[GRASS-SVN] r29548 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Dec 31 13:54:38 EST 2007
Author: martinl
Date: 2007-12-31 13:54:38 -0500 (Mon, 31 Dec 2007)
New Revision: 29548
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
wxGUI/Location wizard: fix #4 and #5
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2007-12-31 18:38:33 UTC (rev 29547)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2007-12-31 18:54:38 UTC (rev 29548)
@@ -23,7 +23,7 @@
AUTHORS: The GRASS Development Team
Michael Barton
Jachym Cepicky
- Various updates: Martin Landa <landa.martin gmail.com>
+ Martin Landa <landa.martin gmail.com>
COPYRIGHT: (C) 2006-2007 by the GRASS Development Team
This program is free software under the GNU General Public
@@ -35,6 +35,7 @@
import re
import string
import sys
+import locale
import wx
import wx.lib.mixins.listctrl as listmix
@@ -66,7 +67,7 @@
def __init__(self):
pass
- def MakeLabel(self, text="", style=wx.ALIGN_RIGHT):
+ def MakeLabel(self, text="", style=wx.ALIGN_LEFT):
"""Make aligned label"""
return wx.StaticText(parent=self, id=wx.ID_ANY, label=text,
style=style)
@@ -87,17 +88,19 @@
labels, text entries, and buttons.
def __init__(self, parent, title):
- wiz.WizardPageSimple.__init__(self, parent)
+ self.page = wiz.WizardPageSimple.__init__(self, parent)
# page title
self.title = wx.StaticText(parent=self, id=wx.ID_ANY, label=title)
self.title.SetFont(wx.Font(13, wx.SWISS, wx.NORMAL, wx.BOLD))
# main sizer
self.sizer = wx.GridBagSizer(vgap=0, hgap=0)
def DoLayout(self):
"""Do page layout"""
tmpsizer = wx.BoxSizer(wx.VERTICAL)
tmpsizer.Add(item=self.title, proportion=0,
@@ -112,6 +115,7 @@
self.SetAutoLayout(True)
self.SetSizer(tmpsizer)
+ tmpsizer.Fit(self)
self.Layout()
class DatabasePage(TitledPage):
@@ -132,6 +136,7 @@
self.tlocation = self.MakeTextCtrl("newLocation", size=(300, -1))
# layout
+ self.sizer.AddGrowableCol(3)
self.sizer.Add(item=self.MakeLabel(_("GIS Data Directory:")),
flag=wx.ALIGN_RIGHT |
wx.ALIGN_CENTER_VERTICAL |
@@ -167,7 +172,7 @@
# bindings
self.Bind(wx.EVT_BUTTON, self.OnBrowse, self.bbrowse)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
- self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnPageChanged)
+ self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
self.tgisdbase.Bind(wx.EVT_TEXT, self.OnChangeName)
self.tlocation.Bind(wx.EVT_TEXT, self.OnChangeName)
@@ -212,22 +217,16 @@
event.Veto()
return
- # if not self.tlocation.GetValue():
- # dlg = wx.MessageDialog(parent=self, message=_("Unable to create new location: location not set "
- # ,"Could not create location", wx.OK|wx.ICON_INFORMATION)
- # dlg.ShowModal()
- # dlg.Destroy()
- # event.Veto()
- # return
self.location = self.tlocation.GetValue()
self.grassdatabase = self.tgisdbase.GetValue()
- def OnPageChanged(self, event=None):
+ def OnEnterPage(self, event):
"""Wizard page changed"""
+ event.Skip()
class CoordinateSystemPage(TitledPage):
Wizard page for choosing method for location creation
@@ -254,6 +253,7 @@
label=_("Create arbitrary non-earth "
"coordinate system (XY)"))
# layout
+ self.sizer.AddGrowableCol(1)
self.sizer.Add(item=self.radio1,
flag=wx.ALIGN_LEFT, pos=(1, 1))
self.sizer.Add(item=self.radio2,
@@ -332,6 +332,7 @@
self.projlist = ItemList(self, data=self.parent.projections.items(),
columns=[_('Code'), _('Description')])
# layout
self.sizer.Add(item=self.MakeLabel(_("Projection code:")),
flag=wx.ALIGN_LEFT |
@@ -346,7 +347,8 @@
self.sizer.Add(item=self.searchb,
flag=wx.ALIGN_RIGHT | wx.EXPAND | wx.ALL,
border=5, pos=(2, 2))
+ self.sizer.AddGrowableRow(3)
self.sizer.Add(item=self.projlist,
flag=wx.EXPAND |
wx.ALIGN_LEFT |
@@ -417,21 +419,25 @@
self.tproj.SetValue(self.proj)
class ItemList(wx.ListCtrl,
- listmix.ListCtrlAutoWidthMixin):
+ listmix.ListCtrlAutoWidthMixin,
+ listmix.ColumnSorterMixin):
"""Generic list (for projections, ellipsoids, etc.)"""
