[GRASS-CVS] hamish: grass6/scripts/d.out.file d.out.file, 1.13,
1.14
grass at intevation.de
Thu Nov 22 04:01:59 EST 2007
Author: hamish
Update of /grassrepository/grass6/scripts/d.out.file
In directory doto:/tmp/cvs-serv22301
Modified Files:
d.out.file
Log Message:
add support for the Cairo driver
Index: d.out.file
RCS file: /grassrepository/grass6/scripts/d.out.file/d.out.file,v
retrieving revision 1.13
retrieving revision 1.14
diff -u -d -r1.13 -r1.14
--- d.out.file 16 May 2007 04:24:06 -0000 1.13
+++ d.out.file 22 Nov 2007 09:01:56 -0000 1.14
@@ -99,19 +99,24 @@
#% description: PostScript level (only limits functionality!)
#% guisection: PostScript
#% required : no
-#%end
+#% end
#%flag
-#%key: b
-#%description: Set background color to black (white default)
-#%end
+#% key: b
+#% description: Set background color to black (white default)
+#% end
#%flag
-#%key: t
-#%description: Set transparent background
+#% key: t
+#% description: Set transparent background
#% guisection: Images
-#%end
+#% end
#%flag
-#%key: r
-#%description: Set paper orientation to landscape (for PostScript output)
+#% key: c
+#% description: Use the Cario driver instead of the PNG driver
+#% guisection: Images
+#% end
+#%flag
+#% key: r
+#% description: Set paper orientation to landscape (for PostScript output)
#%end
@@ -151,6 +156,11 @@
exit 1
fi
+if [ $GIS_FLAG_C -eq 1 ] && [ `d.mon -l | grep -c '^cairo'` -eq 0 ] ; then
+ g.message -e "Cairo driver not present in this build of GRASS."
+ exit 1
+fi
#### set variables
res="$GIS_OPT_RESOLUTION"
@@ -215,6 +225,11 @@
if [ "$GIS_OPT_FORMAT" = "ps" ] || [ "$GIS_OPT_FORMAT" = "eps" ] ; then
+ if [ $GIS_FLAG_C -eq 1 ] ; then
+ g.message -e "Cairo driver is incompatible with the PostScript driver."
+ exit 1
+ fi
GRAPHICS_DRIVER=PS
GRASS_PSFILE="$output"
export GRASS_PSFILE
@@ -244,9 +259,15 @@
fi
else
- GRAPHICS_DRIVER=PNG
- GRASS_PNGFILE="$output"
- export GRASS_PNGFILE
+ if [ $GIS_FLAG_C -eq 0 ] ; then
+ GRAPHICS_DRIVER=PNG
+ GRASS_PNGFILE="$output"
+ export GRASS_PNGFILE
+ else
+ GRAPHICS_DRIVER=cairo
+ GRASS_CAIROFILE="$output"
+ export GRASS_CAIROFILE
+ fi
#make sure that output is 24 bit color
GRASS_TRUECOLOR=TRUE
@@ -310,6 +331,6 @@
\rm "$output"
-g.message "Done."
+g.message "Done."
exit $EXITCODE
