[GRASS-CVS] markus: grass6/raster/r.out.gdal main.c,1.20,1.20.2.1
grass at intevation.de
Tue Nov 20 11:34:58 EST 2007
Author: markus
Update of /grassrepository/grass6/raster/r.out.gdal
In directory doto:/tmp/cvs-serv19090
Modified Files:
Tag: releasebranch_6_3
main.c
Log Message:
better select output type (esp. avoid GeoTIFF color table problems); user message to say which output type was used (merge from HEAD)
Index: main.c
RCS file: /grassrepository/grass6/raster/r.out.gdal/main.c,v
retrieving revision 1.20
retrieving revision 1.20.2.1
diff -u -d -r1.20 -r1.20.2.1
--- main.c 24 Sep 2007 10:13:27 -0000 1.20
+++ main.c 20 Nov 2007 16:34:56 -0000 1.20.2.1
@@ -338,6 +338,10 @@
struct Ref ref;
char *mapset, *gdal_formats = NULL;
RASTER_MAP_TYPE maptype;
+ int bHaveMinMax;
+ double dfCellMin;
+ double dfCellMax;
+ struct FPRange sRange;
G_gisinit(argv[0]);
@@ -411,7 +415,6 @@
#endif
if (flag_l->answer) {
supported_formats(&gdal_formats);
exit(EXIT_SUCCESS);
@@ -532,7 +535,17 @@
/* If file type not set by user ... */
+ /* Get min/max values. */
+ if( G_read_fp_range(input->answer, mapset, &sRange ) == -1 ) {
+ bHaveMinMax = FALSE;
+ } else {
+ bHaveMinMax = TRUE;
+ G_get_fp_range_min_max( &sRange, &dfCellMin, &dfCellMax );
+ G_message( "Range: min: %f, max: %f", dfCellMin, dfCellMax);
if (datatype == GDT_Unknown) {
/* ... determine raster data type from first GRASS raster in a group */
maptype = G_raster_map_type(ref.file[0].name, ref.file[0].mapset);
@@ -545,10 +558,25 @@
nodataval = -1E37f;
else {
- datatype = GDT_Int32;
+ /* Special tricks for GeoTIFF color table support and such */
+ if (dfCellMin >= 0 && dfCellMax < 256 ) {
+ datatype = GDT_Byte;
+ } else {
+ if (dfCellMin >= 0 && dfCellMax < 65536 ) {
+ datatype = GDT_UInt16;
+ } else {
+ datatype = GDT_Int32; /* need to furthermore fine tune this? */
nodataval = (double)(int)0x80000000;
+ G_debug( 3, "Input map datatype=%s\n",
+ (maptype == CELL_TYPE ? "CELL" :
+ (maptype == DCELL_TYPE ? "DCELL" :
+ (maptype == FCELL_TYPE ? "FCELL" : "??"))));
+ G_message(_("Exporting to GDAL data type: %s"), GDALGetDataTypeName(datatype));
/* Create dataset for output with target driver or, if needed, with in-memory driver */
char **papszOptions = NULL;
