[GRASS-CVS] hamish: grass6/raster/r.watershed/front description.html, 1.10, 1.11
grass at intevation.de grass at intevation.de
Thu Nov 15 21:12:33 EST 2007
Author: hamish
Update of /grassrepository/grass6/raster/r.watershed/front
In directory doto:/tmp/cvs-serv20251
Modified Files:
	description.html
Log Message:
be clearer
Index: description.html
RCS file: /grassrepository/grass6/raster/r.watershed/front/description.html,v
retrieving revision 1.10
retrieving revision 1.11
diff -u -d -r1.10 -r1.11
--- description.html	12 Nov 2007 09:09:30 -0000	1.10
+++ description.html	16 Nov 2007 02:12:31 -0000	1.11
@@ -262,8 +262,8 @@
 Zero data values will be treated as elevation data (not no_data).
 <P>
-To isolate a river network using the output of this module, a number of
-approaches may be considered.
+To isolate an individual river network using the output of this module,
+a number of approaches may be considered.
 <OL>
 <LI>Use a resample of the basins catchment raster map as a MASK.<BR>
   The equivalent vector map method is similar using <em>v.select</em> or
