[GRASS-CVS] markus: grass6/vector/v.distance main.c,1.42,1.42.2.1
grass at intevation.de
Sun Nov 18 14:52:54 EST 2007
- Previous message: [GRASS-CVS] markus: grass6/raster/r.watershed/front
description.html, 1.7, 1.7.2.1
- Next message: [GRASS-CVS] markus: grass6/lib/vector/Vlib break_lines.c, 1.4,
1.4.6.1 cindex.c, 1.14, 1.14.2.1 field.c, 1.41,
1.41.6.1 snap.c, 1.8, 1.8.2.1
- Messages sorted by:
[ date ]
[ thread ]
[ subject ]
[ author ]
Author: markus
Update of /grassrepository/grass6/vector/v.distance
In directory doto:/tmp/cvs-serv22980
Modified Files:
Tag: releasebranch_6_3
main.c
Log Message:
to_along and to_angle explained better (merge from HEAD)
Index: main.c
RCS file: /grassrepository/grass6/vector/v.distance/main.c,v
retrieving revision 1.42
retrieving revision 1.42.2.1
diff -u -d -r1.42 -r1.42.2.1
--- main.c 22 Oct 2007 15:23:40 -0000 1.42
+++ main.c 18 Nov 2007 19:52:51 -0000 1.42.2.1
@@ -166,9 +166,11 @@
"dist;minimum distance to nearest feature;"
"to_x;x coordinate of the nearest point on 'to' feature;"
"to_y;y coordinate of the nearest point on 'to' feature;"
- "to_along;distance to the nearest point on 'from' feature along linear feature;"
- "to_angle;angle of linear feature in nearest point, counterclockwise from positive "
- "x axis, in radians, which is between -PI and PI inclusive;"
+ "to_along;distance between points/centroids in 'from' map and the linear feature's "
+ "start point in 'to' map, along this linear feature;"
+ "to_angle;angle between the linear feature in 'to' map and the positive x axis, at "
+ "the location of point/centroid in 'from' map, counterclockwise, in radians, which "
+ "is between -PI and PI inclusive;"
"to_attr;attribute of nearest feature given by to_column option");
/* "from_x - x coordinate of the nearest point on 'from' feature;" */
/* "from_y - y coordinate of the nearest point on 'from' feature;" */
[ date ]
[ thread ]
[ subject ]
[ author ]
