[GRASS-CVS] markus: grass6/locale/po grasslibs_th.po, NONE,
1.1.2.1 grassmods_th.po, NONE, 1.1.2.1 grasstcl_th.po, NONE,
1.1.2.1 grasslibs_ar.po, 1.12, 1.12.2.1 grasslibs_cs.po, 1.33,
1.33.2.1 grasslibs_de.po, 1.53, 1.53.2.1 grasslibs_el.po, 1.7,
1.7.2.1 grasslibs_es.po, 1.65, 1.65.2.1 grasslibs_fr.po, 1.29,
1.29.2.1 grasslibs_hi.po, 1.17, 1.17.2.1 grasslibs_it.po, 1.29,
1.29.2.1 grasslibs_ja.po, 1.27, 1.27.2.1 grasslibs_ko.po, 1.18,
1.18.2.1 grasslibs_lv.po, 1.16, 1.16.2.1 grasslibs_mr.po, 1.17,
1.17.2.1 grasslibs_pl.po, 1.20, 1.20.2.1 grasslibs_pt.po, 1.9,
1.9.2.1 grasslibs_pt_br.po, 1.25, 1.25.2.1 grasslibs_ru.po, 1.24,
1.24.2.1 grasslibs_sl.po, 1.20, 1.20.2.1 grasslibs_tr.po, 1.15,
1.15.2.1 grasslibs_vi.po, 1.20, 1.20.2.1 grasslibs_zh.po, 1.19,
1.19.2.1 grassmods_ar.po, 1.24, 1.24.2.1 grassmods_cs.po, 1.42,
1.42.2.1 grassmods_de.po, 1.118, 1.118.2.1 grassmods_el.po, 1.7,
1.7.2.1 grassmods_es.po, 1.84.2.1, 1.84.2.2 grassmods_fr.po, 1.44,
1.44.2.1 grassmods_hi.po, 1.27, 1.27.2.1 grassmods_it.po, 1.39.2.1,
1.39.2.2 grassmods_ja.po, 1.38, 1.
38.2.1 grassmods_ko.po, 1.26, 1.26.2.1 grassmods_lv.po, 1.26,
1.26.2.1 grassmods_mr.po, 1.27, 1.27.2.1 grassmods_pl.po, 1.30,
1.30.2.1 grassmods_pt.po, 1.5, 1.5.2.1 grassmods_pt_br.po, 1.42,
1.42.2.1 grassmods_ru.po, 1.34, 1.34.2.1 grassmods_sl.po, 1.30,
1.30.2.1 grassmods_tr.po, 1.26, 1.26.2.1 grassmods_vi.po, 1.32,
1.32.2.1 grassmods_zh.po, 1.33, 1.33.2.1 grasstcl_am.po, 1.2,
1.2.4.1 grasstcl_ar.po, 1.7, 1.7.2.1 grasstcl_cs.po, 1.15,
1.15.2.1 grasstcl_de.po, 1.24, 1.24.2.1 grasstcl_el.po, 1.7,
1.7.2.1 grasstcl_es.po, 1.58, 1.58.2.1 grasstcl_fr.po, 1.18,
1.18.2.1 grasstcl_hi.po, 1.13, 1.13.2.1 grasstcl_it.po, 1.19,
1.19.2.1 grasstcl_ja.po, 1.15, 1.15.2.1 grasstcl_ko.po, 1.7,
1.7.2.1 grasstcl_lv.po, 1.13, 1.13.2.1 grasstcl_mr.po, 1.8,
1.8.2.1 grasstcl_pl.po, 1.20, 1.20.2.1 grasstcl_pt.po, 1.10,
1.10.2.1 grasstcl_pt_br.po, 1.25, 1.25.2.1 grasstcl_ru.po, 1.13,
1.13.2.1 grasstcl_sl.po, 1.7, 1.7.2.1 grasstcl_tr.po, 1.14,
1.14.2.1 grasstcl_vi.po, 1.15, 1.15.2.1 grasstcl_zh.po, 1.7, 1.7.2.1
grass at intevation.de
Fri Nov 23 12:33:47 EST 2007
Author: markus
Update of /grassrepository/grass6/locale/po
In directory doto:/tmp/cvs-serv20549/po
Modified Files:
Tag: releasebranch_6_3
grasslibs_ar.po grasslibs_cs.po grasslibs_de.po
grasslibs_el.po grasslibs_es.po grasslibs_fr.po
grasslibs_hi.po grasslibs_it.po grasslibs_ja.po
grasslibs_ko.po grasslibs_lv.po grasslibs_mr.po
grasslibs_pl.po grasslibs_pt.po grasslibs_pt_br.po
grasslibs_ru.po grasslibs_sl.po grasslibs_tr.po
grasslibs_vi.po grasslibs_zh.po grassmods_ar.po
grassmods_cs.po grassmods_de.po grassmods_el.po
grassmods_es.po grassmods_fr.po grassmods_hi.po
grassmods_it.po grassmods_ja.po grassmods_ko.po
grassmods_lv.po grassmods_mr.po grassmods_pl.po
grassmods_pt.po grassmods_pt_br.po grassmods_ru.po
grassmods_sl.po grassmods_tr.po grassmods_vi.po
grassmods_zh.po grasstcl_am.po grasstcl_ar.po grasstcl_cs.po
grasstcl_de.po grasstcl_el.po grasstcl_es.po grasstcl_fr.po
grasstcl_hi.po grasstcl_it.po grasstcl_ja.po grasstcl_ko.po
grasstcl_lv.po grasstcl_mr.po grasstcl_pl.po grasstcl_pt.po
grasstcl_pt_br.po grasstcl_ru.po grasstcl_sl.po grasstcl_tr.po
grasstcl_vi.po grasstcl_zh.po
Added Files:
grasslibs_th.po grassmods_th.po grasstcl_th.po
Log Message:
translations sync'ed
--- NEW FILE: grasslibs_th.po ---
# translation of grasstcl_th.po to Thai
# Sarawut Ninsawat <sarawut.map at gmail.com>, 2007.
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2007, GRASS Development Team
msgid ""
msgstr ""
"Project-Id-Version: grasstcl_th\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2007-10-26 21:10+0200\n"
"PO-Revision-Date: 2007-11-12 02:10+0900\n"
"Last-Translator: Sarawut Ninsawat <sarawut.map at gmail.com>\n"
"Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.11.4\n"
#: ../lib/raster/rem_io.c:43
#, c-format
[...3455 lines suppressed...]
#: ../lib/gmath/la.c:1020
msgid "Output vector has incorrect dimension"
msgstr ""
#: ../lib/gmath/la.c:1067
msgid "Vector dimensions out of range"
msgstr ""
#: ../lib/gmath/la.c:1073
msgid "Row/column out of range"
msgstr ""
#: ../lib/gmath/la.c:1291
msgid "Vector structure is not initialised"
msgstr ""
#: ../lib/gmath/la.c:1413 ../lib/gmath/la.c:1421 ../lib/gmath/la.c:1426
msgid "Input format error"
msgstr ""
--- NEW FILE: grassmods_th.po ---
# translation of grassmods_th.po to Thai
msgid ""
msgstr ""
"Project-Id-Version: grassmods_th\n"
#: ../visualization/xganim/Clr_table.c:98
#: ../visualization/xganim/Clr_table.c:308
[...23359 lines suppressed...]
#: ../raster3d/r3.out.ascii/main.c:85
msgid "Name for ASCII output file"
msgstr ""
#: ../raster3d/r3.out.ascii/main.c:94
msgid "Number of decimal places for floats"
msgstr ""
#: ../raster3d/r3.out.ascii/main.c:259
msgid "raster3d, voxel, export"
msgstr ""
#: ../raster3d/r3.out.ascii/main.c:260
msgid "Converts a 3D raster map layer into an ASCII text file"
msgstr ""
#: ../raster3d/r3.out.ascii/main.c:323
msgid "Error closing new ASCII file"
msgstr ""
--- NEW FILE: grasstcl_th.po ---
msgid ""
msgstr ""
#: ../gui/tcltk/d.m/barscale.tcl:67 ../gui/tcltk/d.m/legend.tcl:106
#, fuzzy
[...5942 lines suppressed...]
msgid "Display attributes"
msgstr "à¹à¸ªà¸à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸¥à¸±à¸à¸©à¸à¸°"
#: ../vector/v.digit/toolbox.tcl:235
msgid "Open settings"
msgstr "à¹à¸à¸´à¸à¸à¸²à¸£à¸à¸±à¹à¸à¸à¹à¸²"
#: ../vector/v.digit/toolbox.tcl:241
msgid "Save and exit"
msgstr "à¸à¸±à¸à¸à¸¶à¸ à¹à¸¥à¸°à¸à¸à¸"
#: ../vector/v.digit/toolbox.tcl:252
msgid "mouse button actions (left, middle, right)"
msgstr ""
#: ../visualization/nviz/scripts/panel_animation.tcl:275
#, fuzzy
msgid "Test"
msgstr "à¸à¸à¸ªà¸à¸"
Index: grasslibs_ar.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_ar.po,v
retrieving revision 1.12
retrieving revision 1.12.2.1
diff -u -d -r1.12 -r1.12.2.1
--- grasslibs_ar.po 21 Sep 2007 22:12:43 -0000 1.12
+++ grasslibs_ar.po 23 Nov 2007 17:33:17 -0000 1.12.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grassmods_ar\n"
-"POT-Creation-Date: 2007-09-22 00:09+0200\n"
+"POT-Creation-Date: 2007-10-26 21:10+0200\n"
"PO-Revision-Date: 2005-03-09 12:50+0100\n"
"Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
-"Language-Team: Arabic <translations at grass.itc.it>\n"
+"Language-Team: Arabic <translations at lists.osgeo.org>\n"
@@ -799,13 +799,11 @@
msgstr "ØºÙØ± ØµØ§ÙØ '%s' اسÙ
اÙÙ
Ù٠اÙÙÙÙØªÙر٠اÙÙ
خرج"
#: ../lib/gis/legal_name.c:88 ../lib/gis/legal_name.c:90
-#: ../lib/vector/Vlib/legal_vname.c:73 ../lib/vector/Vlib/legal_vname.c:75
#, c-format
msgid "Cannot find input map '%s'"
msgstr "'%s' ÙÙ
ÙØªÙ
Ø§ÙØ¹Ø«Ùر عÙÙ Ø§ÙØ®Ø±Ùطة اÙÙ
Ø¯Ø®ÙØ©"
#: ../lib/gis/legal_name.c:109 ../lib/gis/legal_name.c:111
-#: ../lib/vector/Vlib/legal_vname.c:93 ../lib/vector/Vlib/legal_vname.c:95
#, c-format
msgid "Output map '%s' is used as input"
msgstr "Ù
ستخدÙ
ÙÙ
دخ٠'%s' اÙÙÙÙØªÙر اÙÙ
خرج"
@@ -1096,12 +1094,12 @@
msgid "Name of elevation raster map(s)"
msgstr "إسÙ
Ø§ÙØ±Ø§Ø³ØªØ± اÙÙ
Ø¯Ø®ÙØ©"
-#: ../lib/gis/parser.c:480
+#: ../lib/gis/parser.c:480 ../lib/gis/parser.c:505
#, fuzzy
msgid "Name of input raster3d map"
msgstr "إسÙ
Ø§ÙØ±Ø§Ø³ØªØ± اÙÙ
Ø¯Ø®ÙØ©"
-#: ../lib/gis/parser.c:489
+#: ../lib/gis/parser.c:489 ../lib/gis/parser.c:514
#, fuzzy
msgid "Name of input raster3d map(s)"
msgstr "إسÙ
Ø§ÙØ±Ø§Ø³ØªØ± اÙÙ
Ø¯Ø®ÙØ©"
@@ -1111,87 +1109,87 @@
msgid "Name for output raster3d map"
msgstr "إسÙ
Ø§ÙØ±Ø§Ø³ØªØ± اÙÙ
خرجة"
-#: ../lib/gis/parser.c:507 ../lib/gis/parser.c:532
+#: ../lib/gis/parser.c:524 ../lib/gis/parser.c:549
msgid "Name of input vector map"
msgstr "إسÙ
اÙÙÙÙØªÙر اÙÙ
Ø¯Ø®ÙØ©"
-#: ../lib/gis/parser.c:516
+#: ../lib/gis/parser.c:533 ../lib/gis/parser.c:558
#, fuzzy
msgid "Name of input vector map(s)"
msgstr "إسÙ
اÙÙÙÙØªÙر اÙÙ
Ø¯Ø®ÙØ©"
-#: ../lib/gis/parser.c:524
+#: ../lib/gis/parser.c:541
#, fuzzy
msgid "Name for output vector map"
msgstr "إسÙ
اÙÙÙÙØªÙر اÙÙ
خرجة"
-#: ../lib/gis/parser.c:541
+#: ../lib/gis/parser.c:567
msgid "Type"
msgstr "أدخÙ"
-#: ../lib/gis/parser.c:542
+#: ../lib/gis/parser.c:568
msgid "Feature type(s)"
msgstr ""
-#: ../lib/gis/parser.c:549
+#: ../lib/gis/parser.c:575
msgid "Layer number"
msgstr "رÙÙ
Ø§ÙØ·Ø¨ÙØ©"
-#: ../lib/gis/parser.c:550
+#: ../lib/gis/parser.c:576
msgid ""
"A single vector map can be connected to multiple database tables. This "
"number determines which table to use."
msgstr ""
-#: ../lib/gis/parser.c:557
+#: ../lib/gis/parser.c:583
msgid "Category value"
msgstr "ÙÙÙ
Ø© اÙÙØ¦Ø©"
-#: ../lib/gis/parser.c:564
+#: ../lib/gis/parser.c:590
#, fuzzy
msgid "Category values"
msgstr "ÙÙÙ
اÙÙØ¦Ø©."
-#: ../lib/gis/parser.c:565
+#: ../lib/gis/parser.c:591
msgid "Example: 1,3,7-9,13"
msgstr "Ù
Ø«ÙØ§:7,3,1Ù13,9 "
-#: ../lib/gis/parser.c:575
+#: ../lib/gis/parser.c:601
#, fuzzy
msgid "Name of input file"
msgstr "اسÙ
اÙÙ
Ù٠اÙÙ
ÙØªÙØ %s\n"
-#: ../lib/gis/parser.c:583
+#: ../lib/gis/parser.c:609
#, fuzzy
msgid "Name for output file"
msgstr "إسÙ
Ø§ÙØ±Ø§Ø³ØªØ± اÙÙ
خرجة"
-#: ../lib/gis/parser.c:591
+#: ../lib/gis/parser.c:617
msgid "Field separator"
msgstr ""
-#: ../lib/gis/parser.c:602
+#: ../lib/gis/parser.c:628
msgid "Color"
msgstr ""
-#: ../lib/gis/parser.c:603
+#: ../lib/gis/parser.c:629
msgid "Either a standard color name or R:G:B triplet"
msgstr ""
-#: ../lib/gis/parser.c:612
+#: ../lib/gis/parser.c:638
msgid "Background color"
msgstr ""
-#: ../lib/gis/parser.c:613
+#: ../lib/gis/parser.c:639
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
msgstr ""
-#: ../lib/gis/parser.c:915
+#: ../lib/gis/parser.c:941
#, c-format
msgid "Sorry <%s> is not a valid option\n"
msgstr "Ø£Ø³ÙØ§<%s> ÙÙØ³ Ø¥Ø®ØªÙØ§Ø± صØÙØ\n"
-#: ../lib/gis/parser.c:1026
+#: ../lib/gis/parser.c:1052
#, c-format
msgid ""
"\n"
@@ -1200,14 +1198,14 @@
"\n"
"ÙØµÙ:\n"
-#: ../lib/gis/parser.c:1033
+#: ../lib/gis/parser.c:1059
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
-#: ../lib/gis/parser.c:1037
+#: ../lib/gis/parser.c:1063
#, c-format
msgid ""
"\n"
@@ -1218,7 +1216,7 @@
"Ø§ÙØ¥Ø³ØªØ®Ø¯Ø§Ù
:\n"
-#: ../lib/gis/parser.c:1109
+#: ../lib/gis/parser.c:1135
#, c-format
msgid ""
"\n"
@@ -1227,19 +1225,19 @@
"\n"
"Ø¹ÙØ§Ù
ات:\n"
-#: ../lib/gis/parser.c:1132 ../lib/gis/parser.c:1588 ../lib/gis/parser.c:1866
+#: ../lib/gis/parser.c:1158 ../lib/gis/parser.c:1614 ../lib/gis/parser.c:1892
msgid "Allow output files to overwrite existing files"
msgstr ""
-#: ../lib/gis/parser.c:1134 ../lib/gis/parser.c:1592
+#: ../lib/gis/parser.c:1160 ../lib/gis/parser.c:1618
msgid "Verbose module output"
msgstr ""
-#: ../lib/gis/parser.c:1135 ../lib/gis/parser.c:1595
+#: ../lib/gis/parser.c:1161 ../lib/gis/parser.c:1621
msgid "Quiet module output"
msgstr ""
-#: ../lib/gis/parser.c:1141
+#: ../lib/gis/parser.c:1167
#, c-format
msgid ""
"\n"
@@ -1248,109 +1246,109 @@
"\n"
"Ø¥ØØ¯Ø§Ø«Ùات:\n"
-#: ../lib/gis/parser.c:1164
+#: ../lib/gis/parser.c:1190
#, c-format
msgid " %*s default: %s\n"
msgstr " %*s Ø§ÙØ£Ø³Ø§Ø³ Ø§ÙØÙÙØ¸: %s\n"
-#: ../lib/gis/parser.c:1471
+#: ../lib/gis/parser.c:1497
msgid "NAME"
msgstr ""
-#: ../lib/gis/parser.c:1484
+#: ../lib/gis/parser.c:1510
msgid "KEYWORDS"
msgstr ""
-#: ../lib/gis/parser.c:1489
+#: ../lib/gis/parser.c:1515
msgid "SYNOPSIS"
msgstr ""
-#: ../lib/gis/parser.c:1563
+#: ../lib/gis/parser.c:1589
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"Ø¹ÙØ§Ù
ات:\n"
-#: ../lib/gis/parser.c:1604
+#: ../lib/gis/parser.c:1630
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"Ø¥ØØ¯Ø§Ø«Ùات:\n"
-#: ../lib/gis/parser.c:1645
+#: ../lib/gis/parser.c:1671
msgid "Options"
msgstr ""
-#: ../lib/gis/parser.c:1651
+#: ../lib/gis/parser.c:1677
msgid "Default"
msgstr ""
-#: ../lib/gis/parser.c:1868
+#: ../lib/gis/parser.c:1894
msgid "Allow overwrite"
msgstr ""
-#: ../lib/gis/parser.c:1876
+#: ../lib/gis/parser.c:1902
msgid "Run with minimal output messages"
msgstr ""
-#: ../lib/gis/parser.c:1878
+#: ../lib/gis/parser.c:1904
msgid "Run quietly"
msgstr ""
-#: ../lib/gis/parser.c:1967
+#: ../lib/gis/parser.c:1993
#, c-format
msgid " %*s options: "
msgstr " %*s Ø®ÙØ§Ø±Ø§Øª:"
-#: ../lib/gis/parser.c:2016 ../lib/gis/parser.c:2033
+#: ../lib/gis/parser.c:2042 ../lib/gis/parser.c:2059
#, c-format
msgid "Sorry, <%c> is not a valid flag\n"
msgstr ""
-#: ../lib/gis/parser.c:2088
+#: ../lib/gis/parser.c:2114
#, c-format
msgid "Sorry, <%s=> is ambiguous\n"
msgstr ""
-#: ../lib/gis/parser.c:2095
+#: ../lib/gis/parser.c:2121
#, c-format
msgid "Sorry, <%s> is not a valid parameter\n"
msgstr ""
-#: ../lib/gis/parser.c:2180
+#: ../lib/gis/parser.c:2206
#, c-format
msgid ""
"\n"
"ERROR: illegal range syntax for parameter <%s>\n"
msgstr ""
-#: ../lib/gis/parser.c:2182
+#: ../lib/gis/parser.c:2208
#, c-format
msgid " Presented as: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2185
+#: ../lib/gis/parser.c:2211
#, c-format
msgid ""
"\n"
"ERROR: value <%s> out of range for parameter <%s>\n"
msgstr ""
-#: ../lib/gis/parser.c:2187
+#: ../lib/gis/parser.c:2213
#, c-format
msgid " Legal range: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2190
+#: ../lib/gis/parser.c:2216
#, c-format
msgid ""
"\n"
"ERROR: Missing value for parameter <%s>\n"
msgstr ""
-#: ../lib/gis/parser.c:2350
+#: ../lib/gis/parser.c:2376
#, c-format
msgid ""
"\n"
@@ -1358,82 +1356,82 @@
" (%s).\n"
msgstr ""
-#: ../lib/gis/parser.c:2453
+#: ../lib/gis/parser.c:2479
#, c-format
msgid ""
"\n"
"ERROR: option <%s> must be provided in multiples of %d\n"
msgstr ""
-#: ../lib/gis/parser.c:2455
+#: ../lib/gis/parser.c:2481
#, c-format
msgid " You provided %d items:\n"
msgstr ""
-#: ../lib/gis/parser.c:2510
+#: ../lib/gis/parser.c:2536
#, c-format
msgid "ERROR: option <%s>: <%s> exists.\n"
msgstr ""
-#: ../lib/gis/parser.c:2557
+#: ../lib/gis/parser.c:2583
#, c-format
msgid ""
"\n"
"FLAG: Set the following flag?\n"
msgstr ""
-#: ../lib/gis/parser.c:2571
+#: ../lib/gis/parser.c:2597
#, c-format
msgid ""
"\n"
"OPTION: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2572
+#: ../lib/gis/parser.c:2598
#, c-format
msgid " key: %s\n"
msgstr " chiave: %s\n"
-#: ../lib/gis/parser.c:2574
+#: ../lib/gis/parser.c:2600
#, c-format
msgid " format: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2576
+#: ../lib/gis/parser.c:2602
#, c-format
msgid " default: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2577
+#: ../lib/gis/parser.c:2603
#, c-format
msgid "required: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2579
+#: ../lib/gis/parser.c:2605
#, c-format
msgid "multiple: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2581
+#: ../lib/gis/parser.c:2607
#, c-format
msgid " options: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2596
+#: ../lib/gis/parser.c:2622
#, c-format
msgid "enter option > "
msgstr ""
-#: ../lib/gis/parser.c:2610 ../lib/gis/parser.c:2621
+#: ../lib/gis/parser.c:2636 ../lib/gis/parser.c:2647
msgid " Try again? "
msgstr ""
-#: ../lib/gis/parser.c:2619
+#: ../lib/gis/parser.c:2645
#, c-format
msgid "Sorry, %s is not accepted.\n"
msgstr ""
-#: ../lib/gis/parser.c:2630
+#: ../lib/gis/parser.c:2656
#, c-format
msgid ""
"\n"
@@ -1441,11 +1439,11 @@
" %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2631
+#: ../lib/gis/parser.c:2657
msgid "Is this correct? "
msgstr " ÙÙ ÙØ°Ø§ صØÙØØ"
-#: ../lib/gis/parser.c:2700
+#: ../lib/gis/parser.c:2726
msgid "to accept the default"
msgstr "ÙÙØ¨ÙÙ Ø§ÙØ£Ø³Ø§Ø³ اÙÙ
خزÙ"
@@ -2838,7 +2836,7 @@
msgid "Unable to open file %s"
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
-#: ../lib/vector/Vlib/build.c:27 ../lib/vector/Vlib/open.c:53
+#: ../lib/vector/Vlib/build.c:27 ../lib/vector/Vlib/open.c:32
#: ../lib/vector/Vlib/write.c:36
msgid "Requested format is not compiled in this version"
msgstr "Ø§ÙØ´Ù٠اÙÙ
Ø·ÙÙØ¨ ØºÙØ± Ù
ØªØ§Ø ÙÙ ÙØ°Ø§ Ø§ÙØ£ØµØ¯Ø§Ø±"
@@ -3006,6 +3004,59 @@
msgid "OGR feature without ID ignored."
msgstr ""
+#: ../lib/vector/Vlib/cats.c:45
+#, fuzzy
+msgid "Vect_new_cats_struct(): Out of memory"
+msgstr "ÙÙ
ÙÙ
Ù٠تÙÙÙØ± Ø°Ø§ÙØ±Ø©"
+#: ../lib/vector/Vlib/cats.c:138
+#, c-format
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:408
+#, c-format
+msgid "Unable to convert category string '%s' (from '%s') to category range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:30
+msgid "Category index is not up to date"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:62 ../lib/vector/Vlib/cindex.c:129
+#: ../lib/vector/Vlib/cindex.c:148 ../lib/vector/Vlib/cindex.c:171
+msgid "Invalid layer index (index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:110
+msgid "Invalid layer index (index < 0 or index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:235
+#, fuzzy
+msgid "Layer or category index out of range"
+msgstr "دÙÙÙ Ø§ÙØ®Ùاص اÙÙ
Ø¶Ø§Ø¹ÙØ© اÙÙÙÙ
Ø© خارج اÙÙØ·Ø§Ù"
+#: ../lib/vector/Vlib/cindex.c:283
+#, fuzzy
+msgid "Layer index out of range"
Ø¶Ø§Ø¹ÙØ© اÙÙÙÙ
Ø© خارج اÙÙØ·Ø§Ù"
+#: ../lib/vector/Vlib/cindex.c:456
+#, fuzzy, c-format
+msgid "Unable to open cidx file <%s> for write"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
+#: ../lib/vector/Vlib/cindex.c:464
+#, fuzzy, c-format
+msgid "Error writing out category index file <%s>"
+msgstr "خطا ÙÙ ÙØªØ§Ø¨Ø© Ø§ÙØ¯ÙÙ٠اÙÙØ±Ø§ØºÙ\n"
+#: ../lib/vector/Vlib/cindex.c:507
+#, fuzzy, c-format
+msgid "Unable to open category index file for vector map <%s@%s>"
+msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ø§ÙØªØ§Ø±ÙØ® ÙÙÙÙÙØªÙر"
#: ../lib/vector/Vlib/field.c:76
msgid "Field number must be 1 or greater."
msgstr "رÙÙ
Ø§ÙØÙÙ ÙØ¬Ø¨ ا٠ÙÙÙÙ 1 Ø§Ù Ø§ÙØ«Ø±"
@@ -3078,49 +3129,125 @@
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:23
-#, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'.\n"
+#: ../lib/vector/Vlib/legal_vname.c:39
+#, fuzzy, c-format
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
msgstr "ÙØ¬Ø¨ Ø£Ù ÙØ§ ÙØÙÙ ÙÙØ·Ø© Ø£Ù ÙÙÙ
Ø© Ù
عدÙÙ
Ø© <%s> اسÙ
Ù
ا٠ÙÙÙØªÙØ±Ù ØºÙØ± سÙÙÙ
\n"
-#: ../lib/vector/Vlib/legal_vname.c:29
-#, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter.\n"
+#: ../lib/vector/Vlib/legal_vname.c:45
+#, fuzzy, c-format
+msgid "Illegal vector map name <%s>. Must start with a letter."
msgstr " ÙØ¬Ø¨ Ø£Ù ÙØ¨Ø¯Ø£ Ø¨ØØ±Ù <%s> اسÙ
Ù
\n"
-#: ../lib/vector/Vlib/legal_vname.c:35
-#, c-format
-msgid "Illegal vector map name <%s>. Character <%c> not allowed.\n"
+#: ../lib/vector/Vlib/legal_vname.c:51
+#, fuzzy, c-format
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
msgstr ""
"ØºÙØ± ØµØ§ÙØ <%s> ØºÙØ± Ù
سÙ
ÙØ Ø¨ÙØ§ Ù Ø¨Ø§ÙØªØ§Ù٠اسÙ
اÙÙÙÙØªÙر اÙÙ
عط٠<%c> ØØ±ÙÙ Ù\n"
-#: ../lib/vector/Vlib/legal_vname.c:60 ../lib/vector/Vlib/legal_vname.c:62
-#, c-format
-msgid "Output name '%s' is not valid vector name."
+#: ../lib/vector/Vlib/legal_vname.c:81 ../lib/vector/Vlib/legal_vname.c:83
+#, fuzzy, c-format
+msgid "Output vector map name <%s> is not valid map name"
اÙÙ
Ù٠اÙÙÙÙØªÙر٠اÙÙ
خرج"
-#: ../lib/vector/Vlib/map.c:152 ../lib/vector/Vlib/map.c:268
-#: ../lib/vector/Vlib/open.c:526
-#, c-format
-msgid "Map name is not SQL compliant."
+#: ../lib/vector/Vlib/legal_vname.c:94 ../lib/vector/Vlib/legal_vname.c:96
+#: ../lib/vector/Vlib/map.c:302 ../lib/vector/Vlib/open.c:158
+#, fuzzy, c-format
+msgid "Vector map <%s> not found"
+msgstr "ØºÙØ± Ù
ÙØ¬Ùد'%s' اÙÙÙÙØªÙر"
+#: ../lib/vector/Vlib/legal_vname.c:114 ../lib/vector/Vlib/legal_vname.c:116
+#, fuzzy, c-format
+msgid "Output vector map <%s> is used as input"
+msgstr "Ù
ستخدÙ
ÙÙ
خرج"
+#: ../lib/vector/Vlib/map.c:62 ../lib/vector/Vlib/map.c:75
+#, fuzzy, c-format
+msgid "Unable to read vector map <%s%s>"
+msgstr " [%s] ØºÙØ± ÙØ§Ø¯Ø± عÙÙ Ø£ÙØ´Ø§Ø¡ Ù
Ù٠عÙÙØ§Ù Ø±Ø¦ÙØ³Ù Ù"
+#: ../lib/vector/Vlib/map.c:167 ../lib/vector/Vlib/map.c:290
+#: ../lib/vector/Vlib/open.c:508
+#, fuzzy, c-format
+msgid "Vector map name is not SQL compliant"
msgstr "SQL اسÙ
Ø§ÙØ®Ø±Ùطة ØºÙØ± Ù
ØªÙØ§ÙÙ Ù
ع ÙØ¸Ø§Ù
-#: ../lib/vector/Vlib/map.c:156 ../lib/vector/Vlib/map.c:272
-#: ../lib/vector/Vlib/open.c:533
-#, c-format
-msgid "The vector '%s' already exists and will be overwritten."
+#: ../lib/vector/Vlib/map.c:171 ../lib/vector/Vlib/map.c:294
+#: ../lib/vector/Vlib/open.c:515
+#, fuzzy, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
msgstr "Ù
ÙØ¬Ùد ÙÙØ§ÙÙ
Ù٠تغÙÙØ±Ù '%s' اÙÙÙÙØªÙر"
-#: ../lib/vector/Vlib/map.c:280
-#, c-format
-msgid "Input vector '%s' not found"
-msgstr "ØºÙØ± Ù
+#: ../lib/vector/Vlib/map.c:174 ../lib/vector/Vlib/open.c:519
+#, fuzzy, c-format
+msgid "Unable to delete vector map <%s>"
-#: ../lib/vector/Vlib/map.c:283
-#, c-format
-msgid "Cannot copy vector '%s' to '%s'"
+#: ../lib/vector/Vlib/map.c:197 ../lib/vector/Vlib/map.c:305
+#, fuzzy, c-format
+msgid "Unable to copy vector map <%s> to <%s>"
msgstr "'%s'اÙÙ '%s'ÙÙ
ÙÙ
ÙÙ ÙØ³Ø® ÙÙÙØªÙر"
+#: ../lib/vector/Vlib/map.c:225 ../lib/vector/Vlib/map.c:337
+#: ../lib/vector/Vlib/map.c:442 ../lib/vector/Vlib/map.c:551
+#: ../lib/vector/Vlib/map.c:642
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:239 ../lib/vector/Vlib/map.c:352
+#: ../lib/vector/Vlib/map.c:571 ../lib/vector/Vlib/map.c:668
+#, fuzzy, c-format
+msgid "Unable to copy table <%s>"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
+#: ../lib/vector/Vlib/map.c:247 ../lib/vector/Vlib/map.c:373
+#: ../lib/vector/Vlib/map.c:577
+#, fuzzy, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr "ÙÙ
ÙØªÙ
ÙØªØ§Ø¨Ø© Ø±ÙØ§Ø¨Ø· ÙØ§Ø¹Ø¯Ø© Ø§ÙØ¨ÙØ§ÙØ§Øª"
+#: ../lib/vector/Vlib/map.c:251 ../lib/vector/Vlib/map.c:377
+#: ../lib/vector/Vlib/map.c:581
+#, fuzzy, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr "[%s ÙÙ %s]ÙÙ
ÙÙ
ÙÙ Ø§ÙØ´Ø§Ø¡ Ù
ÙÙ Ø§ÙØ¹ÙÙØ§Ù Ø§ÙØ±Ø¦ÙسÙ"
+#: ../lib/vector/Vlib/map.c:366 ../lib/vector/Vlib/map.c:460
+#, fuzzy, c-format
+msgid "Unable to delete table <%s>"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
+#: ../lib/vector/Vlib/map.c:451
+#, fuzzy, c-format
+msgid "Unable to find table <%s> linked to vector map <%s>"
+msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
+#: ../lib/vector/Vlib/map.c:479
+#, fuzzy, c-format
+msgid "Unable to open directory '%s'"
+#: ../lib/vector/Vlib/map.c:490
+#, fuzzy, c-format
+msgid "Unable to delete file '%s'"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
+#: ../lib/vector/Vlib/map.c:507
+#, fuzzy, c-format
+msgid "Unable to rename directory '%s' to '%s'"
+#: ../lib/vector/Vlib/map.c:515
+#, fuzzy, c-format
+msgid "Unable to remove directory '%s'"
+#: ../lib/vector/Vlib/map.c:563 ../lib/vector/Vlib/map.c:656
+#, fuzzy, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
#: ../lib/vector/Vlib/net.c:120
#, fuzzy
msgid "Building graph ..."
@@ -3210,79 +3337,67 @@
msgid "Wrong line direction in Vect_net_get_line_cost()"
msgstr ""
-#: ../lib/vector/Vlib/open.c:114
-#, fuzzy
-msgid "Programmer requested unknown open_level"
-msgstr "ØªØØ°Ùر: اÙÙ
برÙ
ج Ø·ÙØ¨ Ù
ستÙÙ ØºÙØ± Ù
عرÙÙ\n"
-#: ../lib/vector/Vlib/open.c:179
+#: ../lib/vector/Vlib/open.c:93
#, fuzzy, c-format
-msgid "Vector map <%s> not found"
-msgstr "ØºÙØ± Ù
+msgid "Programmer requested unknown open level %d"
+msgstr "ØªØØ°Ùر: اÙÙ
برÙ
ج Ø·ÙØ¨ Ù
ستÙÙ ØºÙØ± Ù
عرÙÙ\n"
-#: ../lib/vector/Vlib/open.c:189
-msgid "A map which is not in the current mapset cannot be opened for update."
