[GRASS-SVN] r29512 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Wed Dec 26 15:39:53 EST 2007
Author: martinl
Date: 2007-12-26 15:39:53 -0500 (Wed, 26 Dec 2007)
New Revision: 29512
grass/trunk/raster/r.in.gdal/main.c
Message standardization, i18n (r.in.gdal)
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2007-12-26 17:49:09 UTC (rev 29511)
+++ grass/trunk/raster/r.in.gdal/main.c 2007-12-26 20:39:53 UTC (rev 29512)
@@ -1,12 +1,20 @@
- * r.in.gdal imports many GIS/image formats into GRASS utilizing the GDAL
- * library
- * copyright of this file
- * Author: Frank Warmerdam
+ * MODULE: r.in.gdal
+ * AUTHOR(S): Frank Warmerdam (copyright of this file)
+ * Added optional GCP transformation: Markus Neteler 10/2001
- * Added optional GCP transformation: Markus Neteler 10/2001
+ * PURPOSE: Imports many GIS/image formats into GRASS utilizing the GDAL
+ * library.
+ * COPYRIGHT: (C) 2001 by Frank Warmerdam
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
#include <stdlib.h>
#include <unistd.h>
@@ -66,19 +74,15 @@
G_gisinit (argv[0]);
module = G_define_module();
- module->keywords = _("raster");
+ module->keywords = _("raster, import");
module->description =
_("Import GDAL supported raster file into a binary raster map layer.");
/* Setup and fetch parameters. */
- parm.input = G_define_option();
- parm.input->key = "input";
- parm.input->type = TYPE_STRING;
- parm.input->required = YES;
+ parm.input = G_define_standard_option(G_OPT_R_INPUT);
parm.input->description = _("Raster file to be imported");
- parm.input->gisprompt = "old_file,file,input";
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -100,6 +104,7 @@
parm.title->type = TYPE_STRING;
parm.title->required = NO;
parm.title->description = _("Title for resultant raster map");
+ parm.title->guisection = _("Metadata");
parm.outloc = G_define_option();
parm.outloc->key = "location";
@@ -118,6 +123,7 @@
flag_f = G_define_flag();
flag_f->key = 'f';
flag_f->description = _("List supported formats and exit");
+ flag_f->guisection = _("Print");
flag_k = G_define_flag();
flag_k->key = 'k';
@@ -189,9 +195,9 @@
l1bdriver=0;
else {
l1bdriver=1; /* AVHRR found, needs north south flip */
- G_warning("The polynomial rectification used in i.rectify does "
- "not work well with NOAA/AVHRR data. Try using gdalwarp with "
- "thin plate spline rectification instead. (-tps)");
+ G_warning(_("The polynomial rectification used in i.rectify does "
+ "not work well with NOAA/AVHRR data. Try using gdalwarp with "
+ "thin plate spline rectification instead. (-tps)"));
@@ -206,7 +212,8 @@
&& adfGeoTransform[5] < 0.0 )
if (adfGeoTransform[2] != 0.0 || adfGeoTransform[4] != 0.0)
- G_fatal_error(_("Input map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."));
+ G_fatal_error(_("Input raster map is rotated - cannot import. "
+ "You may use 'gdalwarp' to transform the map to North-up."));
cellhd.north = adfGeoTransform[3];
cellhd.ns_res = fabs(adfGeoTransform[5]);
@@ -252,7 +259,7 @@
if ( GPJ_wkt_to_grass( &cellhd, &proj_info,
&proj_units, GDALGetProjectionRef(hDS), 0) < 0 )
G_fatal_error(_("Unable to convert input map projection to GRASS "
- "format; cannot create new location."));
+ "format; cannot create new location."));
else
G_make_location( parm.outloc->answer, &cellhd,
proj_info, proj_units, NULL );
@@ -262,8 +269,8 @@
/* Projection only required for checking so convert non-interactively */
- G_warning(_("Unable to convert input map projection information to "
- "GRASS format for checking"));
+ G_warning(_("Unable to convert input raster map projection information to "
+ "GRASS format for checking"));
else
@@ -281,7 +288,7 @@
cellhd.proj = loc_wind.proj;
cellhd.zone = loc_wind.zone;
- G_warning(_("Over-riding projection check."));
+ G_warning(_("Over-riding projection check"));
else if( loc_wind.proj != cellhd.proj
|| (projcomp_error=G_compare_projections( loc_proj_info,
@@ -291,7 +298,7 @@
strcpy( error_msg,
_("Projection of dataset does not"
- " appear to match current location.\n\n"));
+ " appear to match current location.\n\n"));
/* TODO: output this info sorted by key: */
if( loc_proj_info != NULL )
@@ -326,7 +333,7 @@
else
- strcat( error_msg, "Import dataset PROJ_INFO is:\n" );
+ strcat( error_msg, _("Import dataset PROJ_INFO is:\n") );
if( cellhd.proj == PROJECTION_XY )
sprintf( error_msg + strlen(error_msg),
"cellhd.proj = %d (unreferenced/unknown)\n",
@@ -349,16 +356,18 @@
cellhd.proj, cellhd.zone );
strcat( error_msg,
- _("\nYou can use the -o flag to r.in.gdal to override this check and "
- "use the location definition for the dataset.\n" ));
+ _("\nYou can use the -o flag to r.in.gdal to override this check and "