- def __init__(self, parent, data, columns):
+ def __init__(self, parent, columns, data=None):
wx.ListCtrl.__init__(self, parent=parent, id=wx.ID_ANY,
style=wx.LC_REPORT |
+ wx.LC_VIRTUAL |
wx.LC_HRULES |
wx.LC_VRULES |
- wx.LC_SINGLE_SEL, size=(400, 100))
+ wx.LC_SINGLE_SEL |
+ wx.LC_SORT_ASCENDING, size=(400, 100))
- # dict to list
+ # original data or None
self.sourceData = data
- listmix.ListCtrlAutoWidthMixin.__init__(self)
+ # insert columns
i = 0
for column in columns:
self.InsertColumn(i, column)
@@ -443,8 +449,42 @@
for i in range(self.GetColumnCount()):
self.SetColumnWidth(i, wx.LIST_AUTOSIZE_USEHEADER)
+ # listmix
+ listmix.ListCtrlAutoWidthMixin.__init__(self)
+ listmix.ColumnSorterMixin.__init__(self, self.GetColumnCount())
+ # add some attributes
+ self.attr1 = wx.ListItemAttr()
+ self.attr1.SetBackgroundColour(wx.Colour(238,238,238))
+ self.attr2 = wx.ListItemAttr()
+ self.attr2.SetBackgroundColour("white")
+ self.il = wx.ImageList(16, 16)
+ self.sm_up = self.il.Add(wx.ArtProvider_GetBitmap(wx.ART_GO_UP, wx.ART_TOOLBAR,
+ (16,16)))
+ self.sm_dn = self.il.Add(wx.ArtProvider_GetBitmap(wx.ART_GO_DOWN, wx.ART_TOOLBAR,
+ (16,16)))
+ self.SetImageList(self.il, wx.IMAGE_LIST_SMALL)
+ # sort by first column
+ if self.sourceData:
+ self.SortListItems(col=0, ascending=True)
+ # bindings
+ self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColumnClick)
def Populate(self, data=None, update=False):
"""Populate list"""
+ self.itemDataMap = {}
+ self.itemIndexMap = []
if data is None:
data = self.sourceData
elif update:
@@ -453,33 +493,111 @@
try:
data.sort()
self.DeleteAllItems()
+ row = 0
for value in data:
- entry = self.GetItemCount()
- index = self.InsertStringItem(entry, value[0])
+ # index = self.InsertStringItem(sys.maxint, str(value[0]))
+ self.itemDataMap[row] = [value[0]]
for i in range(1, len(value)):
- try:
- self.SetStringItem(index, i, value[i])
- except:
- self.SetStringItem(index, i, unicode(value[i], 'latin1'))
+ # try:
+ # self.SetStringItem(index, i, str(value[i]))
+ # except:
+ # self.SetStringItem(index, i, unicode(str(value[i]), 'latin1'))
+ self.itemDataMap[row].append(value[i])
+ # self.SetItemData(index, row)
+ self.itemIndexMap.append(row)
+ row += 1
+ self.SetItemCount(row)
# set column width
- for i in range(self.GetColumnCount()):
- self.SetColumnWidth(i, wx.LIST_AUTOSIZE)
- if self.GetColumnWidth(i) < 80:
- self.SetColumnWidth(i, 80)
+ # for i in range(self.GetColumnCount()):
+ # self.SetColumnWidth(i, wx.LIST_AUTOSIZE)
+ # if self.GetColumnWidth(i) < 80:
+ # self.SetColumnWidth(i, 80)
+ self.SetColumnWidth(0, 80)
+ self.SetColumnWidth(1, 300)
self.SendSizeEvent()
except StandardError, e:
- dlg = wx.MessageDialog(parent=self,
- message=_("Unable to read list: %s ") % e,
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
- dlg.ShowModal()
- dlg.Destroy()
+ wx.MessageBox(parent=self,
+ message=_("Unable to read list: %s ") % e,
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
+ def OnColumnClick(self, event):
+ """Sort by column"""