+#: ../lib/vector/Vlib/open.c:168
+#, fuzzy
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
msgstr "Ø§ÙØ®Ø±Ùطة ÙØ§ ÙÙ
ÙÙ ÙØªØÙا ÙÙØªØØ¯ÙØ«"
-#: ../lib/vector/Vlib/open.c:207
+#: ../lib/vector/Vlib/open.c:186
#, fuzzy, c-format
-msgid "Cannot open existing vector map <%s>"
-msgstr "%s ÙÙ
ÙÙ
ÙÙ Ù
ØÙ اÙÙÙÙØªÙر اÙÙ
ÙØ¬Ùد"
+msgid "Unable to open vector map <%s>"
-#: ../lib/vector/Vlib/open.c:217 ../lib/vector/Vlib/open.c:277
-#: ../lib/vector/Vlib/open.c:293
+#: ../lib/vector/Vlib/open.c:196 ../lib/vector/Vlib/open.c:256
+#: ../lib/vector/Vlib/open.c:273
#, fuzzy, c-format
-msgid "Cannot open existing vector <%s> on level [%d]"
+msgid "Unable to open vector map <%s> on topology level %d"
msgstr "%d عÙÙ Ù
ستÙÙ %s ÙÙ
ÙÙ
ÙÙ ÙØªØ ÙÙÙØªÙر ÙØ¯ÙÙ
-#: ../lib/vector/Vlib/open.c:218
+#: ../lib/vector/Vlib/open.c:197
#, fuzzy
-msgid "Cannot read head file"
+msgid "Unable to read head file"
msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ Ù
Ø¤ÙØª"
-#: ../lib/vector/Vlib/open.c:238
+#: ../lib/vector/Vlib/open.c:217
#, fuzzy, c-format
-msgid "Cannot open topo file for vector map <%s>"
+msgid "Unable to open topology file for vector map <%s>"
msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
-#: ../lib/vector/Vlib/open.c:261
+#: ../lib/vector/Vlib/open.c:240
#, fuzzy, c-format
-msgid "Cannot open category index file for vector map <%s>"
+msgid "Unable to open category index file for vector map <%s>"
msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
-#: ../lib/vector/Vlib/open.c:340
+#: ../lib/vector/Vlib/open.c:321 ../lib/vector/Vlib/open.c:542
#, fuzzy, c-format
-msgid "Cannot open history file for vector map <%s>"
+msgid "Unable to open history file for vector map <%s>"
msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
-#: ../lib/vector/Vlib/open.c:537
+#: ../lib/vector/Vlib/open.c:533
#, fuzzy, c-format
-msgid "Cannot delete existing vector <%s>"
-msgstr "%s ÙÙ
ÙÙ
ÙÙ Ù
ØÙ اÙÙÙÙØªÙر اÙÙ
ÙØ¬Ùد"
-#: ../lib/vector/Vlib/open.c:551
-#, c-format
-msgid "Cannot open new vector %s"
-msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
ÙÙ ÙÙÙØªÙØ±Ù Ø¬Ø¯ÙØ¯"
-#: ../lib/vector/Vlib/open.c:560
-#, c-format
-msgid "Cannot open history file for vector '%s'"
-msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
+msgid "Unable to create vector map <%s>"
-#: ../lib/vector/Vlib/open.c:608
-#, c-format
-msgid "Could not stat file '%s'"
-msgstr "'%s' ÙÙ
ÙÙ
Ù٠رصد Ø¨ÙØ§Ùات اÙÙ
ÙÙ"
+#: ../lib/vector/Vlib/open.c:590
+#, fuzzy, c-format
+msgid "Unable to stat file <%s>"
+msgstr "ÙÙ
ÙÙ
ÙÙ ÙØªØÙ %s ÙÙ %s"
-#: ../lib/vector/Vlib/open.c:719
-msgid "Size of 'coor' file differs from value saved in topo file."
+#: ../lib/vector/Vlib/open.c:701
+#, fuzzy
+msgid "Size of 'coor' file differs from value saved in topology file"
msgstr "ØØ¬Ù
Ù
ÙÙ Ø§ÙØ£ØØ¯Ø§Ø«Ùات Ù
ختÙ٠ع٠اÙÙÙÙ
اÙÙ
ØÙÙØ¸Ø© ÙÙ Ù
ÙÙ Ø§ÙØ·Ø¨ÙغراÙÙØ©"
-#: ../lib/vector/Vlib/open.c:730
-#, c-format
-msgid "Please rebuild topology for vector '%s@%s'"
-msgstr ""
+#: ../lib/vector/Vlib/open.c:712
+#, fuzzy, c-format
+msgid "Please rebuild topology for vector map <%s@%s>"
+msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
#: ../lib/vector/Vlib/read_nat.c:160
#, c-format
@@ -3303,37 +3418,37 @@
msgid "Cannot get feature geometry, FID [%ld]"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:139 ../lib/vector/Vlib/snap.c:179
+#: ../lib/vector/Vlib/snap.c:119 ../lib/vector/Vlib/snap.c:159
#, fuzzy
msgid "Registering points"
msgstr ":تسجÙÙ Ø§ÙØ®Ø·ÙØ·"
-#: ../lib/vector/Vlib/snap.c:188
+#: ../lib/vector/Vlib/snap.c:168
msgid "All vertices"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:189
+#: ../lib/vector/Vlib/snap.c:169
#, fuzzy
msgid "Registered points"
-#: ../lib/vector/Vlib/snap.c:234
+#: ../lib/vector/Vlib/snap.c:214
msgid "Nodes marked as anchor"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:235
+#: ../lib/vector/Vlib/snap.c:215
msgid "Nodes marked to be snapped"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:244 ../lib/vector/Vlib/snap.c:384
+#: ../lib/vector/Vlib/snap.c:224 ../lib/vector/Vlib/snap.c:364
msgid "Snaps"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:392
+#: ../lib/vector/Vlib/snap.c:372
msgid "Snapped vertices"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:393
+#: ../lib/vector/Vlib/snap.c:373
msgid "New vertices"
msgstr ""
@@ -3466,6 +3581,29 @@
"node = [%d] line = [%d]"
msgstr ""
+#~ msgid "Output name '%s' is not valid vector name."
+#~ msgstr "ØºÙØ± ØµØ§ÙØ '%s' اسÙ
اÙÙ
Ù٠اÙÙÙÙØªÙر٠اÙÙ
خرج"
+#~ msgid "Input vector '%s' not found"
+#~ msgstr "ØºÙØ± Ù
+#, fuzzy
+#~ msgid "Cannot open existing vector map <%s>"
+#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ Ù
ØÙ اÙÙÙÙØªÙر اÙÙ
ÙØ¬Ùد"
+#, fuzzy
+#~ msgid "Cannot delete existing vector <%s>"
+#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ Ù
ØÙ اÙÙÙÙØªÙر اÙÙ
ÙØ¬Ùد"
+#~ msgid "Cannot open new vector %s"
+#~ msgstr "%s ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
+#~ msgid "Cannot open history file for vector '%s'"
+#~ msgstr "'%s' ÙÙ
ÙÙ
ÙÙ ÙØªØ Ù
+#~ msgid "Could not stat file '%s'"
+#~ msgstr "'%s' ÙÙ
ÙÙ
Ù٠رصد Ø¨ÙØ§Ùات اÙÙ
ÙÙ"
#, fuzzy
#~ msgid "Can't open directory %s"
#~ msgstr "%s ÙÙ
ÙÙ
@@ -3709,9 +3847,6 @@
#~ msgid "No double attributes in site_list"
#~ msgstr "ÙØ§ ØªÙØ¬Ø¯ Ø®ÙØ§Øµ Ù
Ø¶Ø§Ø¹ÙØ© اÙÙÙÙ
Ø© ÙÙ ÙØ§Ø¦Ù
Ø© اÙÙ
ÙÙØ¹"
-#~ msgid "Double attribute index out of range"
-#~ msgstr "دÙÙÙ Ø§ÙØ®Ùاص اÙÙ
Ø¶Ø§Ø¹ÙØ© اÙÙÙÙ
Ø© خارج اÙÙØ·Ø§Ù"
#~ msgid "No string attributes in site_list"
#~ msgstr "ÙØ§ ØªÙØ¬Ø¯ Ø®ÙØ§Øµ زخرÙÙØ© ÙÙ ÙØ§Ø¦Ù
Ø© اÙÙ
ÙÙØ¹"
Index: grasslibs_cs.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_cs.po,v
retrieving revision 1.33
retrieving revision 1.33.2.1
diff -u -d -r1.33 -r1.33.2.1
--- grasslibs_cs.po 21 Sep 2007 22:12:43 -0000 1.33
+++ grasslibs_cs.po 23 Nov 2007 17:33:17 -0000 1.33.2.1
@@ -11,10 +11,10 @@
msgstr ""
"Project-Id-Version: grasslibs_cs\n"
-"PO-Revision-Date: 2007-08-31 16:02+0200\n"
+"PO-Revision-Date: 2007-10-26 10:57+0200\n"
"Last-Translator: Martin Landa <landa.martin gmail.com>\n"
-"Language-Team: Czech <translations at grass.itc.it>\n"
+"Language-Team: Czech <translations at lists.osgeo.org>\n"
[...1104 lines suppressed...]
-#~ msgstr "io chybové hlá¹ení uvedeno %d"
+#~ msgstr "io chybovÄÅ hlÄÄĹÄenÄ uvedeno %d"
#~ msgid "xdr stream for reading fp %p"
-#~ msgstr "xdr tok pro ètení hodnot s plovoucí desetinnou èárkou %p"
+#~ msgstr "xdr tok pro ÃÂtenÄÂ hodnot s plovoucÄÂ desetinnou ÃÂÄÄrkou %p"
#~ msgid "NULL_ROWS array[%d] = %p"
#~ msgstr "NULL_ROWS pole[%d] = %p"
#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "datový buffer pro ètení prázdných øádkù %p"
+#~ msgstr "datovÄË buffer pro ÃÂtenÄ prÄÄzdnÄËch ĹÂÄÄdkĹŻ %p"
#~ msgid "Minimum row null row number in memory %d"
-#~ msgstr "Minimální prázdný øádek v pamìti %d"
+#~ msgstr "MinimÄÄlnÄ prÄÄzdnÄË Ä¹ÂÄÄdek v pamÃÂti %d"
#~ msgid "Quant ptr = %p"
#~ msgstr "Quant ptr = %p"
Index: grasslibs_de.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_de.po,v
retrieving revision 1.53
retrieving revision 1.53.2.1
diff -u -d -r1.53 -r1.53.2.1
--- grasslibs_de.po 21 Sep 2007 22:12:43 -0000 1.53
+++ grasslibs_de.po 23 Nov 2007 17:33:17 -0000 1.53.2.1
@@ -9,10 +9,10 @@
msgstr ""
"Project-Id-Version: grasslibs_de\n"
"PO-Revision-Date: 2007-03-23 16:50+0100\n"
"Last-Translator: Stephan Holl <stephan.holl at intevation.de>\n"
-"Language-Team: deutsch <translations at grass.itc.it>\n"
+"Language-Team: deutsch <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=ISO-8859-15\n"
@@ -841,13 +841,11 @@
msgstr "Ausgabename '%s' ist kein erlaubter Rasterkartenname."
#, c-format
msgstr "Kann Eingabekarte '%s' nicht finden."
#, c-format
msgstr "Ergebniskarte '%s' ist gleichzeitig Eingabekarte."
@@ -1144,11 +1142,11 @@
msgstr "Name der Höhenrasterkarte(n)."
msgstr "Name der 3D Eingaberasterkarte."
msgstr "Name der 3D Eingaberasterkarte(n)."
@@ -1156,31 +1154,31 @@
msgstr "Name der 3D Ausgaberasterkarte."
msgstr "Name der Vektoreingabekarte."
msgstr "Name der Vektoreingabekarte(n)"
msgstr "Name der Vektorausgabekarte."
msgid "Type"
msgstr "Typ"
msgstr "Eigenschaften"
msgstr "Layer-Nummer"
msgid ""
@@ -1188,52 +1186,52 @@
"Eine Vektorkarte kann mit mehreren Attributdatenquellen verbunden werden."
"Diese Zahl gibt Auskunft über die zu benutzende Tabelle."
msgstr "Kategoriewert"
msgstr "Kategoriewerte"
msgstr "Beispiel: 1,3,7-9,13"
msgstr "Name der Eingabedatei"
msgstr "Name der Ausgabedatei"
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgstr "Tut mir leid, <%s> ist keine erlaubte Option\n"
#, c-format
msgid ""
"\n"
@@ -1242,7 +1240,7 @@
"\n"
"Beschreibung:\n"
#, c-format
msgid ""
"\n"
@@ -1251,7 +1249,7 @@
"\n"
"Schlüsselwörter:\n"
#, c-format
msgid ""
"\n"
@@ -1262,7 +1260,7 @@
"Benutzung:\n"
#, c-format
msgid ""
"\n"
@@ -1271,19 +1269,19 @@
"\n"
"Flags:\n"
msgstr "Ausgabedateien dürfen bereits existierende Dateien überschreiben."
msgstr "Gesprächige Modulausgabe (verbose)"
msgstr "Schweigsame Modulausgabe"
#, c-format
msgid ""
"\n"
@@ -1292,80 +1290,80 @@
"\n"
"Parameter:\n"
#, c-format
msgstr " %*s Standard: %s\n"
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"Flags:\n"
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"Parameter:\n"
#, fuzzy
msgid "Options"
msgstr " Optionen: %s\n"
#, fuzzy
msgid "Default"
msgstr " Standard: %s\n"
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
msgstr " %*s Optionen: "
#, c-format
msgstr "Tut mir leid, <%c> ist keine gültiges Flag\n"
#, c-format
msgstr "Tut mir leid, <%s=> ist nicht eindeutig\n"
#, c-format
msgstr "Tut mir leid, <%s> ist kein gültiger Parameter\n"
#, c-format
msgid ""
"\n"
@@ -1374,12 +1372,12 @@
"\n"
"Fehler: Ungültige Spannensyntax für den Parameter <%s>\n"
#, c-format
msgstr " Präsentiert als: %s\n"
#, c-format
msgid ""
"\n"
@@ -1388,12 +1386,12 @@
"\n"
"FEHLER: Wert <%s> ist außerhalb der Spanne von Parameter <%s>\n"
#, c-format
msgstr " Erlaubte Spanne: %s\n"
#, c-format
msgid ""
"\n"
@@ -1402,7 +1400,7 @@
"\n"
"FEHLER: Fehlender Wert für Parameter <%s>\n"
#, c-format
msgid ""
"\n"
@@ -1413,7 +1411,7 @@
"Fehler: Benötigter Parameter <%s> ist nicht gesetzt:\n"
" (%s).\n"
#, c-format
msgid ""
"\n"
@@ -1422,17 +1420,17 @@
"\n"
"FEHLER: Option <%s> muss als Vielfaches von %d angegeben werden\n"
#, c-format
msgstr " Sie haben %d Punkte angegeben:\n"
#, c-format
msgstr "FEHLER: Option <%s>: <%s> existiert bereits.\n"
#, c-format
msgid ""
"\n"
@@ -1441,7 +1439,7 @@
"\n"
"FLAG: Soll das folgende Flag gesetzt werden?\n"
#, c-format
msgid ""
"\n"
@@ -1450,51 +1448,51 @@
"\n"
"OPTION: %s\n"
#, c-format
msgid " key: %s\n"
msgstr " Key: %s\n"
#, c-format
msgstr " Format: %s\n"
#, c-format
#, c-format
msgstr "benötigt werden: %s\n"
#, c-format
msgstr "vielfach: %s\n"
#, c-format
#, c-format
msgstr "Geben Sie eine Option ein > "
msgstr " Nochmal versuchen? "
#, c-format
msgstr "Tut mir leid, %s wird nicht akzeptiert.\n"
#, c-format
msgid ""
"\n"
@@ -1505,11 +1503,11 @@
"Sie haben ausgewählt:\n"
" %s\n"
msgstr "Ist das richtig?"
msgstr "Zum Akzeptieren der Standardeinstellung"
@@ -3010,7 +3008,7 @@
msgstr "Kann Datei %s nicht öffnen."
msgstr "Das angeforderte Format ist in dieser Version nicht einkompiliert."
@@ -3180,6 +3178,59 @@
msgstr "OGR feature ohne ID ignoriert."
+#, fuzzy
+msgstr "G_calloc: Kein Speicher mehr da."
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Vektordimension außerhalb der Reichweite"
+#, fuzzy
+msgstr "Matrix-Dimensionen liegen außerhalb der Spanne."
+#, fuzzy, c-format
+msgstr "Kann %s nicht zum Beschreiben öffnen."
+#, fuzzy, c-format
+msgstr "Fehler beim Schreiben des spatial index aufgetreten"
+#, fuzzy, c-format
+msgstr "Kann den Kategorieindex der Vektorkarte <%s> nicht öffnen."
msgstr "Feldnummer muss 1 oder größer sein."
@@ -3257,52 +3308,128 @@
msgstr ""
"Fehler in Vect_segment_intersection() (collineare nicht vertikale Segmente)"
-#, c-format
+#, fuzzy, c-format
msgstr ""
"Ungültiger Name der Vektorkarte <%s>. Es dürfen nicht '.' oder 'NULL' "
"enthalten sein.\n"
-#, c-format
+#, fuzzy, c-format
msgstr ""
"Ungültiger Name der Vektorkarte <%s>. Sie muss mit einem Buchstaben "
"beginnen.\n"
-#, c-format
+#, fuzzy, c-format
msgstr ""
"Ungültiger Name der Vektorkarte <%s>. Zeichenfolge <%c> ist nicht erlaubt.\n"
-#, c-format
-msgstr "Ergebniskarte '%s' ist kein gültiger Vektorkartenname."
+#, fuzzy, c-format
+msgstr "Ausgabename '%s' ist kein erlaubter Rasterkartenname."
#, c-format
+msgstr "Eingabevektorkarte <%s> nicht gefunden."
+#, fuzzy, c-format
+msgstr "Ergebniskarte '%s' ist gleichzeitig Eingabekarte."
+#, fuzzy, c-format
+msgstr "Kann nicht zum Verzeichnis %s wechseln."
+#, fuzzy, c-format
msgstr "Kartenname ist nicht SQL-kompatibel."
-#, c-format
+#, fuzzy, c-format
msgstr "Die Vektorkarte '%s' existiert bereits und wird überschrieben."
-#, c-format
-msgstr "Eingabevektorkarte '%s' nicht gefunden."
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Kann Rasterkarte [%s in %s] nicht öffnen."
#, c-format
-msgstr "Kann Vektorkarte '%s' nicht zu '%s' kopieren."
+msgstr ""
+#, fuzzy, c-format
+msgstr "Kann Datei %s nicht öffnen."
+#, fuzzy, c-format
+msgstr "Kann Datenbank '%s' nicht öffnen."
+#, fuzzy, c-format
+msgstr "Kann Header-Datei für [%s in %s] nicht erstellen."
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Kann to topo-Datei der Vektorkarte <%s> nicht öffnen."
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
#, fuzzy
@@ -3392,79 +3519,69 @@
msgstr ""
+#, fuzzy, c-format
msgstr "Programmierer fordert unbekanntes open_level an"
-#, c-format
-msgstr "Eingabevektorkarte <%s> nicht gefunden."
+#, fuzzy
+msgid ""
msgstr ""
"Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht für eine "
"Aktualisierung geöffnet werden."
-#, c-format
-msgstr "Kann die existierende Vektordatei <%s> nicht öffnen."
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
msgstr "Kann die existierende Vektordatei <%s> nicht auf Level [%d] öffnen"
+#, fuzzy
msgstr "Kann Datei head nicht lesen"
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
msgstr "Kann die History-Datei für die Vektorkarte <%s> nicht öffnen."
-#, c-format
-msgstr "Kann die existierende Vektordatei <%s> nicht löschen."
-#, c-format
-msgstr "Kann neue Vektordatei '%s' nicht öffnen."
-#, c-format
-msgstr "Kann History-Datei für die Vektorkarte '%s' nicht öffnen."
+#, fuzzy, c-format
-#, c-format
-msgstr "Kann Datei '%s' nicht anfordern."
+#, fuzzy, c-format
+#, fuzzy
msgstr ""
"Größe der 'coor' Datei unterscheidet sich vom Werte in der 'topo' Datei."
-#, c-format
+#, fuzzy, c-format
msgstr "Bitte Topologie für Vektorkarte '%s@%s' neu erzeugen"
@@ -3486,37 +3603,37 @@
msgstr "Kann Objektgeometrie FID [%ld] nicht holen"
#, fuzzy
msgstr "Registriere Linien..."
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3649,6 +3766,30 @@
msgstr ""
"Versuch, den Winkel einer Linie ,die nicht an den Knoten angebunden ist, zu "
"lesen: Knoten = [%d], Linie = [%d]"
+#~ msgstr "Ergebniskarte '%s' ist kein gültiger Vektorkartenname."
+#~ msgstr "Eingabevektorkarte '%s' nicht gefunden."
+#~ msgid "Cannot copy vector '%s' to '%s'"
+#~ msgstr "Kann Vektorkarte '%s' nicht zu '%s' kopieren."
+#~ msgstr "Kann die existierende Vektordatei <%s> nicht öffnen."
+#~ msgstr "Kann die existierende Vektordatei <%s> nicht löschen."
+#~ msgstr "Kann neue Vektordatei '%s' nicht öffnen."
+#~ msgstr "Kann History-Datei für die Vektorkarte '%s' nicht öffnen."
+#~ msgstr "Kann Datei '%s' nicht anfordern."
#, fuzzy
Index: grasslibs_el.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_el.po,v
retrieving revision 1.7
retrieving revision 1.7.2.1
diff -u -d -r1.7 -r1.7.2.1
--- grasslibs_el.po 21 Sep 2007 22:12:43 -0000 1.7
+++ grasslibs_el.po 23 Nov 2007 17:33:17 -0000 1.7.2.1
@@ -8,10 +8,10 @@
msgstr ""
"Project-Id-Version: grasslibs_el\n"
"PO-Revision-Date: 2007-03-23 16:35+0100\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
-"Language-Team: Greek <translations at grass.itc.it>\n"
+"Language-Team: Greek <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=ISO-8859-7\n"
@@ -780,13 +780,11 @@
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
@@ -1066,11 +1064,11 @@
msgstr ""
msgstr ""
msgstr ""
@@ -1078,96 +1076,96 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Type"
msgstr ""
msgstr ""
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
"Description:\n"
msgstr ""
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1175,129 +1173,129 @@
msgstr ""
#, c-format
msgid ""
"\n"
"Flags:\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
"Parameters:\n"
msgstr ""
#, c-format
msgstr ""
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
msgid "Flags"
msgstr ""
msgid "Parameters"
msgstr ""
msgid "Options"
msgstr ""
msgid "Default"
msgstr ""
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1305,82 +1303,82 @@
" (%s).\n"
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgid ""
"\n"
"OPTION: %s\n"
msgstr ""
#, c-format
msgid " key: %s\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1388,11 +1386,11 @@
" %s\n"
msgstr ""
msgstr ""
msgstr ""
@@ -2763,7 +2761,7 @@
msgstr ""
msgstr ""
@@ -2927,6 +2925,56 @@
msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
msgstr ""
@@ -2998,46 +3046,122 @@
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
msgstr ""
@@ -3122,76 +3246,63 @@
msgstr ""
-msgstr ""
#, c-format
-msgstr ""
msgstr ""
-#, c-format
+msgid ""
msgstr ""
#, c-format
-msgstr ""
msgstr ""
#, c-format
msgstr ""
-#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
msgstr ""
#, c-format
msgstr ""
@@ -3213,35 +3324,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
Index: grasslibs_es.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_es.po,v
retrieving revision 1.65
retrieving revision 1.65.2.1
diff -u -d -r1.65 -r1.65.2.1
--- grasslibs_es.po 22 Oct 2007 15:54:23 -0000 1.65
+++ grasslibs_es.po 23 Nov 2007 17:33:17 -0000 1.65.2.1
@@ -14,10 +14,10 @@
msgstr ""
"Project-Id-Version: grasslibs_es\n"
-"POT-Creation-Date: 2007-10-22 17:52+0200\n"
"PO-Revision-Date: 2007-10-19 12:32+0200\n"
-"Language-Team: Español <translations at grass.itc.it>\n"
+"Language-Team: Español <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=ISO-8859-1\n"
@@ -3203,32 +3203,36 @@
msgstr "El índice de categorías no está actualizado"
-#: ../lib/vector/Vlib/cindex.c:62 ../lib/vector/Vlib/cindex.c:109
-#: ../lib/vector/Vlib/cindex.c:128 ../lib/vector/Vlib/cindex.c:147
-#: ../lib/vector/Vlib/cindex.c:170
msgstr "Índice de capa no válido (índice >= número de capas)"
-#: ../lib/vector/Vlib/cindex.c:234
+#, fuzzy
+msgstr "Índice de capa no válido (índice >= número de capas)"
msgstr "Índice de capa o de categoría fuera de intervalo"
-#: ../lib/vector/Vlib/cindex.c:282
msgstr "Índice de capa fuera del intervalo"
-#: ../lib/vector/Vlib/cindex.c:455
#, c-format
msgstr "No se puede abrir el archivo cidx <%s> para escritura"
-#: ../lib/vector/Vlib/cindex.c:463
#, c-format
msgstr "Error al escribir el archivo de índices de categoría <%s>"
-#: ../lib/vector/Vlib/cindex.c:506
#, c-format
msgstr ""
@@ -3621,35 +3625,35 @@
msgstr "No se puede adquirir la geometría, FID [%ld]"
msgstr "Registrando puntos: "
msgstr "Todos los vértices"
msgstr "Nodos marcados como fijos"
msgstr "Nodos marcados para eliminar"
msgid "Snaps"
msgstr ""
msgstr "Vértices eliminados"
msgstr "Nuevos vértices"
Index: grasslibs_fr.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_fr.po,v
retrieving revision 1.29
retrieving revision 1.29.2.1
diff -u -d -r1.29 -r1.29.2.1
--- grasslibs_fr.po 21 Sep 2007 22:12:44 -0000 1.29
+++ grasslibs_fr.po 23 Nov 2007 17:33:17 -0000 1.29.2.1
@@ -9,10 +9,10 @@
msgstr ""
"Project-Id-Version: grasslibs_fr\n"
"PO-Revision-Date: 2005-02-23 20:47-0500\n"
"Last-Translator: Eve\n"
-"Language-Team: French <translations at grass.itc.it>\n"
+"Language-Team: French <translations at lists.osgeo.org>\n"
@@ -842,13 +842,11 @@
msgstr "Le nom de sortie '%s' n'est pas un nom de vecteur valide."
#, c-format
msgstr "Impossible de trouver la couche d'entrée '%s'"
#, c-format
msgstr "La couche de sortie '%s' est utilisée en entrée"
@@ -1161,12 +1159,12 @@
msgstr "Nom de l'entrée raster"
#, fuzzy
#, fuzzy
@@ -1176,88 +1174,88 @@
msgstr "Nom de la sortie raster"
#, fuzzy
msgstr "Nom de l'entrée vecteur"
#, fuzzy
#, fuzzy
msgstr "Nom de la sortie vecteur"
msgid "Type"
msgstr "Type"
msgstr ""
msgstr "Numéro de la couche"
msgid ""
msgstr ""
msgstr "Valeur de la catégorie"
#, fuzzy
msgstr "Valeurs de la catégorie."
msgstr "Exemple: 1,3,7-9,13"
#, fuzzy
msgstr "Nom du fichier ouvert %s"
#, fuzzy
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgstr "Désolé, <%s> n'est pas une option valide\n"
#, c-format
msgid ""
"\n"
@@ -1266,14 +1264,14 @@
"\n"
"Description:\n"
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1284,7 +1282,7 @@
"Utilisation:\n"
#, c-format
msgid ""
"\n"
@@ -1293,19 +1291,19 @@
"\n"
"Drapeaux:\n"
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1314,80 +1312,80 @@
"\n"
"Paramètres:\n"
#, c-format
msgstr " %*s par défaut: %s\n"
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"Drapeaux:\n"
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"Paramètres:\n"
#, fuzzy
msgid "Options"
msgstr " options: %s\n"
#, fuzzy
msgid "Default"
msgstr " par défaut: %s\n"
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
msgstr " %*s options: "
#, c-format
msgstr "Désolé, <%c> n'est pas un drapeau valide\n"
#, c-format
msgstr "Désolé, <%s=> est ambigu\n"
#, c-format
msgstr "Désolé, <%s> n'est pas un paramètre valide\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1396,12 +1394,12 @@
"\n"
"Erreur: syntaxe de l'intervalle illégale pour le paramètre <%s>\n"
#, c-format
msgstr " Présenté comme: %s\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1410,12 +1408,12 @@
"\n"
"Erreur: valeur <%s> en dehors des limites pour le paramètre <%s>\n"
#, c-format
msgstr " Intervalle: %s\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1424,7 +1422,7 @@
"\n"
"Erreur: Valeur manquante pour le paramètre <%s>\n"
#, c-format
msgid ""
"\n"
@@ -1435,7 +1433,7 @@
"ERREUR: Le paramètre obligatoire <%s> n'a pas de valeur:\n"
" (%s).\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1444,17 +1442,17 @@
"\n"
"Erreur: l'option <%s> doit être un multiple de %d\n"
#, c-format
msgstr " Vous avez fourni %d éléments:\n"
#, fuzzy, c-format
msgstr "Erreur: option <%s>: <%s> existe.\n"
#, c-format
msgid ""
"\n"
@@ -1463,7 +1461,7 @@
"\n"
"DRAPEAU: Avez-vous placé ce drapeau?\n"
#, c-format
msgid ""
"\n"
@@ -1472,51 +1470,51 @@
"\n"
"OPTION: %s\n"
#, c-format
msgid " key: %s\n"
msgstr " clé: %s\n"
#, c-format
msgstr " format: %s\n"
#, c-format
#, c-format
msgstr "obligatoire: %s\n"
#, c-format
msgstr "multiple: %s\n"
#, c-format
#, c-format
msgstr "entrez une option > "
msgstr " Essayer à nouveau? "
#, c-format
msgstr "Désolé, %s n'est pas acceptée.\n"
#, c-format
msgid ""
"\n"
@@ -1527,11 +1525,11 @@
"Vous avez choisi:\n"
" %s\n"
msgstr "Est-ce correct? "
msgstr "pour accepter le choix par défaut"
@@ -2973,7 +2971,7 @@
msgstr "Impossible d'ouvrir le fichier %s dans %s"
msgstr "Le format demandé n'est pas compatible avec cette version"
@@ -3141,6 +3139,59 @@
msgstr "L'objet OGR sans ID a été ignoré"
+#, fuzzy
+msgstr "Allocation mémoire impossible"
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Index de l'attribut double en dehors des limites"
+#, fuzzy
+#, fuzzy, c-format
+msgstr "Impossible d'ouvrir %s en écriture"
+#, fuzzy, c-format
+msgstr "Erreur lors de l'écriture du fichier d'index spatial.\n"
+#, fuzzy, c-format
+msgstr "Impossible d'ouvrir le fichier d'historique pour le vecteur '%s'"
msgstr "Le champ doit être supérieur ou égal à 1."
@@ -3219,49 +3270,125 @@
msgstr ""
-#, c-format
+#, fuzzy, c-format
msgstr ""
"Nom de couche vecteur illégal <%s>. Ne doit contenir ni '.', ni 'NULL'.\n"
-#, c-format
+#, fuzzy, c-format
msgstr "Nom de couche vecteur illégal <%s>. Doit commencer par une lettre.\n"
-#, c-format
+#, fuzzy, c-format
msgstr ""
"Nom de couche vecteur illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
+msgstr "Le vecteur d'entrée '%s' n'a pas été trouvé"
+#, fuzzy, c-format
+msgstr "La couche de sortie '%s' est utilisée en entrée"
+#, fuzzy, c-format
+msgstr "impossible de changer de répertoire pour aller dans %s"
+#, fuzzy, c-format
msgstr "Le nom de la couche n'est pas compatible avec le SQL."
-#, c-format
+#, fuzzy, c-format
msgstr "Le vecteur '%s' existe déjà et va être écrasé."
-#, c-format
-msgstr "Le vecteur d'entrée '%s' n'a pas été trouvé"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "impossible d'ouvrir la couche raster |%s dans %s]"
#, c-format
-msgstr "Impossible de copier le vecteur '%s' vers '%s'"
+msgstr ""
+#, fuzzy, c-format
+msgstr "Impossible d'ouvrir le fichier %s dans %s"
+#, fuzzy, c-format
+msgstr "Impossible d'ouvrir la base de données %s"
+#, fuzzy, c-format
+msgstr "Impossible de créer l'en-tête de fichier pour [%s dans %s]"
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
#, fuzzy
@@ -3353,82 +3480,70 @@
msgstr ""
-#, fuzzy
-msgstr "Attention, Le programmeur a demandé un open_level inconnu\n"
#, fuzzy, c-format
+msgstr "Attention, Le programmeur a demandé un open_level inconnu\n"
+#, fuzzy
+msgid ""
msgstr ""
"Une couche qui n'est pas dans le jeu de données (mapset) courant ne peut pas "
"être ouverte en modification."
#, fuzzy, c-format
-msgstr "Impossible de supprimer le vecteur %s"
#, fuzzy, c-format
msgstr "Impossible d'ouvrir l'ancien vecteur %s au niveau %d"
#, fuzzy
msgstr "Impossible d'ouvrir le fichier temporaire"
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
-#, c-format
-msgstr "Impossible d'ouvrir le nouveau vecteur %s"
-#, c-format
-msgstr "Impossible d'ouvrir le fichier d'historique pour le vecteur '%s'"
-#, c-format
-msgstr "Impossible d'obtenir des informations sur le fichier '%s'"
+#, fuzzy, c-format
+#, fuzzy
msgstr ""
"La taille du fichier 'coord' est différente de la valeur sauvegardée dans le "
"fichier de topo."
-#, c-format
+#, fuzzy, c-format
msgstr "Veuillez reconstruire la topologie pour le vecteur '%s@%s'"
@@ -3451,37 +3566,37 @@
msgstr ""
#, fuzzy
msgstr "Enregistrement des lignes: "
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3618,6 +3733,32 @@
msgstr ""
+#~ msgstr "Le nom de sortie '%s' n'est pas un nom de vecteur valide."
+#~ msgstr "Le vecteur d'entrée '%s' n'a pas été trouvé"
+#~ msgstr "Impossible de copier le vecteur '%s' vers '%s'"
+#, fuzzy
+#~ msgstr "Impossible de supprimer le vecteur %s"
+#, fuzzy
+#~ msgstr "Impossible d'ouvrir le nouveau vecteur %s"
+#~ msgstr "Impossible d'ouvrir le fichier d'historique pour le vecteur '%s'"
+#~ msgstr "Impossible d'obtenir des informations sur le fichier '%s'"
#, fuzzy
#~ msgstr "Impossible d'ouvrir l'ancien vecteur %s"
@@ -3849,9 +3990,6 @@
#~ msgstr "Aucun attribut double dans site_list"
-#~ msgstr "Index de l'attribut double en dehors des limites"
#~ msgstr "Pas d'attribut chaîne de caractère dans site_list"
Index: grasslibs_hi.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_hi.po,v
retrieving revision 1.17
retrieving revision 1.17.2.1
diff -u -d -r1.17 -r1.17.2.1
--- grasslibs_hi.po 21 Sep 2007 22:12:44 -0000 1.17
+++ grasslibs_hi.po 23 Nov 2007 17:33:17 -0000 1.17.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasslibs_hi\n"
"PO-Revision-Date: 2005-12-22 14:34+0100\n"
"Last-Translator: Markus Neteler <neteler at itc.it>\n"
-"Language-Team: Hindi <translations at grass.itc.it>\n"
+"Language-Team: Hindi <translations at lists.osgeo.org>\n"
@@ -798,13 +798,11 @@
msgstr "हॠनहà¥à¤."
