[GRASS-CVS] markus: grass6/locale/po grasslibs_th.po, NONE,
1.1 grassmods_th.po, NONE, 1.1 grasstcl_th.po, NONE, 1.1
grass at intevation.de
Thu Nov 15 02:48:16 EST 2007
Author: markus
Update of /grassrepository/grass6/locale/po
In directory doto:/tmp/cvs-serv20309/locale/po
Added Files:
grasslibs_th.po grassmods_th.po grasstcl_th.po
Log Message:
new Thai translation started by Sarawut Ninsawat
--- NEW FILE: grasslibs_th.po ---
# translation of grasstcl_th.po to Thai
# Sarawut Ninsawat <sarawut.map at gmail.com>, 2007.
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2007, GRASS Development Team
msgid ""
msgstr ""
"Project-Id-Version: grasstcl_th\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2007-10-26 21:10+0200\n"
"PO-Revision-Date: 2007-11-12 02:10+0900\n"
"Last-Translator: Sarawut Ninsawat <sarawut.map at gmail.com>\n"
"Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.11.4\n"
#: ../lib/raster/rem_io.c:43
#, c-format
[...3455 lines suppressed...]
#: ../lib/gmath/la.c:1020
msgid "Output vector has incorrect dimension"
msgstr ""
#: ../lib/gmath/la.c:1067
msgid "Vector dimensions out of range"
msgstr ""
#: ../lib/gmath/la.c:1073
msgid "Row/column out of range"
msgstr ""
#: ../lib/gmath/la.c:1291
msgid "Vector structure is not initialised"
msgstr ""
#: ../lib/gmath/la.c:1413 ../lib/gmath/la.c:1421 ../lib/gmath/la.c:1426
msgid "Input format error"
msgstr ""
--- NEW FILE: grassmods_th.po ---
# translation of grassmods_th.po to Thai
msgid ""
msgstr ""
"Project-Id-Version: grassmods_th\n"
#: ../visualization/xganim/Clr_table.c:98
#: ../visualization/xganim/Clr_table.c:308
[...23359 lines suppressed...]
#: ../raster3d/r3.out.ascii/main.c:85
msgid "Name for ASCII output file"
msgstr ""
#: ../raster3d/r3.out.ascii/main.c:94
msgid "Number of decimal places for floats"
msgstr ""
#: ../raster3d/r3.out.ascii/main.c:259
msgid "raster3d, voxel, export"
msgstr ""
#: ../raster3d/r3.out.ascii/main.c:260
msgid "Converts a 3D raster map layer into an ASCII text file"
msgstr ""
#: ../raster3d/r3.out.ascii/main.c:323
msgid "Error closing new ASCII file"
msgstr ""
--- NEW FILE: grasstcl_th.po ---
msgid ""
msgstr ""
#: ../gui/tcltk/d.m/barscale.tcl:67 ../gui/tcltk/d.m/legend.tcl:106
#, fuzzy
[...5942 lines suppressed...]
msgid "Display attributes"
msgstr "à¹à¸ªà¸”งข้à¸à¸¡à¸¹à¸¥à¸¥à¸±à¸à¸©à¸“ะ"
#: ../vector/v.digit/toolbox.tcl:235
msgid "Open settings"
msgstr "เปิดà¸à¸²à¸£à¸•à¸±à¹‰à¸‡à¸„่า"
#: ../vector/v.digit/toolbox.tcl:241
msgid "Save and exit"
msgstr "บันทึภà¹à¸¥à¸°à¸à¸à¸"
#: ../vector/v.digit/toolbox.tcl:252
msgid "mouse button actions (left, middle, right)"
msgstr ""
#: ../visualization/nviz/scripts/panel_animation.tcl:275
#, fuzzy
msgid "Test"
msgstr "ทดสà¸à¸š"
