres,
+ 't=%f' % self.top,
+ 'b=%f' % self.bottom,
+ 'tbres=%f' % self.tbres]
- output = p.ReadStdOutput()[0]
- wx.MessageBox('New default region:\n%s' % output)
- else:
- wx.MessageBox('Setting default region failed\n%s %s' % \
- (p.ReadErrOutput()[0],p.ReadStdOutput()[0]))
- self.Destroy()
+ self.Destroy()
def OnCancel(self, event):
self.Destroy()
@@ -1657,16 +1911,16 @@
dlg.CenterOnScreen()
if dlg.ShowModal() == wx.ID_YES:
dlg.Destroy()
- defineRegion = RegionDef(None, location=self.location)
+ defineRegion = RegionDef(self.parent, location=self.location)
defineRegion.Show()
else:
dlg.Destroy()
elif success == False:
- wx.MessageBox(parent=self.wizard,
- message=_("Unable to create new location."),
- caption=_("Error"),
- style=wx.OK | wx.ICON_ERROR)
+ dlg = wx.MessageBox(parent=self.wizard,
+ message=_("Unable to create new location."),
else: # None
pass
else:
@@ -2074,7 +2328,7 @@
return False
if __name__ == "__main__":
- gWizard = GWizard(None, "")
- GRASSStartUp = GWizard.StartUp(0)
- GRASSStartUp.MainLoop()
+ app = wx.PySimpleApp()
+ gWizard = LocationWizard(None, "")
+ gWizzard.Show()
+ app.MainLoop()