#, c-format
msgstr ""
#, fuzzy, c-format
msgstr "हà¥"
@@ -1102,12 +1100,12 @@
msgstr "à¤à¤¾"
#, fuzzy
msgstr "à¤à¤¾"
#, fuzzy
msgstr "à¤à¤¾"
@@ -1117,103 +1115,103 @@
msgstr "à¤à¤¾"
#, fuzzy
msgstr "à¤à¤¾"
#, fuzzy
msgstr "à¤à¤¾"
#, fuzzy
msgstr "à¤à¤¾"
msgid "Type"
msgstr ""
msgstr ""
#, fuzzy
msgstr "सà¤à¤à¥à¤¯à¤¾"
msgid ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "13"
#, fuzzy
msgstr "à¤à¤¾"
#, fuzzy
msgstr "à¤à¤¾"
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy, c-format
msgstr "à¤à¥à¤¦ हॠहॠनहà¥à¤ a n"
#, fuzzy, c-format
msgid ""
"\n"
"Description:\n"
msgstr "n"
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, fuzzy, c-format
msgid ""
"\n"
@@ -1221,133 +1219,133 @@
msgstr "n "
#, fuzzy, c-format
msgid ""
"\n"
"Flags:\n"
msgstr "n"
msgstr ""
msgstr ""
msgstr ""
#, fuzzy, c-format
msgid ""
"\n"
"Parameters:\n"
msgstr "n"
#, fuzzy, c-format
msgstr "n"
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
#, fuzzy
msgid "Flags"
msgstr "n"
#, fuzzy
msgid "Parameters"
msgstr "n"
#, fuzzy
msgid "Options"
msgstr "n"
#, fuzzy
msgid "Default"
msgstr "n"
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
msgstr ""
#, fuzzy, c-format
#, fuzzy, c-format
msgstr "à¤à¥à¤¦ हॠहॠn"
#, fuzzy, c-format
#, fuzzy, c-format
msgid ""
"\n"
msgstr "à¤à¥ लिठn"
#, fuzzy, c-format
msgstr "n"
#, fuzzy, c-format
msgid ""
"\n"
msgstr "à¤à¤¾ à¤à¥ लिठn"
#, fuzzy, c-format
msgstr "n"
#, fuzzy, c-format
msgid ""
"\n"
msgstr "à¤à¥à¤®à¤¾ à¤à¥ लिठn"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1357,83 +1355,83 @@
"नहà¥à¤ सà¥à¤\n"
" n"
#, fuzzy, c-format
msgid ""
"\n"
msgstr "à¤à¤¾ n"
#, fuzzy, c-format
msgstr "n"
#, fuzzy, c-format
msgstr "तà¥à¤°à¥à¤à¤¿ n"
#, fuzzy, c-format
msgid ""
"\n"
msgstr "सà¥à¤ n"
#, fuzzy, c-format
msgid ""
"\n"
"OPTION: %s\n"
msgstr "n"
#, fuzzy, c-format
msgid " key: %s\n"
msgstr "n"
#, fuzzy, c-format
msgstr "n"
#, fuzzy, c-format
msgstr "n"
#, fuzzy, c-format
msgstr "n"
#, fuzzy, c-format
msgstr "n"
#, fuzzy, c-format
msgstr "n"
#, c-format
msgstr ""
#, fuzzy
msgstr "à¤à¥à¤¶à¤¿à¤¶ à¤à¤°à¥à¤ "
#, fuzzy, c-format
msgstr "à¤à¥à¤¦ हॠहॠनहà¥à¤ n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1443,12 +1441,12 @@
"\n"
" n"
#, fuzzy
msgstr "हॠ"
msgstr ""
@@ -2879,7 +2877,7 @@
msgstr "à¤à¤¾"
#, fuzzy
@@ -3052,6 +3050,58 @@
msgstr "विशà¥à¤·à¤¤à¤¾."
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "दà¥à¤à¥à¤¨à¤¾ à¤à¤¾"
+#, fuzzy
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
+#, fuzzy, c-format
+msgstr "तà¥à¤°à¥à¤à¤¿ n"
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
#, fuzzy
@@ -3130,48 +3180,124 @@
msgstr ""
#, fuzzy, c-format
msgstr "नहà¥à¤ रà¤à¥ हà¥à¤ n"
#, fuzzy, c-format
msgstr "पà¥à¤°à¤¾à¤°à¤à¤ a n"
#, fuzzy, c-format
msgstr "नहà¥à¤ n"
#, fuzzy, c-format
msgstr "हॠनहà¥à¤."
#, fuzzy, c-format
+msgstr "नहà¥à¤"
+#, fuzzy, c-format
+msgstr "हà¥"
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
+#, fuzzy, c-format
msgstr "हॠनहà¥à¤."
#, c-format
msgstr ""
#, fuzzy, c-format
-msgstr "नहà¥à¤"
+msgstr "à¤à¥ लिà¤"
#, fuzzy, c-format
msgstr "नà¤à¤¼à¤²"
+#, c-format
+msgstr ""
+#, fuzzy, c-format
+msgstr "à¤à¤¾"
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
+#, fuzzy, c-format
+msgstr "à¤à¤¾"
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
+#, fuzzy, c-format
+msgstr "à¤à¤¾"
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
+#, fuzzy, c-format
+msgstr "à¤à¥ लिà¤"
#, fuzzy
@@ -3259,80 +3385,66 @@
msgstr ""
-#, fuzzy
-msgstr "à¤à¥à¤¤à¤¾à¤µà¤¨à¥ n"
#, fuzzy, c-format
-msgstr "नहà¥à¤"
+msgstr "à¤à¥à¤¤à¤¾à¤µà¤¨à¥ n"
#, fuzzy
+msgid ""
msgstr "हॠनहà¥à¤ à¤à¥ लिà¤."
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
#, fuzzy, c-format
msgstr "à¤à¤¾à¤²à¥"
#, fuzzy
msgstr "à¤à¥ लिठn"
-#, fuzzy, c-format
-msgstr "à¤à¥ लिà¤"
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
-#, c-format
-msgstr ""
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
#, fuzzy, c-format
-msgstr "नहà¥à¤"
+msgstr "à¤à¤¾"
#, fuzzy
msgstr "à¤à¤¾."
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
@@ -3355,35 +3467,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3521,6 +3633,30 @@
msgstr ""
#, fuzzy
+#~ msgstr "हॠनहà¥à¤."
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
+#~ msgstr "à¤à¥ लिà¤"
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr "नहà¥à¤"
+#, fuzzy
@@ -3705,10 +3841,6 @@
#, fuzzy
#~ msgstr "नहà¥à¤"
-#, fuzzy
-#~ msgstr "दà¥à¤à¥à¤¨à¤¾ à¤à¤¾"
#, fuzzy
Index: grasslibs_it.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_it.po,v
--- grasslibs_it.po 21 Sep 2007 22:12:44 -0000 1.29
+++ grasslibs_it.po 23 Nov 2007 17:33:17 -0000 1.29.2.1
@@ -1,19 +1,20 @@
-# translation of grassmods_it.po to Italian
+# translation of grasslibs_it.po to Italian
-# Copyright (C) 2005, 2006 GRASS Development Team
+# Copyright (C) 2005, 2006, 2007 GRASS Development Team
# Maurizio Napolitano <napo at itc.it>, 2005.
# Markus Neteler <neteler at itc.it>, 2005.
# Luciano Montanaro <mikelima at cirulla.net>, 2006.
# Giuseppe Patti <gpatt at tiscali.it>, 2006.
+# Tobias Vigl <vigltobias at icqmail.com>, 2007.
[...2302 lines suppressed...]
#~ msgid "open mode = %d"
#~ msgstr "modalità di apertura = %d"
#~ msgid "Cell header %p"
#~ msgstr "Intestazione cella %p"
@@ -3759,12 +3920,10 @@
#, fuzzy
#~ msgid "Not able to open cellfile for [%s]"
#~ msgstr "Impossibile aprire il file %s in %s"
#~ msgid "Too many open raster maps"
#~ msgstr "Troppi file raster aperti"
#~ msgid "Too many open files"
#~ msgstr "Troppi file aperti"
#~ msgid "ERROR: GISBASE not set\n"
#~ msgstr "ERRORE: GISBASE non definito\n"
Index: grasslibs_ja.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_ja.po,v
retrieving revision 1.27
retrieving revision 1.27.2.1
diff -u -d -r1.27 -r1.27.2.1
--- grasslibs_ja.po 21 Sep 2007 22:12:44 -0000 1.27
+++ grasslibs_ja.po 23 Nov 2007 17:33:17 -0000 1.27.2.1
@@ -8,10 +8,10 @@
msgstr ""
"Project-Id-Version: grasslibs_ja\n"
"PO-Revision-Date: 2005-12-30 17:41+0100\n"
-"Language-Team: Japanese <translations at grass.itc.it>\n"
+"Language-Team: Japanese <translations at lists.osgeo.org>\n"
@@ -783,13 +783,11 @@
msgstr "���."
#, c-format
msgstr ""
#, c-format
msgstr ""
@@ -1077,12 +1075,12 @@
msgstr "���"
#, fuzzy
msgstr "���"
#, fuzzy
msgstr "���"
@@ -1092,87 +1090,87 @@
msgstr "���"
#, fuzzy
msgstr "���"
#, fuzzy
msgstr "���"
#, fuzzy
msgstr "���"
msgid "Type"
msgstr ""
msgstr ""
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "���"
#, fuzzy
msgstr "���"
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgstr ""
#, fuzzy, c-format
msgid ""
"\n"
@@ -1181,14 +1179,14 @@
"\n"
"説æ:\n"
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, fuzzy, c-format
msgid ""
"\n"
@@ -1199,7 +1197,7 @@
"ä½¿ãæ¹:\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1208,19 +1206,19 @@
"\n"
"ãã©ã°:\n"
msgstr ""
msgstr ""
msgstr ""
#, fuzzy, c-format
msgid ""
"\n"
@@ -1229,109 +1227,109 @@
"\n"
"ãã©ã¡ã¼ã¿:\n"
#, fuzzy, c-format
msgstr " %*s ããã©ã«ã: %s\n"
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"ãã©ã°:\n"
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"ãã©ã¡ã¼ã¿:\n"
msgid "Options"
msgstr ""
msgid "Default"
msgstr ""
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, fuzzy, c-format
msgstr " %*s ãªãã·ã§ã³: "
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1339,82 +1337,82 @@
" (%s).\n"
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgid ""
"\n"
"OPTION: %s\n"
msgstr ""
#, c-format
msgid " key: %s\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1422,11 +1420,11 @@
" %s\n"
msgstr ""
msgstr ""
msgstr ""
@@ -2828,7 +2826,7 @@
msgstr "���"
msgstr ""
@@ -2992,6 +2990,56 @@
msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy, c-format
+msgstr "���"
+#, fuzzy, c-format
+msgstr "���"
+#, fuzzy, c-format
+msgstr "���"
msgstr ""
@@ -3063,46 +3111,122 @@
msgstr ""
#, fuzzy, c-format
msgstr "���"
#, fuzzy, c-format
msgstr "���"
#, fuzzy, c-format
msgstr "���"
#, fuzzy, c-format
msgstr "���."
+#, fuzzy, c-format
+msgstr "���"
#, c-format
msgstr ""
#, fuzzy, c-format
+msgstr "����� ���� ���\n"
+#, fuzzy, c-format
+msgstr "���"
+#, fuzzy, c-format
msgstr "���."
#, fuzzy, c-format
+#, fuzzy, c-format
msgstr "���"
+#, c-format
+msgstr ""
#, fuzzy, c-format
+msgstr "���"
+#, fuzzy, c-format
+msgstr "���"
+#, fuzzy, c-format
+msgstr "�������: ����� �����������n"
+#, fuzzy, c-format
+msgstr "���"
+#, fuzzy, c-format
+msgstr "���"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "���"
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
msgstr "���"
@@ -3190,77 +3314,64 @@
msgstr ""
+#, c-format
msgstr ""
-#, fuzzy, c-format
-msgstr "���"
+msgid ""
msgstr ""
#, fuzzy, c-format
-msgstr "���"
#, fuzzy, c-format
msgstr "���"
#, fuzzy
-msgstr "���"
-#, fuzzy, c-format
msgstr "���"
#, fuzzy, c-format
msgstr "���"
#, fuzzy, c-format
msgstr "���"
#, fuzzy, c-format
msgstr "���"
#, fuzzy, c-format
-msgstr "���"
#, fuzzy, c-format
msgstr "���"
-#, c-format
-msgstr ""
msgstr ""
#, fuzzy, c-format
msgstr "���"
@@ -3282,35 +3393,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3441,6 +3552,30 @@
"Attempt to read line angle for the line which is not connected to the node: "
msgstr ""
+#, fuzzy
+#~ msgstr "���."
+#, fuzzy
+#~ msgstr "���"
+#, fuzzy
+#~ msgstr "���"
+#, fuzzy
+#~ msgstr "���"
+#, fuzzy
+#~ msgstr "���"
+#, fuzzy
+#~ msgstr "���"
#, fuzzy
Index: grasslibs_ko.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_ko.po,v
retrieving revision 1.18
retrieving revision 1.18.2.1
diff -u -d -r1.18 -r1.18.2.1
--- grasslibs_ko.po 21 Sep 2007 22:12:44 -0000 1.18
+++ grasslibs_ko.po 23 Nov 2007 17:33:17 -0000 1.18.2.1
@@ -8,10 +8,10 @@
msgstr ""
"Project-Id-Version: grasslibs_ko\n"
"PO-Revision-Date: 2005-12-22 14:49+0100\n"
"Last-Translator: Huidae Cho\n"
-"Language-Team: Korean <translations at grass.itc.it>\n"
+"Language-Team: Korean <translations at lists.osgeo.org>\n"
@@ -793,13 +793,11 @@
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
@@ -1079,11 +1077,11 @@
msgstr ""
msgstr ""
msgstr ""
@@ -1091,96 +1089,96 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Type"
msgstr ""
msgstr ""
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
"Description:\n"
msgstr ""
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1188,129 +1186,129 @@
msgstr ""
#, c-format
msgid ""
"\n"
"Flags:\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
"Parameters:\n"
msgstr ""
#, c-format
msgstr ""
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
msgid "Flags"
msgstr ""
msgid "Parameters"
msgstr ""
msgid "Options"
msgstr ""
msgid "Default"
msgstr ""
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1318,82 +1316,82 @@
" (%s).\n"
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgid ""
"\n"
"OPTION: %s\n"
msgstr ""
#, c-format
msgid " key: %s\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1401,11 +1399,11 @@
" %s\n"
msgstr ""
msgstr ""
msgstr ""
@@ -2777,7 +2775,7 @@
msgstr "Datum %s í
ì´ë¸íì¼ì ì´ ì ììµëë¤"
msgstr ""
@@ -2941,6 +2939,56 @@
msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy, c-format
+msgstr "Datum %s í
+#, fuzzy, c-format
+msgstr "ììíì¼ì ì´ ì ììµëë¤"
+#, fuzzy, c-format
msgstr ""
@@ -3012,48 +3060,124 @@
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
+#, fuzzy, c-format
+msgstr "Datum %s í
#, c-format
msgstr ""
#, c-format
+msgstr ""
+#, fuzzy, c-format
+msgstr "Datum %s í
+#, fuzzy, c-format
+msgstr "Datum %s í
+#, c-format
+msgstr ""
+#, fuzzy, c-format
+msgstr "Datum %s í
+#, fuzzy, c-format
+msgstr "'%s' ëë²ê·¸íì¼ì ì´ ì ììµëë¤"
+#, c-format
msgstr ""
+#, fuzzy, c-format
+msgstr "Datum %s í
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Datum %s í
+#, fuzzy, c-format
+msgstr "Datum %s í
+#, fuzzy, c-format
+msgstr "Datum %s í
+#, fuzzy, c-format
+msgstr "Datum %s í
+#, fuzzy, c-format
msgstr ""
@@ -3138,78 +3262,65 @@
msgstr ""
-msgstr ""
#, c-format
msgstr ""
+msgid ""
msgstr ""
#, fuzzy, c-format
-msgstr "'%s' ëë²ê·¸íì¼ì ì´ ì ììµëë¤"
+msgstr "Datum %s í
#, c-format
msgstr ""
#, fuzzy
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "Datum %s í
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+msgstr "Datum %s í
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -3230,35 +3341,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3388,6 +3499,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "'%s' ëë²ê·¸íì¼ì ì´ ì ììµëë¤"
#, fuzzy
Index: grasslibs_lv.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_lv.po,v
retrieving revision 1.16
retrieving revision 1.16.2.1
diff -u -d -r1.16 -r1.16.2.1
--- grasslibs_lv.po 21 Sep 2007 22:12:44 -0000 1.16
+++ grasslibs_lv.po 23 Nov 2007 17:33:17 -0000 1.16.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasslibs_lv\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2007-09-22 00:09+0200\n"
+"POT-Creation-Date: 2007-10-26 21:10+0200\n"
"PO-Revision-Date: 2006-12-09 01:00+0200\n"
"Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
-"Language-Team: Latvian <translations at grass.itc.it>\n"
+"Language-Team: Latvian <translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
@@ -822,13 +822,11 @@
msgstr "Izejas vÄrds '%s' nav derÄ«gs rastra nosaukums."
#: ../lib/gis/legal_name.c:88 ../lib/gis/legal_name.c:90
-#: ../lib/vector/Vlib/legal_vname.c:73 ../lib/vector/Vlib/legal_vname.c:75
#, c-format
msgid "Cannot find input map '%s'"
msgstr "Nevar atrast ieejas karti '%s'"
#: ../lib/gis/legal_name.c:109 ../lib/gis/legal_name.c:111
-#: ../lib/vector/Vlib/legal_vname.c:93 ../lib/vector/Vlib/legal_vname.c:95
#, c-format
msgid "Output map '%s' is used as input"
msgstr "Izejas karte '%s' tiek lietota kÄ iejas karte"
@@ -1125,11 +1123,11 @@
msgid "Name of elevation raster map(s)"
msgstr "Reljefa rastra faila(u) nosaukums(i)"
-#: ../lib/gis/parser.c:480
+#: ../lib/gis/parser.c:480 ../lib/gis/parser.c:505
msgid "Name of input raster3d map"
msgstr "Ieejas 3drastra faila nosaukums"
-#: ../lib/gis/parser.c:489
+#: ../lib/gis/parser.c:489 ../lib/gis/parser.c:514
msgid "Name of input raster3d map(s)"
msgstr "Ieejas 3drastra faila nosaukums(i)"
@@ -1137,85 +1135,85 @@
msgid "Name for output raster3d map"
msgstr "Izejas 3drastra faila nosaukums"
-#: ../lib/gis/parser.c:507 ../lib/gis/parser.c:532
+#: ../lib/gis/parser.c:524 ../lib/gis/parser.c:549
msgid "Name of input vector map"
msgstr "Ieejas vektorkartes nosaukums"
-#: ../lib/gis/parser.c:516
+#: ../lib/gis/parser.c:533 ../lib/gis/parser.c:558
#, fuzzy
msgid "Name of input vector map(s)"
-#: ../lib/gis/parser.c:524
+#: ../lib/gis/parser.c:541
msgid "Name for output vector map"
msgstr "Izejas vektorkartes nosaukums"
-#: ../lib/gis/parser.c:541
+#: ../lib/gis/parser.c:567
msgid "Type"
msgstr "Tips"
-#: ../lib/gis/parser.c:542
+#: ../lib/gis/parser.c:568
msgid "Feature type(s)"
msgstr ""
-#: ../lib/gis/parser.c:549
+#: ../lib/gis/parser.c:575
msgid "Layer number"
msgstr "LÄ«meÅa numurs"
-#: ../lib/gis/parser.c:550
+#: ../lib/gis/parser.c:576
msgid ""
"A single vector map can be connected to multiple database tables. This "
"number determines which table to use."
msgstr ""
-#: ../lib/gis/parser.c:557
+#: ../lib/gis/parser.c:583
msgid "Category value"
msgstr "Kategorijas vÄrtÄ«ba"
-#: ../lib/gis/parser.c:564
+#: ../lib/gis/parser.c:590
msgid "Category values"
msgstr "Kategoriju vÄrtÄ«bas"
-#: ../lib/gis/parser.c:565
+#: ../lib/gis/parser.c:591
msgid "Example: 1,3,7-9,13"
msgstr "PiemÄram: 1,3,7-9,13"
-#: ../lib/gis/parser.c:575
+#: ../lib/gis/parser.c:601
#, fuzzy
msgid "Name of input file"
msgstr "AtvÄrtÄ faila nosaukums %s"
-#: ../lib/gis/parser.c:583
+#: ../lib/gis/parser.c:609
#, fuzzy
msgid "Name for output file"
msgstr "Izvades rastra faila nosaukums"
-#: ../lib/gis/parser.c:591
+#: ../lib/gis/parser.c:617
msgid "Field separator"
msgstr ""
-#: ../lib/gis/parser.c:602
+#: ../lib/gis/parser.c:628
msgid "Color"
msgstr ""
-#: ../lib/gis/parser.c:603
+#: ../lib/gis/parser.c:629
msgid "Either a standard color name or R:G:B triplet"
msgstr ""
-#: ../lib/gis/parser.c:612
+#: ../lib/gis/parser.c:638
msgid "Background color"
msgstr ""
-#: ../lib/gis/parser.c:613
+#: ../lib/gis/parser.c:639
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
msgstr ""
-#: ../lib/gis/parser.c:915
+#: ../lib/gis/parser.c:941
#, c-format
msgid "Sorry <%s> is not a valid option\n"
msgstr "Atvainojiet, <%s> ir nedrīgs parametrs\n"
-#: ../lib/gis/parser.c:1026
+#: ../lib/gis/parser.c:1052
#, c-format
msgid ""
"\n"
@@ -1224,7 +1222,7 @@
"\n"
"Apraksts:\n"
-#: ../lib/gis/parser.c:1033
+#: ../lib/gis/parser.c:1059
#, c-format
msgid ""
"\n"
@@ -1233,7 +1231,7 @@
"\n"
"AtslÄgvÄrdi:\n"
-#: ../lib/gis/parser.c:1037
+#: ../lib/gis/parser.c:1063
#, c-format
msgid ""
"\n"
@@ -1244,7 +1242,7 @@
"Pieleitojums:\n"
-#: ../lib/gis/parser.c:1109
+#: ../lib/gis/parser.c:1135
#, c-format
msgid ""
"\n"
@@ -1253,19 +1251,19 @@
"\n"
"Karogi:\n"
-#: ../lib/gis/parser.c:1132 ../lib/gis/parser.c:1588 ../lib/gis/parser.c:1866
+#: ../lib/gis/parser.c:1158 ../lib/gis/parser.c:1614 ../lib/gis/parser.c:1892
msgid "Allow output files to overwrite existing files"
msgstr ""
-#: ../lib/gis/parser.c:1134 ../lib/gis/parser.c:1592
+#: ../lib/gis/parser.c:1160 ../lib/gis/parser.c:1618
msgid "Verbose module output"
msgstr ""
-#: ../lib/gis/parser.c:1135 ../lib/gis/parser.c:1595
+#: ../lib/gis/parser.c:1161 ../lib/gis/parser.c:1621
msgid "Quiet module output"
msgstr ""
-#: ../lib/gis/parser.c:1141
+#: ../lib/gis/parser.c:1167
#, c-format
msgid ""
"\n"
@@ -1274,80 +1272,80 @@
"\n"
"Parametri:\n"
-#: ../lib/gis/parser.c:1164
+#: ../lib/gis/parser.c:1190
#, c-format
msgid " %*s default: %s\n"
msgstr " %*s noklusÄtais: %s\n"
-#: ../lib/gis/parser.c:1471
+#: ../lib/gis/parser.c:1497
msgid "NAME"
msgstr ""
-#: ../lib/gis/parser.c:1484
+#: ../lib/gis/parser.c:1510
msgid "KEYWORDS"
msgstr ""
-#: ../lib/gis/parser.c:1489
+#: ../lib/gis/parser.c:1515
msgid "SYNOPSIS"
msgstr ""
-#: ../lib/gis/parser.c:1563
+#: ../lib/gis/parser.c:1589
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"Karogi:\n"
-#: ../lib/gis/parser.c:1604
+#: ../lib/gis/parser.c:1630
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"Parametri:\n"
-#: ../lib/gis/parser.c:1645
+#: ../lib/gis/parser.c:1671
#, fuzzy
msgid "Options"
msgstr " opcijas: %s\n"
-#: ../lib/gis/parser.c:1651
+#: ../lib/gis/parser.c:1677
#, fuzzy
msgid "Default"
msgstr " noklusÄts: %s\n"
-#: ../lib/gis/parser.c:1868
+#: ../lib/gis/parser.c:1894
msgid "Allow overwrite"
msgstr ""
-#: ../lib/gis/parser.c:1876
+#: ../lib/gis/parser.c:1902
msgid "Run with minimal output messages"
msgstr ""
-#: ../lib/gis/parser.c:1878
+#: ../lib/gis/parser.c:1904
msgid "Run quietly"
msgstr ""
-#: ../lib/gis/parser.c:1967
+#: ../lib/gis/parser.c:1993
#, c-format
msgid " %*s options: "
msgstr " %*s opcijas: "
-#: ../lib/gis/parser.c:2016 ../lib/gis/parser.c:2033
+#: ../lib/gis/parser.c:2042 ../lib/gis/parser.c:2059
#, c-format
msgid "Sorry, <%c> is not a valid flag\n"
msgstr "Atvainojiet, <%c> ir nedrīgs karogs\n"
-#: ../lib/gis/parser.c:2088
+#: ../lib/gis/parser.c:2114
#, c-format
msgid "Sorry, <%s=> is ambiguous\n"
msgstr "Atvainojiet, <%s=> ir pÄrÄk lielas prasÄ«bas\n"
-#: ../lib/gis/parser.c:2095
+#: ../lib/gis/parser.c:2121
#, c-format
msgid "Sorry, <%s> is not a valid parameter\n"
-#: ../lib/gis/parser.c:2180
+#: ../lib/gis/parser.c:2206
#, fuzzy, c-format
msgid ""
"\n"
@@ -1356,12 +1354,12 @@
"\n"
"Kļūda: nepieÅemama parametra sintakse <%s>\n"
-#: ../lib/gis/parser.c:2182
+#: ../lib/gis/parser.c:2208
#, c-format
msgid " Presented as: %s\n"
msgstr " AttÄlots kÄ: %s\n"
-#: ../lib/gis/parser.c:2185
+#: ../lib/gis/parser.c:2211
#, fuzzy, c-format
msgid ""
"\n"
@@ -1370,12 +1368,12 @@
"\n"
"Kļūda: vÄrtÄ«ba <%s> ir Ärpus apgabala parametram <%s>\n"
-#: ../lib/gis/parser.c:2187
+#: ../lib/gis/parser.c:2213
#, c-format
msgid " Legal range: %s\n"
msgstr " Atļautais diapzons: %s\n"
-#: ../lib/gis/parser.c:2190
+#: ../lib/gis/parser.c:2216
#, fuzzy, c-format
msgid ""
"\n"
@@ -1384,7 +1382,7 @@
"\n"
"Kļūda: TrÅ«kst vÄrtÄ«ba parametram <%s>\n"
-#: ../lib/gis/parser.c:2350
+#: ../lib/gis/parser.c:2376
#, c-format
msgid ""
"\n"
@@ -1395,7 +1393,7 @@
"KĻŪDA: Prasītais parametrs <%s> nav iestatīts:\n"
" (%s).\n"
-#: ../lib/gis/parser.c:2453
+#: ../lib/gis/parser.c:2479
#, fuzzy, c-format
msgid ""
"\n"
@@ -1404,17 +1402,17 @@
"\n"
"Kļūda: opcija/pazÄ«me <%s> ir jabÅ«t paredzÄtai daudzskaitlÄ«gi no %d\n"
-#: ../lib/gis/parser.c:2455
+#: ../lib/gis/parser.c:2481
#, c-format
msgid " You provided %d items:\n"
msgstr " Tu paredzÄji %d vienumus:\n"
-#: ../lib/gis/parser.c:2510
+#: ../lib/gis/parser.c:2536
#, fuzzy, c-format
msgid "ERROR: option <%s>: <%s> exists.\n"
msgstr "Kļūda: opcija/pazÄ«me <%s>: <%s> jau eksistÄ.\n"
-#: ../lib/gis/parser.c:2557
+#: ../lib/gis/parser.c:2583
#, c-format
msgid ""
"\n"
@@ -1423,7 +1421,7 @@
"\n"
"KAROGS: Likt sekojošo pazīmi/karogu?\n"
-#: ../lib/gis/parser.c:2571
+#: ../lib/gis/parser.c:2597
#, c-format
msgid ""
"\n"
@@ -1432,51 +1430,51 @@
"\n"
"OPCIJA/PAZĪME: %s\n"
-#: ../lib/gis/parser.c:2572
+#: ../lib/gis/parser.c:2598
#, c-format
msgid " key: %s\n"
msgstr " atslÄga: %s\n"
-#: ../lib/gis/parser.c:2574
+#: ../lib/gis/parser.c:2600
#, c-format
msgid " format: %s\n"
msgstr " formÄts: %s\n"
-#: ../lib/gis/parser.c:2576
+#: ../lib/gis/parser.c:2602
#, c-format
msgid " default: %s\n"
-#: ../lib/gis/parser.c:2577
+#: ../lib/gis/parser.c:2603
#, c-format
msgid "required: %s\n"
msgstr "prasītais: %s\n"
-#: ../lib/gis/parser.c:2579
+#: ../lib/gis/parser.c:2605
#, c-format
msgid "multiple: %s\n"
msgstr "daudzskaitlīgs: %s\n"
-#: ../lib/gis/parser.c:2581
+#: ../lib/gis/parser.c:2607
#, c-format
msgid " options: %s\n"
-#: ../lib/gis/parser.c:2596
+#: ../lib/gis/parser.c:2622
#, c-format
msgid "enter option > "
msgstr "ievadi opciju/pazīmi > "
-#: ../lib/gis/parser.c:2610 ../lib/gis/parser.c:2621
+#: ../lib/gis/parser.c:2636 ../lib/gis/parser.c:2647
msgid " Try again? "
msgstr " MeiÄ£ini vÄl? "
-#: ../lib/gis/parser.c:2619
+#: ../lib/gis/parser.c:2645
#, c-format
msgid "Sorry, %s is not accepted.\n"
msgstr "Atvainojiet, %s nav akceptÄts.\n"
-#: ../lib/gis/parser.c:2630
+#: ../lib/gis/parser.c:2656
#, c-format
msgid ""
"\n"
@@ -1487,11 +1485,11 @@
"Tu esi izvÄlÄjies:\n"
" %s\n"
-#: ../lib/gis/parser.c:2631
+#: ../lib/gis/parser.c:2657
msgid "Is this correct? "
msgstr "Vai tas ir pareizi?"
-#: ../lib/gis/parser.c:2700
+#: ../lib/gis/parser.c:2726
msgid "to accept the default"
msgstr "lai apstiprinÄtu noklusÄto"
@@ -2907,7 +2905,7 @@
msgid "Unable to open file %s"
msgstr "NeiespÄjami atvÄrt failu %s iekÅ¡ %s"
-#: ../lib/vector/Vlib/build.c:27 ../lib/vector/Vlib/open.c:53
+#: ../lib/vector/Vlib/build.c:27 ../lib/vector/Vlib/open.c:32
#: ../lib/vector/Vlib/write.c:36
msgid "Requested format is not compiled in this version"
msgstr "PieprasÄ«tais formÄts nav pieejams/iekļauts Å¡ijÄ versijÄ"
@@ -3075,6 +3073,59 @@
msgid "OGR feature without ID ignored."
msgstr ""
+#: ../lib/vector/Vlib/cats.c:45
+#, fuzzy
+msgid "Vect_new_cats_struct(): Out of memory"
+msgstr "NeiespÄjami piešķirt atmiÅu\n"
+#: ../lib/vector/Vlib/cats.c:138
+#, c-format
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:408
+#, c-format
+msgid "Unable to convert category string '%s' (from '%s') to category range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:30
+msgid "Category index is not up to date"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:62 ../lib/vector/Vlib/cindex.c:129
+#: ../lib/vector/Vlib/cindex.c:148 ../lib/vector/Vlib/cindex.c:171
+msgid "Invalid layer index (index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:110
+msgid "Invalid layer index (index < 0 or index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:235
+#, fuzzy
+msgid "Layer or category index out of range"
+msgstr "Dubulto atribÅ«tu indekss Ärpus diapazona"
+#: ../lib/vector/Vlib/cindex.c:283
+#, fuzzy
+msgid "Layer index out of range"
+#: ../lib/vector/Vlib/cindex.c:456
+#, fuzzy, c-format
+msgid "Unable to open cidx file <%s> for write"
+msgstr "NeiespÄjami atvÄrt %s priekÅ¡ rakstīšanas"
+#: ../lib/vector/Vlib/cindex.c:464
+#, fuzzy, c-format
+msgid "Error writing out category index file <%s>"
+msgstr "Kļūdu rakstīšana Ärpus telpisko datu index faila.\n"
+#: ../lib/vector/Vlib/cindex.c:507
+#, fuzzy, c-format
+msgid "Unable to open category index file for vector map <%s@%s>"
+msgstr "Nevar atvÄrt vÄsturi vektoram '%s'"
#: ../lib/vector/Vlib/field.c:76
msgid "Field number must be 1 or greater."
msgstr "Lauka nummuram ir jÄbÅ«t 1 vai lielÄkam."
@@ -3151,48 +3202,124 @@
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:23
-#, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'.\n"
+#: ../lib/vector/Vlib/legal_vname.c:39
+#, fuzzy, c-format
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
msgstr ""
"NepieÅemams vektoru kartes nosaukums <%s>. NedrÄ«kst saturÄt '.' vai 'NULL'.\n"
-#: ../lib/vector/Vlib/legal_vname.c:29
-#, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter.\n"
+#: ../lib/vector/Vlib/legal_vname.c:45
+#, fuzzy, c-format
+msgid "Illegal vector map name <%s>. Must start with a letter."
msgstr "NepieÅemams vektoru kartes nosaukums <%s>. JÄsÄkas ar burtu.\n"
-#: ../lib/vector/Vlib/legal_vname.c:35
-#, c-format
-msgid "Illegal vector map name <%s>. Character <%c> not allowed.\n"
+#: ../lib/vector/Vlib/legal_vname.c:51
+#, fuzzy, c-format
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
msgstr "NepieÅemams vektoru kartes nosaukums <%s>. ZÄ«me <%c> nav atļauta.\n"
-#: ../lib/vector/Vlib/legal_vname.c:60 ../lib/vector/Vlib/legal_vname.c:62
-#, c-format
-msgid "Output name '%s' is not valid vector name."
