[GRASS-SVN] r29473 - grass/trunk/lib/db/dbmi_client
svn_grass at osgeo.org
Tue Dec 18 13:07:04 EST 2007
Author: glynn
Date: 2007-12-18 13:07:04 -0500 (Tue, 18 Dec 2007)
New Revision: 29473
grass/trunk/lib/db/dbmi_client/start.c
MSVC fixes (from J?\195?\188rgen E. Fischer):
check for any negative return value, not just -1
Modified: grass/trunk/lib/db/dbmi_client/start.c
--- grass/trunk/lib/db/dbmi_client/start.c 2007-12-18 17:14:55 UTC (rev 29472)
+++ grass/trunk/lib/db/dbmi_client/start.c 2007-12-18 18:07:04 UTC (rev 29473)
@@ -143,8 +143,8 @@
uses ReadFile to make more buffer space available.
(Which does not seem to be true on NT 5.1)
- if( _pipe(p1, 250000, _O_BINARY) == -1 ||
- _pipe(p2, 250000, _O_BINARY) == -1 )
+ if( _pipe(p1, 250000, _O_BINARY) < 0 ||
+ _pipe(p2, 250000, _O_BINARY) < 0 )
db_syserror ("can't open any pipes");
return (dbDriver *) NULL;
@@ -161,7 +161,7 @@
have_stdin = have_stdout = 1;
- if ( _fileno(stdin) == -1 )
+ if ( _fileno(stdin) < 0 )
have_stdin = 0;
stdin_fd = 0;
@@ -170,7 +170,7 @@
stdin_fd = _fileno(stdin);
- if ( (stdin_orig = _dup(_fileno(stdin ))) == -1 )
+ if ( (stdin_orig = _dup(_fileno(stdin ))) < 0 )
db_syserror ("can't duplicate stdin");
@@ -184,7 +184,7 @@
- if ( _fileno(stdout) == -1 )
+ if ( _fileno(stdout) < 0 )
have_stdout = 0;
stdout_fd = 1;
@@ -193,7 +193,7 @@
stdout_fd = _fileno(stdout);
- if ( (stdout_orig = _dup(_fileno(stdout ))) == -1 )
+ if ( (stdout_orig = _dup(_fileno(stdout ))) < 0 )
db_syserror ("can't duplicate stdout");
@@ -219,7 +219,7 @@
* descriptors in driver (which is another problem)
- pid = _spawnl ( _P_NOWAIT, startup, "", NULL );
+ pid = _spawnl ( _P_NOWAIT, startup, startup, NULL );
/* This does not help. It runs but pipe remains open when close() is
* called in model but caling close() on that descriptor in driver gives
