[GRASS-SVN] r29477 - grass/trunk/gui/wxpython/gui_modules
Wed Dec 19 08:19:04 EST 2007
Author: martinl
Date: 2007-12-19 08:19:04 -0500 (Wed, 19 Dec 2007)
New Revision: 29477
   grass/trunk/gui/wxpython/gui_modules/dbm.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
wxGUI: Use wx.MessageBox instead of wx.MessageDialog.
Fix bug when digitizing new vector object and no DB connection is defined.
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py	2007-12-19 11:40:05 UTC (rev 29476)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py	2007-12-19 13:19:04 UTC (rev 29477)
@@ -362,13 +362,10 @@
         self.mapDBInfo = VectorDBInfo(self.vectmap)
         if len(self.mapDBInfo.layers.keys()) == 0:
-            dlg = wx.MessageDialog(patent=self.parent,
-                                   message=_("No attribute table linked to "
-                                             "vector map <%s> found.") % \
-                                       self.vectmap,
-                                   caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
-            dlg.ShowModal()
-            dlg.Destroy()
+            wx.MessageBox(patent=self.parent,
+                          message=_("Database connection for map <%s> "
+                                    "is not defined in DB file") % self.vectmap,
+                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
             return
@@ -1058,12 +1055,10 @@
                         valuesString += "%s," % values[i]
             except ValueError, err:
-                dlg = wx.MessageDialog(parent=self,
-                                       message=_("Unable to insert new record.%s"
-                                                 "%s") % (os.linesep, err),
-                dlg.ShowModal()
-                dlg.Destroy()
+                wx.MessageBox(parent=self,
+                              message=_("Unable to insert new record.%s"
+                                        "%s") % (os.linesep, err),
                 return
             # remove category if need
@@ -1159,12 +1154,10 @@
                             updateString += "%s=NULL," % (columnName[i])
-                                       message=_("Unable to update existing record.%s"
-                dlg.ShowModal()
-                dlg.Destroy()
+                              message=_("Unable to update existing record.%s"
                 return
             if len(updateString) > 0:
@@ -1241,23 +1234,19 @@
         nameTo = self.FindWindowById(self.layerPage[self.layer]['renameColTo']).GetValue()
         if not name or not nameTo:
-            dlg = wx.MessageDialog(self.parent,
-                                   _("Unable to rename column. "
-                                     "No column name defined."),
-                                   _("Error"), wx.OK | wx.ICON_ERROR)
-            dlg.ShowModal()
-            dlg.Destroy()
+            wx.MessageBox(self=self.parent,
+                          message=_("Unable to rename column. "
+                                    "No column name defined."),
         else:
             item = list.FindItem(start=-1, str=name)
             if item > -1:
                 if list.FindItem(start=-1, str=nameTo) > -1:
-                                             "Column <%s> already exists in the table.") % \
-                                               nameTo,
-                    dlg.ShowModal()
-                    dlg.Destroy()
+                    wx.MessageBox(parent=self.parent,
+                                            "Column <%s> already exists in the table.") % \
+                                  nameTo,
                 else:
                     list.SetItemText(item, nameTo)
@@ -1266,12 +1255,10 @@
                                                 'layer=%d' % self.layer,
                                                 'column=%s,%s' % (name, nameTo)])
             else:
-                                         "Column <%s> doesn't exist in the table.") % name,
-                dlg.ShowModal()
-                dlg.Destroy()
+                                        "Column <%s> doesn't exist in the table.") % name,
         event.Skip()
@@ -1334,12 +1321,10 @@
         name = self.FindWindowById(self.layerPage[self.layer]['addColName']).GetValue()
         if not name:
-                                   _("Unable to add column to the table. "
-            dlg.ShowModal()
-            dlg.Destroy()
+                          message=_("Unable to add column to the table. "
         else:
             type = self.FindWindowById(self.layerPage[self.layer]['addColType']). \
                 GetStringSelection()
@@ -1355,12 +1340,10 @@
             list = self.FindWindowById(self.layerPage[self.layer]['tableData'])
             # check for duplicate items
             if list.FindItem(start=-1, str=name) > -1:
-                                       _("Unable to add column <%s> to the table. "
-                                         "Column already exists.") % name,
-                dlg.ShowModal()
-                dlg.Destroy()
+                              message=_("Unable to add column <%s> to the table. "
+                                        "Column already exists.") % name,
                 return
             index = list.InsertStringItem(sys.maxint, str(name))
             list.SetStringItem(index, 0, str(name))
@@ -1648,7 +1631,9 @@
         # cats = list.selectedCats[:]
         cats = list.GetSelectedItems()
         if len(cats) == 0:
-            wx.MessageBox(message=_('Nothing to extract.'), caption=_('Extract selected'))
+                          message=_('Nothing to extract.'),
+                          caption=_('Extract selected'), style=wx.CENTRE)
             return False
         else:
             # dialog to get file name
@@ -2400,13 +2385,11 @@
         key      = self.tableWidgets['key'][1].GetValue()
         if not table or not key:
-                                   _("Unable to create new table.%s"
-                                     "Table name or key column name is missing.") % \
-                                       (os.linesep),
-            dlg.ShowModal()
-            dlg.Destroy()
+                          message=_("Unable to create new table.%s"
+                                    "Table name or key column name is missing.") % \
+                          (os.linesep),
+                          caption=_("Error"), flag=wx.OK | wx.ICON_ERROR | wx.CENTRE)
             return
         # create table
@@ -2440,13 +2423,11 @@
         key      = self.addLayerWidgets['key'][1].GetStringSelection()
         if layer in self.mapDBInfo.layers.keys():
-                                   _("Unable to add new layer to vector map <%s>.%s"
-                                     "Layer %d already exists.") % \
-                                       (self.mapDBInfo.map, os.linesep, layer),
-            dlg.ShowModal()
-            dlg.Destroy()
+                          message=_("Unable to add new layer to vector map <%s>.%s"
+                                    "Layer %d already exists.") % \
+                          (self.mapDBInfo.map, os.linesep, layer),
             return
         connectCmd = gcmd.Command(['v.db.connect',
@@ -2603,19 +2584,17 @@
         if (self.layer == -1 and len(layers) <= 0) or \
                 (self.layer > 0 and self.layer not in layers):
             if self.layer == -1:
-                label = _("Database connection for vector map <%s> "
-                          "is not defined in DB file.") % (self.map)
+                label = _("Database connection "
+                          "is not defined in DB file.")
             else:
-                label = _("Layer <%d> is not available for vector map <%s>.") % \
-                    (self.layer, self.map)
+                label = _("Database connection for layer %d "
+                          "is not defined in DB file.") % self.layer
-                                   _("No attribute table linked to "
-                                     "vector map <%s> found.\n"
-                                     "%s") % (self.map, label),
-            dlg.ShowModal()
-            dlg.Destroy()
+                          message=_("No attribute table linked to "
+                                    "vector map <%s> found.%s"
+                                    "%s") % (self.map, os.linesep, label),
             self.mapDBInfo = None
             return
@@ -2931,9 +2910,9 @@
     def __CheckDBConnection(self):
         """Check DB connection"""
         layerCommand = gcmd.Command(cmd=["v.db.connect",
-                                        "-g", "--q",
+                                         "-g", "--q",
                                         "map=%s" % self.map,],
-                                    log='txt')
+                                    log=None)
         if layerCommand.returncode != 0:
             return False
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2007-12-19 11:40:05 UTC (rev 29476)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2007-12-19 13:19:04 UTC (rev 29477)
@@ -1378,8 +1378,8 @@
        cat=digitClass.settings["category"],
        pos=posWindow,
        action="add")
-                        if addRecordDlg.mapInfo and \
-                                addRecordDlg.ShowModal() == wx.ID_OK:
+                        if addRecordDlg.mapDBInfo and \
+                               addRecordDlg.ShowModal() == wx.ID_OK:
                             sqlfile = tempfile.NamedTemporaryFile(mode="w")
                             for sql in addRecordDlg.GetSQLString():
                                 sqlfile.file.write(sql + ";\n")