-msgstr "Izejas vÄrds '%s' nav derÄ«gs vektora nosaukums."
+#: ../lib/vector/Vlib/legal_vname.c:81 ../lib/vector/Vlib/legal_vname.c:83
+#, fuzzy, c-format
+msgid "Output vector map name <%s> is not valid map name"
+msgstr "Izejas vÄrds '%s' nav derÄ«gs rastra nosaukums."
-#: ../lib/vector/Vlib/map.c:152 ../lib/vector/Vlib/map.c:268
-#: ../lib/vector/Vlib/open.c:526
-#, c-format
-msgid "Map name is not SQL compliant."
+#: ../lib/vector/Vlib/legal_vname.c:94 ../lib/vector/Vlib/legal_vname.c:96
+#: ../lib/vector/Vlib/map.c:302 ../lib/vector/Vlib/open.c:158
+#, fuzzy, c-format
+msgid "Vector map <%s> not found"
+msgstr "Ieejas vektors '%s' nav atrasts"
+#: ../lib/vector/Vlib/legal_vname.c:114 ../lib/vector/Vlib/legal_vname.c:116
+#, fuzzy, c-format
+msgid "Output vector map <%s> is used as input"
+msgstr "Izejas karte '%s' tiek lietota kÄ iejas karte"
+#: ../lib/vector/Vlib/map.c:62 ../lib/vector/Vlib/map.c:75
+#, fuzzy, c-format
+msgid "Unable to read vector map <%s%s>"
+msgstr "neispÄjami mainÄ«t direktoriju uz %s"
+#: ../lib/vector/Vlib/map.c:167 ../lib/vector/Vlib/map.c:290
+#: ../lib/vector/Vlib/open.c:508
+#, fuzzy, c-format
+msgid "Vector map name is not SQL compliant"
msgstr "Kartes nosaukums nav SQL savietojams."
-#: ../lib/vector/Vlib/map.c:156 ../lib/vector/Vlib/map.c:272
-#: ../lib/vector/Vlib/open.c:533
-#, c-format
-msgid "The vector '%s' already exists and will be overwritten."
+#: ../lib/vector/Vlib/map.c:171 ../lib/vector/Vlib/map.c:294
+#: ../lib/vector/Vlib/open.c:515
+#, fuzzy, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
msgstr "Vektors '%s' jau eksistÄ un tiks pÄrrakstÄ«ts."
-#: ../lib/vector/Vlib/map.c:280
-#, c-format
-msgid "Input vector '%s' not found"
-msgstr "Ieejas vektors '%s' nav atrasts"
+#: ../lib/vector/Vlib/map.c:174 ../lib/vector/Vlib/open.c:519
+#, fuzzy, c-format
+msgid "Unable to delete vector map <%s>"
-#: ../lib/vector/Vlib/map.c:283
+#: ../lib/vector/Vlib/map.c:197 ../lib/vector/Vlib/map.c:305
+#, fuzzy, c-format
+msgid "Unable to copy vector map <%s> to <%s>"
+msgstr "neiespÄjami atvÄrt rastra karti [%s iekÅ¡ %s]"
+#: ../lib/vector/Vlib/map.c:225 ../lib/vector/Vlib/map.c:337
+#: ../lib/vector/Vlib/map.c:442 ../lib/vector/Vlib/map.c:551
+#: ../lib/vector/Vlib/map.c:642
#, c-format
-msgid "Cannot copy vector '%s' to '%s'"
-msgstr "Nevar kopÄt vektoru '%s' uz '%s'"
+msgid "Database connection not defined for layer %d"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:239 ../lib/vector/Vlib/map.c:352
+#: ../lib/vector/Vlib/map.c:571 ../lib/vector/Vlib/map.c:668
+#, fuzzy, c-format
+msgid "Unable to copy table <%s>"
+msgstr "NeiespÄjami atvÄrt failu %s iekÅ¡ %s"
+#: ../lib/vector/Vlib/map.c:247 ../lib/vector/Vlib/map.c:373
+#: ../lib/vector/Vlib/map.c:577
+#, fuzzy, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr "Nevar atvÄrt datubÄzi %s"
+#: ../lib/vector/Vlib/map.c:251 ../lib/vector/Vlib/map.c:377
+#: ../lib/vector/Vlib/map.c:581
+#, fuzzy, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr "NiespÄjami izveidot atkarÄ«bu failu [%s iekÅ¡ %s]"
+#: ../lib/vector/Vlib/map.c:366 ../lib/vector/Vlib/map.c:460
+#, fuzzy, c-format
+msgid "Unable to delete table <%s>"
+#: ../lib/vector/Vlib/map.c:451
+#, fuzzy, c-format
+msgid "Unable to find table <%s> linked to vector map <%s>"
+#: ../lib/vector/Vlib/map.c:479
+#, fuzzy, c-format
+msgid "Unable to open directory '%s'"
+#: ../lib/vector/Vlib/map.c:490
+#, fuzzy, c-format
+msgid "Unable to delete file '%s'"
+#: ../lib/vector/Vlib/map.c:507
+#, fuzzy, c-format
+msgid "Unable to rename directory '%s' to '%s'"
+#: ../lib/vector/Vlib/map.c:515
+#, fuzzy, c-format
+msgid "Unable to remove directory '%s'"
+#: ../lib/vector/Vlib/map.c:563 ../lib/vector/Vlib/map.c:656
+#, fuzzy, c-format
+msgid "Unable to add database link for vector map <%s>"
#: ../lib/vector/Vlib/net.c:120
#, fuzzy
@@ -3283,82 +3410,70 @@
msgid "Wrong line direction in Vect_net_get_line_cost()"
msgstr ""
-#: ../lib/vector/Vlib/open.c:114
-#, fuzzy
-msgid "Programmer requested unknown open_level"
+#: ../lib/vector/Vlib/open.c:93
+#, fuzzy, c-format
+msgid "Programmer requested unknown open level %d"
msgstr ""
"BrÄ«dinÄjums. Programma atklÄjusi nezinÄmu atvÄrtolÄ«meni (open_level) \n"
-#: ../lib/vector/Vlib/open.c:179
-#, fuzzy, c-format
-msgid "Vector map <%s> not found"
-#: ../lib/vector/Vlib/open.c:189
-msgid "A map which is not in the current mapset cannot be opened for update."
+#: ../lib/vector/Vlib/open.c:168
+#, fuzzy
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
msgstr ""
"Karte kura nav iekļauta tekoÅ¡ajÄ karÅ¡u kolekcijÄ nevar tikt atvÄrta "
"papildinÄÅ¡anai."
-#: ../lib/vector/Vlib/open.c:207
+#: ../lib/vector/Vlib/open.c:186
#, fuzzy, c-format
-msgid "Cannot open existing vector map <%s>"
-msgstr "Nevar izdzÄst eksistÄjoÅ¡u vektoru %s "
+msgid "Unable to open vector map <%s>"
-#: ../lib/vector/Vlib/open.c:217 ../lib/vector/Vlib/open.c:277
-#: ../lib/vector/Vlib/open.c:293
+#: ../lib/vector/Vlib/open.c:196 ../lib/vector/Vlib/open.c:256
+#: ../lib/vector/Vlib/open.c:273
#, fuzzy, c-format
-msgid "Cannot open existing vector <%s> on level [%d]"
+msgid "Unable to open vector map <%s> on topology level %d"
msgstr "Nevar atvÄrt veco vektoru %s lÄ«menÄ« %d"
-#: ../lib/vector/Vlib/open.c:218
+#: ../lib/vector/Vlib/open.c:197
#, fuzzy
-msgid "Cannot read head file"
+msgid "Unable to read head file"
msgstr "Nevar atvÄrt 'temp'/pagaidu failu"
-#: ../lib/vector/Vlib/open.c:238
+#: ../lib/vector/Vlib/open.c:217
#, fuzzy, c-format
-msgid "Cannot open topo file for vector map <%s>"
+msgid "Unable to open topology file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:261
+#: ../lib/vector/Vlib/open.c:240
#, fuzzy, c-format
-msgid "Cannot open category index file for vector map <%s>"
+msgid "Unable to open category index file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:340
+#: ../lib/vector/Vlib/open.c:321 ../lib/vector/Vlib/open.c:542
#, fuzzy, c-format
-msgid "Cannot open history file for vector map <%s>"
+msgid "Unable to open history file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:537
+#: ../lib/vector/Vlib/open.c:533
#, fuzzy, c-format
-msgid "Cannot delete existing vector <%s>"
-#: ../lib/vector/Vlib/open.c:551
-#, c-format
-msgid "Cannot open new vector %s"
-msgstr "Nevar atvÄrt jaunu vektoru %s"
-#: ../lib/vector/Vlib/open.c:560
-#, c-format
-msgid "Cannot open history file for vector '%s'"
-msgstr "Nevar atvÄrt vÄsturi vektoram '%s'"
+msgid "Unable to create vector map <%s>"
-#: ../lib/vector/Vlib/open.c:608
-#, c-format
-msgid "Could not stat file '%s'"
-msgstr "Nevar palaist failu '%s'"
+#: ../lib/vector/Vlib/open.c:590
+#, fuzzy, c-format
+msgid "Unable to stat file <%s>"
-#: ../lib/vector/Vlib/open.c:719
-msgid "Size of 'coor' file differs from value saved in topo file."
+#: ../lib/vector/Vlib/open.c:701
+#, fuzzy
+msgid "Size of 'coor' file differs from value saved in topology file"
msgstr ""
"KrÄsas paremetru fails atšķiras no vÄrtÄ«bÄm kuras saglabÄtas topo failÄ."
-#: ../lib/vector/Vlib/open.c:730
-#, c-format
-msgid "Please rebuild topology for vector '%s@%s'"
+#: ../lib/vector/Vlib/open.c:712
+#, fuzzy, c-format
+msgid "Please rebuild topology for vector map <%s@%s>"
msgstr "LÅ«dzu pÄrveido topoloÄ£iju vektoram '%s@%s'"
#: ../lib/vector/Vlib/read_nat.c:160
@@ -3380,37 +3495,37 @@
msgid "Cannot get feature geometry, FID [%ld]"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:139 ../lib/vector/Vlib/snap.c:179
+#: ../lib/vector/Vlib/snap.c:119 ../lib/vector/Vlib/snap.c:159
#, fuzzy
msgid "Registering points"
msgstr "SaglabÄjam/reÄ£istrÄjam lÄ«nijas"
-#: ../lib/vector/Vlib/snap.c:188
+#: ../lib/vector/Vlib/snap.c:168
msgid "All vertices"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:189
+#: ../lib/vector/Vlib/snap.c:169
#, fuzzy
msgid "Registered points"
-#: ../lib/vector/Vlib/snap.c:234
+#: ../lib/vector/Vlib/snap.c:214
msgid "Nodes marked as anchor"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:235
+#: ../lib/vector/Vlib/snap.c:215
msgid "Nodes marked to be snapped"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:244 ../lib/vector/Vlib/snap.c:384
+#: ../lib/vector/Vlib/snap.c:224 ../lib/vector/Vlib/snap.c:364
msgid "Snaps"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:392
+#: ../lib/vector/Vlib/snap.c:372
msgid "Snapped vertices"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:393
+#: ../lib/vector/Vlib/snap.c:373
msgid "New vertices"
msgstr ""
@@ -3544,6 +3659,32 @@
"node = [%d] line = [%d]"
msgstr ""
+#~ msgid "Output name '%s' is not valid vector name."
+#~ msgstr "Izejas vÄrds '%s' nav derÄ«gs vektora nosaukums."
+#~ msgid "Input vector '%s' not found"
+#~ msgstr "Ieejas vektors '%s' nav atrasts"
+#~ msgstr "Nevar kopÄt vektoru '%s' uz '%s'"
+#, fuzzy
+#~ msgid "Cannot open existing vector map <%s>"
+#~ msgstr "Nevar izdzÄst eksistÄjoÅ¡u vektoru %s "
+#, fuzzy
+#~ msgid "Cannot delete existing vector <%s>"
+#~ msgid "Cannot open new vector %s"
+#~ msgstr "Nevar atvÄrt jaunu vektoru %s"
+#~ msgid "Cannot open history file for vector '%s'"
+#~ msgstr "Nevar atvÄrt vÄsturi vektoram '%s'"
+#~ msgid "Could not stat file '%s'"
+#~ msgstr "Nevar palaist failu '%s'"
#, fuzzy
#~ msgid "Can't open directory %s"
#~ msgstr "Nevar atvÄrt veco vektoru %s"
@@ -3766,9 +3907,6 @@
#~ msgid "No double attributes in site_list"
#~ msgstr "Nav dubulto atribūtu site_list"
-#~ msgid "Double attribute index out of range"
-#~ msgstr "Dubulto atribÅ«tu indekss Ärpus diapazona"
#~ msgid "No string attributes in site_list"
#~ msgstr "Nav teksta (string) atribūtu site_list"
Index: grasslibs_mr.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_mr.po,v
--- grasslibs_mr.po 21 Sep 2007 22:12:44 -0000 1.17
+++ grasslibs_mr.po 23 Nov 2007 17:33:17 -0000 1.17.2.1
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: Grass 6.0\n"
"PO-Revision-Date: 2005-06-02 18:00+0530\n"
"Last-Translator: Swapnil Hajare <dreamil at gmail.com>\n"
"Language-Team: Marathi <www.janabhaaratii.org.in>\n"
@@ -785,13 +785,11 @@
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
@@ -1071,11 +1069,11 @@
msgstr ""
msgstr ""
msgstr ""
@@ -1083,98 +1081,98 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Type"
msgstr ""
msgstr ""
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "à¤à¤à¤¡à¤²à¥à¤²à¥à¤¯à¤¾ फाà¤à¤²à¤à¥ नाव %s\n"
#, fuzzy
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
"Description:\n"
msgstr ""
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1182,129 +1180,129 @@
msgstr ""
#, c-format
msgid ""
"\n"
"Flags:\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
"Parameters:\n"
msgstr ""
#, c-format
msgstr ""
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
msgid "Flags"
msgstr ""
msgid "Parameters"
msgstr ""
msgid "Options"
msgstr ""
msgid "Default"
msgstr ""
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
"ERROR: illegal range syntax for parameter <%s>\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
"ERROR: value <%s> out of range for parameter <%s>\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
"ERROR: Missing value for parameter <%s>\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1312,82 +1310,82 @@
" (%s).\n"
msgstr ""
#, c-format
msgid ""
"\n"
"ERROR: option <%s> must be provided in multiples of %d\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
"FLAG: Set the following flag?\n"
msgstr ""
#, c-format
msgid ""
"\n"
"OPTION: %s\n"
msgstr ""
#, c-format
msgid " key: %s\n"
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
msgstr ""
#, c-format
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1395,11 +1393,11 @@
" %s\n"
msgstr ""
msgstr ""
msgstr ""
@@ -2771,7 +2769,7 @@
msgstr "%s à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
msgstr ""
@@ -2935,6 +2933,56 @@
msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy, c-format
+msgstr "%s à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
+#, fuzzy, c-format
+msgstr "temp फाà¤à¤² à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
+#, fuzzy, c-format
msgstr ""
@@ -3006,48 +3054,124 @@
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
#, c-format
msgstr ""
+#, fuzzy, c-format
+msgstr "%s मिळालॠनाहà¥"
#, c-format
msgstr ""
+#, fuzzy, c-format
+#, fuzzy, c-format
#, c-format
msgstr ""
+#, fuzzy, c-format
+#, fuzzy, c-format
#, c-format
msgstr ""
+#, fuzzy, c-format
+#, fuzzy, c-format
#, c-format
msgstr ""
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
msgid "Building graph ..."
msgstr ""
@@ -3133,78 +3257,65 @@
msgstr ""
+#, c-format
msgstr ""
-#, fuzzy, c-format
-msgstr "%s मिळालॠनाहà¥"
+msgid ""
msgstr ""
#, fuzzy, c-format
-msgstr "temp फाà¤à¤² à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
#, c-format
msgstr ""
#, fuzzy
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
-#, c-format
-msgstr ""
+#, fuzzy, c-format
msgstr ""
-#, c-format
-msgstr ""
+#, fuzzy, c-format
#, c-format
@@ -3225,35 +3336,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3383,6 +3494,10 @@
msgstr ""
+#, fuzzy
+#~ msgstr "temp फाà¤à¤² à¤à¤à¤¡à¤¤à¤¾ à¤à¤²à¥ नाहà¥"
#, fuzzy
Index: grasslibs_pl.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_pl.po,v
retrieving revision 1.20
retrieving revision 1.20.2.1
diff -u -d -r1.20 -r1.20.2.1
--- grasslibs_pl.po 22 Sep 2007 09:08:39 -0000 1.20
+++ grasslibs_pl.po 23 Nov 2007 17:33:18 -0000 1.20.2.1
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_pl\n"
"PO-Revision-Date: 2007-09-21 14:20+0100\n"
"Last-Translator: Monika Tylus <monikatylus_gmail.com>\n"
"Language-Team: Polska <translation at grass.itc.it>\n"
@@ -834,13 +834,11 @@
msgstr "Nazwa pliku wyj¶ciowego '%s' nie jest poprawn± nazw± rastra."
#, c-format
msgstr "Nie mo¿na znale¼æ wej¶ciowej mapy '%s'"
#, fuzzy, c-format
msgstr "Mapa wyj¶ciowa '%s' jest u¿ywana jako plik wej¶cowy"
@@ -1138,12 +1136,12 @@
msgstr "Nazwy ¼ród³owych map(y) rastrowych"
#, fuzzy
msgstr "Nazwa ¼ród³owej mapy rastrowej"
#, fuzzy
@@ -1153,85 +1151,85 @@
msgstr "Nazwa wyj¶ciowej mapy rastrowej"
msgstr "Nazwa ¼ród³owej mapy wektorowej"
#, fuzzy
msgstr "Nazwa wyj¶ciowej mapy wketorowej"
msgid "Type"
msgstr "Typ"
msgstr ""
msgstr "Liczna warstw"
msgid ""
msgstr ""
msgstr "Warto¶æ kategorii"
msgstr "Warto¶ci kategorii"
msgstr "Przyk³ad: 1,3,7-9,13"
#, fuzzy
msgstr "Nazwa otwartego pliku: %s"
#, fuzzy
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy, c-format
msgstr "<%s> nie jest poprawn± opcj±\n"
#, c-format
msgid ""
"\n"
@@ -1240,14 +1238,14 @@
"\n"
"Opis:\n"
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1255,7 +1253,7 @@
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1264,19 +1262,19 @@
"\n"
"Flagi:\n"
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1285,80 +1283,80 @@
"\n"
"Parametry:\n"
#, c-format
msgstr " %*s domy¶lnie: %s\n"
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"Flagi:\n"
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"Parametry:\n"
#, fuzzy
msgid "Options"
msgstr " opcjes: %s\n"
#, fuzzy
msgid "Default"
msgstr " domy¶lnie: %s\n"
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, fuzzy, c-format
msgstr " %*s opcje: "
#, c-format
msgstr "<%c>to niepoprawna flaga\n"
#, c-format
msgstr "<%s=> jest niedozwolone\n"
#, c-format
msgstr "<%s> nie jest poprawnym parametrem\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1367,12 +1365,12 @@
"\n"
"B³±d: niedopuszczalna sk³adnia zakresu sla parametru <%s>\n"
#, fuzzy, c-format
msgstr " Przedstawiony jako: %s\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1381,12 +1379,12 @@
"\n"
"B³±d: warto¶æ <%s> zajduje siê poza zakresem dla parametru <%s>\n"
#, c-format
msgstr ""
#, fuzzy, c-format
msgid ""
"\n"
"\n"
"B³±d: Brakuj±ca warto¶æ dla parametru <%s>\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1406,31 +1404,31 @@
"B£¡D: Wymagany parametr <%s> nie jest ustawiony:\n"
" (%s).\n"
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, fuzzy, c-format
msgstr "B³±d: opcja <%s>: <%s> ju¿ istnieje.\n"
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1439,51 +1437,51 @@
"\n"
"OPCJA: %s\n"
#, c-format
msgid " key: %s\n"
msgstr ""
#, c-format
#, fuzzy, c-format
#, fuzzy, c-format
msgstr "wymagany: %s\n"
#, c-format
msgstr ""
#, c-format
#, c-format
msgstr "wprowad¼ opcjê >"
msgstr " Czy ponowiæ próbê ? "
#, c-format
msgstr "Warto¶æ %s nie jest poprawna\n"
#, c-format
msgid ""
"\n"
@@ -1494,11 +1492,11 @@
"Wybra³e¶:\n"
" %s\n"
msgstr "Czy to siê zgadza ?"
msgstr "aby zaakceptopwaæ domy¶lne"
@@ -2940,7 +2938,7 @@
msgstr "W %s nie mo¿na otworzyæ pliku %s"
msgstr ""
@@ -3105,6 +3103,58 @@
msgstr "Obiekt OGR bez ID zosta³ zignorowany."
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Rozmiar wektore poza zakresem"
+#, fuzzy
+msgstr "Nieprawid³owy rozmiar macierzy"
+#, fuzzy, c-format
+msgstr "Nie mo¿na otworzyæ %s do zapisu"
+#, fuzzy, c-format
+msgstr "b³±d podczas zapisu zerowego wiersza %d"
+#, fuzzy, c-format
+msgstr "Nie mo¿na otworzyæ pliku ¶ledzenia b³êdu '%s'"
msgstr "Numer pola musi mieæ warto¶æ 1 lub wiêksz±. "
@@ -3178,50 +3228,126 @@
msgstr ""
-#, c-format
+#, fuzzy, c-format
msgstr ""
"Nazwa mapy wektorowej <%s> jest niedozwolona. Mo¿e zawieraæ '.' lub 'NULL'.\n"
-#, c-format
+#, fuzzy, c-format
msgstr ""
"Nazwa mapy wektorowej <%s> jest niedozwolona. Nazwa musi zaczynaæ siê od "
"litery.\n"
#, fuzzy, c-format
msgstr "Nazwa mapy wektorowej <%s> jest niedozwolona. Znak <%c> "
-#, c-format
-msgstr "Nazwa wyniku '%s' nie jest poprawn± nazw± wektora."
+#, fuzzy, c-format
+msgstr "Nazwa pliku wyj¶ciowego '%s' nie jest poprawn± nazw± rastra."
-#, c-format
+#, fuzzy, c-format
+msgstr "Nie mo¿na znale¼æ wektora ¼ród³owego '%s'"
+#, fuzzy, c-format
+msgstr "Mapa wyj¶ciowa '%s' jest u¿ywana jako plik wej¶cowy"
+#, fuzzy, c-format
+msgstr "Nie mo¿na otworzyæ %s"
+#, fuzzy, c-format
msgstr "Nazwa mapy nie jest zgodna z SQL."
-#, c-format
+#, fuzzy, c-format
msgstr "Wektor '%s' ju¿ istnieje i zostanie nadpisany."
-#, c-format
-msgstr "Nie mo¿na znale¼æ wektora ¼ród³owego '%s'"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "nie mo¿na otworzyæ rastrowej mapy [%s w %s]"
#, c-format
-msgstr "Nie mo¿na skopiowaæ wektora '%s' do '%s'"
+msgstr ""
+#, fuzzy, c-format
+msgstr "W %s nie mo¿na otworzyæ pliku %s"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Nie mo¿na utworzyæ nag³ówka pliku dla [%s]"
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
#, fuzzy
@@ -3309,78 +3435,67 @@
msgstr ""
+#, c-format
msgstr ""
-#, fuzzy, c-format
+#, fuzzy
+msgid ""
msgstr ""
"Mapa, które nie jest w bie¿±cym mapsecie nie mo¿e byæ otwarta do "
"uaktualniania."
#, fuzzy, c-format
-msgstr "Nie mo¿na otworzyæ pliku ¶ledzenia b³êdu '%s'"
#, fuzzy, c-format
msgstr "Nie mo¿na otworzyæ istniej±cego wektora <%s> na poziomie [%d]"
+#, fuzzy
msgstr "Nie mo¿na odczytaæ nag³ówka pliku"
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
-msgstr "Nie mo¿na usun±æ istniej±cego wektora <%s>"
-#, c-format
-msgstr "Nie mo¿na otworzyæ nowego wektora %s"
-#, c-format
-msgstr "Nie mo¿na otworzyæ pliku historii dla wektora '%s'"
-#, c-format
-msgstr ""
+#, fuzzy, c-format
msgstr ""
-#, c-format
+#, fuzzy, c-format
msgstr "Przebuduj topologiê dla wektora '%s@%s'"
@@ -3403,35 +3518,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3562,6 +3677,29 @@
msgstr ""
+#~ msgstr "Nazwa wyniku '%s' nie jest poprawn± nazw± wektora."
+#~ msgstr "Nie mo¿na znale¼æ wektora ¼ród³owego '%s'"
+#~ msgid "Cannot copy vector '%s' to '%s'"
+#~ msgstr "Nie mo¿na skopiowaæ wektora '%s' do '%s'"
+#, fuzzy
+#~ msgstr "Nie mo¿na otworzyæ pliku ¶ledzenia b³êdu '%s'"
+#, fuzzy
+#~ msgstr "Nie mo¿na usun±æ istniej±cego wektora <%s>"
+#~ msgstr "Nie mo¿na otworzyæ nowego wektora %s"
+#~ msgstr "Nie mo¿na otworzyæ pliku historii dla wektora '%s'"
#~ msgid "Setting map window"
#~ msgstr "Ustawienia okna mapy"
Index: grasslibs_pt.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_pt.po,v
retrieving revision 1.9
retrieving revision 1.9.2.1
diff -u -d -r1.9 -r1.9.2.1
--- grasslibs_pt.po 21 Sep 2007 22:12:44 -0000 1.9
+++ grasslibs_pt.po 23 Nov 2007 17:33:18 -0000 1.9.2.1
@@ -10,10 +10,10 @@
msgstr ""
"Project-Id-Version: grasslibs_pt\n"
"PO-Revision-Date: 2007-06-18 22:26-0300\n"
"Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail dot com>\n"
-"Language-Team: Portuguese <translations at grass.itc.it>\n"
+"Language-Team: Portuguese <translations at lists.osgeo.org>\n"
@@ -826,13 +826,11 @@
msgstr "Nome de arquivo de saída '%s' não é um nome de raster válido."
#, c-format
msgstr "não consegui encontrar mapa de entrada '%s'"
#, c-format
msgstr "Mapa de saída '%s' usado como entrada"
msgstr "Nome dos mapas raster de elevação"
msgstr "Nome do mapa raster3D de entrada"
msgstr "Nome dos mapas raster3d de entrada"
@@ -1137,31 +1135,31 @@
msgstr "Nome do mapa raster3d de saída"
msgstr "Nome do mapa vetor de entrada"
msgstr "Nome do mapa vetor de saída"
msgid "Type"
msgstr "Tipo"
msgstr "Tipo(s) de feição"
msgstr "Número da camada"
msgid ""
@@ -1169,52 +1167,52 @@
"Apenas um mapa vetorial pode ser conectado a múltiplas tabelas. Este número "
"determina qual tabela usar."
msgstr "Valor da categoria"
msgstr "Valores da categoria"
msgstr "Exemplo: 1,3,7-9,13"
msgstr "Nome do arquivo de entrada"
msgstr "Nome do arquivo de saída"
msgstr "Separador de Campos"
msgid "Color"
msgstr "Cor"
msgstr "Um nome de cor padrão ou tripla R:G:B"
msgstr "Cor de fundo"
msgstr "Cor padrão do GRASS, tripla R:G:B ou \"none\""
#, c-format
msgstr "Desculpe <%s> não é uma opção válida\n"
#, c-format
msgid ""
"\n"
@@ -1223,7 +1221,7 @@
"\n"
"Descrição:\n"
#, c-format
msgid ""
"\n"
@@ -1232,7 +1230,7 @@
"\n"
"Palavras chave:\n"
#, c-format
msgid ""
"\n"
@@ -1243,7 +1241,7 @@
"Uso:\n"
#, c-format
msgid ""
"\n"
@@ -1252,19 +1250,19 @@
"\n"
"Flags:\n"
msgstr "Permitir aos arquivos de saída a sobrescrever arquivos existentes"
msgstr "Saída do módulo verbosa"
msgstr "Saída do módulo silenciosa"
#, c-format
msgid ""
"\n"
@@ -1273,72 +1271,72 @@
"\n"
"Parâmetros:\n"
#, c-format
msgstr " %*s padrão: %s\n"
msgid "NAME"
msgstr "NOME"
msgid "KEYWORDS"
msgstr "PALAVRAS CHAVE"
msgid "SYNOPSIS"
msgstr "RESUMO"
msgid "Flags"
msgstr "Opções"
msgid "Parameters"
msgstr "Parâmetros"
msgid "Options"
msgstr "Opções"
msgid "Default"
msgstr "padrão"
msgstr "Permitir sobrescrever"
msgstr "Executar com mínimo de mensagens (silencioso)"
msgid "Run quietly"
msgstr "Executa silenciosamente"
#, c-format
msgstr " %*s opções: "
#, c-format
msgstr "Desculpe, <%c> não é um flag válido\n"
#, c-format
msgstr "Desculpe, <%s=> é ambíguo\n"
#, c-format
msgstr "Desculpe, <%s> não é um parâmetro válido\n"
#, c-format
msgid ""
"\n"
@@ -1347,12 +1345,12 @@
"\n"
"ERRO: sintaxe ilegal no intervalo do parâmetro <%s>\n"
#, c-format
msgstr " Apresentado como: %s\n"
#, c-format
msgid ""
"\n"
@@ -1361,12 +1359,12 @@
"\n"
"ERRO: valor <%s> fora do intervalo do parâmetro <%s>\n"
#, c-format
msgstr " Intervalo legal: %s\n"
#, c-format
msgid ""
"\n"
@@ -1375,7 +1373,7 @@
"\n"
"ERRO: Falta valor para o parâmetro <%s>\n"
#, c-format
msgid ""
"\n"
@@ -1386,7 +1384,7 @@
"ERRO: Parâmetro necessário <%s> não fornecido:\n"
" (%s).\n"
#, c-format
msgid ""
"\n"
@@ -1395,17 +1393,17 @@
"\n"
"ERRO: A opção <%s> deve ser múltipla de %d\n"
#, c-format
msgstr " Você forneceu %d elementos:\n"
#, c-format
msgstr "ERRO: opção <%s>:<%s> já existe.\n"
#, c-format
msgid ""
"\n"
@@ -1414,7 +1412,7 @@
"\n"
"FLAG: forneça o flag seguinte?\n"
#, c-format
msgid ""
"\n"
@@ -1423,51 +1421,51 @@
"\n"
"OPÇÃO: %s\n"
#, c-format
msgid " key: %s\n"
msgstr " chave: %s\n"
#, c-format
msgstr " formato: %s\n"
#, c-format
msgstr " padrão: %s\n"
#, c-format
msgstr "obrigatória: %s\n"
#, c-format
msgstr "múltipla: %s\n"
#, c-format
msgstr " opções: %s\n"
#, c-format
msgstr "Digite uma opção > "
msgstr " Tentar outra vez? "
#, c-format
msgstr "Desculpe, %s não é aceito.\n"
#, c-format
msgid ""
"\n"
@@ -1478,11 +1476,11 @@
"Você escolheu.:\n"
" %s\n"
msgstr "Isso está certo? "
msgstr "para aceitar os valores padrão"
@@ -2885,7 +2883,7 @@
msgstr "Impossível abrir arquivo %s"
msgstr "O formato requisitado não foi compilado nesta versão"
@@ -3051,6 +3049,59 @@
msgstr "Ignorando feição OGR sem ID"
+#, fuzzy
+msgstr "G_calloc: memória esgotada"
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Dimensões do vetor além dos limites"
+#, fuzzy
+msgstr "Dimensões da matriz além dos limites"
+#, fuzzy, c-format
+msgstr "não consegui abrir %s para escrita"
+#, fuzzy, c-format
+msgstr "Erro de escrita no arquivo de índices espaciais."
+#, fuzzy, c-format
+msgstr "Impossível abrir índice de categoria para mapa vetorial <%s>"
msgstr "Número do campo deve ser 1 ou maior."
@@ -3127,47 +3178,123 @@
msgstr ""
-#, c-format
+#, fuzzy, c-format
msgstr "Nome de mapa de vetor <%s> ilegal. não pode conter '.' ou 'NULL'.\n"
-#, c-format
+#, fuzzy, c-format
msgstr "Illegal vector map name <%s>. Must start with a letter.\n"
-#, c-format
+#, fuzzy, c-format
msgstr "Nome de mapa de vetor <%s> ilegal. Caractere <%c> não permitido.\n"
-#, c-format
-msgstr "Nome de arquivo de saída %s não é um nome de vetor válido."
+#, fuzzy, c-format
+msgstr "Nome de arquivo de saída '%s' não é um nome de raster válido."
#, c-format
+msgstr "Vetor de entrada '%s' não encontrado"
+#, fuzzy, c-format
+msgstr "Mapa de saída '%s' usado como entrada"
+#, fuzzy, c-format
+msgstr "Impossível mudar de diretório para %s"
+#, fuzzy, c-format
msgstr "Nome do mapa não obedece ao SQL"
-#, c-format
+#, fuzzy, c-format
msgstr "O vetor '%s' já existe e será sobrescrito."
-#, c-format
-msgstr "Vetor de entrada '%s' não encontrado"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "não foi possível abrir o mapa raster [%s em %s]"
#, c-format
-msgstr "não consegui copiar o vetor '%s' para '%s'"
+msgstr ""
+#, fuzzy, c-format
+msgstr "Impossível abrir arquivo %s"
+#, fuzzy, c-format
+msgstr "Impossível abrir base de dados <%s> com driver <%s>"
+#, fuzzy, c-format
+msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Impossível abrir topologia para mapa vetorial <%s>"
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
@@ -3252,77 +3379,67 @@
msgstr "Direção da linha errada em Vect_net_get_line_cost()"
+#, fuzzy, c-format
msgstr "ATENÇÃO: Programador solicitou open_level desconhecido"
-#, c-format
+#, fuzzy
+msgid ""
msgstr ""
"Um mapa que não está no mapset atual não pode ser aberto para atualização."
-#, c-format
-msgstr "Impossível abrir mapa vetorial existente <%s>"
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
msgstr "Impossível abrir vetor existente <%s> no nível [%d]"
+#, fuzzy
msgstr "Impossível ler arquivo de cabeçalho"
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
msgstr "Impossível abrir histórico para mapa vetorial %s"
-#, c-format
-msgstr "Impossível apagar o vetor existente <%s>"
-#, c-format
-msgstr "não consegui abrir vetor novo %s"
-#, c-format
-msgstr "Não consegui abrir histórico para o vetor %s"
+#, fuzzy, c-format
-#, c-format
-msgstr "não consegui obter informações sobre o arquivo '%s'"
+#, fuzzy, c-format
+#, fuzzy
msgstr "Tamanho do arquivo 'coor' difere do valor gravado no arquivo topo."
