[GRASS-SVN] r29467 - grass/trunk/raster/r.patch
svn_grass at osgeo.org
Tue Dec 18 03:22:22 EST 2007
Author: martinl
Date: 2007-12-18 03:22:12 -0500 (Tue, 18 Dec 2007)
New Revision: 29467
grass/trunk/raster/r.patch/do_patch.c
grass/trunk/raster/r.patch/main.c
Use standardized options, message cosmetics in r.patch.
Modified: grass/trunk/raster/r.patch/do_patch.c
--- grass/trunk/raster/r.patch/do_patch.c 2007-12-18 02:01:55 UTC (rev 29466)
+++ grass/trunk/raster/r.patch/do_patch.c 2007-12-18 08:22:12 UTC (rev 29467)
@@ -70,6 +70,3 @@
return more;
Modified: grass/trunk/raster/r.patch/main.c
--- grass/trunk/raster/r.patch/main.c 2007-12-18 02:01:55 UTC (rev 29466)
+++ grass/trunk/raster/r.patch/main.c 2007-12-18 08:22:12 UTC (rev 29467)
@@ -16,9 +16,9 @@
#include <stdlib.h>
#include <unistd.h>
#include <grass/gis.h>
+#include <grass/glocale.h>
#include "nfiles.h"
#include "local_proto.h"
-#include <grass/glocale.h>
int main (int argc, char *argv[])
@@ -53,27 +53,18 @@
module->keywords = _("raster");
module->description =
_("Creates a composite raster map layer by using "
- "known category values from one (or more) map layer(s) "
- "to fill in areas of \"no data\" in another map layer.");
+ "known category values from one (or more) map layer(s) "
+ "to fill in areas of \"no data\" in another map layer.");
-/* Define the different options */
+ /* Define the different options */
- opt1 = G_define_option() ;
- opt1->key = "input";
- opt1->type = TYPE_STRING;
- opt1->required = YES;
- opt1->multiple = YES;
- opt1->gisprompt = "old,cell,raster" ;
- opt1->description= _("Name of raster maps to be patched together") ;
+ opt1 = G_define_standard_option(G_OPT_R_INPUTS);
+ opt1->description= _("Name of raster maps to be patched together");
- opt2 = G_define_option() ;
- opt2->key = "output";
- opt2->type = TYPE_STRING;
- opt2->required = YES;
- opt2->gisprompt = "new,cell,raster" ;
- opt2->description= _("Name of the resultant map");
+ opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt2->description= _("Name for resultant raster map");
-/* Define the different flags */
+ /* Define the different flags */
/* please, remove before GRASS 7 released */
flag1 = G_define_flag() ;
@@ -108,7 +99,7 @@
if (nfiles < 2)
- G_fatal_error(_("The minimum number of input maps is two."));
+ G_fatal_error(_("The minimum number of input raster maps is two"));
infd = G_malloc(nfiles * sizeof(int));
statf = G_malloc(nfiles * sizeof(struct Cell_stats));
@@ -148,7 +139,7 @@
if (!ok)
- G_fatal_error(_("One or more input maps not found"));
+ G_fatal_error(_("One or more input raster maps not found"));
rname = opt2->answer;
outfd = G_open_raster_new (new_name = rname, out_type);
@@ -161,19 +152,21 @@
nrows = G_window_rows();
ncols = G_window_cols();
- G_message (_("%s: percent complete: "), G_program_name());
+ G_verbose_message(_("Percent complete..."));
for (row = 0; row < nrows; row++)
G_percent (row, nrows, 2);
if(G_get_raster_row (infd[0], presult, row, out_type) < 0)
- G_fatal_error("Cannot get raster row of input map");
+ G_fatal_error(_("Unable to read raster map <%s> row %d"),
+ names[0], row);
if(out_type == CELL_TYPE)
G_update_cell_stats ((CELL *) presult, ncols, &statf[0]);
for (i = 1; i < nfiles; i++)
if(G_get_raster_row (infd[i], patch, row, out_type) < 0)
- G_fatal_error("Cannot raster row of input map");
+ names[i], row);
if(!do_patch (presult, patch, &statf[i], ncols, out_type, ZEROFLAG))
break;
@@ -189,7 +182,7 @@
* build the new cats and colors. do this before closing the new
* file, in case the new file is one of the patching files as well.
- G_message (_("Creating support files for <%s>..."), new_name);
+ G_message (_("Creating support files for raster map <%s>"), new_name);
support (names, statf, nfiles, &cats, &cats_ok, &colr, &colr_ok, out_type);
/* now close (and create) the result */
