[GRASS-CVS] jachym: grass6/locale/po grassmods_cs.po,1.45,1.46
grass at intevation.de
Tue Nov 20 09:54:49 EST 2007
Author: jachym
Update of /grassrepository/grass6/locale/po
In directory doto:/tmp/cvs-serv15891
Modified Files:
grassmods_cs.po
Log Message:
czech translation updated
Index: grassmods_cs.po
RCS file: /grassrepository/grass6/locale/po/grassmods_cs.po,v
retrieving revision 1.45
retrieving revision 1.46
diff -u -d -r1.45 -r1.46
--- grassmods_cs.po 8 Nov 2007 11:36:51 -0000 1.45
+++ grassmods_cs.po 20 Nov 2007 14:54:46 -0000 1.46
@@ -11,7 +11,7 @@
"Project-Id-Version: grassmods_cs\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2007-10-26 10:42+0200\n"
-"PO-Revision-Date: 2007-11-06 19:03+0100\n"
+"PO-Revision-Date: 2007-11-20 15:53+0100\n"
"Last-Translator: Radim Bla¾ek <blazek at itc.it>\n"
"Language-Team: Czech <translations at grass.itc.it>\n"
"MIME-Version: 1.0\n"
@@ -233,7 +233,7 @@
"ERROR: Required parameter <%s> not set:\n"
" (%s).\n"
[...5167 lines suppressed...]
#~ msgid "Total species representation is < 100"
#~ msgstr ""
-#~ "CelkovÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂà"
-#~ "zastoupenÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
-#~ "druhÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂàje < 100"
+#~ "CelkovÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂà"
+#~ "zastoupenÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
+#~ "druhÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂàje < 100"
#~ msgid "Cannot select attributes for point #%d"
#~ msgstr "Nelze vybrat atributy pro bod #%d"
#~ msgid "Species <%s> not known. I'll use parameters for spruce instead"
#~ msgstr ""
-#~ "Druh <%s> nenÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
-#~ "znÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂm. "
-#~ "PouÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÃÂÃÂÃÅ¡ÃÂÄÂĹÄÃšĹžiji parametry pro smrk."
+#~ "Druh <%s> nenÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
+#~ "znÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂm. "
+#~ "PouÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÃÂÃÂÃÅ¡ÃÂÄÂĹÄÃšĹžiji parametry pro smrk."