-#, c-format
+#, fuzzy, c-format
msgstr "Favor reconstruir a topologia do vetor '%s@%s'"
@@ -3344,35 +3461,35 @@
msgstr "Impossível obter geometria do elemento, FID [%ld]"
msgstr "Registrando pontos"
msgstr "Todos os vértices"
msgstr "Pontos registrados"
msgstr ""
msgstr "Nós marcados para encaixar"
msgid "Snaps"
msgstr "Encaixe"
msgstr "Vértices encaixados"
msgstr "Novos vértices"
@@ -3500,6 +3617,30 @@
msgstr ""
+#~ msgstr "Nome de arquivo de saída %s não é um nome de vetor válido."
+#~ msgstr "Vetor de entrada '%s' não encontrado"
+#~ msgstr "não consegui copiar o vetor '%s' para '%s'"
+#~ msgstr "Impossível abrir mapa vetorial existente <%s>"
+#~ msgstr "Impossível apagar o vetor existente <%s>"
+#~ msgstr "não consegui abrir vetor novo %s"
+#~ msgstr "Não consegui abrir histórico para o vetor %s"
+#~ msgstr "não consegui obter informações sobre o arquivo '%s'"
#~ msgstr "Impossível abrir diretório %s"
Index: grasslibs_pt_br.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_pt_br.po,v
retrieving revision 1.25
retrieving revision 1.25.2.1
diff -u -d -r1.25 -r1.25.2.1
--- grasslibs_pt_br.po 21 Sep 2007 22:12:44 -0000 1.25
+++ grasslibs_pt_br.po 23 Nov 2007 17:33:18 -0000 1.25.2.1
@@ -10,10 +10,10 @@
msgstr ""
"Project-Id-Version: grasslibs_pt_br\n"
"PO-Revision-Date: 2007-05-20 10:44-0300\n"
"Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail.com>\n"
-"Language-Team: Brazilian Portuguese <translations at grass.itc.it>\n"
+"Language-Team: Brazilian Portuguese <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=ISO-8859-1\n"
#, c-format
#, c-format
@@ -1126,11 +1124,11 @@
@@ -1138,82 +1136,82 @@
msgid "Type"
msgstr "Tipo"
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
#, c-format
msgid ""
"\n"
@@ -1222,14 +1220,14 @@
"\n"
"Descrição:\n"
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1240,7 +1238,7 @@
"Uso:\n"
#, c-format
msgid ""
"\n"
@@ -1249,19 +1247,19 @@
"\n"
"Flags:\n"
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1270,80 +1268,80 @@
"\n"
"Parâmetros:\n"
#, c-format
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"Flags:\n"
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"Parâmetros:\n"
#, fuzzy
msgid "Options"
#, fuzzy
msgid "Default"
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
#, c-format
#, c-format
#, c-format
#, c-format
msgid ""
"\n"
@@ -1352,12 +1350,12 @@
"\n"
#, c-format
#, c-format
msgid ""
"\n"
@@ -1366,12 +1364,12 @@
"\n"
#, c-format
#, c-format
msgid ""
"\n"
@@ -1380,7 +1378,7 @@
"\n"
#, c-format
msgid ""
"\n"
@@ -1391,7 +1389,7 @@
" (%s).\n"
#, c-format
msgid ""
"\n"
@@ -1400,17 +1398,17 @@
"\n"
#, c-format
#, c-format
#, c-format
msgid ""
"\n"
@@ -1419,7 +1417,7 @@
"\n"
#, c-format
msgid ""
"\n"
@@ -1428,51 +1426,51 @@
"\n"
"OPÇÃO: %s\n"
#, c-format
msgid " key: %s\n"
#, c-format
#, c-format
#, c-format
#, c-format
#, c-format
#, c-format
#, c-format
#, c-format
msgid ""
"\n"
@@ -1483,11 +1481,11 @@
"Você escolheu.:\n"
" %s\n"
@@ -2891,7 +2889,7 @@
msgstr "não foi possível abrir o arquivo %s em %s"
@@ -3059,6 +3057,57 @@
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Erro de escrita no arquivo de índices espaciais.\n"
+#, fuzzy, c-format
+msgstr "Não consegui abrir histórico para o vetor %s"
@@ -3135,47 +3184,123 @@
msgstr ""
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
#, c-format
+msgstr ""
+#, fuzzy, c-format
+msgstr "não foi possível abrir o arquivo %s em %s"
+#, fuzzy, c-format
+msgstr "não consegui abrir banco de dados %s"
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
#, fuzzy
@@ -3267,79 +3392,67 @@
msgstr ""
-#, fuzzy
-msgstr "ATENÇÃO: Programador solicitou open_level desconhecido\n"
#, fuzzy, c-format
+msgstr "ATENÇÃO: Programador solicitou open_level desconhecido\n"
+#, fuzzy
+msgid ""
msgstr ""
#, fuzzy, c-format
-msgstr "não posso apagar o vetor existente %s"
#, fuzzy, c-format
msgstr "não consegui abrir vetor antigo %s no nível %d"
#, fuzzy
msgstr "não consegui abrir arquivo temporário"
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
-#, c-format
-#, c-format
-#, c-format
+#, fuzzy, c-format
+#, fuzzy
-#, c-format
+#, fuzzy, c-format
@@ -3362,37 +3475,37 @@
msgstr ""
#, fuzzy
msgstr "Registrando linhas: "
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3524,6 +3637,32 @@
msgstr ""
+#, fuzzy
+#~ msgstr "não posso apagar o vetor existente %s"
+#, fuzzy
#, fuzzy
Index: grasslibs_ru.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_ru.po,v
retrieving revision 1.24
retrieving revision 1.24.2.1
diff -u -d -r1.24 -r1.24.2.1
--- grasslibs_ru.po 21 Sep 2007 22:12:44 -0000 1.24
+++ grasslibs_ru.po 23 Nov 2007 17:33:18 -0000 1.24.2.1
@@ -6,10 +6,10 @@
msgstr ""
"Project-Id-Version: grasslibs_ru\n"
"PO-Revision-Date: 2006-07-07 11:52+0200\n"
"Last-Translator: Markus Neteler <neteler at itc.it>\n"
-"Language-Team: Russian <translations at grass.itc.it>\n"
+"Language-Team: Russian <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=KOI8-R\n"
@@ -805,13 +805,11 @@
msgstr " ."
#, fuzzy, c-format
msgstr " "
#, fuzzy, c-format
msgstr " "
@@ -1109,12 +1107,12 @@
msgstr " "
#, fuzzy
msgstr " "
#, fuzzy
msgstr " "
@@ -1124,101 +1122,101 @@
msgstr "×ÅËÔÏÒ"
#, fuzzy
msgstr "×ÅËÔÏÒ"
#, fuzzy
msgstr "×ÅËÔÏÒ"
#, fuzzy
msgstr "×ÅËÔÏÒ"
msgid "Type"
msgstr ""
msgstr ""
msgstr ""
msgid ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr " "
#, fuzzy
msgstr "×ÅËÔÏÒ"
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy, c-format
msgstr "éÚ×ÉÎÉÔÅ <%s> ÎÅ×ÏÚÍÏÖÎÁÑ ÏÐÃÉÑ\n"
#, c-format
msgid ""
"\n"
"Description:\n"
msgstr ""
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1226,131 +1224,131 @@
msgstr ""
#, c-format
msgid ""
"\n"
"Flags:\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
"Parameters:\n"
msgstr ""
#, fuzzy, c-format
msgstr " %*s ÐÏ ÕÍÏÌÞÁÎÉÀ: %s\n"
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
msgid "Flags"
msgstr ""
msgid "Parameters"
msgstr ""
#, fuzzy
msgid "Options"
msgstr " ÏÐÃÉÉ: %s\n"
#, fuzzy
msgid "Default"
msgstr " ÐÏ ÕÍÏÌ.: %s\n"
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, fuzzy, c-format
msgstr " %*s ÏÐÃÉÉ: "
#, fuzzy, c-format
msgstr "éÚ×ÉÎÉÔÅ, <%c> ÎÅ×ÏÚÍÏÖÎÙÊ ÆÌÁÇ\n"
#, fuzzy, c-format
msgstr "éÚ×ÉÎÉÔÅ, <%s=> ÎÅÏÄÎÏÚÎÁÞÎÙÊ ÐÁÒÁÍÅÔÒ\n"
#, fuzzy, c-format
msgstr "éÚ×ÉÎÉÔÅ, <%s> ÎÅ×ÏÚÍÏÖÎÙÊ ÐÁÒÁÍÅÔÒ\n"
#, fuzzy, c-format
msgid ""
"\n"
msgstr " "
#, fuzzy, c-format
msgstr " ðÒÅÄÓÔÁ×ÌÅÎÎÏÇÏ ËÁË: %s\n"
#, fuzzy, c-format
msgid ""
"\n"
msgstr " "
#, fuzzy, c-format
msgstr " ÷ÏÚÍÏÖÎÙÊ ÄÉÁÐÁÚÏÎ: %s\n"
#, fuzzy, c-format
msgid ""
"\n"
msgstr " "
#, fuzzy, c-format
msgid ""
"\n"
@@ -1360,83 +1358,83 @@
" \n"
#, fuzzy, c-format
msgid ""
"\n"
msgstr " "
#, fuzzy, c-format
msgstr " ÷Ù ÚÁÄÁÌÉ %d ÒÁÚ:\n"
#, fuzzy, c-format
msgstr " "
#, c-format
msgid ""
"\n"
msgstr ""
#, fuzzy, c-format
msgid ""
"\n"
"OPTION: %s\n"
msgstr " "
#, fuzzy, c-format
msgid " key: %s\n"
msgstr " ËÌÀÞ: %s\n"
#, fuzzy, c-format
msgstr " ÆÏÒÍÁÔ: %s\n"
#, fuzzy, c-format
#, fuzzy, c-format
msgstr "ÎÅÏÂÈ.: %s\n"
#, fuzzy, c-format
msgstr "ÍÎÏÖ.: %s\n"
#, fuzzy, c-format
#, fuzzy, c-format
msgstr "ÚÁÄÁÊÔÅ ÏÐÃÉÀ > "
#, fuzzy
msgstr " ðÏÐÒÏÂÏ×ÁÔØ ÓÎÏ×Á? "
#, fuzzy, c-format
msgstr "éÚ×ÉÎÉÔÅ, %s ÎÅ ÐÒÉÅÍÌÅÍÏ.\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1446,12 +1444,12 @@
"\n"
#, fuzzy
msgstr "ðÒÁ×ÉÌØÎÏ?"
#, fuzzy
msgstr "ÞÔÏÂÙ ÕÓÔÁÎÏ×ÉÔØ ÐÏ ÕÍÏÌÞÁÎÉÀ"
@@ -2875,7 +2873,7 @@
msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ ÆÁÊÌ %s × %s"
#, fuzzy
@@ -3041,6 +3039,56 @@
msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy, c-format
+msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ %s ÄÌÑ ÚÁÐÉÓÉ"
+#, fuzzy, c-format
+msgstr "ïÛÉÂËÁ ÚÁÐÉÓÉ × ÆÁÊÌ Ó ÐÌÁ×ÁÀÝÅÊ ÔÏÞËÏÊ ÄÌÑ ËÁÒÔÙ %s"
+#, fuzzy, c-format
+msgstr "×ÅËÔÏÒ "
msgstr ""
@@ -3116,47 +3164,123 @@
msgstr ""
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
#, fuzzy, c-format
-msgstr " ×ÅËÔÏÒ."
+msgstr " ."
#, fuzzy, c-format
+msgstr "×ÅËÔÏÒ "
+#, fuzzy, c-format
+msgstr " "
+#, fuzzy, c-format
+msgstr " "
+#, fuzzy, c-format
msgstr " ."
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ ."
#, fuzzy, c-format
+msgstr " "
+#, fuzzy, c-format
+msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ ÒÁÓÔÒÏ×ÕÀ ËÁÒÔÕ [%s × %s]"
+#, c-format
+msgstr ""
+#, fuzzy, c-format
+msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ ÆÁÊÌ %s × %s"
+#, fuzzy, c-format
+msgstr " "
+#, fuzzy, c-format
+msgstr "îÅ×ÏÚÍÏÖÎÏ ÓÏÚÄÁÔØ ÆÁÊÌ ÚÁÇÏÌÏ×ËÁ ÄÌÑ [%s × %s]"
+#, fuzzy, c-format
+#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
#, fuzzy, c-format
-msgstr "×ÅËÔÏÒ "
+msgstr " "
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr " "
+#, fuzzy, c-format
+msgstr " "
+#, fuzzy, c-format
+msgstr "×ÅËÔÏÒ "
@@ -3244,78 +3368,65 @@
msgstr ""
+#, c-format
msgstr ""
-#, fuzzy, c-format
-msgstr "×ÅËÔÏÒ "
#, fuzzy
+msgid ""
msgstr " ."
#, fuzzy, c-format
-msgstr "×ÅËÔÏÒ "
+msgstr " "
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
#, fuzzy
msgstr "îÅ ÍÏÇÕ ÏÔËÒÙÔØ ×ÒÅÍ. ÆÁÊÌ"
-#, fuzzy, c-format
-msgstr "×ÅËÔÏÒ "
-#, fuzzy, c-format
-msgstr "×ÅËÔÏÒ "
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
#, fuzzy, c-format
-msgstr "×ÅËÔÏÒ "
+msgstr " "
#, fuzzy, c-format
-msgstr " "
msgstr ""
#, fuzzy, c-format
msgstr "×ÅËÔÏÒ "
@@ -3337,35 +3448,35 @@
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3498,6 +3609,38 @@
msgstr ""
+#, fuzzy
+#~ msgstr " ×ÅËÔÏÒ."
+#, fuzzy
+#~ msgstr "×ÅËÔÏÒ "
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#, fuzzy
+#~ msgstr " "
#, fuzzy
Index: grasslibs_sl.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_sl.po,v
--- grasslibs_sl.po 21 Sep 2007 22:12:44 -0000 1.20
+++ grasslibs_sl.po 23 Nov 2007 17:33:18 -0000 1.20.2.1
@@ -8,10 +8,10 @@
msgstr ""
"Project-Id-Version: grasslibs_sl\n"
"PO-Revision-Date: 2005-04-26 09:38+0200\n"
"Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
-"Language-Team: Sloven¹èina <translations at grass.itc.it>\n"
+"Language-Team: Sloven¹èina <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=ISO-8859-2\n"
msgstr "Izhodno ime '%s' ni veljavno ime za vektor."
#, c-format
msgstr "Ne najdem vhodnega sloja '%s'"
#, c-format
msgstr "Izhodni sloj '%s' je uporabljen kot vhodni"
msgstr "Ime vhodnega rastrskega sloja"
#, fuzzy
#, fuzzy
@@ -1153,89 +1151,89 @@
msgstr "Ime izhodnega rastrskega sloja"
#, fuzzy
msgstr "Ime vhodnega vektorskega sloja"
#, fuzzy
#, fuzzy
msgstr "Ime izhodnega vektorskega sloja"
msgid "Type"
msgstr "Tip"
msgstr ""
msgstr "©tevilka sloja"
msgid ""
msgstr ""
msgstr "Vrednost kategorije"
#, fuzzy
msgstr "Vrednost kategorij"
#, fuzzy
msgstr "Vrednost kategorij (primer: 1,3,7-9,13)"
#, fuzzy
msgstr "Ime odprte datoteke %s\n"
#, fuzzy
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgstr "Oprostite <%s> ni veljavna mo¾nost\n"
#, c-format
msgid ""
"\n"
@@ -1244,14 +1242,14 @@
"\n"
"Opis:\n"
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1262,7 +1260,7 @@
"Uporaba:\n"
#, c-format
msgid ""
"\n"
@@ -1271,19 +1269,19 @@
"\n"
"Izbire:\n"
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1292,80 +1290,80 @@
"\n"
"Parametri:\n"
#, c-format
msgstr " %*s privzet: %s\n"
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"Izbire:\n"
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"Parametri:\n"
#, fuzzy
msgid "Options"
msgstr "mo¾nosti: %s\n"
#, fuzzy
msgid "Default"
msgstr " privzet: %s\n"
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
msgstr " %*s mo¾nosti: "
#, c-format
msgstr "Oprostite <%c> ni veljavna izbira\n"
#, c-format
msgstr "Oprostite <%s=> je dvoumno\n"
#, c-format
msgstr "Oprostite <%s> ni veljaven parameter\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1374,12 +1372,12 @@
"\n"
"Napaka: neveljaven razpon sintakse za parameter <%s>\n"
#, c-format
msgstr " Predstavljen kot: %s\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1388,12 +1386,12 @@
"\n"
"Napaka: vrednost <%s> izven razpona za parameter <%s>\n"
#, c-format
msgstr " Dovoljeni razpon: %s\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1402,7 +1400,7 @@
"\n"
"Napaka: Manjkajoèa vrednost za parameter <%s>\n"
#, c-format
msgid ""
"\n"
@@ -1413,7 +1411,7 @@
"NAPAKA: Zahtevani parameter <%s> ni nastavljen:\n"
" (%s).\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1422,17 +1420,17 @@
"\n"
"Napaka: mo¾nost <%s> mora biti podana v veèkratnikih %d\n"
#, fuzzy, c-format
msgstr " Podali ste %d postavk:\n"
#, fuzzy, c-format
msgstr "Napaka: mo¾nost <%s>: <%s> obstaja.\n"
#, c-format
msgid ""
"\n"
@@ -1441,7 +1439,7 @@
"\n"
"IZBIRA: Doloèite naslednjo izbiro?\n"
#, c-format
msgid ""
"\n"
@@ -1450,51 +1448,51 @@
"\n"
"MO®NOST: %s\n"
#, c-format
msgid " key: %s\n"
msgstr " kljuè: %s\n"
#, c-format
msgstr " format: %s\n"
#, c-format
#, c-format
msgstr "zahtevan: %s\n"
#, c-format
msgstr "veèkraten: %s\n"
#, c-format
#, c-format
msgstr "vpi¹ite mo¾nost > "
msgstr " Poskusite ¹e enkrat. "
#, c-format
msgstr "Oprostite, %s ni sprejet.\n"
#, c-format
msgid ""
"\n"
@@ -1505,11 +1503,11 @@
"Izbrali ste:\n"
" %s\n"
msgstr "Ali je to pravilno? "
msgstr "za izbrati privzeto"
@@ -2921,7 +2919,7 @@
msgstr "Nezmo¾en odpreti datoteko %s v %s"
msgstr "Zahtevani format ni bil preveden v tej verziji"
@@ -3089,6 +3087,59 @@
msgstr ""
+#, fuzzy
+msgstr "ne morem dodeliti spomina"
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Dvojni atributni indeks je izven razpona"
+#, fuzzy
+#, fuzzy, c-format
+msgstr "Nezmo¾en odpreti %s za pisanje"
+#, fuzzy, c-format
+msgstr "Napaka pri pisanju datoteke sidx.\n"
+#, fuzzy, c-format
+msgstr "Ne morem odpreti datoteke z zgodovino za vektor '%s'"
msgstr "©tevilka polja mora biti 1 ali veè."
@@ -3165,48 +3216,124 @@
msgstr ""
-#, c-format
+#, fuzzy, c-format
msgstr ""
"Neveljavno ime vektorskega sloja <%s>. Ne sme vsebovati '.' ali 'NULL'.\n"
-#, c-format
+#, fuzzy, c-format
msgstr "Neveljavno ime vektorskega sloja <%s>. Zaèeti se mora s èrko.\n"
-#, c-format
+#, fuzzy, c-format
msgstr "Neveljavno ime vektorskega sloja <%s>. Znak <%c> ni dovoljen.\n"
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
+msgstr "Vneseni vektor '%s' ni bil najden"
+#, fuzzy, c-format
+msgstr "Izhodni sloj '%s' je uporabljen kot vhodni"
+#, fuzzy, c-format
+msgstr "ne morem spremeniti direktorija v %s"
+#, fuzzy, c-format
msgstr "Ime sloja se ne sklada z SQL pravili."
-#, c-format
+#, fuzzy, c-format
msgstr "Vektor '%s' ¾e obstaja in bo prepisan."
-#, c-format
-msgstr "Vneseni vektor '%s' ni bil najden"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "ne morem odpreti rastrskega sloja [%s v %s]"
#, c-format
-msgstr "Ne morem kopirati '%s' v '%s'"
+msgstr ""
+#, fuzzy, c-format
+msgstr "Nezmo¾en odpreti datoteko %s v %s"
+#, fuzzy, c-format
+msgstr "Ne morem zapisati povezav z bazo podatkov."
+#, fuzzy, c-format
+msgstr "Nezmo¾en ustvariti datoteko z vzglavjem za [%s v %s]"
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
#, fuzzy
@@ -3297,79 +3424,67 @@
msgstr ""
-#, fuzzy
-msgstr "Opozorilo, Za¾elen programer: nepoznan open_level\n"
#, fuzzy, c-format
+msgstr "Opozorilo, Za¾elen programer: nepoznan open_level\n"
+#, fuzzy
+msgid ""
msgstr "Sloj, ki ni v trenutnem mapset ne more biti odprt za posodabljanje."
#, fuzzy, c-format
-msgstr "Ne morem zbrisati obstojeèega vektorja %s"
#, fuzzy, c-format
msgstr "Ne morem odpreti starega vektorja %s na nivoju %d"
#, fuzzy
msgstr "Ne morem odpreti temp datoteke"
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
-#, c-format
-msgstr "Ne morem odpreti novega vektorja %s"
-#, c-format
-msgstr "Ne morem odpreti datoteke z zgodovino za vektor '%s'"
-#, c-format
-msgstr ""
+#, fuzzy, c-format
+#, fuzzy
msgstr ""
"Velikost datoteke 'coor' je razlièna od vrednosti shranjene v datoteki topo."
-#, c-format
+#, fuzzy, c-format
msgstr "Prosim ponovno izgradi topologijo vektorja '%s@%s'"
@@ -3391,37 +3506,37 @@
msgstr ""
#, fuzzy
msgstr "Registriram linije: "
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3554,6 +3669,29 @@
msgstr ""
+#~ msgstr "Izhodno ime '%s' ni veljavno ime za vektor."
+#~ msgstr "Vneseni vektor '%s' ni bil najden"
+#~ msgstr "Ne morem kopirati '%s' v '%s'"
+#, fuzzy
+#~ msgstr "Ne morem zbrisati obstojeèega vektorja %s"
+#, fuzzy
+#~ msgstr "Ne morem odpreti novega vektorja %s"
+#~ msgstr "Ne morem odpreti datoteke z zgodovino za vektor '%s'"
#, fuzzy
#~ msgstr "Starega vektorja %s ne morem odpreti"
@@ -3794,9 +3932,6 @@
#~ msgstr "Ni dvojnih atributov v site_list"
-#~ msgstr "Dvojni atributni indeks je izven razpona"
#~ msgstr "V site_list ni atributov tipa \"string\" "
Index: grasslibs_tr.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_tr.po,v
retrieving revision 1.15
retrieving revision 1.15.2.1
diff -u -d -r1.15 -r1.15.2.1
--- grasslibs_tr.po 21 Sep 2007 22:12:44 -0000 1.15
+++ grasslibs_tr.po 23 Nov 2007 17:33:18 -0000 1.15.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasslibs_tr\n"
"PO-Revision-Date: 2006-04-18 06:17+0300\n"
"Last-Translator: oyy <yilmazy at istanbul.edu.tr>\n"
-"Language-Team: Turkish <translations at grass.itc.it>\n"
+"Language-Team: Turkish <translations at lists.osgeo.org>\n"
@@ -814,13 +814,11 @@
msgstr "'%s' çıktı adı geçerli bir raster adı deÄildir."
#, c-format
msgstr "'%s' girdi haritası bulunamadı"
#, c-format
msgstr "'%s' çıktı haritası girdi olarak kullanılıyor"
@@ -1114,12 +1112,12 @@
msgstr "Girdi raster haritan(lar)ın adı"
#, fuzzy
msgstr "Girdi raster haritanın adı"
#, fuzzy
@@ -1129,86 +1127,86 @@
msgstr "Ãıktı raster haritanın adı"
msgstr "Girdi vektör haritanın adı"
#, fuzzy
#, fuzzy
msgstr "Ãıktı vektör haritanın adı"
msgid "Type"
msgstr "Tip"
msgstr ""
msgstr "Katman numarası"
msgid ""
msgstr ""
msgstr "Kategori deÄeri"
msgstr "Kategori deÄerleri"
msgstr "Ãrnek: 1,3,7-9,13"
#, fuzzy
msgstr "Açık %s dosyasının adı"
#, fuzzy
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgstr "Ãzgünüm <%s> geçerli bir seçenek deÄil\n"
#, c-format
msgid ""
"\n"
@@ -1217,14 +1215,14 @@
"\n"
"Tanım:\n"
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1235,7 +1233,7 @@
"Kullanım:\n"
#, c-format
msgid ""
"\n"
@@ -1244,19 +1242,19 @@
"\n"
"Flamalar:\n"
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1265,80 +1263,80 @@
"\n"
"Parametreler:\n"
#, c-format
msgstr " %*s varsayılan: %s\n"
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"Flamalar:\n"
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"Parametreler:\n"
#, fuzzy
msgid "Options"
msgstr "seçenekler: %s\n"
#, fuzzy
msgid "Default"
msgstr "varsayılan: %s\n"
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
msgstr " %*s seçenekler: "
#, c-format
msgstr "Ãzgünüm, <%c> geçerli bir flama deÄil\n"
#, c-format
msgstr ""
#, c-format
msgstr "Ãzgünüm <%s> geçerli bir parametre deÄil\n"
#, fuzzy, c-format
msgid ""
"\n"
"\n"
"Hata: <%s> parametresi için kayıp deÄer\n"
#, c-format
msgstr ""
#, fuzzy, c-format
msgid ""
"\n"
"\n"
#, c-format
msgstr "Uygun aralık: %s\n"
#, fuzzy, c-format
msgid ""
"\n"
"\n"
#, c-format
msgid ""
"\n"
@@ -1383,31 +1381,31 @@
" (%s).\n"
msgstr ""
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgstr ""
#, fuzzy, c-format
msgstr "Hata: seçenek <%s>: <%s> mevcut.\n"
#, c-format
msgid ""
"\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1416,51 +1414,51 @@
"\n"
"SEÃENEK: %s\n"
#, c-format
msgid " key: %s\n"
msgstr " anahtar: %s\n"
#, c-format
msgstr "format: %s\n"
#, c-format
#, c-format
msgstr "istenen: %s\n"
#, c-format
msgstr "çoklu: %s\n"
#, c-format
#, c-format
msgstr "seçeneÄi girin >"
msgstr "Tekrar deneyeyim mi?"
#, c-format
msgstr "Ãzgünüm, %s kabul edilmedi.\n"
#, c-format
msgid ""
"\n"
@@ -1471,11 +1469,11 @@
"Siz seçtiniz:\n"
" %s\n"
msgstr "Bu doÄru mu?"
msgstr "varsayılanı kabul et"
@@ -2870,7 +2868,7 @@
msgstr "%s içindeki %s dosyası açılamadı"
msgstr "İstenen format bu sürümde derlenmedi."
@@ -3036,6 +3034,56 @@
msgstr "ID'si olmayan OGR objesi görmezden gelindi."
+msgstr ""
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy, c-format
+msgstr "%s okuma için yazılamıyor"
+#, fuzzy, c-format
+msgstr "Mekansal indek dosyasını yazmada hata.\n"
+#, fuzzy, c-format
+msgstr "'%s' vektörünün geçmiŠdosyası açılamıyor"
msgstr "Alan numarası 1 veya daha büyük olmalıdır."
@@ -3107,47 +3155,123 @@
msgstr ""
-#, c-format
+#, fuzzy, c-format
msgstr "<%s> uygun olmayan vektör harita adı. '.' veya 'NULL' içermemelidir.\n"
-#, c-format
+#, fuzzy, c-format
msgstr "<%s> uygun olmayan vektör harita adı. Harf ile baÅlamalıdır.\n"
-#, c-format
+#, fuzzy, c-format
msgstr "<%s> uygun olmayan vektör harita adı. <%c> karakteri kullanılamaz.\n"
-#, c-format
-msgstr "'%s' çıktı adı geçerli vektör adı deÄil."
+#, fuzzy, c-format
+msgstr "'%s' çıktı adı geçerli bir raster adı deÄildir."
-#, c-format
+#, fuzzy, c-format
+msgstr "'%s' girdi vektörü bulunamadı"
+#, fuzzy, c-format
+msgstr "'%s' çıktı haritası girdi olarak kullanılıyor"
+#, fuzzy, c-format
+msgstr "Dizin %s'e deÄiÅtirilemiyor"
+#, fuzzy, c-format
msgstr "Harita adı SQL uyumlu deÄil"
-#, c-format
+#, fuzzy, c-format
msgstr "'%s' vektörü zaten mevcut ve üzerine yazılacak."
-#, c-format
-msgstr "'%s' girdi vektörü bulunamadı"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "[%s deki %s] raster haritası açılamıyor"
#, c-format
-msgstr "'%s' vektörü '%s' e kopyalanamıyor"
+msgstr ""
+#, fuzzy, c-format
+msgstr "%s içindeki %s dosyası açılamadı"
+#, fuzzy, c-format
+msgstr "%s veritabanı açılamıyor"
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
#, fuzzy
@@ -3239,77 +3363,65 @@
msgstr ""
+#, c-format
msgstr ""
-#, fuzzy, c-format
+#, fuzzy
+msgid ""
msgstr "Geçerli harita takımında olmayan harita güncellemek için açılamıyor."
#, fuzzy, c-format
-msgstr "Mevcut %s vektörü silinemiyor"
#, fuzzy, c-format
msgstr "%s eski vektörü %d katmanında açılamıyor"
#, fuzzy
msgstr "Geçici dosya açılamıyor"
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
-#, c-format
-msgstr "Yeni %s vektör dosyası açılamıyor"
-#, c-format
-msgstr "'%s' vektörünün geçmiŠdosyası açılamıyor"
-#, c-format
-msgstr ""
+#, fuzzy, c-format
msgstr ""
-#, c-format
+#, fuzzy, c-format
msgstr "Lütfen '%s@%s' vektörünün topolojisiin tekrar kurun"
@@ -3332,37 +3444,37 @@
msgstr ""
#, fuzzy
msgstr "çizgiler kaydediliyor: "
msgstr ""
#, fuzzy
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3493,6 +3605,29 @@
"Attempt to read line angle for the line which is not connected to the node: "
msgstr ""
+#~ msgstr "'%s' çıktı adı geçerli vektör adı deÄil."