+ "use the location definition for the dataset.\n" ));
strcat( error_msg,
- _("Consider generating a new location from the input dataset using "
- "the 'location' parameter.\n") );
+ _("Consider generating a new location from the input dataset using "
+ "the 'location' parameter.\n") );
G_fatal_error( error_msg );
- else
+ else {
G_message(_("Projection of input dataset and current location "
- "appear to match.\nProceeding with import...\n"));
+ "appear to match"));
+ G_verbose_message(_("Proceeding with import..."));
@@ -388,9 +397,8 @@
hBand = GDALGetRasterBand(hDS,1);
if( hBand == NULL )
- sprintf( error_msg, _("Selected band (%d) does not exist.\n"),
- nBand );
- G_fatal_error( error_msg );
+ G_fatal_error(_("Selected band (%d) does not exist"),
+ nBand );
ImportBand( hBand, output, NULL );
@@ -468,16 +476,13 @@
sPoints.n2 = sPoints.e1 + 3 * sPoints.count;
sPoints.status = (int *) G_malloc (sizeof(int) * sPoints.count);
- G_message (_("Copying %d GCPS in points file for %s"),
- sPoints.count, output );
+ G_message (_("Copying %d GCPS in points file for <%s>"),
+ sPoints.count, output );
if( GDALGetGCPProjection(hDS) != NULL
&& strlen(GDALGetGCPProjection(hDS)) > 0 )
- fprintf(stderr,
- "\n"
- "GCPs have the following OpenGIS WKT Coordinate System:\n"
- "%s\n",
- GDALGetGCPProjection( hDS ) );
+ G_message("%s:\n%s", _("GCPs have the following OpenGIS WKT Coordinate System:"),
+ GDALGetGCPProjection( hDS ) );
if (parm.target->answer)
@@ -485,11 +490,11 @@
SetupReprojector( GDALGetGCPProjection(hDS),
parm.target->answer,
&iproj, &oproj );
- fprintf(stderr, "Re-projecting GCPs table:\n");
- fprintf(stderr, " Input projection for GCP table: %s\n",
- iproj.proj);
- fprintf(stderr, " Output projection for GCP table: %s\n",
- oproj.proj);
+ G_message(_("Re-projecting GCPs table:"));
+ G_message(_("* Input projection for GCP table: %s"),
+ iproj.proj);
+ G_message(_("* Output projection for GCP table: %s"),
+ oproj.proj);
for( iGCP = 0; iGCP < sPoints.count; iGCP++ )
@@ -508,7 +513,7 @@
if(pj_do_proj( &(sPoints.e2[iGCP]), &(sPoints.n2[iGCP]),
&iproj, &oproj) < 0)
G_fatal_error(_("Error in pj_do_proj (can't "
- "re-projection GCP %i)\n"),
+ "re-projection GCP %i)"),
iGCP);
} /* for all GCPs*/
@@ -543,6 +548,8 @@
G__put_window( &def_wind, "../PERMANENT", "DEFAULT_WIND" );
+ G_done_msg(" ");
exit (EXIT_SUCCESS);
@@ -569,7 +576,7 @@
GPJ_wkt_to_grass( &cellhd, &proj_info, &proj_units, pszSrcWKT, 0 );
if (pj_get_kv(iproj, proj_info, proj_units) < 0)
- G_fatal_error("Can't translate projection key values of input GCPs.");
+ G_fatal_error(_("Unable to translate projection key values of input GCPs"));
/* Get the projection of the target location. */
@@ -585,19 +592,19 @@
/* Get projection info from target location */
if ((out_proj_info = G_get_projinfo()) == NULL)
- G_fatal_error("Can't get projection info of target location");
+ G_fatal_error(_("Unable to get projection info of target location"));
if ((out_unit_info = G_get_projunits()) == NULL)
- G_fatal_error("Can't get projection units of target location");
+ G_fatal_error(_("Unable to get projection units of target location"));
if (pj_get_kv(oproj, out_proj_info, out_unit_info) < 0)
- G_fatal_error("Can't get projection key values of target location");
+ G_fatal_error(_("Unable to get projection key values of target location"));
else
{ /* can't access target mapset */
- sprintf(errbuf, _("Mapset [%s] in target location [%s] - "),
+ sprintf(errbuf, _("Mapset <%s> in target location <%s> - "),
target_mapset, pszDstLoc);
strcat(errbuf, permissions == 0
- ? _("permission denied\n")
- : _("not found\n"));
+ ? _("permission denied")
+ : _("not found"));
G_fatal_error(errbuf);
} /* permission check */
@@ -676,12 +683,12 @@
sprintf( outputReal, "%s.real", output);
cfR = (*raster_open_new_func)((char *)outputReal, data_type);
if (cfR < 0)
- G_fatal_error(_("Unable to create raster map %s"), outputReal);
+ G_fatal_error(_("Unable to create raster map <%s>"), outputReal);
sprintf( outputImg, "%s.imaginary", output);
cfI = (*raster_open_new_func)((char *)outputImg, data_type);
if (cfI < 0)
- G_fatal_error(_("Unable to create raster map %s"), outputImg);
+ G_fatal_error(_("Unable to create raster map <%s>"), outputImg);
cellReal = G_allocate_raster_buf(data_type);
cellImg = G_allocate_raster_buf(data_type);
@@ -697,7 +704,7 @@
cf = (*raster_open_new_func)((char *)output, data_type);
if (cf < 0)
- G_fatal_error(_("Unable to create raster map %s"), output);
+ G_fatal_error(_("Unable to create raster map <%s>"), output);
if( group_ref != NULL )
I_add_file_to_group_ref ((char *) output, G_mapset(), group_ref);