+ self._col = event.GetColumn()
+ # remove duplicated arrow symbol from column header
+ # FIXME: should be done automatically
+ info = wx.ListItem()
+ info.m_mask = wx.LIST_MASK_TEXT | wx.LIST_MASK_IMAGE
+ info.m_image = -1
+ for column in range(self.GetColumnCount()):
+ info.m_text = self.GetColumn(column).GetText()
+ self.SetColumn(column, info)
+ event.Skip()
+ def GetSortImages(self):
+ """Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py"""
+ return (self.sm_dn, self.sm_up)
+ def OnGetItemText(self, item, col):
+ """Get item text"""
+ index = self.itemIndexMap[item]
+ s = str(self.itemDataMap[index][col])
+ return s
+ def OnGetItemAttr(self, item):
+ """Get item attributes"""
+ if ( index % 2) == 0:
+ return self.attr2
+ else:
+ return self.attr1
+ def SortItems(self, sorter=cmp):
+ """Sort items"""
+ items = list(self.itemDataMap.keys())
+ items.sort(self.Sorter)
+ self.itemIndexMap = items
+ # redraw the list
+ self.Refresh()
+ def Sorter(self, key1, key2):
+ colName = self.GetColumn(self._col).GetText()
+ ascending = self._colSortFlag[self._col]
+ # convert always string
+ item1 = self.itemDataMap[key1][self._col]
+ item2 = self.itemDataMap[key2][self._col]
+ if type(item1) == type('') or type(item2) == type(''):
+ cmpVal = locale.strcoll(str(item1), str(item2))
+ else:
+ cmpVal = cmp(item1, item2)
+ # If the items are equal then pick something else to make the sort value unique
+ if cmpVal == 0:
+ cmpVal = apply(cmp, self.GetSecondarySortValues(self._col, key1, key2))
+ if ascending:
+ return cmpVal
+ else:
+ return -cmpVal
+ def GetListCtrl(self):
+ """Used by listmix.ColumnSorterMixin"""
+ return self
def Search (self, index, str):
- """Search projection by name"""
+ """Search projection by description
+ Return first found item or None
if str == '':
self.Populate(self.sourceData)
return None
@@ -524,6 +642,7 @@
self.label_hemisphere = self.MakeLabel(_("Hemisphere for zone:"))
# layout
+ self.sizer.AddGrowableCol(2)
flag=wx.ALIGN_LEFT, pos=(1, 1), span=(1, 2))
@@ -647,6 +766,7 @@
self.transformlist.sourceData = data
# layout
+ self.sizer.AddGrowableCol(4)
self.sizer.Add(item=self.MakeLabel(_("Datum code:")),
@@ -665,6 +785,7 @@
wx.ALL, border=5, pos=(2, 2))
self.sizer.Add(item=self.datumlist,
flag=wx.EXPAND |
wx.ALIGN_LEFT |
@@ -778,7 +899,7 @@
index = event.m_itemIndex
item = event.GetItem()
- self.transform = item.GetText()
+ self.transform = self.transformlist.GetItem(index, 0).GetText()
self.transdatum = self.parent.transforms[self.transform][0]
self.transregion = self.parent.transforms[self.transform][1]
self.transparams = self.parent.transforms[self.transform][2]
@@ -789,7 +910,7 @@
- self.datum = item.GetText()
+ self.datum = self.datumlist.GetItem(index, 0).GetText()
self.datumdesc = self.parent.datums[self.datum][0]
self.ellipsoid = self.parent.datums[self.datum][1]
self.datumparams = self.parent.datums[self.datum][2]
@@ -829,6 +950,7 @@
# layout
self.sizer.Add(item=self.MakeLabel(_("Ellipsoid code:")),
@@ -845,11 +967,12 @@
self.sizer.Add(item=self.ellipselist,
flag=wx.EXPAND |