+#~ msgstr "'%s' girdi vektörü bulunamadı"
+#~ msgstr "'%s' vektörü '%s' e kopyalanamıyor"
+#, fuzzy
+#~ msgstr "Mevcut %s vektörü silinemiyor"
+#, fuzzy
+#~ msgstr "Yeni %s vektör dosyası açılamıyor"
+#~ msgstr "'%s' vektörünün geçmiŠdosyası açılamıyor"
#, fuzzy
Index: grasslibs_vi.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_vi.po,v
--- grasslibs_vi.po 21 Sep 2007 22:12:44 -0000 1.20
+++ grasslibs_vi.po 23 Nov 2007 17:33:18 -0000 1.20.2.1
@@ -8,10 +8,10 @@
msgstr ""
"Project-Id-Version: grasslibs_vi\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2007-09-22 00:09+0200\n"
+"POT-Creation-Date: 2007-10-26 21:10+0200\n"
"PO-Revision-Date: 2006-09-20 16:09+0200\n"
"Last-Translator: Bui Huu Manh <bhmanh73 at yahoo.com>\n"
-"Language-Team: Vietnamese <translations at grass.itc.it>\n"
+"Language-Team: Vietnamese <translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
@@ -823,13 +823,11 @@
msgstr "Tên Äầu ra '%s' không phải là tên raster hợp lá»"
#: ../lib/gis/legal_name.c:88 ../lib/gis/legal_name.c:90
-#: ../lib/vector/Vlib/legal_vname.c:73 ../lib/vector/Vlib/legal_vname.c:75
#, c-format
msgid "Cannot find input map '%s'"
msgstr "Không thá» tìm thấy bản Äá» Äầu và o '%s'"
#: ../lib/gis/legal_name.c:109 ../lib/gis/legal_name.c:111
-#: ../lib/vector/Vlib/legal_vname.c:93 ../lib/vector/Vlib/legal_vname.c:95
#, c-format
msgid "Output map '%s' is used as input"
msgstr "Bản Äá» Äầu ra '%s' ÄÆ°á»£c sá» dụng là m Äầu và o"
@@ -1130,11 +1128,11 @@
msgid "Name of elevation raster map(s)"
msgstr "Tên cá»§a (các) bản Äá» raster Äá» cao"
-#: ../lib/gis/parser.c:480
+#: ../lib/gis/parser.c:480 ../lib/gis/parser.c:505
msgid "Name of input raster3d map"
msgstr "Tên cá»§a bản Äá» raster 3d Äầu và o"
-#: ../lib/gis/parser.c:489
+#: ../lib/gis/parser.c:489 ../lib/gis/parser.c:514
msgid "Name of input raster3d map(s)"
msgstr "Tên cá»§a (các) bản Äá» raster 3d Äầu và o"
@@ -1142,85 +1140,85 @@
msgid "Name for output raster3d map"
msgstr "Tên cá»§a bản Äá» raster 3d Äầu ra"
-#: ../lib/gis/parser.c:507 ../lib/gis/parser.c:532
+#: ../lib/gis/parser.c:524 ../lib/gis/parser.c:549
msgid "Name of input vector map"
msgstr "Tên cá»§a bản Äá» vector Äầu và o"
-#: ../lib/gis/parser.c:516
+#: ../lib/gis/parser.c:533 ../lib/gis/parser.c:558
#, fuzzy
msgid "Name of input vector map(s)"
-#: ../lib/gis/parser.c:524
+#: ../lib/gis/parser.c:541
msgid "Name for output vector map"
msgstr "Tên cá»§a bản Äá» vector Äầu ra"
-#: ../lib/gis/parser.c:541
+#: ../lib/gis/parser.c:567
msgid "Type"
msgstr "Kiá»u"
-#: ../lib/gis/parser.c:542
+#: ../lib/gis/parser.c:568
msgid "Feature type(s)"
msgstr ""
-#: ../lib/gis/parser.c:549
+#: ../lib/gis/parser.c:575
msgid "Layer number"
msgstr "Lá»p sá»"
-#: ../lib/gis/parser.c:550
+#: ../lib/gis/parser.c:576
msgid ""
"A single vector map can be connected to multiple database tables. This "
"number determines which table to use."
msgstr ""
-#: ../lib/gis/parser.c:557
+#: ../lib/gis/parser.c:583
msgid "Category value"
msgstr "Giá trỠphạm trù"
-#: ../lib/gis/parser.c:564
+#: ../lib/gis/parser.c:590
msgid "Category values"
msgstr "Các giá trỠphạm trù"
-#: ../lib/gis/parser.c:565
+#: ../lib/gis/parser.c:591
msgid "Example: 1,3,7-9,13"
msgstr "Và dụ: 1,3,7-9,13"
-#: ../lib/gis/parser.c:575
+#: ../lib/gis/parser.c:601
#, fuzzy
msgid "Name of input file"
msgstr "Tên cá»§a táºp tin má» %s"
-#: ../lib/gis/parser.c:583
+#: ../lib/gis/parser.c:609
#, fuzzy
msgid "Name for output file"
msgstr "Tên cá»§a bản Äá» raster Äầu ra"
-#: ../lib/gis/parser.c:591
+#: ../lib/gis/parser.c:617
msgid "Field separator"
msgstr ""
-#: ../lib/gis/parser.c:602
+#: ../lib/gis/parser.c:628
msgid "Color"
msgstr ""
-#: ../lib/gis/parser.c:603
+#: ../lib/gis/parser.c:629
msgid "Either a standard color name or R:G:B triplet"
msgstr ""
-#: ../lib/gis/parser.c:612
+#: ../lib/gis/parser.c:638
msgid "Background color"
msgstr ""
-#: ../lib/gis/parser.c:613
+#: ../lib/gis/parser.c:639
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
msgstr ""
-#: ../lib/gis/parser.c:915
+#: ../lib/gis/parser.c:941
#, c-format
msgid "Sorry <%s> is not a valid option\n"
msgstr "Xin lá»i <%s> không phải là tùy chá»n hợp lá»\n"
-#: ../lib/gis/parser.c:1026
+#: ../lib/gis/parser.c:1052
#, c-format
msgid ""
"\n"
@@ -1229,7 +1227,7 @@
"\n"
"Mô tả:\n"
-#: ../lib/gis/parser.c:1033
+#: ../lib/gis/parser.c:1059
#, c-format
msgid ""
"\n"
@@ -1238,7 +1236,7 @@
"\n"
"Các từ khóa:\n"
-#: ../lib/gis/parser.c:1037
+#: ../lib/gis/parser.c:1063
#, c-format
msgid ""
"\n"
@@ -1249,7 +1247,7 @@
"Cách sỠdụng:\n"
-#: ../lib/gis/parser.c:1109
+#: ../lib/gis/parser.c:1135
#, c-format
msgid ""
"\n"
@@ -1258,19 +1256,19 @@
"\n"
"Các cá»:\n"
-#: ../lib/gis/parser.c:1132 ../lib/gis/parser.c:1588 ../lib/gis/parser.c:1866
+#: ../lib/gis/parser.c:1158 ../lib/gis/parser.c:1614 ../lib/gis/parser.c:1892
msgid "Allow output files to overwrite existing files"
msgstr ""
-#: ../lib/gis/parser.c:1134 ../lib/gis/parser.c:1592
+#: ../lib/gis/parser.c:1160 ../lib/gis/parser.c:1618
msgid "Verbose module output"
msgstr ""
-#: ../lib/gis/parser.c:1135 ../lib/gis/parser.c:1595
+#: ../lib/gis/parser.c:1161 ../lib/gis/parser.c:1621
msgid "Quiet module output"
msgstr ""
-#: ../lib/gis/parser.c:1141
+#: ../lib/gis/parser.c:1167
#, c-format
msgid ""
"\n"
@@ -1279,80 +1277,80 @@
"\n"
"Các tham sá»:\n"
-#: ../lib/gis/parser.c:1164
+#: ../lib/gis/parser.c:1190
#, c-format
msgid " %*s default: %s\n"
msgstr " %*s mặc Äá»nh: %s\n"
-#: ../lib/gis/parser.c:1471
+#: ../lib/gis/parser.c:1497
msgid "NAME"
msgstr ""
-#: ../lib/gis/parser.c:1484
+#: ../lib/gis/parser.c:1510
msgid "KEYWORDS"
msgstr ""
-#: ../lib/gis/parser.c:1489
+#: ../lib/gis/parser.c:1515
msgid "SYNOPSIS"
msgstr ""
-#: ../lib/gis/parser.c:1563
+#: ../lib/gis/parser.c:1589
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"Các cá»:\n"
-#: ../lib/gis/parser.c:1604
+#: ../lib/gis/parser.c:1630
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"Các tham sá»:\n"
-#: ../lib/gis/parser.c:1645
+#: ../lib/gis/parser.c:1671
#, fuzzy
msgid "Options"
msgstr " tùy_chá»n: %s\n"
-#: ../lib/gis/parser.c:1651
+#: ../lib/gis/parser.c:1677
#, fuzzy
msgid "Default"
msgstr " mặc Äá»nh: %s\n"
-#: ../lib/gis/parser.c:1868
+#: ../lib/gis/parser.c:1894
msgid "Allow overwrite"
msgstr ""
-#: ../lib/gis/parser.c:1876
+#: ../lib/gis/parser.c:1902
msgid "Run with minimal output messages"
msgstr ""
-#: ../lib/gis/parser.c:1878
+#: ../lib/gis/parser.c:1904
msgid "Run quietly"
msgstr ""
-#: ../lib/gis/parser.c:1967
+#: ../lib/gis/parser.c:1993
#, c-format
msgid " %*s options: "
msgstr " %*s tùy_chá»n: "
-#: ../lib/gis/parser.c:2016 ../lib/gis/parser.c:2033
+#: ../lib/gis/parser.c:2042 ../lib/gis/parser.c:2059
#, c-format
msgid "Sorry, <%c> is not a valid flag\n"
msgstr "Xin lá»i, <%c> không phải là cá» hợp lá»\n"
-#: ../lib/gis/parser.c:2088
+#: ../lib/gis/parser.c:2114
#, c-format
msgid "Sorry, <%s=> is ambiguous\n"
msgstr "Xin lá»i, <%s=> không rõ rà ng\n"
-#: ../lib/gis/parser.c:2095
+#: ../lib/gis/parser.c:2121
#, c-format
msgid "Sorry, <%s> is not a valid parameter\n"
msgstr "Xin lá»i, <%s> không phải là tham sá» hợp lá»\n"
-#: ../lib/gis/parser.c:2180
+#: ../lib/gis/parser.c:2206
#, fuzzy, c-format
msgid ""
"\n"
"\n"
"Lá»i: Cú pháp miá»n cho tham sá» không hợp lá» <%s>\n"
-#: ../lib/gis/parser.c:2182
+#: ../lib/gis/parser.c:2208
#, c-format
msgid " Presented as: %s\n"
msgstr " ÄÆ°á»£c biá»u diá»
n thà nh: %s\n"
-#: ../lib/gis/parser.c:2185
+#: ../lib/gis/parser.c:2211
#, fuzzy, c-format
msgid ""
"\n"
@@ -1375,12 +1373,12 @@
"\n"
"Lá»i: giá trá» <%s> nằm ngoà i miá»n cho tham sá» <%s>\n"
-#: ../lib/gis/parser.c:2187
+#: ../lib/gis/parser.c:2213
#, c-format
msgid " Legal range: %s\n"
msgstr " Miá»n hợp lá»: %s\n"
-#: ../lib/gis/parser.c:2190
+#: ../lib/gis/parser.c:2216
#, fuzzy, c-format
msgid ""
"\n"
@@ -1389,7 +1387,7 @@
"\n"
"Lá»i: Giá trá» cho tham sá» bá» thiếu <%s>\n"
-#: ../lib/gis/parser.c:2350
+#: ../lib/gis/parser.c:2376
#, c-format
msgid ""
"\n"
@@ -1400,7 +1398,7 @@
"Lá»I: Tham sá» yêu cầu <%s> không ÄÆ°á»£c thiết láºp:\n"
" (%s).\n"
-#: ../lib/gis/parser.c:2453
+#: ../lib/gis/parser.c:2479
#, fuzzy, c-format
msgid ""
"\n"
@@ -1409,17 +1407,17 @@
"\n"
"Lá»i: tùy_chá»n <%s> phải ÄÆ°á»£c cung cấp á» dạng bá»i sá» cá»§a %d\n"
-#: ../lib/gis/parser.c:2455
+#: ../lib/gis/parser.c:2481
#, c-format
msgid " You provided %d items:\n"
msgstr " Bạn Äã cung cấp %d mục:\n"
-#: ../lib/gis/parser.c:2510
+#: ../lib/gis/parser.c:2536
#, fuzzy, c-format
msgid "ERROR: option <%s>: <%s> exists.\n"
msgstr "Lá»i: tùy_chá»n <%s>: <%s> Äã có.\n"
-#: ../lib/gis/parser.c:2557
+#: ../lib/gis/parser.c:2583
#, c-format
msgid ""
"\n"
@@ -1428,7 +1426,7 @@
"\n"
"Cá»: Thiết láºp cá» sau?\n"
-#: ../lib/gis/parser.c:2571
+#: ../lib/gis/parser.c:2597
#, c-format
msgid ""
"\n"
@@ -1437,51 +1435,51 @@
"\n"
"TÃY_CHá»N: %s\n"
-#: ../lib/gis/parser.c:2572
+#: ../lib/gis/parser.c:2598
#, c-format
msgid " key: %s\n"
msgstr " khóa: %s\n"
-#: ../lib/gis/parser.c:2574
+#: ../lib/gis/parser.c:2600
#, c-format
msgid " format: %s\n"
msgstr " Äá»nh dạng: %s\n"
-#: ../lib/gis/parser.c:2576
+#: ../lib/gis/parser.c:2602
#, c-format
msgid " default: %s\n"
-#: ../lib/gis/parser.c:2577
+#: ../lib/gis/parser.c:2603
#, c-format
msgid "required: %s\n"
msgstr "cần có: %s\n"
-#: ../lib/gis/parser.c:2579
+#: ../lib/gis/parser.c:2605
#, c-format
msgid "multiple: %s\n"
msgstr "bá»i: %s\n"
-#: ../lib/gis/parser.c:2581
+#: ../lib/gis/parser.c:2607
#, c-format
msgid " options: %s\n"
-#: ../lib/gis/parser.c:2596
+#: ../lib/gis/parser.c:2622
#, c-format
msgid "enter option > "
msgstr "nháºp tùy_chá»n > "
-#: ../lib/gis/parser.c:2610 ../lib/gis/parser.c:2621
+#: ../lib/gis/parser.c:2636 ../lib/gis/parser.c:2647
msgid " Try again? "
msgstr " ThỠlại? "
-#: ../lib/gis/parser.c:2619
+#: ../lib/gis/parser.c:2645
#, c-format
msgid "Sorry, %s is not accepted.\n"
msgstr "Xin lá»i, %s không ÄÆ°á»£c chấp nháºn.\n"
-#: ../lib/gis/parser.c:2630
+#: ../lib/gis/parser.c:2656
#, c-format
msgid ""
"\n"
@@ -1492,11 +1490,11 @@
"Bạn Äã chá»n:\n"
" %s\n"
-#: ../lib/gis/parser.c:2631
+#: ../lib/gis/parser.c:2657
msgid "Is this correct? "
msgstr "Äã Äúng chưa? "
-#: ../lib/gis/parser.c:2700
+#: ../lib/gis/parser.c:2726
msgid "to accept the default"
msgstr "Äá» chấp nháºn mặc Äá»nh"
@@ -2914,7 +2912,7 @@
msgid "Unable to open file %s"
msgstr "Không thá» má» táºp tin %s trong %s"
-#: ../lib/vector/Vlib/build.c:27 ../lib/vector/Vlib/open.c:53
+#: ../lib/vector/Vlib/build.c:27 ../lib/vector/Vlib/open.c:32
#: ../lib/vector/Vlib/write.c:36
msgid "Requested format is not compiled in this version"
msgstr "Äá»nh dạng ÄÆ°á»£c yêu cầu không ÄÆ°á»£c biên dá»ch trong phiên bản nà y"
@@ -3082,6 +3080,56 @@
msgid "OGR feature without ID ignored."
msgstr "Äá»i tượng OGR không có ID bá» bá» qua"
+#: ../lib/vector/Vlib/cats.c:45
+msgid "Vect_new_cats_struct(): Out of memory"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:138
+#, c-format
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:408
+#, c-format
+msgid "Unable to convert category string '%s' (from '%s') to category range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:30
+msgid "Category index is not up to date"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:62 ../lib/vector/Vlib/cindex.c:129
+#: ../lib/vector/Vlib/cindex.c:148 ../lib/vector/Vlib/cindex.c:171
+msgid "Invalid layer index (index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:110
+msgid "Invalid layer index (index < 0 or index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:235
+msgid "Layer or category index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:283
+msgid "Layer index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:456
+#, fuzzy, c-format
+msgid "Unable to open cidx file <%s> for write"
+msgstr "Kann %s nicht zum Beschreiben öffnen."
+#: ../lib/vector/Vlib/cindex.c:464
+#, fuzzy, c-format
+msgid "Error writing out category index file <%s>"
+msgstr "Lá»i khi Äang ghi táºp tin chá» mục không gian.\n"
+#: ../lib/vector/Vlib/cindex.c:507
+#, fuzzy, c-format
+msgid "Unable to open category index file for vector map <%s@%s>"
+msgstr "Không thá» má» táºp tin lá»ch sá» cá»§a vector '%s'"
#: ../lib/vector/Vlib/field.c:76
msgid "Field number must be 1 or greater."
msgstr "Sá» trưá»ng phải là 1 hoặc lá»n hÆ¡n."
@@ -3156,48 +3204,124 @@
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:23
-#, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'.\n"
+#: ../lib/vector/Vlib/legal_vname.c:39
+#, fuzzy, c-format
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
msgstr ""
"Tên bản Äá» vector không hợp lá» <%s>. Có thá» ÄÆ°á»£c chứa '.' hoặc 'NULL'.\n"
-#: ../lib/vector/Vlib/legal_vname.c:29
-#, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter.\n"
+#: ../lib/vector/Vlib/legal_vname.c:45
+#, fuzzy, c-format
+msgid "Illegal vector map name <%s>. Must start with a letter."
msgstr "Tên bản Äá» vector không hợp lá» <%s>. Phải bắt Äầu vá»i má»t chữ cái.\n"
-#: ../lib/vector/Vlib/legal_vname.c:35
-#, c-format
-msgid "Illegal vector map name <%s>. Character <%c> not allowed.\n"
+#: ../lib/vector/Vlib/legal_vname.c:51
+#, fuzzy, c-format
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
msgstr "Tên bản Äá» vector không hợp lá» <%s>. Ký tá»± <%c> không ÄÆ°á»£c phép.\n"
-#: ../lib/vector/Vlib/legal_vname.c:60 ../lib/vector/Vlib/legal_vname.c:62
-#, c-format
-msgid "Output name '%s' is not valid vector name."
-msgstr "Tên bản Äá» Äầu ra '%s' không phải là tên vector hợp lá»"
+#: ../lib/vector/Vlib/legal_vname.c:81 ../lib/vector/Vlib/legal_vname.c:83
+#, fuzzy, c-format
+msgid "Output vector map name <%s> is not valid map name"
+msgstr "Tên Äầu ra '%s' không phải là tên raster hợp lá»"
-#: ../lib/vector/Vlib/map.c:152 ../lib/vector/Vlib/map.c:268
-#: ../lib/vector/Vlib/open.c:526
-#, c-format
-msgid "Map name is not SQL compliant."
+#: ../lib/vector/Vlib/legal_vname.c:94 ../lib/vector/Vlib/legal_vname.c:96
+#: ../lib/vector/Vlib/map.c:302 ../lib/vector/Vlib/open.c:158
+#, fuzzy, c-format
+msgid "Vector map <%s> not found"
+msgstr "Không tìm thấy vector Äầu và o '%s'"
+#: ../lib/vector/Vlib/legal_vname.c:114 ../lib/vector/Vlib/legal_vname.c:116
+#, fuzzy, c-format
+msgid "Output vector map <%s> is used as input"
+msgstr "Bản Äá» Äầu ra '%s' ÄÆ°á»£c sá» dụng là m Äầu và o"
+#: ../lib/vector/Vlib/map.c:62 ../lib/vector/Vlib/map.c:75
+#, fuzzy, c-format
+msgid "Unable to read vector map <%s%s>"
+msgstr "không thá» Äá»i thư mục Äến %s"
+#: ../lib/vector/Vlib/map.c:167 ../lib/vector/Vlib/map.c:290
+#: ../lib/vector/Vlib/open.c:508
+#, fuzzy, c-format
+msgid "Vector map name is not SQL compliant"
msgstr "Tên bản Äá» không tương thÃch SQL."
-#: ../lib/vector/Vlib/map.c:156 ../lib/vector/Vlib/map.c:272
-#: ../lib/vector/Vlib/open.c:533
-#, c-format
-msgid "The vector '%s' already exists and will be overwritten."
+#: ../lib/vector/Vlib/map.c:171 ../lib/vector/Vlib/map.c:294
+#: ../lib/vector/Vlib/open.c:515
+#, fuzzy, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
msgstr "Vector '%s' Äã tá»n tại và sẽ bá» ghi Äè"
-#: ../lib/vector/Vlib/map.c:280
-#, c-format
-msgid "Input vector '%s' not found"
-msgstr "Không tìm thấy vector Äầu và o '%s'"
+#: ../lib/vector/Vlib/map.c:174 ../lib/vector/Vlib/open.c:519
+#, fuzzy, c-format
+msgid "Unable to delete vector map <%s>"
-#: ../lib/vector/Vlib/map.c:283
+#: ../lib/vector/Vlib/map.c:197 ../lib/vector/Vlib/map.c:305
+#, fuzzy, c-format
+msgid "Unable to copy vector map <%s> to <%s>"
+msgstr "không thá» má» bản Äá» raster [%s in %s]"
+#: ../lib/vector/Vlib/map.c:225 ../lib/vector/Vlib/map.c:337
+#: ../lib/vector/Vlib/map.c:442 ../lib/vector/Vlib/map.c:551
+#: ../lib/vector/Vlib/map.c:642
#, c-format
-msgid "Cannot copy vector '%s' to '%s'"
-msgstr "Không thá» sao chép vector '%s' tá»i '%s'"
+msgid "Database connection not defined for layer %d"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:239 ../lib/vector/Vlib/map.c:352
+#: ../lib/vector/Vlib/map.c:571 ../lib/vector/Vlib/map.c:668
+#, fuzzy, c-format
+msgid "Unable to copy table <%s>"
+msgstr "Không thá» má» táºp tin %s trong %s"
+#: ../lib/vector/Vlib/map.c:247 ../lib/vector/Vlib/map.c:373
+#: ../lib/vector/Vlib/map.c:577
+#, fuzzy, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr "Không thỠmỠCSDL"
+#: ../lib/vector/Vlib/map.c:251 ../lib/vector/Vlib/map.c:377
+#: ../lib/vector/Vlib/map.c:581
+#, fuzzy, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr "Không thá» tạo ra táºp tin header cho [%s á» %s]"
+#: ../lib/vector/Vlib/map.c:366 ../lib/vector/Vlib/map.c:460
+#, fuzzy, c-format
+msgid "Unable to delete table <%s>"
+#: ../lib/vector/Vlib/map.c:451
+#, fuzzy, c-format
+msgid "Unable to find table <%s> linked to vector map <%s>"
+#: ../lib/vector/Vlib/map.c:479
+#, fuzzy, c-format
+msgid "Unable to open directory '%s'"
+#: ../lib/vector/Vlib/map.c:490
+#, fuzzy, c-format
+msgid "Unable to delete file '%s'"
+#: ../lib/vector/Vlib/map.c:507
+#, fuzzy, c-format
+msgid "Unable to rename directory '%s' to '%s'"
+#: ../lib/vector/Vlib/map.c:515
+#, fuzzy, c-format
+msgid "Unable to remove directory '%s'"
+#: ../lib/vector/Vlib/map.c:563 ../lib/vector/Vlib/map.c:656
+#, fuzzy, c-format
+msgid "Unable to add database link for vector map <%s>"
#: ../lib/vector/Vlib/net.c:120
#, fuzzy
@@ -3289,79 +3413,67 @@
msgid "Wrong line direction in Vect_net_get_line_cost()"
msgstr ""
-#: ../lib/vector/Vlib/open.c:114
-#, fuzzy
-msgid "Programmer requested unknown open_level"
-msgstr "Cảnh báo: Láºp trình viên Äã yêu cầu open_level không biết\n"
-#: ../lib/vector/Vlib/open.c:179
+#: ../lib/vector/Vlib/open.c:93
#, fuzzy, c-format
-msgid "Vector map <%s> not found"
+msgid "Programmer requested unknown open level %d"
+msgstr "Cảnh báo: Láºp trình viên Äã yêu cầu open_level không biết\n"
-#: ../lib/vector/Vlib/open.c:189
-msgid "A map which is not in the current mapset cannot be opened for update."
+#: ../lib/vector/Vlib/open.c:168
+#, fuzzy
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
msgstr ""
"Má»t bản Äá» không á» trong bản Äá» hiá»n hà nh thì không thá» má» Äá» cáºp nháºt. "
-#: ../lib/vector/Vlib/open.c:207
+#: ../lib/vector/Vlib/open.c:186
#, fuzzy, c-format
-msgid "Cannot open existing vector map <%s>"
-msgstr "Không thá» xóa vector hiá»n có %s"
+msgid "Unable to open vector map <%s>"
-#: ../lib/vector/Vlib/open.c:217 ../lib/vector/Vlib/open.c:277
-#: ../lib/vector/Vlib/open.c:293
+#: ../lib/vector/Vlib/open.c:196 ../lib/vector/Vlib/open.c:256
+#: ../lib/vector/Vlib/open.c:273
#, fuzzy, c-format
-msgid "Cannot open existing vector <%s> on level [%d]"
+msgid "Unable to open vector map <%s> on topology level %d"
msgstr "Không thỠmỠvector cũ %s Ỡcấp %d"
-#: ../lib/vector/Vlib/open.c:218
+#: ../lib/vector/Vlib/open.c:197
#, fuzzy
-msgid "Cannot read head file"
+msgid "Unable to read head file"
msgstr "Không thá» má» táºp tin tạm"
-#: ../lib/vector/Vlib/open.c:238
+#: ../lib/vector/Vlib/open.c:217
#, fuzzy, c-format
-msgid "Cannot open topo file for vector map <%s>"
+msgid "Unable to open topology file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:261
+#: ../lib/vector/Vlib/open.c:240
#, fuzzy, c-format
-msgid "Cannot open category index file for vector map <%s>"
+msgid "Unable to open category index file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:340
+#: ../lib/vector/Vlib/open.c:321 ../lib/vector/Vlib/open.c:542
#, fuzzy, c-format
-msgid "Cannot open history file for vector map <%s>"
+msgid "Unable to open history file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:537
+#: ../lib/vector/Vlib/open.c:533
#, fuzzy, c-format
-msgid "Cannot delete existing vector <%s>"
-#: ../lib/vector/Vlib/open.c:551
-#, c-format
-msgid "Cannot open new vector %s"
-msgstr "Không thá» má» vector má»i %s"
-#: ../lib/vector/Vlib/open.c:560
-#, c-format
-msgid "Cannot open history file for vector '%s'"
-msgstr "Không thá» má» táºp tin lá»ch sá» cá»§a vector '%s'"
+msgid "Unable to create vector map <%s>"
-#: ../lib/vector/Vlib/open.c:608
-#, c-format
-msgid "Could not stat file '%s'"
-msgstr "Không thá» khá»i Äá»ng táºp tin %s"
+#: ../lib/vector/Vlib/open.c:590
+#, fuzzy, c-format
+msgid "Unable to stat file <%s>"
-#: ../lib/vector/Vlib/open.c:719
-msgid "Size of 'coor' file differs from value saved in topo file."
+#: ../lib/vector/Vlib/open.c:701
+#, fuzzy
+msgid "Size of 'coor' file differs from value saved in topology file"
msgstr "KÃch thưá»c cá»§a táºp tin 'coor' khác vá»i giá trá» lưu trong táºp tin tôpô."
-#: ../lib/vector/Vlib/open.c:730
-#, c-format
-msgid "Please rebuild topology for vector '%s@%s'"
+#: ../lib/vector/Vlib/open.c:712
+#, fuzzy, c-format
+msgid "Please rebuild topology for vector map <%s@%s>"
msgstr "Vui lòng xây dựng lại tôpô cho vector '%s@%s'"
#: ../lib/vector/Vlib/read_nat.c:160
@@ -3384,37 +3496,37 @@
msgid "Cannot get feature geometry, FID [%ld]"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:139 ../lib/vector/Vlib/snap.c:179
+#: ../lib/vector/Vlib/snap.c:119 ../lib/vector/Vlib/snap.c:159
#, fuzzy
msgid "Registering points"
msgstr "Äang ÄÄng ký các ÄÆ°á»ng:"
-#: ../lib/vector/Vlib/snap.c:188
+#: ../lib/vector/Vlib/snap.c:168
msgid "All vertices"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:189
+#: ../lib/vector/Vlib/snap.c:169
#, fuzzy
msgid "Registered points"
-#: ../lib/vector/Vlib/snap.c:234
+#: ../lib/vector/Vlib/snap.c:214
msgid "Nodes marked as anchor"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:235
+#: ../lib/vector/Vlib/snap.c:215
msgid "Nodes marked to be snapped"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:244 ../lib/vector/Vlib/snap.c:384
+#: ../lib/vector/Vlib/snap.c:224 ../lib/vector/Vlib/snap.c:364
msgid "Snaps"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:392
+#: ../lib/vector/Vlib/snap.c:372
msgid "Snapped vertices"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:393
+#: ../lib/vector/Vlib/snap.c:373
msgid "New vertices"
msgstr ""
@@ -3545,6 +3657,32 @@
"node = [%d] line = [%d]"
msgstr ""
+#~ msgid "Output name '%s' is not valid vector name."
+#~ msgstr "Tên bản Äá» Äầu ra '%s' không phải là tên vector hợp lá»"
+#~ msgid "Input vector '%s' not found"
+#~ msgstr "Không tìm thấy vector Äầu và o '%s'"
+#~ msgstr "Không thá» sao chép vector '%s' tá»i '%s'"
+#, fuzzy
+#~ msgid "Cannot open existing vector map <%s>"
+#~ msgstr "Không thá» xóa vector hiá»n có %s"
+#, fuzzy
+#~ msgid "Cannot delete existing vector <%s>"
+#~ msgid "Cannot open new vector %s"
+#~ msgstr "Không thá» má» vector má»i %s"
+#~ msgid "Cannot open history file for vector '%s'"
+#~ msgstr "Không thá» má» táºp tin lá»ch sá» cá»§a vector '%s'"
+#~ msgid "Could not stat file '%s'"
+#~ msgstr "Không thá» khá»i Äá»ng táºp tin %s"
#, fuzzy
#~ msgid "Can't open directory %s"
Index: grasslibs_zh.po
RCS file: /grassrepository/grass6/locale/po/grasslibs_zh.po,v
retrieving revision 1.19
retrieving revision 1.19.2.1
diff -u -d -r1.19 -r1.19.2.1
--- grasslibs_zh.po 21 Sep 2007 22:12:44 -0000 1.19
+++ grasslibs_zh.po 23 Nov 2007 17:33:18 -0000 1.19.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasslibs_zh\n"
"PO-Revision-Date: 2006-02-09 14:37+0800\n"
"Last-Translator: Zhang Jun <nilarcs at gmail.com>\n"
-"Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
+"Language-Team: Simplified Chinese <translations at lists.osgeo.org>\n"
@@ -819,13 +819,11 @@
msgstr "è¾åºçåç§°'%s'䏿¯ææçç¢éåç§°ã"
#, c-format
msgstr "æ æ³æ¾å°è¾å
¥å°å¾'%s'"
#, c-format
msgstr "è¾åºå°å¾'%s'被ç¨ä½è¾å
@@ -1129,12 +1127,12 @@
msgstr "è¾å
¥æ
æ ¼çåç§°"
#, fuzzy
msgstr "è¾å
¥æ
æ ¼çåç§°"
#, fuzzy
msgstr "è¾å
¥æ
æ ¼çåç§°"
@@ -1144,87 +1142,87 @@
msgstr "è¾åºæ
æ ¼çåç§°"
#, fuzzy
msgstr "è¾å
¥ç¢éçåç§°"
#, fuzzy
msgstr "è¾å
¥ç¢éçåç§°"
#, fuzzy
msgstr "è¾åºç¢éçåç§°"
msgid "Type"
msgstr "ç±»å"
msgstr ""
msgstr "å¾å±å·"
msgid ""
msgstr ""
msgstr "ç±»å«å¼"
msgstr "ç±»å«å¼"
msgstr "ä¾å¦ï¼1,3,7-9,13"
#, fuzzy
msgstr "æå¼æä»¶çåç§° %s"
#, fuzzy
msgstr "è¾åºæ
æ ¼çåç§°"
msgstr ""
msgid "Color"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgstr "对ä¸èµ·ï¼<%s>䏿¯ææçé项\n"
#, c-format
msgid ""
"\n"
@@ -1233,14 +1231,14 @@
"\n"
"æè¿°ï¼\n"
#, c-format
msgid ""
"\n"
"Keywords:\n"
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1251,7 +1249,7 @@
"ç¨æ³ï¼\n"
#, c-format
msgid ""
"\n"
@@ -1260,19 +1258,19 @@
"\n"
"æ è®°ï¼\n"
msgstr ""
msgstr ""
msgstr ""
#, c-format
msgid ""
"\n"
@@ -1281,80 +1279,80 @@
"\n"
"åæ°ï¼\n"
#, c-format
msgstr " %*s é»è®¤å¼ï¼ %s\n"
msgid "NAME"
msgstr ""
msgid "KEYWORDS"
msgstr ""
msgid "SYNOPSIS"
msgstr ""
#, fuzzy
msgid "Flags"
msgstr ""
"\n"
"æ è®°ï¼\n"
#, fuzzy
msgid "Parameters"
msgstr ""
"\n"
"åæ°ï¼\n"
#, fuzzy
msgid "Options"
msgstr " éé¡¹ï¼ %s\n"
#, fuzzy
msgid "Default"
msgstr " é»è®¤å¼ï¼ %s\n"
msgstr ""
msgstr ""
msgid "Run quietly"
msgstr ""
#, c-format
msgstr " %*s éé¡¹ï¼ "
#, c-format
msgstr "对ä¸èµ·ï¼<%c>䏿¯ææçæ è®°\n"
#, c-format
msgstr "对ä¸èµ·ï¼<%s=>ä¸æç¡®\n"
#, c-format
msgstr "对ä¸èµ·ï¼<%s>䏿¯ææçåæ°\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1363,12 +1361,12 @@
"\n"
"é误ï¼åæ°<%s>çéæ³èå´è¯æ³\n"
#, c-format
msgstr " åºè¡¨è¿°ä¸ºï¼ %s\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1377,12 +1375,12 @@
"\n"
"é误ï¼å¼<%s>è¶
åºäºåæ°<%s>çèå´\n"
#, c-format
msgstr " åæ³èå´æ¯ï¼ %s\n"
#, fuzzy, c-format
msgid ""
"\n"
"\n"
"é误ï¼åæ°<%s>缺å°å¼\n"
#, c-format
msgid ""
"\n"
"é误ï¼å¿
é¡»çåæ°<%s>æªè®¾ç½®ï¼\n"
" (%s)ã\n"
#, fuzzy, c-format
msgid ""
"\n"
@@ -1411,17 +1409,17 @@
"\n"
"é误ï¼é项<%s>å¿
é¡»ä¹ä»¥%d\n"
#, c-format
msgstr " æ¨æä¾äº %d 个æ¡ç®ï¼\n"
#, fuzzy, c-format
msgstr "é误ï¼é项<%s>ï¼<%s>å·²åå¨ã\n"
#, c-format
msgid ""
"\n"
@@ -1430,7 +1428,7 @@
"\n"
"æ è®°ï¼æ¯å¦è®¾ç½®ä¸é¢çæ è®°ï¼\n"
#, c-format
msgid ""
"\n"
@@ -1439,51 +1437,51 @@
"\n"
"éé¡¹ï¼ %s\n"
#, c-format
msgid " key: %s\n"
msgstr " å
³é®åï¼ %s\n"
#, c-format
msgstr " æ ¼å¼ï¼ %s\n"
#, c-format
#, c-format
msgstr " å¿
é¡»å¼ï¼ %s\n"
#, c-format
msgstr " åæ°ï¼ %s\n"
#, c-format
#, c-format
msgstr "è¾å
¥é项 > "
msgstr " éè¯ï¼"
#, c-format
msgstr "对ä¸èµ·ï¼%s ä¸è½è¢«æ¥åã\n"
#, c-format
msgid ""
"\n"
@@ -1494,11 +1492,11 @@
"æ¨éæ©äºï¼\n"
" %s\n"
msgstr "æ£ç¡®åï¼"
msgstr "æ¥åé»è®¤å¼"
@@ -2907,7 +2905,7 @@
msgstr "æ æ³æå¼æä»¶ %s å¨ %s ä¸"
msgstr "å¨è¿ä¸çæ¬ä¸æ²¡æç¼è¯è¯·æ±çæ ¼å¼"
@@ -3075,6 +3073,59 @@
msgstr "没æ ID ç OGR è¦ç´ 被忽ç¥ã "
+#, fuzzy
+msgstr "æ æ³åé
å
å"
+#, c-format
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "åç²¾åº¦å±æ§ç´¢å¼è¶ç"
+#, fuzzy
+#, fuzzy, c-format
+msgstr "æ æ³ä¸ºåå
¥æå¼%s"
+#, fuzzy, c-format
+msgstr "å空é´ç´¢å¼æä»¶æ¶åºéã\n"
+#, fuzzy, c-format
+msgstr "æ æ³æå¼ç¢é'%s'çåå²è®°å½"
msgstr "åæ®µæ°éå¿
须大äºçäº1ã"
@@ -3149,47 +3200,123 @@
msgstr ""
-#, c-format
+#, fuzzy, c-format
msgstr "éæ³çç¢éå°å¾åç§°<%s>ãå¯è½å
å«'.'æ'NULL'ã\n"
-#, c-format
+#, fuzzy, c-format
msgstr "éæ³çç¢éå°å¾åç§°<%s>ãå¿
须以忝å¼å¤´ã\n"
-#, c-format
+#, fuzzy, c-format
msgstr "éæ³çç¢éå°å¾åç§°<%s>ãä¸å
许æå符<%c>ã\n"
-#, c-format
+#, fuzzy, c-format
-#, c-format
+#, fuzzy, c-format
+msgstr "è¾å
¥ç¢é'%s'æªæ¾å°"
+#, fuzzy, c-format
+msgstr "è¾åºå°å¾'%s'被ç¨ä½è¾å
+#, fuzzy, c-format
+msgstr "æ æ³å°ç®å½æ¹åå°%s"
+#, fuzzy, c-format
msgstr "å°å¾åç§°ä¸éåºSQL"
-#, c-format
+#, fuzzy, c-format
msgstr "ç¢é'%s'å·²ç»åå¨ï¼å®å°ä¼è¢«è¦çã"
-#, c-format
-msgstr "è¾å
¥ç¢é'%s'æªæ¾å°"
+#, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "æ æ³æå¼æ
æ ¼å¾[%så¨%sä¸]"
#, c-format
-msgstr "æ æ³å°ç¢é'%s'æ·è´ä¸º'%s'"
+msgstr ""
+#, fuzzy, c-format
+msgstr "æ æ³æå¼æä»¶ %s å¨ %s ä¸"
+#, fuzzy, c-format
+msgstr "æ æ³æå¼æ°æ®åº %s"
+#, fuzzy, c-format
+msgstr "æ æ³ä¸º[%så¨%sä¸]å建头æä»¶"
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
+#, fuzzy, c-format
#, fuzzy
@@ -3281,78 +3408,66 @@
msgstr ""
-#, fuzzy
-msgstr "è¦åï¼ç¨åºåè¯·æ±æªç¥çopen_level\n"
#, fuzzy, c-format
-msgstr "è¾å
¥ç¢é'%s'æªæ¾å°"
+msgstr "è¦åï¼ç¨åºåè¯·æ±æªç¥çopen_level\n"
+#, fuzzy
+msgid ""
msgstr "ä¸å¨å½åå°å¾éä¸çå°å¾ä¸è½è¢«æå¼å¹¶æ´æ°ã"
#, fuzzy, c-format
-msgstr "æ æ³å é¤å·²æç¢é%s"
#, fuzzy, c-format
msgstr "æ æ³æå¼æ§çç¢é%så¨çº§å«%dä¸"
#, fuzzy
msgstr "æ æ³æå¼ä¸´æ¶æä»¶"
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
#, fuzzy, c-format
-#, c-format
-msgstr "æ æ³æå¼æ°çç¢é%s"
-#, c-format
-msgstr "æ æ³æå¼ç¢é'%s'çåå²è®°å½"
-#, c-format
-msgstr "æ æ³ç»è®¡æä»¶'%s'"
+#, fuzzy, c-format
+#, fuzzy
msgstr "'coor'æä»¶ç大å°ä¸æææä»¶ä¸ä¿åçå¼ä¸åã"
-#, c-format
+#, fuzzy, c-format
msgstr "请为ç¢é'%s@%s'é建ææ"
@@ -3375,37 +3490,37 @@
msgstr ""
#, fuzzy
msgstr "注åçº¿ï¼ "
msgstr ""
#, fuzzy
msgstr "注åçº¿ï¼ "
msgstr ""
msgstr ""
msgid "Snaps"
msgstr ""
msgstr ""
msgstr ""
@@ -3537,6 +3652,32 @@
msgstr ""
+#~ msgstr "è¾åºçåç§°'%s'䏿¯ææçç¢éåç§°ã"
+#~ msgstr "è¾å
¥ç¢é'%s'æªæ¾å°"
+#~ msgid "Cannot copy vector '%s' to '%s'"
+#~ msgstr "æ æ³å°ç¢é'%s'æ·è´ä¸º'%s'"
+#, fuzzy
+#~ msgstr "æ æ³å é¤å·²æç¢é%s"
+#, fuzzy
+#~ msgstr "æ æ³æå¼æ°çç¢é%s"
+#~ msgstr "æ æ³æå¼ç¢é'%s'çåå²è®°å½"
+#~ msgstr "æ æ³ç»è®¡æä»¶'%s'"
#, fuzzy
#~ msgstr "æ æ³æå¼æ§çç¢é%s"
@@ -3743,9 +3884,6 @@
#~ msgid "No double attributes in site_list"
#~ msgstr "å¨ç«ç¹åè¡¨ä¸æ²¡æåç²¾åº¦å±æ§"
-#~ msgid "Double attribute index out of range"
-#~ msgstr "åç²¾åº¦å±æ§ç´¢å¼è¶ç"
#~ msgid "No string attributes in site_list"
#~ msgstr "å¨ç«ç¹åè¡¨ä¸æ²¡æåç¬¦ä¸²å±æ§"
Index: grassmods_ar.po
RCS file: /grassrepository/grass6/locale/po/grassmods_ar.po,v
--- grassmods_ar.po 21 Sep 2007 22:12:44 -0000 1.24
+++ grassmods_ar.po 23 Nov 2007 17:33:18 -0000 1.24.2.1
@@ -7,33 +7,36 @@
msgstr ""
"Project-Id-Version: grassmods_ar\n"
-"POT-Creation-Date: 2007-09-21 23:54+0200\n"
"PO-Revision-Date: 2005-03-09 12:50+0100\n"
"Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
-"Language-Team: Arabic <translations at grass.itc.it>\n"
+"Language-Team: Arabic <translations at lists.osgeo.org>\n"
[...6846 lines suppressed...]
