[GRASS-SVN] r29533 - grass/trunk/vector/v.extract
svn_grass at osgeo.org
Sat Dec 29 06:58:52 EST 2007
Author: martinl
Date: 2007-12-29 06:58:49 -0500 (Sat, 29 Dec 2007)
New Revision: 29533
grass/trunk/vector/v.extract/main.c
v.extract: Message cleaning (verbosity), module description fixed
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c 2007-12-28 17:40:29 UTC (rev 29532)
+++ grass/trunk/vector/v.extract/main.c 2007-12-29 11:58:49 UTC (rev 29533)
@@ -10,7 +10,7 @@
* boundaries for 1 or several areas of a list of
* user provided categories.
- * COPYRIGHT: (C) 2002 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002-2007 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -71,13 +71,9 @@
/* set up the options and flags for the command line parser */
module = G_define_module();
module->keywords = _("vector");
- module->label =
+ module->description =
_("Selects vector objects from an existing vector map and "
"creates a new map containing only the selected objects.");
- module->description =
- _("If 'list', 'file' and 'where' options are not specified, "
- "all features of given type and layer are extracted. Categories "
- "are not changed in that case.");
d_flag = G_define_flag();
d_flag->key = 'd';
@@ -174,7 +170,7 @@
for (i = 0; listopt->answers[i]; i++) {
G_debug ( 2, "catlist item: %s", listopt->answers[i]);
if (!scan_cats (listopt->answers[i], &x, &y))
- G_fatal_error(_("Category value in <%s> not valid"), listopt->answers[i]);
+ G_fatal_error(_("Category value in '%s' not valid"), listopt->answers[i]);
/* valid list, put into cat value array */
@@ -217,9 +213,11 @@
Fi = Vect_get_field( &In, field);
if ( !Fi ) {
- G_fatal_error ( _("No layer database connection") );
+ G_fatal_error ( _("Database connection not defined for layer %d"), field);
- G_message(_("Load categories from the database (table = %s, db = %s)."), Fi->table, Fi->database);
+ G_debug(1, "Loading categories from table <%s>",
+ Fi->table);
driver = db_start_driver(Fi->driver);
if (driver == NULL)
@@ -231,7 +229,7 @@
G_fatal_error(_("Unable to open database <%s> by driver <%s>"), Fi->database, driver) ;
ncats = db_select_int( driver, Fi->table, Fi->key, whereopt->answer, &cats);
- G_message(_("%d categories loaded from the database"), ncats);
+ G_message(_("%d categories loaded from table <%s>"), ncats, Fi->table);
db_close_database(driver);
db_shutdown_driver(driver);
@@ -247,7 +245,10 @@
xtract_line( cat_count, cat_array, &In, &Out, new_cat, type, dissolve, field, type_only, r_flag -> answer ? 1 : 0);
- Vect_build (&Out, stdout );
+ if (G_verbose() > G_verbose_min())
+ Vect_build (&Out, stdout);
+ else
+ Vect_build (&Out, NULL);
/* Copy tables */
@@ -286,7 +287,7 @@
/* Copy tables */
- G_message ( _("Writing attributes...") );
+ G_verbose_message ( _("Writing attributes...") );
/* Number of output tabs */
for ( i = 0; i < Vect_get_num_dblinks ( &In ); i++ ) {
@@ -315,12 +316,12 @@
if ( nocats[i] == 0 ) continue;
if ( fields[i] == field && new_cat != -1 ) continue;
- G_message ( _("Layer %d"), fields[i] );
+ G_verbose_message ( _("Layer %d"), fields[i] );
/* Make a list of categories */
IFi = Vect_get_field ( &In, fields[i] );
if ( !IFi ) { /* no table */
- G_message ( _("No table") );
+ G_verbose_message ( _("No table") );
continue;
@@ -336,7 +337,7 @@
Vect_map_add_dblink ( &Out, OFi->number, OFi->name, OFi->table,
IFi->key, OFi->database, OFi->driver);
- G_message ( _("Done") );
+ G_done_msg(" ");
@@ -363,7 +364,10 @@
Vect_build_partial ( &Out, GV_BUILD_NONE, NULL );
- Vect_build ( &Out, stderr );
+ Vect_build (&Out, stderr);
+ else
Vect_close (&Out);