wx.ALIGN_LEFT |
- wx.ALL, border=5, pos=(3, 1), span=(1, 3))
+ wx.ALL, border=5, pos=(3, 1), span=(1, 4))
# events
self.ellipselist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
@@ -916,7 +1039,7 @@
- self.ellipse = item.GetText()
+ self.ellipse = self.ellipselist.GetItem(index, 0).GetText()
self.ellipsedesc = self.parent.ellipsoids[self.ellipse][0]
self.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
@@ -939,6 +1062,7 @@
self.bbrowse = self.MakeButton(_("Browse"))
# do layout
self.sizer.Add(item=self.lfile, flag=wx.ALIGN_LEFT |
wx.ALIGN_CENTRE_VERTICAL |
wx.ALL, border=5, pos=(1, 1))
@@ -1009,7 +1133,7 @@
TitledPage.__init__(self, wizard, _("Choose EPSG Code"))
self.parent = parent
self.epsgCodeDict = {}
- self.epsgcode = ''
+ self.epsgcode = None
self.epsgdesc = ''
self.epsgparams = ''
@@ -1038,6 +1162,7 @@
columns=[_('Code'), _('Description'), _('Parameters')])
# layout
@@ -1073,9 +1198,10 @@
wx.ALL, border=5, pos=(3, 3))
+ self.sizer.AddGrowableRow(4)
self.sizer.Add(item=self.epsglist,
flag=wx.ALIGN_LEFT | wx.EXPAND, pos=(4, 1),
- span=(2, 4))
+ span=(1, 3))
# events
self.bbrowse.Bind(wx.EVT_BUTTON, self.OnBrowse)
@@ -1091,7 +1217,7 @@
# self.DoLayout()
- if len(self.epsgcode) == 0:
+ if self.epsgcode:
# disable 'next' button by default
wx.FindWindowById(wx.ID_FORWARD).Enable(False)
else:
@@ -1106,9 +1232,14 @@
def OnText(self, event):
self.epsgcode = event.GetString()
+ try:
+ self.epsgcode = int(self.epsgcode)
+ except:
nextButton = wx.FindWindowById(wx.ID_FORWARD)
- if len(self.epsgcode) > 0 and self.epsgcode in self.epsgCodeDict.keys():
+ if self.epsgcode and self.epsgcode in self.epsgCodeDict.keys():
self.epsgdesc = self.epsgCodeDict[self.epsgcode][0]
self.epsgparams = self.epsgCodeDict[self.epsgcode][1]
if not nextButton.IsEnabled():
@@ -1126,11 +1257,11 @@
try:
self.epsgcode = self.epsglist.Search(index=1, str=str)[0]
+ self.tcode.SetValue(str(self.epsgcode))
except:
+ self.tcode.SetValue('')
- self.tcode.SetValue(self.epsgcode)
event.Skip()
def OnBrowse(self, event):
@@ -1144,54 +1275,47 @@
event.Skip()
- def OnItemSelected(self,event):
+ def OnItemSelected(self, event):
+ """EPSG code selected from the list"""
- self.epsgcode = item.GetText()
+ self.epsgcode = int(self.epsglist.GetItem(index, 0).GetText())
self.epsgdesc = self.epsglist.GetItem(index, 1).GetText()
+ event.Skip()
def OnBrowseCodes(self, event, search=None):
"""Browse EPSG codes"""
try:
data = []
- f = open(self.tfile.GetValue(),"r")
- descr = None
+ f = open(self.tfile.GetValue(), "r")
+ i = 0
code = None
- params = None
- i = 0
for line in f.readlines():
line = line.strip()
- if line.find("#") == 0:
+ if line[0] == '#':
descr = line[1:].strip()
- elif line.find("<") == 0:
- code = line.split(" ")[0]
- for par in line.split(" ")[1:]:
- params += par + " "
- code = code[1:-1]
- if code == None:
- code = 'no code'
- if descr == None:
- descr = 'no description'
- if params == None:
- params = 'no parameters'
- if i % 2 == 0:
+ elif line[0] == '<':
+ code, params = line.split(" ", 1)