#, fuzzy
-#~ msgid "Unable to find cell map <%s>"
-#~ msgstr "<%s> ÙÙ
ÙÙ
ÙÙ ÙØªØ"
-#, fuzzy
#~ msgid "Unable to read map raster row %d"
#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ©"
@@ -27923,10 +28229,6 @@
#, fuzzy
#~ msgid "Sorry, with method '%s' you have to define an output map."
#~ msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة اÙÙ
خرجة"
-#, fuzzy
-#~ msgid "raster map [%s] "
-#~ msgstr "تسجÙÙ Ø§ÙØ®Ø±Ø§Ø¦Ø· Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© "
#, fuzzy
#~ msgid "Calculation time"
Index: grassmods_cs.po
RCS file: /grassrepository/grass6/locale/po/grassmods_cs.po,v
retrieving revision 1.42
retrieving revision 1.42.2.1
diff -u -d -r1.42 -r1.42.2.1
--- grassmods_cs.po 21 Sep 2007 22:12:44 -0000 1.42
+++ grassmods_cs.po 23 Nov 2007 17:33:18 -0000 1.42.2.1
@@ -10,1238 +10,77 @@
msgstr ""
"Project-Id-Version: grassmods_cs\n"
-"PO-Revision-Date: 2006-12-30 21:02+0100\n"
+"POT-Creation-Date: 2007-10-26 10:42+0200\n"
+"PO-Revision-Date: 2007-11-23 18:06+0100\n"
"Last-Translator: Radim Bla¾ek <blazek at itc.it>\n"
-"Language-Team: Czech <translations at grass.itc.it>\n"
+"Language-Team: Czech <translations at lists.osgeo.org>\n"
[...47542 lines suppressed...]
#~ msgid "Total species representation is < 100"
#~ msgstr ""
-#~ "CelkovÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂà"
-#~ "zastoupenÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
-#~ "druhÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÃÂÃÂÃÅ¡ÃÂÄÂĹÄÄÂàje < 100"
+#~ "CelkovÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂ
ÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂ
ÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
+#~ "zastoupenÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ
ÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃ
ÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
+#~ "druhÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃ
ÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃ
ÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ je < 100"
#~ msgid "Cannot select attributes for point #%d"
#~ msgstr "Nelze vybrat atributy pro bod #%d"
#~ msgid "Species <%s> not known. I'll use parameters for spruce instead"
#~ msgstr ""
-#~ "Druh <%s> nenÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
-#~ "znÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂm. "
-#~ "PouÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÃÂÃÂÃÅ¡ÃÂÄÂĹÄÃšĹžiji parametry pro smrk."
+#~ "Druh <%s> nenÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂ
ÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄ
ÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂ "
+#~ "znÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂ
ÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂ
ÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂm. "
+#~ "PouÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃ
ÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÄÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÄÂÃÂÃÂÃÂÃÅ¡ÃÂÃÂ
ÃÂÄÂÃÂÄÂÃÂÄÂÃÂÄÂĹÄÄÂÃÂÃÂÃÂÃÅ¡ÃÂÄÂĹÄÃšĹžiji parametry pro smrk."
Index: grassmods_de.po
RCS file: /grassrepository/grass6/locale/po/grassmods_de.po,v
retrieving revision 1.118
retrieving revision 1.118.2.1
diff -u -d -r1.118 -r1.118.2.1
--- grassmods_de.po 9 Oct 2007 21:47:27 -0000 1.118
+++ grassmods_de.po 23 Nov 2007 17:33:20 -0000 1.118.2.1
@@ -9,33 +9,36 @@
msgstr ""
"Project-Id-Version: grassmods_de\n"
"PO-Revision-Date: 2007-08-17 20:19+0200\n"
"Last-Translator: Robert Nuske <rnuske at gwdg.de>\n"
-"Language-Team: Deutsch <translations at grass.itc.it>\n"
+"Language-Team: Deutsch <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=ISO-8859-15\n"
[...6911 lines suppressed...]
@@ -28002,9 +28365,6 @@
#~ msgid "%s - illegal name "
#~ msgstr "%s - ungültiger Name."
-#~ msgid "Unable to find file [%s]."
-#~ msgstr "Kann Datei [%s] nicht finden."
#~ msgid "Couldn't find raster map [%s]"
#~ msgstr "Kann die Rasterkarte [%s] nicht finden."
@@ -28631,9 +28991,6 @@
#~ msgid "Unable to open cell map <%s> for output.\n"
#~ msgstr "Kann die Cell-Karte <%s> nicht für die Ausgabe öffnen.\n"
-#~ msgstr "Kann Rasterkarte %s nicht finden. "
#~ msgstr "Kann Rasterreihe %d nicht lesen."
Index: grassmods_el.po
RCS file: /grassrepository/grass6/locale/po/grassmods_el.po,v
retrieving revision 1.7
retrieving revision 1.7.2.1
diff -u -d -r1.7 -r1.7.2.1
--- grassmods_el.po 21 Sep 2007 22:12:45 -0000 1.7
+++ grassmods_el.po 23 Nov 2007 17:33:21 -0000 1.7.2.1
@@ -8,31 +8,34 @@
msgstr ""
"Project-Id-Version: grassmods_el\n"
"PO-Revision-Date: 2007-03-23 16:35+0100\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
-"Language-Team: Greek <translations at grass.itc.it>\n"
+"Language-Team: Greek <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=ISO-8859-7\n"
[...6011 lines suppressed...]
-msgid "unable to open image file"
+msgid "Unable to open image file"
msgstr ""
#: ../visualization/ximgview/main.c:243
-msgid "unable to read BMP header"
+msgid "Unable to read BMP header"
msgstr ""
#: ../visualization/ximgview/main.c:246
-msgid "invalid BMP header"
+msgid "Invalid BMP header"
msgstr ""
#: ../visualization/ximgview/main.c:252
-msgid "unable to map image file"
+msgid "Unable to map image file"
msgstr ""
#: ../visualization/ximgview/main.c:273
Index: grassmods_es.po
RCS file: /grassrepository/grass6/locale/po/grassmods_es.po,v
retrieving revision 1.84.2.1
retrieving revision 1.84.2.2
diff -u -d -r1.84.2.1 -r1.84.2.2
--- grassmods_es.po 26 Oct 2007 18:51:26 -0000 1.84.2.1
+++ grassmods_es.po 23 Nov 2007 17:33:21 -0000 1.84.2.2
@@ -1,4 +1,4 @@
-# translation of grassmods_es.po to español
+# translation of grassmods_es.po to Español
# Spanish translation of grassmods.pot
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2004 GRASS Development Team
@@ -14,17 +14,17 @@
msgstr ""
"Project-Id-Version: grassmods_es\n"
-"POT-Creation-Date: 2007-10-24 18:22+0200\n"
-"PO-Revision-Date: 2007-10-26 14:38+0200\n"
+"PO-Revision-Date: 2007-10-26 21:29+0200\n"
-"Language-Team: español <grass-es at itc.it.org>\n"
+"Language-Team: Español <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=ISO-8859-1\n"
"X-Poedit-Language: Spanish\n"
"X-Poedit-Country: SPAIN\n"
"X-Generator: KBabel 1.11.4\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
#: ../db/base/columns.c:44 ../db/base/createdb.c:42 ../db/base/databases.c:51
#: ../db/base/describe.c:49 ../db/base/dropdb.c:42 ../db/base/droptable.c:43
@@ -246,7 +246,7 @@
msgid "Output vertical record separator"
msgstr "Separador de registros vertical de salida"
-#: ../db/base/select.c:212 ../vector/v.db.select/main.c:67
+#: ../db/base/select.c:212 ../vector/v.db.select/main.c:68
msgid "Null value indicator"
msgstr "Indicador de valores nulos"
@@ -254,7 +254,7 @@
msgid "Name of file with sql statement"
msgstr "Nombre de archivo con sentencia SQL"
-#: ../db/base/select.c:220 ../vector/v.db.select/main.c:71
+#: ../db/base/select.c:220 ../vector/v.db.select/main.c:72
msgid "Do not include column names in output"
msgstr "No incluir nombres de columna en la salida"
@@ -262,7 +262,7 @@
msgid "Describe query only (don't run it)"
msgstr "Sólo describir la consulta (no ejecutarla)"
-#: ../db/base/select.c:228 ../vector/v.db.select/main.c:75
+#: ../db/base/select.c:228 ../vector/v.db.select/main.c:76
msgid "Vertical output (instead of horizontal)"
msgstr "Salida vertical (en vez de horizontal)"
@@ -543,8 +543,8 @@
#: ../raster/r.cats/main.c:121 ../raster/r.cats/main.c:141
#: ../raster/r.clump/main.c:88 ../raster/r.contour/main.c:156
#: ../raster/r.cost/main.c:319 ../raster/r.covar/main.c:96
-#: ../raster/r.grow2/main.c:185 ../raster/r.his/main.c:126
-#: ../raster/r.his/main.c:167 ../raster/r.his/main.c:195
+#: ../raster/r.grow2/main.c:185 ../raster/r.his/main.c:128
+#: ../raster/r.his/main.c:169 ../raster/r.his/main.c:197
#: ../raster/r.info/main.c:116 ../raster/r.kappa/main.c:141
#: ../raster/r.kappa/stats.c:30 ../raster/r.kappa/stats.c:35
#: ../raster/r.los/main.c:164 ../raster/r.los/main.c:171
@@ -617,8 +617,8 @@
#: ../raster/r.buffer/write_map.c:45 ../raster/r.carve/main.c:176
#: ../raster/r.clump/main.c:95 ../raster/r.contour/main.c:160
#: ../raster/r.cost/main.c:337 ../raster/r.covar/main.c:99
-#: ../raster/r.grow2/main.c:201 ../raster/r.his/main.c:130
-#: ../raster/r.his/main.c:156 ../raster/r.his/main.c:184
+#: ../raster/r.grow2/main.c:201 ../raster/r.his/main.c:132
+#: ../raster/r.his/main.c:158 ../raster/r.his/main.c:186
#: ../raster/r.los/main.c:197 ../raster/r.los/main.c:209
#: ../raster/r.mapcalc/map3.c:527 ../raster/r.out.bin/main.c:133
#: ../raster/r.out.gdal/main.c:102 ../raster/r.out.mat/main.c:99
@@ -715,7 +715,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:241 ../vector/v.buffer/main.c:353
#: ../vector/v.build.polylines/main.c:136 ../vector/v.clean/main.c:225
#: ../vector/v.convert/old2new.c:27 ../vector/v.db.connect/main.c:113
-#: ../vector/v.db.select/main.c:90 ../vector/v.distance/main.c:272
+#: ../vector/v.db.select/main.c:91 ../vector/v.distance/main.c:272
#: ../vector/v.edit/main.c:114 ../vector/v.extract/main.c:143
#: ../vector/v.extrude/main.c:143 ../vector/v.hull/main.c:253
#: ../vector/v.info/main.c:96 ../vector/v.kcv/main.c:132
@@ -729,16 +729,18 @@
#: ../vector/v.net/main.c:153 ../vector/v.net.alloc/main.c:130
#: ../vector/v.net.iso/main.c:174 ../vector/v.net.path/main.c:126
#: ../vector/v.net.salesman/main.c:158 ../vector/v.net.steiner/main.c:394
-#: ../vector/v.out.dxf/main.c:67 ../vector/v.out.ogr/main.c:190
-#: ../vector/v.out.pov/main.c:93 ../vector/v.out.svg/main.c:124
-#: ../vector/v.overlay/main.c:184 ../vector/v.perturb/main.c:153
-#: ../vector/v.sample/main.c:151 ../vector/v.segment/main.c:95
-#: ../vector/v.select/main.c:180 ../vector/v.surf.rst/main.c:513
-#: ../vector/v.to.db/parse.c:117 ../vector/v.to.points/main.c:228
-#: ../vector/v.to.rast/vect2rast.c:37 ../vector/v.transform/main.c:228
-#: ../vector/v.type/main.c:204 ../vector/v.univar/main.c:109
-#: ../vector/v.voronoi/dt_main.c:74 ../vector/v.voronoi/vo_main.c:143
-#: ../vector/v.what/main.c:142 ../vector/v.what.rast/main.c:116
+#: ../vector/v.normal/main.c:128 ../vector/v.out.dxf/main.c:67
+#: ../vector/v.out.ogr/main.c:190 ../vector/v.out.pov/main.c:93
+#: ../vector/v.out.svg/main.c:124 ../vector/v.overlay/main.c:184
+#: ../vector/v.perturb/main.c:153 ../vector/v.qcount/main.c:126
+#: ../vector/v.reclass/main.c:100 ../vector/v.sample/main.c:151
+#: ../vector/v.segment/main.c:95 ../vector/v.select/main.c:180
+#: ../vector/v.surf.rst/main.c:513 ../vector/v.to.db/parse.c:117
+#: ../vector/v.to.points/main.c:228 ../vector/v.to.rast/vect2rast.c:37
+#: ../vector/v.transform/main.c:228 ../vector/v.type/main.c:204
+#: ../vector/v.univar/main.c:109 ../vector/v.voronoi/dt_main.c:74
+#: ../vector/v.voronoi/vo_main.c:143 ../vector/v.what/main.c:142
+#: ../vector/v.what.rast/main.c:116
#, c-format
msgstr "Mapa vectorial <%s> no encontrado"
@@ -987,9 +989,8 @@
msgstr "L: añadir M: eliminar R: salir y guardar\n"
#: ../display/d.extract/main.c:50
-#, fuzzy
msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr "Seleccionar y extraer vectores con el ratón en nuevo mapa vectorial"
+msgstr "Selecciona y extrae vectores con el ratón en nuevo mapa vectorial."
#: ../display/d.extract/main.c:63 ../display/d.path/main.c:98
msgid "Original line color"
@@ -1000,9 +1001,8 @@
msgstr "Color de selección"
#: ../display/d.extract/main.c:115
-#, fuzzy
msgid "Copying tables..."
-msgstr "Copiando tablas ..."
+msgstr "Copiando tablas..."
#: ../display/d.extract/main.c:123
msgid "Cannot get db link info -> cannot copy table."
@@ -1328,15 +1328,15 @@
"Muestra el resultado de combinar valores de tonalidad, intensidad y "
"saturación (HIS) de capas de mapa ráster especificadas por el usuario."
-#: ../display/d.his/main.c:76 ../raster/r.his/main.c:74
+#: ../display/d.his/main.c:76 ../raster/r.his/main.c:75
msgid "Name of layer to be used for HUE"
msgstr "Nombre de la capa a usar para TONALIDAD"
-#: ../display/d.his/main.c:83 ../raster/r.his/main.c:81
+#: ../display/d.his/main.c:83 ../raster/r.his/main.c:82
msgid "Name of layer to be used for INTENSITY"
msgstr "Nombre de la capa a usar para INTENSIDAD"
-#: ../display/d.his/main.c:90 ../raster/r.his/main.c:88
+#: ../display/d.his/main.c:90 ../raster/r.his/main.c:89
msgid "Name of layer to be used for SATURATION"
msgstr "Nombre de la capa a usar para SATURACIÓN"
@@ -1344,7 +1344,7 @@
msgid "Percent to brighten intensity channel"
msgstr "Porcentaje para incrementar el brillo del canal de intensidad"
-#: ../display/d.his/main.c:101 ../raster/r.his/main.c:113
+#: ../display/d.his/main.c:101 ../raster/r.his/main.c:114
msgid "Respect NULL values while drawing"
msgstr "Respetar valores NULOS mientras se dibuja"
@@ -1360,8 +1360,8 @@
#: ../display/d.his/main.c:202 ../display/d.histogram/main.c:160
#: ../display/d.legend/main.c:258 ../display/d.rast/display.c:22
#: ../display/d.rast.edit/cell.c:51 ../display/d.rast.num/number.c:281
-#: ../display/d.rgb/main.c:110 ../raster/r.his/main.c:141
-#: ../raster/r.his/main.c:163 ../raster/r.his/main.c:191
+#: ../display/d.rgb/main.c:110 ../raster/r.his/main.c:143
+#: ../raster/r.his/main.c:165 ../raster/r.his/main.c:193
#: ../raster/r.out.ppm3/main.c:128
#, c-format
msgid "Color file for <%s> not available"
@@ -2036,9 +2036,8 @@
msgstr "visualización, trabajo en red"
#: ../display/d.path/main.c:50
-#, fuzzy
msgid "Finds shortest path for selected starting and ending node."
-msgstr "Encontrar la ruta más corta para los nodos inicial y final seleccionados"
+msgstr "Encuentra la ruta más corta para los nodos inicial y final seleccionados."
#: ../display/d.path/main.c:57 ../vector/v.net.alloc/main.c:69
#: ../vector/v.net.iso/main.c:79 ../vector/v.net.path/main.c:48
@@ -4606,12 +4605,12 @@
msgstr "Mostrar información de resumen"
#: ../general/g.version/main.c:34
-msgid "Displays version and copyright information"
-msgstr "Muestra información de versión y copyright"
+msgid "Displays version and copyright information."
+msgstr "Muestra información de versión y copyright."
#: ../general/g.version/main.c:38
-msgid "Print the copyright message as well"
-msgstr "Imprimir el mensaje de copyright también"
+msgid "Print the copyright message"
+msgstr "Imprimir el mensaje de copyright"
#: ../general/g.version/main.c:42
msgid "Print the GRASS build information"
@@ -6508,7 +6507,7 @@
msgstr "Inicializando datos..."
#: ../imagery/i.zc/main.c:168 ../raster/r.carve/raster.c:12
-#: ../raster/r.out.tiff/r.out.tiff.c:285 ../raster/r.texture/main.c:258
+#: ../raster/r.out.tiff/r.out.tiff.c:286 ../raster/r.texture/main.c:258
msgid "Reading raster map..."
msgstr "Leyendo mapa ráster..."
@@ -7502,7 +7501,7 @@
#: ../raster/r.digit/main.c:44 ../raster/r.distance/main.c:38
#: ../raster/r.drain/main.c:102 ../raster/r.fill.dir/main.c:85
#: ../raster/r.grow2/main.c:127 ../raster/r.gwflow/main.c:219
-#: ../raster/r.his/main.c:63 ../raster/r.in.arc/main.c:58
+#: ../raster/r.his/main.c:64 ../raster/r.in.arc/main.c:58
#: ../raster/r.in.gdal/main.c:69 ../raster/r.in.gridatb/main.c:43
#: ../raster/r.in.mat/main.c:93 ../raster/r.in.xyz/main.c:76
#: ../raster/r.info/main.c:68 ../raster/r.kappa/main.c:49
@@ -8778,33 +8777,36 @@
#: ../ps/ps.map/catval.c:47 ../ps/ps.map/catval.c:105
#: ../ps/ps.map/catval.c:166 ../vector/v.buffer/main.c:371
#: ../vector/v.label/main.c:271 ../vector/v.label.sa/labels.c:76
-#: ../vector/v.to.rast/support.c:126 ../vector/v.to.rast/support.c:260
-#: ../vector/v.to.rast/vect2rast.c:51 ../vector/v.to.rast3/main.c:81
-#: ../vector/v.univar/main.c:131 ../vector/v.vol.rst/user1.c:92
+#: ../vector/v.reclass/main.c:114 ../vector/v.to.rast/support.c:126
+#: ../vector/v.to.rast/support.c:260 ../vector/v.to.rast/vect2rast.c:51
+#: ../vector/v.to.rast3/main.c:81 ../vector/v.univar/main.c:131
+#: ../vector/v.vol.rst/user1.c:92
msgid "Unable to get layer info for vector map"
msgstr "No se puede obtener información de la capa para el mapa vectorial"
-#: ../ps/ps.map/catval.c:52 ../raster/r.contour/main.c:179
+#: ../ps/ps.map/catval.c:52 ../ps/ps.map/catval.c:110
+#: ../ps/ps.map/catval.c:171 ../raster/r.contour/main.c:179
#: ../raster/r.to.vect/main.c:153 ../vector/lidar/v.surf.bspline/main.c:297
#: ../vector/v.buffer/main.c:375 ../vector/v.db.connect/main.c:176
-#: ../vector/v.db.connect/main.c:268 ../vector/v.db.select/main.c:102
-#: ../vector/v.db.select/main.c:172 ../vector/v.distance/main.c:331
+#: ../vector/v.db.connect/main.c:268 ../vector/v.db.select/main.c:103
+#: ../vector/v.db.select/main.c:173 ../vector/v.distance/main.c:331
#: ../vector/v.distance/main.c:365 ../vector/v.edit/select.c:514
#: ../vector/v.extract/main.c:231 ../vector/v.extrude/main.c:167
#: ../vector/v.in.db/main.c:113 ../vector/v.kcv/main.c:173
#: ../vector/v.label/main.c:274 ../vector/v.label.sa/labels.c:79
#: ../vector/v.lrs/v.lrs.create/main.c:257
#: ../vector/v.lrs/v.lrs.create/main.c:265 ../vector/v.mkgrid/main.c:207
-#: ../vector/v.out.ogr/main.c:283 ../vector/v.out.svg/main.c:145
-#: ../vector/v.overlay/main.c:168 ../vector/v.overlay/main.c:261
-#: ../vector/v.patch/main.c:132 ../vector/v.patch/main.c:164
-#: ../vector/v.patch/main.c:287 ../vector/v.patch/main.c:347
+#: ../vector/v.normal/main.c:141 ../vector/v.out.ogr/main.c:283
+#: ../vector/v.out.svg/main.c:145 ../vector/v.overlay/main.c:168
+#: ../vector/v.overlay/main.c:261 ../vector/v.patch/main.c:132
+#: ../vector/v.patch/main.c:164 ../vector/v.patch/main.c:287
+#: ../vector/v.patch/main.c:347 ../vector/v.reclass/main.c:118
#: ../vector/v.sample/main.c:201 ../vector/v.surf.idw/read_sites.c:39
#: ../vector/v.to.db/query.c:81 ../vector/v.to.db/update.c:32
#: ../vector/v.to.rast/support.c:129 ../vector/v.to.rast/support.c:263
-#: ../vector/v.to.rast/vect2rast.c:54 ../vector/v.transform/trans_digit.c:58
-#: ../vector/v.vol.rst/main.c:561 ../vector/v.vol.rst/user1.c:96
-#: ../vector/v.what.rast/main.c:127
+#: ../vector/v.to.rast/vect2rast.c:54 ../vector/v.to.rast3/main.c:85
+#: ../vector/v.transform/trans_digit.c:58 ../vector/v.vol.rst/main.c:561
+#: ../vector/v.vol.rst/user1.c:96 ../vector/v.what.rast/main.c:127
#, c-format
msgstr "No se puede abrir la base de datos <%s> por el controlador <%s>"
@@ -8815,18 +8817,12 @@
#: ../ps/ps.map/catval.c:64 ../ps/ps.map/catval.c:125
#: ../ps/ps.map/catval.c:187 ../vector/lidar/v.surf.bspline/main.c:307
-#: ../vector/v.buffer/main.c:383 ../vector/v.sample/main.c:181
-#: ../vector/v.surf.idw/read_sites.c:49 ../vector/v.to.rast3/main.c:93
-#: ../vector/v.univar/main.c:147
+#: ../vector/v.buffer/main.c:383 ../vector/v.normal/main.c:150
+#: ../vector/v.sample/main.c:181 ../vector/v.surf.idw/read_sites.c:49
+#: ../vector/v.to.rast3/main.c:93 ../vector/v.univar/main.c:147
msgid "Unable to select data from table"
msgstr "No se pueden seleccionar datos de la tabla"
-#: ../ps/ps.map/catval.c:110 ../ps/ps.map/catval.c:171
-#: ../vector/v.to.rast3/main.c:85
-#, fuzzy, c-format
-msgid "Unable to open database %s by driver %s"
-msgstr "No se puede abrir la base de datos <%s> por el controlador <%s>"
#: ../ps/ps.map/catval.c:122
msgid "Size column type must be numeric"
msgstr "El tipo de columna de tamaño debe ser numérico"
@@ -8986,9 +8982,9 @@
#: ../ps/ps.map/outl_io.c:77 ../raster/r.neighbors/main.c:203
#: ../raster/r.series/main.c:174
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open raster map <%s> in mapset <%s>"
-msgstr "a ráster directorio de mapas"
+msgstr "No se puede abrir el mapa ráster <%s> en el directorio de mapas <%s>"
#: ../ps/ps.map/ps_clrtbl.c:30 ../ps/ps.map/ps_fclrtbl.c:40
#, c-format
@@ -11046,7 +11042,7 @@
msgid "Unable to create and solve the linear equation system"
msgstr "No se puede crear y resolver el sistema de ecuaciones lineal"
-#: ../raster/r.his/main.c:65
+#: ../raster/r.his/main.c:66
msgid ""
"Generates red, green and blue raster map layers combining hue, intensity and "
"saturation (HIS) values from user-specified input raster map layers."
@@ -11055,27 +11051,27 @@
"intensidad y saturación (HIS) a partir de capas de mapa ráster de entrada "
"especificadas por el usuario."
-#: ../raster/r.his/main.c:95
+#: ../raster/r.his/main.c:96
msgid "Name of output layer to be used for RED"
msgstr "Nombre de la capa de salida a usar para el ROJO"
-#: ../raster/r.his/main.c:102
+#: ../raster/r.his/main.c:103
msgid "Name of output layer to be used for GREEN"
msgstr "Nombre de la capa de salida a usar para el VERDE"
-#: ../raster/r.his/main.c:109
+#: ../raster/r.his/main.c:110
msgid "Name of output layer to be used for BLUE"
msgstr "Nombre de la capa de salida a usar para el AZUL"
-#: ../raster/r.his/main.c:252
+#: ../raster/r.his/main.c:254
msgid "Error reading 'hue' map"
msgstr "Error al leer el mapa 'matiz'"
-#: ../raster/r.his/main.c:254
+#: ../raster/r.his/main.c:256
msgid "Error reading 'intensity' map"
msgstr "Error al leer el mapa 'intensidad'"
-#: ../raster/r.his/main.c:256
+#: ../raster/r.his/main.c:258
msgid "Error reading 'saturation' map"
msgstr "Error al leer el mapa 'saturación'"
@@ -13552,24 +13548,24 @@
"El mapa de color para paleta debe tener menos de 256 colores para el rango "
"disponible de datos"
-#: ../raster/r.out.tiff/r.out.tiff.c:197
+#: ../raster/r.out.tiff/r.out.tiff.c:198
#, c-format
msgid "Unable to open TIFF file <%s>"
msgstr "No se puede abrir el archivo TIFF <%s>"
-#: ../raster/r.out.tiff/r.out.tiff.c:429
+#: ../raster/r.out.tiff/r.out.tiff.c:430
msgid "Writing TIFF World file"
msgstr "Escribiendo archivo TIFF World"
-#: ../raster/r.out.tiff/r.out.tiff.c:432
+#: ../raster/r.out.tiff/r.out.tiff.c:433
msgid "Got null file name"
msgstr "Se obtuvo un nombre de archivo nulo"
-#: ../raster/r.out.tiff/r.out.tiff.c:434
+#: ../raster/r.out.tiff/r.out.tiff.c:435
msgid "Got null region struct"
msgstr "Se obtuvo una estructura de región nula"
-#: ../raster/r.out.tiff/r.out.tiff.c:437
+#: ../raster/r.out.tiff/r.out.tiff.c:438
#, fuzzy
msgid "Unable to open TIFF world file for writing"
msgstr "No se pudo abrir el archivo TIFF World para escritura"
@@ -15603,7 +15599,7 @@
#: ../raster/simwe/r.sim.water/main.c:185
#: ../raster/simwe/r.sim.water/main.c:194
msgid "Input_options"
-msgstr ""
+msgstr "Opciones de entrada"
#: ../raster/r.sun/main.c:193
msgid ""
@@ -18304,6 +18300,8 @@
"\n"
"Roads, ditches, changes in ground cover, and other factors will stop"
msgstr ""
+"\n"
+"Las carreteras, zanjas, cambios en la cobertura del terreno y otros factores detendrán"
#: ../raster/r.watershed/shed/com_line.c:342
msgid "slope length. You may input a raster map indicating the locations of these"
@@ -18766,7 +18764,11 @@
"Simulates elliptically anisotropic spread on a graphics window and generates "
"a raster map of the cumulative time of spread, given raster maps containing "
"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr "Simula propagación anisotrópica elípticamente en una ventana de gráficos y general un mapa ráster del tiempo acumulado de propagación, dados mapas ráster que contengan las tasas de propagación (ROS), las direcciones de ROS y los orígenes de propagación."
+msgstr ""
+"Simula propagación anisotrópica elípticamente en una ventana de gráficos y "
+"general un mapa ráster del tiempo acumulado de propagación, dados mapas "
+"ráster que contengan las tasas de propagación (ROS), las direcciones de ROS "
+"y los orígenes de propagación."
#: ../raster/wildfire/r.spread/main.c:109
msgid ""
@@ -20061,7 +20063,9 @@
msgid ""
"It was not possible to drop <%s> table. Nothing will be done. Try to drop it "
"manually."
-msgstr "No fue posible quitar la tabla <%s>. No se hará nada. Intente quitarla manualmente."
+msgstr ""
+"No fue posible quitar la tabla <%s>. No se hará nada. Intente quitarla "
+"manualmente."
#: ../vector/lidar/v.surf.bspline/main.c:217
msgid "Choose either vector or raster output, not both"
@@ -20392,12 +20396,15 @@
msgid ""
"build;build topology;dump;write topology to stdout;sdump;write spatial index "
"to stdout;cdump;write category index to stdout"
-msgstr "build:construir topología;dump;escribir topología en stdout;sdump;escribir índice espacial en stdout;cdump;escribir índice de categoría en stdout"
+msgstr ""
+"build:construir topología;dump;escribir topología en stdout;sdump;escribir "
+"índice espacial en stdout;cdump;escribir índice de categoría en stdout"
-#: ../vector/v.build/main.c:77 ../vector/v.support/main.c:121
+#: ../vector/v.build/main.c:77 ../vector/v.edit/main.c:89
+#: ../vector/v.neighbors/main.c:76 ../vector/v.support/main.c:121
#, c-format
-msgid "Vector map <%s> not found in current mapset"
-msgstr "No se encontró el mapa vectorial <%s> en el directorio de mapas actual"
+msgid "Vector map <%s> not found in the current mapset"
+msgstr "No se encuentra el mapa vectorial <%s> en el directorio de mapas actual"
#: ../vector/v.build/main.c:150 ../vector/v.clean/main.c:366
msgid "Building topology for error vector map..."
