[GRASS-CVS] hamish: grass6/raster/r.coin cmd_parms.c,2.7,2.8
grass at intevation.de
Fri Nov 16 04:24:36 EST 2007
Author: hamish
Update of /grassrepository/grass6/raster/r.coin
In directory doto:/tmp/cvs-serv29411
Modified Files:
cmd_parms.c
Log Message:
explain unit codes
Index: cmd_parms.c
RCS file: /grassrepository/grass6/raster/r.coin/cmd_parms.c,v
retrieving revision 2.7
retrieving revision 2.8
diff -u -d -r2.7 -r2.8
--- cmd_parms.c 14 Oct 2006 16:55:57 -0000 2.7
+++ cmd_parms.c 16 Nov 2007 09:24:34 -0000 2.8
@@ -38,31 +38,34 @@
/* please, remove before GRASS 7 released */
struct Flag *q_flag;
- module = G_define_module();
- module->keywords = _("raster");
+ module = G_define_module();
+ module->keywords = _("raster");
module->description =
- _("Tabulates the mutual occurrence (coincidence) "
- "of categories for two raster map layers.");
+ _("Tabulates the mutual occurrence (coincidence) "
+ "of categories for two raster map layers.");
parm.map1 = G_define_option();
- parm.map1->key = "map1";
- parm.map1->required = YES;
- parm.map1->type = TYPE_STRING;
- parm.map1->gisprompt = "old,cell,raster" ;
+ parm.map1->key = "map1";
+ parm.map1->required = YES;
+ parm.map1->type = TYPE_STRING;
+ parm.map1->gisprompt = "old,cell,raster" ;
parm.map1->description = _("Name of first raster map");
parm.map2 = G_define_option();
- parm.map2->key = "map2";
- parm.map2->required = YES;
- parm.map2->type = TYPE_STRING;
- parm.map2->gisprompt = "old,cell,raster" ;
+ parm.map2->key = "map2";
+ parm.map2->required = YES;
+ parm.map2->type = TYPE_STRING;
+ parm.map2->gisprompt = "old,cell,raster" ;
parm.map2->description = _("Name of second raster map");
parm.units = G_define_option();
- parm.units->key = "units";
+ parm.units->key = "units";
parm.units->required = YES;
- parm.units->type = TYPE_STRING;
- parm.units->description = _("Unit of measure");
+ parm.units->type = TYPE_STRING;
+ parm.units->label = _("Unit of measure");
+ parm.units->description = _("c(ells), p(ercent), x(percent of category [column]), "
+ "y(percent of category [row]), a(cres), h(ectares), "
+ "k(square kilometers), m(square miles)");
parm.units->options = "c,p,x,y,a,h,k,m";
flag.w = G_define_flag();