+ code = int(code.replace('<', '').replace('>', ''))
+ if code is not None:
data.append((code, descr, params))
self.epsgCodeDict[code] = (descr, params)
- descr = None; code = None; params = ""
+ code = None
i += 1
f.close()
self.epsglist.Populate(data, update=True)
- message=_("Unable to read EPGS codes: %s " % e,
- _("Error"), wx.OK | wx.ICON_ERROR))
- dlg.ShowModal()
- dlg.Destroy()
+ message=_("Unable to read EPGS codes: %s ") % e,
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
class CustomPage(TitledPage):
@@ -1212,12 +1336,14 @@
self.label_proj4string = self.MakeLabel(_("Enter PROJ.4 parameters string:"))
# layout
self.sizer.Add(self.label_proj4string,
flag=wx.ALIGN_LEFT | wx.ALL,
+ self.sizer.AddGrowableRow(2)
self.sizer.Add(self.text_proj4string,
flag=wx.ALIGN_LEFT | wx.ALL | wx.EXPAND,
- border=5, pos=(2, 1), span=(1, 4))
+ border=5, pos=(2, 1), span=(1, 2))
self.text_proj4string.Bind(wx.EVT_TEXT, self.GetProjstring)
@@ -1263,10 +1389,10 @@
# labels
- self.ldatabase = self.MakeLabel("")
- self.llocation = self.MakeLabel("")
- self.lprojection = self.MakeLabel("")
- self.lproj4string = self.MakeLabel("")
+ self.ldatabase = self.MakeLabel("")
+ self.llocation = self.MakeLabel("")
+ self.lprojection = self.MakeLabel("")
+ self.lproj4string = self.MakeLabel("")
self.lproj4stringLabel = self.MakeLabel("")
self.lprojection.Wrap(400)
@@ -1279,6 +1405,7 @@
def __DoLayout(self):
self.sizer.Add(item=self.MakeLabel(_("GRASS Database:")),
border=5, pos=(1, 0))
@@ -1291,12 +1418,6 @@
self.sizer.Add(item=self.llocation,
border=5, pos=(2, 1))
- # self.sizer.Add(item=wx.StaticLine(self, -1),
- # flag=wx.ALIGN_RIGHT | wx.EXPAND | wx.ALL,
- # pos=(3, 0), span=(1, 2))
- # self.sizer.Add(item=(10,10),
- # flag=wx.ALIGN_CENTER_HORIZONTAL | wx.ALL,
- # border=5, pos=(4, 0))
self.sizer.Add(item=self.MakeLabel(_("Projection:")),
border=5, pos=(3, 0))
@@ -1311,14 +1432,14 @@
border=5, pos=(4, 1))
self.sizer.Add(item=(10,20),
- border=5, pos=(5, 0))
+ border=5, pos=(5, 0), span=(1, 2))
+ self.sizer.AddGrowableRow(6)
self.sizer.Add(item=self.MakeLabel(_("You can set the default extents "
- "and resolution after creating new location")),
- flag=wx.ALIGN_CENTRE | wx.ALL,
- border=5, pos=(6, 0), span=(1, 3))
- self.sizer.Add(item=self.MakeLabel(_("or you can set them during a working session.")),
- flag=wx.ALIGN_CENTRE | wx.ALL, border=5, pos=(7, 0),
- span=(1, 3))
+ "and resolution after creating new location%s"
+ "or you can set them during a working session.") % os.linesep,
+ style=wx.ALIGN_CENTER),
+ flag=wx.ALIGN_CENTRE | wx.ALL, border=5, pos=(6, 0),
+ span=(1, 2))
def OnEnterPage(self,event):
@@ -1503,11 +1624,12 @@
dlg.Destroy()
elif success == False:
- dlg = wx.MessageBox(parent=self.wizard,
- message=_("Unable to create new location."),
- style=wx.OK | wx.ICON_ERROR)
- self.Destroy()
+ dlg = wx.MessageDialog(parent=self.wizard,
+ message=_("Unable to create new location."),
+ style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ if dlg.ShowModal() == wx.ID_OK:
+ self.wizard.Destroy()
else: # None
pass
else:
