[GRASS-SVN] r29520 - grass/trunk/imagery/i.group
svn_grass at osgeo.org
Thu Dec 27 10:14:44 EST 2007
Author: martinl
Date: 2007-12-27 10:14:43 -0500 (Thu, 27 Dec 2007)
New Revision: 29520
grass/trunk/imagery/i.group/main.c
Allow to remove multiple raster maps from group/subgroup.
Message cleaning.
Modified: grass/trunk/imagery/i.group/main.c
--- grass/trunk/imagery/i.group/main.c 2007-12-27 14:34:04 UTC (rev 29519)
+++ grass/trunk/imagery/i.group/main.c 2007-12-27 15:14:43 UTC (rev 29520)
@@ -10,7 +10,7 @@
* Hamish Bowman <hamish_nospam yahoo.com>
* PURPOSE: collect raster map layers into an imagery group by assigning
* them to user-named subgroups or other groups
- * COPYRIGHT: (C) 2001-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2007 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -51,11 +51,7 @@
_("Creates, edits, and lists groups and subgroups of imagery files.");
/* Get Args */
- grp = G_define_option();
- grp->key = "group";
- grp->type = TYPE_STRING;
- grp->required = YES;
- grp->gisprompt = "old,group,group";
+ grp = G_define_standard_option(G_OPT_I_GROUP);
grp->description = _("Name of imagery group");
sgrp = G_define_option();
@@ -64,13 +60,9 @@
sgrp->required = NO;
sgrp->description = _("Name of imagery sub-group");
- rast = G_define_option();
- rast->key = "input";
- rast->type = TYPE_STRING;
- rast->required = NO; /* why is it NO? so the -list flag is easy. */
- rast->multiple = YES;
- rast->gisprompt = "old,cell,raster";
- rast->description = _("Name of raster(s) to include in group");
+ rast = G_define_standard_option(G_OPT_R_INPUTS);
+ rast->required = NO; /* -l flag */
+ rast->description = _("Name of raster map(s) to include in group");
r = G_define_flag();
r->key = 'r';
@@ -79,10 +71,12 @@
l = G_define_flag();
l->key = 'l';
l->description = _("List files from specified (sub)group (fancy)");
+ l->guisection = _("Print");
simple_flag = G_define_flag();
simple_flag->key = 'g';
- simple_flag->description = _("List files from specified (sub)group (simple)");
+ simple_flag->description = _("List files from specified (sub)group (shell script style)");
+ simple_flag->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -101,21 +95,23 @@
if (k < 1 && !l->answer) /* remove if input is requirement */
- G_fatal_error( _("No input map(s) specified.") );
+ G_fatal_error( _("No input raster map(s) specified") );
I_location_info(title, argv[0]);
if (r->answer) {
/* Remove files from Group */
- if (I_find_group(grp->answer) == 0)
- G_fatal_error(_("Specified group does not exist... Exiting."));
+ if (I_find_group(grp->answer) == 0) {
+ G_fatal_error(_("Specified group does not exist"));
if (sgrp->answer) {
- G_message(_("Removing files from subgroup"));
+ G_verbose_message(_("Removing raster maps from subgroup <%s>..."), sgrp->answer);
remove_subgroup_files(grp->answer, sgrp->answer, rast->answers, k);
else {
- G_message(_("Removing files from group"));
+ G_verbose_message(_("Removing raster maps from group <%s>..."), grp->answer);
remove_group_files(grp->answer, rast->answers, k);
@@ -123,6 +119,12 @@
if (l->answer) {
struct Ref ref;
+ /* List raster maps */
if (sgrp->answer) {
/* list subgroup files */
I_get_subgroup_ref(grp->answer, sgrp->answer, &ref);
@@ -141,25 +143,27 @@
else {
- /* Create or update Group REF */
- G_message(_("group [%s] - does not yet exist. Creating..."), grp->answer);
- if (sgrp->answer) {
- G_message(_("Adding files to group [%s]"), grp->answer);
- add_or_update_group(grp->answer, rast->answers, k);
- G_message(_("Adding files to subgroup [%s]"), sgrp->answer);
- add_or_update_subgroup(grp->answer, sgrp->answer, rast->answers, k);
- else {
+ /* Create or update Group REF */
+ G_verbose_message(_("Group <%s> does not yet exist. Creating..."), grp->answer);
+ if (sgrp->answer) {
+ G_verbose_message(_("Adding raster maps to group <%s>..."), grp->answer);
+ add_or_update_group(grp->answer, rast->answers, k);
+ G_verbose_message(_("Adding raster maps to subgroup <%s>..."), sgrp->answer);
+ add_or_update_subgroup(grp->answer, sgrp->answer, rast->answers, k);
+ else {
+ G_done_msg(" ");
- return 0;
+ return EXIT_SUCCESS;
@@ -176,13 +180,13 @@
if ((mapset = G_find_cell(rasters[m], "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"), rasters[m]);
- G_message(_("Adding raster map [%s]"), rasters[m]);
+ G_message(_("Adding raster map <%s> to group"), G_fully_qualified_name(rasters[m], mapset));
/* Go through existing files to check for duplicates */
for (n = 0; n < ref.nfiles; n++) {
if (strcmp(rasters[m], ref.file[n].name) == 0) {
- G_message(_("Raster map [%s] exists in group."), rasters[m]);
- G_message(_("Skipping [%s]..."), rasters[m]);
+ G_message(_("Raster map <%s> exists in group. Skipping..."),
+ G_fully_qualified_name(rasters[m], mapset));
skip = 1;
continue;
@@ -192,9 +196,8 @@
I_add_file_to_group_ref(rasters[m], mapset, &ref);
- G_message(_("Writing group REF"));
+ G_debug(1, "writing group REF");
I_put_group_ref(group, &ref);
- G_message(_("Done."));
return 0;
@@ -212,15 +215,17 @@
for (m = 0; m < k; m++) {
skip = 0;
- G_fatal_error(_("Raster map <%s> not found"), rasters[m]);
+ G_fatal_error(_("Raster map <%s> not found"),
+ G_message(_("Adding raster map <%s> to subgroup"),
+ G_message(_("Raster map <%s> exists in subgroup. Skipping..."),
skip = 1;
continue;
@@ -229,9 +234,8 @@
- G_message(_("Writing subgroup REF"));
+ G_debug(1, "writing subgroup REF");
I_put_subgroup_ref(group, subgroup, &ref);
return 0;
@@ -249,41 +253,49 @@
I_get_group_ref(group, &ref_tmp);
I_init_group_ref(&ref);
- /* Parse through supplied rasters */
- for (m = 0; m < k; m++) {
+ /* Go through existing files to check for duplicates */
+ for (m = 0; m < ref_tmp.nfiles; m++) {
skip = 0;
- strcpy(tmp_name, rasters[m]);
- mapset = G_mapset();
+ /* Parse through supplied rasters */
+ for (n = 0; n < k; n++) {
+ strcpy(tmp_name, rasters[n]);
+ mapset = G_mapset();
- /* Parse out mapset */
- if (G__name_is_fully_qualified(rasters[m], xname, xmapset)) {
- strcpy(tmp_name, xname);
- strcpy(mapset, xmapset);
+ /* Parse out mapset */
+ if (G__name_is_fully_qualified(rasters[n], xname, xmapset)) {
+ strcpy(tmp_name, xname);
+ strcpy(mapset, xmapset);
- /* Go through existing files to check for duplicates */
- for (n = 0; n < ref_tmp.nfiles; n++) {
- if ((strcmp(tmp_name, ref_tmp.file[n].name) == 0) &&
- (strcmp(mapset, ref_tmp.file[n].mapset) == 0)) {
- G_message(_("Found file <%s@%s> in group."), tmp_name, mapset);
+ if ((strcmp(tmp_name, ref_tmp.file[m].name) == 0) &&
+ (strcmp(mapset, ref_tmp.file[m].mapset) == 0)) {
+ G_message(_("Removing raster map <%s> from group"),
+ G_fully_qualified_name(tmp_name, mapset));
+ skip = 1;
+ break;
- else {
- I_add_file_to_group_ref(ref_tmp.file[n].name,
- ref_tmp.file[n].mapset, &ref);
+ if (skip == 0) {
+ I_add_file_to_group_ref(ref_tmp.file[m].name,
+ ref_tmp.file[m].mapset, &ref);
+ if (ref.nfiles == ref_tmp.nfiles) {
+ G_warning(_("No raster map removed"));
return 0;
static int remove_subgroup_files(char group[INAME_LEN],
- char subgroup[INAME_LEN], char **rasters, int k)
+ char subgroup[INAME_LEN], char **rasters, int k)
int m, n, skip;
struct Ref ref;
@@ -295,35 +307,42 @@
I_get_subgroup_ref(group, subgroup, &ref_tmp);
skip = 0;
- G_message(_("Found file <%s@%s> in subgroup."), tmp_name, mapset);
+ G_message(_("Removing raster map <%s> from subgroup"),
+ skip = 1;
+ break;
- else {
+ if (skip == 0) {
return 0;