@@ -20541,14 +20548,14 @@
"conectan áreas e islas o 2 islas de perímetro a línea;snap;ajustar líneas a "
"vértices en el umbral; rmdac;eliminar centroides de área duplicados (opción "
"'tipo' ignorada);bpol;rompe (topológicamente limpios) polígonos (importados "
-"de formatos no topológicos (como shapefile). Los perímetros se rompen en cada "
-"punto compartido entre dos o más polígonos donde los ángulos de segmentos "
-"son diferentes;prune;eliminar vértices en umbral de líneas y perímetros, el "
-"perímetro sólo se recorta si no se daña la topología (nueva intersección, "
-"cambiada la vinculación de centroide), los segmentos primero y último del "
-"perímetro nunca se cambian;rmarea;eliminar pequeñas áreas, se elimina el "
-"perímetro más largo con el área adyacente;rmsa;eliminar ángulos pequeños "
-"entre líneas y nodos"
+"de formatos no topológicos (como shapefile). Los perímetros se rompen en "
+"cada punto compartido entre dos o más polígonos donde los ángulos de "
+"segmentos son diferentes;prune;eliminar vértices en umbral de líneas y "
+"perímetros, el perímetro sólo se recorta si no se daña la topología (nueva "
+"intersección, cambiada la vinculación de centroide), los segmentos primero y "
+"último del perímetro nunca se cambian;rmarea;eliminar pequeñas áreas, se "
+"elimina el perímetro más largo con el área adyacente;rmsa;eliminar ángulos "
+"pequeños entre líneas y nodos"
#: ../vector/v.clean/main.c:92
msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
@@ -21038,7 +21045,7 @@
"capa <%d> tabla <%s> en la base de datos <%s> a través del controlador <%s> "
"con clave <%s>\n"
-#: ../vector/v.db.connect/main.c:168 ../vector/v.db.select/main.c:96
+#: ../vector/v.db.connect/main.c:168 ../vector/v.db.select/main.c:97
#: ../vector/v.distance/main.c:326 ../vector/v.distance/main.c:360
#: ../vector/v.edit/select.c:499 ../vector/v.extrude/main.c:162
#: ../vector/v.overlay/main.c:254 ../vector/v.sample/main.c:166
@@ -21098,11 +21105,11 @@
msgid "Prints vector map attributes."
msgstr "Imprime atributos de mapa vectorial."
-#: ../vector/v.db.select/main.c:123
+#: ../vector/v.db.select/main.c:124
msgid "Unable to open select cursor"
msgstr "No se puede abrir el cursor de selección"
-#: ../vector/v.db.select/main.c:141
+#: ../vector/v.db.select/main.c:142
#, c-format
msgid "Unable to fetch data from table <%s>"
msgstr "No se pueden recuperar datos de la tabla <%s>"
@@ -21391,13 +21398,11 @@
msgid "Unknown keyword '%s' in vector head"
msgstr "Palabra clave '%s' desconocida en la cabecera del vectorial"
-#: ../vector/v.edit/a2b.c:300 ../vector/v.edit/break.c:108
-#: ../vector/v.edit/break.c:128 ../vector/v.edit/break.c:304
-#: ../vector/v.edit/cats.c:95 ../vector/v.edit/flip.c:58
-#: ../vector/v.edit/merge.c:170 ../vector/v.edit/move.c:79
-#: ../vector/v.edit/snap.c:119 ../vector/v.edit/snap.c:277
-#: ../vector/v.edit/vertex.c:155 ../vector/v.edit/vertex.c:244
-#: ../vector/v.edit/vertex.c:325
+#: ../vector/v.edit/a2b.c:300 ../vector/v.edit/cats.c:95
+#: ../vector/v.edit/flip.c:58 ../vector/v.edit/merge.c:170
+#: ../vector/v.edit/move.c:79 ../vector/v.edit/snap.c:119
+#: ../vector/v.edit/snap.c:277 ../vector/v.edit/vertex.c:155
+#: ../vector/v.edit/vertex.c:244 ../vector/v.edit/vertex.c:325
#, c-format
msgid "Unable to rewrite line %d"
msgstr "No se puede reescribir la línea %d"
@@ -21411,19 +21416,19 @@
msgstr "Herramienta"
#: ../vector/v.edit/args.c:34
+#, fuzzy
msgid ""
"create;Create new (empty) vector map;add;Add new features to existing vector "
"map;delete;Delete selected features from vector map;move;Move selected "
"features in vector map;vertexmove;Move vertex of selected vector lines;"
"vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex "
-"to selected vector lines;merge;Merge selected vector lines;break;Break "
-"(split) vector line into two separate lines;select;Select lines and print "
-"their ID's;catadd;Set new categories to selected vector features for defined "
-"layer;catdel;Delete categories from selected vector features for defined "
-"layer;copy;Copy selected features;snap;Snap vector features in given "
-"threshold;flip;Flip direction of selected vector lines;connect;Connect two "
-"lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector "
-"lines)"
+"to selected vector lines;merge;Merge selected vector lines;break;Break/split "
+"vector lines;select;Select lines and print their ID's;catadd;Set new "
+"categories to selected vector features for defined layer;catdel;Delete "
+"categories from selected vector features for defined layer;copy;Copy "
+"selected features;snap;Snap vector features in given threshold;flip;Flip "
+"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
+"labeling (automated assignment of z coordinate to vector lines)"
msgstr ""
"create;Crear nuevo mapa vectorial (vacío);add;Añadir nuevo(s) elemento(s) a "
"un mapa vectorial existente;delete;Borrar los elementos seleccionados del "
@@ -21431,8 +21436,7 @@
"vertexmove;Mover vértice de líneas vectoriales seleccionadas;vertexdel;"
"Eliminar vértices de líneas vectoriales seleccionadas;vertexadd;Añadir nuevo "
"vértice a las líneas vectoriales seleccionadas;merge;Fundir líneas "
-"vectoriales seleccionadas;break;Romper (dividir) línea vectorial en dos "
-"líneas separadas;select;Seleccionar líneas e imprimir sus ID;catadd;"
+"vectoriales seleccionadas;break;Romper/dividir líneas vectoriales;select;Seleccionar líneas e imprimir sus ID;catadd;"
"Establecer nuevas categorías a los elementos vectoriales seleccionados para "
"la capa definida;catdel;Borrar categorías de los elementos vectoriales "
"seleccionados para la capa definida;copy;Copiar elementos seleccionados;snap;"
@@ -21553,19 +21557,19 @@
msgid "At least one option from %s must be specified"
msgstr "Se debe especificar al menos una opción de %s"
-#: ../vector/v.edit/args.c:306 ../vector/v.edit/args.c:318
-#: ../vector/v.edit/args.c:329 ../vector/v.edit/args.c:337
-#: ../vector/v.edit/args.c:342
+#: ../vector/v.edit/args.c:306 ../vector/v.edit/args.c:317
+#: ../vector/v.edit/args.c:328 ../vector/v.edit/args.c:336
+#: ../vector/v.edit/args.c:341
#, c-format
msgid "Tool %s requires option %s"
msgstr "La herramienta %s requiere la opción %s"
-#: ../vector/v.edit/break.c:254 ../vector/v.edit/break.c:336
+#: ../vector/v.edit/break.c:257 ../vector/v.edit/break.c:335
#, c-format
msgid "Unable to connect line id %d to line %d"
msgstr "No se puede conectar la línea con ID %d a la línea %d"
-#: ../vector/v.edit/break.c:285
+#: ../vector/v.edit/break.c:288
#, c-format
msgid ""
"Unable to connect line id %d to line %d because of threshold distance. Run v."
@@ -21616,11 +21620,6 @@
msgid "Unable to open ASCII file <%s>"
msgstr "No se puede abrir el archivo ASCII <%s>"
-#: ../vector/v.edit/main.c:89 ../vector/v.neighbors/main.c:76
-#, c-format
-msgid "Vector map <%s> not found in the current mapset"
-msgstr "No se encuentra el mapa vectorial <%s> en el directorio de mapas actual"
#: ../vector/v.edit/main.c:100 ../vector/v.kcv/main.c:137
#, c-format
msgid "Unable to open vector map <%s> at topological level %d"
@@ -21689,27 +21688,27 @@
msgid "%d vertices removed"
msgstr "%d vértices eliminados"
-#: ../vector/v.edit/main.c:263
+#: ../vector/v.edit/main.c:268
#, c-format
msgid "%d lines broken"
msgstr "%d líneas rotas"
-#: ../vector/v.edit/main.c:268
+#: ../vector/v.edit/main.c:273
#, c-format
msgid "%d lines connected"
msgstr "%d líneas conectadas"
-#: ../vector/v.edit/main.c:272
+#: ../vector/v.edit/main.c:277
#, c-format
msgid "%d lines merged"
msgstr "%d líneas fundidas"
-#: ../vector/v.edit/main.c:281 ../vector/v.edit/main.c:286
+#: ../vector/v.edit/main.c:286 ../vector/v.edit/main.c:291
#, c-format
msgid "%d features modified"
msgstr "%d elementos modificados"
-#: ../vector/v.edit/main.c:291
+#: ../vector/v.edit/main.c:296
#, c-format
msgid ""
"Multiple background maps were given. Selected features will be copied only "
@@ -21718,22 +21717,22 @@
"Se han dado múltiples mapas de fondo. Los elementos seleccionados se "
"copiarán sólo del mapa vectorial <%s>."
-#: ../vector/v.edit/main.c:301
+#: ../vector/v.edit/main.c:306
#, c-format
msgid "%d features copied"
msgstr "%d elementos copiados"
-#: ../vector/v.edit/main.c:308
+#: ../vector/v.edit/main.c:313
#, c-format
msgid "%d lines flipped"
msgstr "%d líneas dadas la vuelta"
-#: ../vector/v.edit/main.c:329
+#: ../vector/v.edit/main.c:334
#, c-format
msgid "%d lines labeled"
msgstr "%d líneas etiquetadas"
-#: ../vector/v.edit/main.c:333
+#: ../vector/v.edit/main.c:338
msgid "Operation not implemented"
msgstr "Operación no implementada"
@@ -25019,7 +25018,7 @@
#: ../vector/v.qcount/main.c:69
#, fuzzy
-msgid "Indices for quadrat counts of sites lists"
+msgid "Indices for quadrat counts of sites lists."
msgstr "lugares"
#: ../vector/v.qcount/main.c:75
@@ -25046,12 +25045,12 @@
#: ../vector/v.qcount/main.c:132
#, fuzzy
-msgid "Finding quadrats ..."
+msgid "Finding quadrats..."
msgstr "Imprimiendo ... "
#: ../vector/v.qcount/main.c:137
#, fuzzy
-msgid "Counting sites in quadrats ..."
+msgid "Counting sites in quadrats..."
msgstr "lugares."
#: ../vector/v.random/main.c:84
Index: grassmods_fr.po
RCS file: /grassrepository/grass6/locale/po/grassmods_fr.po,v
retrieving revision 1.44
retrieving revision 1.44.2.1
diff -u -d -r1.44 -r1.44.2.1
--- grassmods_fr.po 21 Sep 2007 22:12:45 -0000 1.44
+++ grassmods_fr.po 23 Nov 2007 17:33:21 -0000 1.44.2.1
@@ -11,34 +11,37 @@
msgstr ""
"Project-Id-Version: grassmods_fr\n"
"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2007-10-26 21:10+0200\n"
"PO-Revision-Date: 2005-10-14 23:38-0500\n"
"Last-Translator: Eve\n"
-"Language-Team: Français <translations at grass.itc.it>\n"
+"Language-Team: Français <translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
[...7182 lines suppressed...]
-# c-format
-#, fuzzy
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
#, fuzzy
#~ msgstr "Impossible de lire la ligne raster."
@@ -30224,11 +30625,6 @@
#, fuzzy
#~ msgid "Writing "
#~ msgstr "Écriture %s..."
-# c-format
-#, fuzzy
-#~ msgstr "Ajouter la couche raster [%s]."
#~ msgid "%s: %s in %s - can't read category file"
#~ msgstr "%s: %s dans %s - impossible de lire le fichier de catégorie"
Index: grassmods_hi.po
RCS file: /grassrepository/grass6/locale/po/grassmods_hi.po,v
retrieving revision 1.27
retrieving revision 1.27.2.1
diff -u -d -r1.27 -r1.27.2.1
--- grassmods_hi.po 21 Sep 2007 22:12:45 -0000 1.27
+++ grassmods_hi.po 23 Nov 2007 17:33:22 -0000 1.27.2.1
@@ -7,33 +7,36 @@
msgstr ""
"Project-Id-Version: grassmods_hi\n"
"PO-Revision-Date: 2005-12-20 22:29+0100\n"
"Last-Translator: Markus Neteler <neteler at itc.it>\n"
-"Language-Team: Hindi <translations at grass.itc.it>\n"
+"Language-Team: Hindi <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=UTF-8\n"
[...6928 lines suppressed...]
#, fuzzy
-#~ msgid "number of rows and columns in the input file"
-#~ msgstr "सà¤à¤à¥à¤¯à¤¾ à¤à¤¾"
-#, fuzzy
#~ msgid "resolution of the input (in arc seconds)"
#~ msgstr "à¤à¤¾ à¤à¤¾à¤ª"
@@ -30091,10 +30389,6 @@
#~ "Extracts area edges from a raster map layer and converts data to GRASS "
#~ "vector format."
#~ msgstr "a."
-#, fuzzy
-#~ msgid "Name of a new vector map"
-#~ msgstr "à¤à¤¾ a"
#, fuzzy
#~ msgid "Number of values printed before wrapping a line"
Index: grassmods_it.po
RCS file: /grassrepository/grass6/locale/po/grassmods_it.po,v
retrieving revision 1.39.2.1
retrieving revision 1.39.2.2
diff -u -d -r1.39.2.1 -r1.39.2.2
--- grassmods_it.po 2 Nov 2007 20:53:51 -0000 1.39.2.1
+++ grassmods_it.po 23 Nov 2007 17:33:22 -0000 1.39.2.2
@@ -11,34 +11,37 @@
msgstr ""
"Project-Id-Version: grassmods_it\n"
"PO-Revision-Date: 2006-11-03 19:42+0100\n"
"Last-Translator: Stefano Costa <steko at iosa.it>\n"
-"Language-Team: Italian <translations at grass.itc.it>\n"
+"Language-Team: Italian <translations at lists.osgeo.org>\n"
[...6847 lines suppressed...]
#, fuzzy
-#~ msgstr "impossibile aprire <%s>"
-#, fuzzy
#~ msgstr "Nome del raster"
@@ -27985,10 +28306,6 @@
#, fuzzy
#~ msgid "Writing "
#~ msgstr "Sto disegnando ..."
-#, fuzzy
-#~ msgstr "Nome del driver in input"
#, fuzzy
#~ msgid "Maximum number of iteration"
Index: grassmods_ja.po
RCS file: /grassrepository/grass6/locale/po/grassmods_ja.po,v
retrieving revision 1.38
retrieving revision 1.38.2.1
diff -u -d -r1.38 -r1.38.2.1
--- grassmods_ja.po 21 Sep 2007 22:12:45 -0000 1.38
+++ grassmods_ja.po 23 Nov 2007 17:33:22 -0000 1.38.2.1
@@ -8,33 +8,36 @@
msgstr ""
"Project-Id-Version: grassmods_ja\n"
"PO-Revision-Date: 2005-12-30 17:42+0100\n"
-"Language-Team: Japanese <translations at grass.itc.it>\n"
+"Language-Team: Japanese <translations at lists.osgeo.org>\n"
[...6925 lines suppressed...]
#, fuzzy
-#~ msgid "To display the color table associated with a raster map layer."
-#~ msgstr "ã©ã¹ã¿ã¼ãããã®ã«ã©ã¼ãã¼ãã«ã表示ãã¾ã"
-#, fuzzy
#~ msgid "Color of lines separating the colors of the color table"
#~ msgstr "ã»ãã¬ã¼ã¿ã®è²"
@@ -29952,10 +30236,6 @@
#~ "one corner latitude and longitude of the input\n"
#~ "format: {nw|ne|sw|se},%s,%s"
#~ msgstr "é åã®ç«¯ã®åº§æ¨å¤ãå
¥åå½¢å¼: {nw|ne|sw|se},%s,%s"
-#, fuzzy
-#~ msgstr "æ ¼åæ°(è¡ï¼å)"
#, fuzzy
Index: grassmods_ko.po
RCS file: /grassrepository/grass6/locale/po/grassmods_ko.po,v
retrieving revision 1.26
retrieving revision 1.26.2.1
diff -u -d -r1.26 -r1.26.2.1
--- grassmods_ko.po 21 Sep 2007 22:12:46 -0000 1.26
+++ grassmods_ko.po 23 Nov 2007 17:33:23 -0000 1.26.2.1
@@ -8,31 +8,34 @@
msgstr ""
"Project-Id-Version: grassmods_ko\n"
"PO-Revision-Date: 2005-08-09 22:53-0500\n"
"Last-Translator: Huidae Cho\n"
-"Language-Team: Korean <translations at grass.itc.it>\n"
+"Language-Team: Korean <translations at lists.osgeo.org>\n"
[...6318 lines suppressed...]
+#, fuzzy
+#~ msgid "Input map containing lines"
+#~ msgstr "ì¶ë ¥í ëì¤í°ë§µ"
+#, fuzzy
#~ msgid "Table to be imported"
@@ -25486,10 +25480,6 @@
#, fuzzy
#~ msgid "Unalbe to open vector map <%s>"
-#~ msgstr "ì¶ë ¥í ëì¤í°ë§µ"
-#, fuzzy
-#~ msgid "Raster map <%s>] not found"
#, fuzzy
Index: grassmods_lv.po
RCS file: /grassrepository/grass6/locale/po/grassmods_lv.po,v
--- grassmods_lv.po 21 Sep 2007 22:12:47 -0000 1.26
+++ grassmods_lv.po 23 Nov 2007 17:33:23 -0000 1.26.2.1
@@ -8,10 +8,10 @@
msgstr ""
"Project-Id-Version: grassmods_lv\n"
"PO-Revision-Date: 2006-12-09 01:04+0200\n"
"Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
-"Language-Team: Latvian <translations at grass.itc.it>\n"
+"Language-Team: Latvian <translations at lists.osgeo.org>\n"
[...6762 lines suppressed...]
#, fuzzy
-#~ msgstr "neiespÄjami atvÄrt <%s>"
-#, fuzzy
#~ msgstr "Rastra kartes nosaukums"
@@ -27551,10 +27834,6 @@
#, fuzzy
#~ msgid "Writing "
#~ msgstr "Rakstu jaunu failu... \n"
-#, fuzzy
-#~ msgstr "PÄrkodÄt rastra kartes."
#, fuzzy
Index: grassmods_mr.po
RCS file: /grassrepository/grass6/locale/po/grassmods_mr.po,v
--- grassmods_mr.po 21 Sep 2007 22:12:47 -0000 1.27
+++ grassmods_mr.po 23 Nov 2007 17:33:24 -0000 1.27.2.1
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: Grass 6.0\n"
"PO-Revision-Date: 2005-06-02 18:00+0530\n"
"Last-Translator: Swapnil Hajare <dreamil at gmail.com>\n"
"Language-Team: Marathi <www.janabhaaratii.org.in>\n"
@@ -14,24 +14,27 @@
"Content-Transfer-Encoding: 8bit\n"
[...6474 lines suppressed...]
#, fuzzy
-#~ msgid "Unable to find base map <%s>"
-#~ msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
-#, fuzzy
#~ msgid "%s: unable to open raster map [%s]"
@@ -26125,10 +26232,6 @@
#, fuzzy
-#, fuzzy
#, fuzzy
Index: grassmods_pl.po
RCS file: /grassrepository/grass6/locale/po/grassmods_pl.po,v
retrieving revision 1.30
retrieving revision 1.30.2.1
diff -u -d -r1.30 -r1.30.2.1
--- grassmods_pl.po 22 Sep 2007 09:08:39 -0000 1.30
+++ grassmods_pl.po 23 Nov 2007 17:33:24 -0000 1.30.2.1
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmodes_pl\n"
-"POT-Creation-Date: 2007-09-22 00:09+0200\n"
"PO-Revision-Date: 2007-09-19 21:58+0100\n"
"Last-Translator: Monika Tylus <monikatylus_gmail.com>\n"
"Language-Team: Polska <translation at grass.itc.it>\n"
@@ -16,23 +16,26 @@
"X-Poedit-Bookmarks: 235,-1,-1,-1,-1,-1,-1,-1,-1,-1\n"
[...6794 lines suppressed...]
#~ msgstr "Nazwa kolumny z"
-#, fuzzy
-#~ msgid "category column name"
-#~ msgstr "Nazwa kolumny kategorii"
#~ msgid "%s: Cannot open dxf file"
#~ msgstr "%s: Nie mo¿na otworzyæ pliku dxf"
@@ -27656,10 +27964,6 @@
#, fuzzy
#~ msgid " Patching file %s"
#~ msgstr "Odczytywanie obrazu ..."
-#, fuzzy
-#~ msgid "Cannot not find input vector map <%s>"
-#~ msgstr "Nie mo¿na odnale¿æ pliku wej¶ciowego"
#, fuzzy
#~ msgid ""
Index: grassmods_pt.po
RCS file: /grassrepository/grass6/locale/po/grassmods_pt.po,v
retrieving revision 1.5
retrieving revision 1.5.2.1
diff -u -d -r1.5 -r1.5.2.1
--- grassmods_pt.po 9 Aug 2007 18:43:00 -0000 1.5
+++ grassmods_pt.po 23 Nov 2007 17:33:24 -0000 1.5.2.1
@@ -10,49 +10,38 @@
msgstr ""
"Project-Id-Version: grassmods_pt\n"
-"POT-Creation-Date: 2007-08-09 20:17+0200\n"
"PO-Revision-Date: 2007-06-21 21:54-0300\n"
"Last-Translator: Daniel de Castro Victoria <daniel dot victoria at gmail dot "
"com>\n"
-"Language-Team: Portuguese <translations at grass.itc.it>\n"
+"Language-Team: Portuguese <translations at lists.osgeo.org>\n"
[...10291 lines suppressed...]
#~ msgstr "Subgrupo [%s] só contém 1 arquivo"
#, fuzzy
-#~ msgid "Ascii raster file to be imported (or \"-\" to read from stdin)"
-#~ msgstr "Arquivos raster ASCII para importar"
-#, fuzzy
#~ msgid "%s -- illegal output file name"
#~ msgstr "Nome ilegal do arquivo de saída"
#, fuzzy
#~ msgstr "mapear."
-#, fuzzy
-#~ msgstr "Adicionando arquivo raster [%s]"
#~ msgstr "%s: %s em %s - não consegui ler arquivo de categoria"
Index: grassmods_pt_br.po
RCS file: /grassrepository/grass6/locale/po/grassmods_pt_br.po,v
--- grassmods_pt_br.po 21 Sep 2007 22:12:47 -0000 1.42
+++ grassmods_pt_br.po 23 Nov 2007 17:33:25 -0000 1.42.2.1
@@ -10,34 +10,37 @@
msgstr ""
"PO-Revision-Date: 2007-06-16 19:30-0300\n"
"Last-Translator: Daniel de Castro Victoria <daniel.victoria at gmail.com>\n"
[...6931 lines suppressed...]
#, fuzzy
-#~ msgstr "Não consegui abrir mapa raster [%s]."
-#, fuzzy
#~ msgstr "Não consegui ler arquivo raster agora."
@@ -29404,10 +29779,6 @@
#, fuzzy
#~ msgstr "mapear."
-#, fuzzy
Index: grassmods_ru.po
RCS file: /grassrepository/grass6/locale/po/grassmods_ru.po,v
retrieving revision 1.34
retrieving revision 1.34.2.1
diff -u -d -r1.34 -r1.34.2.1
--- grassmods_ru.po 21 Sep 2007 22:12:47 -0000 1.34
+++ grassmods_ru.po 23 Nov 2007 17:33:25 -0000 1.34.2.1
@@ -6,32 +6,35 @@
msgstr ""
"Project-Id-Version: grassmods_ru\n"
"PO-Revision-Date: 2006-07-07 11:53+0200\n"
-"Language-Team: Russian <translations at grass.itc.it>\n"
+"Language-Team: Russian <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=KOI8-R\n"
[...6715 lines suppressed...]
#, fuzzy
-#~ msgstr " "
-#, fuzzy
#~ msgid "Unable to get row %d from raster map"
#~ msgstr " "
@@ -27363,10 +27642,6 @@
#, fuzzy
-#~ msgstr " "
-#, fuzzy
#~ msgstr " "
#, fuzzy
Index: grassmods_sl.po
RCS file: /grassrepository/grass6/locale/po/grassmods_sl.po,v
--- grassmods_sl.po 21 Sep 2007 22:12:47 -0000 1.30
+++ grassmods_sl.po 23 Nov 2007 17:33:25 -0000 1.30.2.1
@@ -8,33 +8,36 @@
msgstr ""
"Project-Id-Version: grassmods_sl\n"
"PO-Revision-Date: 2005-06-10 11:15+0200\n"
"Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
-"Language-Team: Sloven¹èina <translations at grass.itc.it>\n"
+"Language-Team: Sloven¹èina <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=ISO-8859-2\n"
[...6872 lines suppressed...]
#, fuzzy
-#~ msgstr "Ime izhodnega rastrskega sloja"
-#, fuzzy
#~ msgstr "Ime rastrskega sloja"
@@ -28285,10 +28603,6 @@
#, fuzzy
#~ msgstr "Ime izhodnega sloja"
-#, fuzzy
-#~ msgstr "Rekodira rastrske sloje"
#, fuzzy
Index: grassmods_tr.po
RCS file: /grassrepository/grass6/locale/po/grassmods_tr.po,v
--- grassmods_tr.po 21 Sep 2007 22:12:48 -0000 1.26
+++ grassmods_tr.po 23 Nov 2007 17:33:26 -0000 1.26.2.1
@@ -6,10 +6,10 @@
msgstr ""
"Project-Id-Version: grassmods_tr\n"
"PO-Revision-Date: 2006-04-17 06:58+0300\n"
"Last-Translator: oyy <yilmazy at istanbul.edu.tr>\n"
-"Language-Team: Turkish <translations at grass.itc.it>\n"
+"Language-Team: Turkish <translations at lists.osgeo.org>\n"
[...6818 lines suppressed...]
#, fuzzy
-#~ msgstr "[%s] raster haritası açılamıyor."
-#, fuzzy
#~ msgstr "Raster satırı okunamıyor."
@@ -27674,10 +27973,6 @@
#, fuzzy
#~ msgid "Writing "
#~ msgstr "Yazılıyor %s ..."
-#, fuzzy
-#~ msgstr " [%s] raster dosyasını ekleme"
#, fuzzy
Index: grassmods_vi.po
RCS file: /grassrepository/grass6/locale/po/grassmods_vi.po,v
retrieving revision 1.32
retrieving revision 1.32.2.1
diff -u -d -r1.32 -r1.32.2.1
--- grassmods_vi.po 21 Sep 2007 22:12:48 -0000 1.32
+++ grassmods_vi.po 23 Nov 2007 17:33:26 -0000 1.32.2.1
@@ -8,32 +8,35 @@
msgstr ""
"Project-Id-Version: grassmods_vi\n"
"PO-Revision-Date: 2006-09-20 09:40+0700\n"
"Last-Translator: Bui Huu Manh <bhmanh73 at yahoo.com>\n"
-"Language-Team: Vietnamese <translations at grass.itc.it>\n"
+"Language-Team: Vietnamese <translations at lists.osgeo.org>\n"
[...6993 lines suppressed...]
#, fuzzy
-#~ msgstr "Không thá» má» bản Äá» raster <%s>"
-#, fuzzy
#~ msgstr "Không thá» Äá»c hà ng raster."
@@ -29107,10 +29492,6 @@
#, fuzzy
#~ msgid "Writing "
#~ msgstr "Äang ghi %s..."
-#, fuzzy
-#~ msgstr "Thêm bản Äá» raster [%s]"
#~ msgstr "%s: %s trong %s - không thá» Äá»c táºp tin phạm trù"
Index: grassmods_zh.po
RCS file: /grassrepository/grass6/locale/po/grassmods_zh.po,v
retrieving revision 1.33
retrieving revision 1.33.2.1
diff -u -d -r1.33 -r1.33.2.1
--- grassmods_zh.po 21 Sep 2007 22:12:48 -0000 1.33
+++ grassmods_zh.po 23 Nov 2007 17:33:27 -0000 1.33.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grassmods_zh\n"
"PO-Revision-Date: 2006-02-15 14:45+0800\n"
[...6836 lines suppressed...]
#, fuzzy
-#~ msgstr "æ æ³å建æ
æ ¼å°å¾ %s"
-#, fuzzy
#~ msgstr "æ æ³è·åè¡ %d (仿
æ ¼å¾ %s ä¸)"
@@ -27872,10 +28206,6 @@
#, fuzzy
#~ msgstr "æ æ³å
³éè¾åºå°å¾"
-#, fuzzy
-#~ msgstr "æ
æ ¼å°å¾ [%s] æªåç°"
#~ msgstr "%sï¼%s (å¨ %s ä¸) - æ æ³è¯»åç±»å«æä»¶"
Index: grasstcl_am.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_am.po,v
retrieving revision 1.2.4.1
diff -u -d -r1.2 -r1.2.4.1
--- grasstcl_am.po 21 Sep 2007 22:12:48 -0000 1.2
+++ grasstcl_am.po 23 Nov 2007 17:33:27 -0000 1.2.4.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasstcl_am\n"
"PO-Revision-Date: 2007-06-07 18:17-0500\n"
"Last-Translator: Solomon Gizaw <solohavi at yahoo.com>\n"
-"Language-Team: <translations at grass.itc.it>\n"
+"Language-Team: <translations at lists.osgeo.org>\n"
"Content-Type: text/plain; charset=utf-8\n"
[...2018 lines suppressed...]
+#: ../gui/tcltk/gis.m/animate.tcl:513
msgid "Maps for frame 4 (optional): "
msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:524
+#: ../gui/tcltk/gis.m/animate.tcl:551
msgid "You must select maps to animate for frame 1"
msgstr ""
-#: ../gui/tcltk/gis.m/animate.tcl:525
+#: ../gui/tcltk/gis.m/animate.tcl:552
#, fuzzy
msgid "No maps selected"
msgstr "ááá áµáá¥áᥠá áá°áá¨á á "
-#: ../gui/tcltk/gis.m/animate.tcl:983
+#: ../gui/tcltk/gis.m/animate.tcl:1019
msgid "Animation Window"
msgstr ""
Index: grasstcl_ar.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_ar.po,v
--- grasstcl_ar.po 21 Sep 2007 22:12:48 -0000 1.7
+++ grasstcl_ar.po 23 Nov 2007 17:33:27 -0000 1.7.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasstcl_ar\n"
"PO-Revision-Date: 2007-03-16 21:31+0100\n"
[...1983 lines suppressed...]
-#: ../gui/tcltk/gis.m/animate.tcl:486
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_cs.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_cs.po,v
retrieving revision 1.15
retrieving revision 1.15.2.1
diff -u -d -r1.15 -r1.15.2.1
--- grasstcl_cs.po 21 Sep 2007 22:12:48 -0000 1.15
+++ grasstcl_cs.po 23 Nov 2007 17:33:27 -0000 1.15.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasstcl_cs\n"
"PO-Revision-Date: 2006-12-27 21:06+0100\n"
"Last-Translator: Martin Landa <landa.martin at gmail.com>\n"
[...2145 lines suppressed...]
msgstr ""
msgstr ""
#, fuzzy
msgstr "Pøevod volume na øadu rastrových vrstev"
msgstr ""
Index: grasstcl_de.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_de.po,v
retrieving revision 1.24
retrieving revision 1.24.2.1
diff -u -d -r1.24 -r1.24.2.1
--- grasstcl_de.po 21 Sep 2007 22:12:48 -0000 1.24
+++ grasstcl_de.po 23 Nov 2007 17:33:27 -0000 1.24.2.1
@@ -9,10 +9,10 @@
msgstr ""
"Project-Id-Version: grasstcl_de\n"
"PO-Revision-Date: 2007-02-23 09:12+0100\n"
"Last-Translator: Stephan Holl <stephan.holl at intevation.de>\n"
-"Language-Team: deutsch <translations at grass.itc.it>\n"
+"Language-Team: deutsch <translations at lists.osgeo.org>\n"
[...2147 lines suppressed...]
msgstr ""
msgstr ""
#, fuzzy
msgstr "Volumen zu Rasterkartenserien"
msgstr ""
Index: grasstcl_el.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_el.po,v
--- grasstcl_el.po 21 Sep 2007 22:12:49 -0000 1.7
+++ grasstcl_el.po 23 Nov 2007 17:33:28 -0000 1.7.2.1
@@ -8,10 +8,10 @@
msgstr ""
"Project-Id-Version: grasstcl_el\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_es.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_es.po,v
retrieving revision 1.58
retrieving revision 1.58.2.1
diff -u -d -r1.58 -r1.58.2.1
--- grasstcl_es.po 22 Oct 2007 15:54:23 -0000 1.58
+++ grasstcl_es.po 23 Nov 2007 17:33:28 -0000 1.58.2.1
@@ -11,10 +11,10 @@
msgstr ""
"Project-Id-Version: grasstcl_es\n"
-"POT-Creation-Date: 2007-10-22 17:52+0200\n"
-"PO-Revision-Date: 2007-10-22 17:40+0200\n"
+"PO-Revision-Date: 2007-10-26 21:33+0200\n"
-"Language-Team: Español <translations at grass.itc.it>\n"
[...1468 lines suppressed...]
#: ../lib/init/file_option.tcl:106
msgid "Browse to locate georeferenced file"
@@ -5541,10 +5532,8 @@
#: ../lib/init/gis_set.tcl:132
#, tcl-format
-msgid ""
-"Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
-msgstr ""
-"AVISO: la localización <%s> en GISDBASE <%s> no es un directorio o no existe."
+msgid "Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
+msgstr "AVISO: la localización <%s> en GISDBASE <%s> no es un directorio o no existe."
#: ../lib/init/gis_set.tcl:177
#, tcl-format
@@ -5967,3 +5956,4 @@
#: ../visualization/nviz/scripts/panel_animation.tcl:275
msgid "Test"
msgstr "Test"
Index: grasstcl_fr.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_fr.po,v
retrieving revision 1.18
retrieving revision 1.18.2.1
diff -u -d -r1.18 -r1.18.2.1
--- grasstcl_fr.po 21 Sep 2007 22:12:49 -0000 1.18
+++ grasstcl_fr.po 23 Nov 2007 17:33:28 -0000 1.18.2.1
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasstcl_fr\n"
"PO-Revision-Date: 2007-08-08 22:40+0200\n"
"Last-Translator: BAIN <bain at toraval.fr>\n"
"Language-Team: french\n"
@@ -57,14 +57,14 @@
#: ../gui/tcltk/gis.m/labels.tcl:136 ../gui/tcltk/gis.m/labels.tcl:140
#: ../gui/tcltk/gis.m/legend.tcl:189 ../gui/tcltk/gis.m/legend.tcl:192
[...2032 lines suppressed...]
msgstr ""
msgstr ""
#, fuzzy
msgstr "Echantillonner des couches rasters"
msgstr ""
Index: grasstcl_hi.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_hi.po,v
retrieving revision 1.13
retrieving revision 1.13.2.1
diff -u -d -r1.13 -r1.13.2.1
--- grasstcl_hi.po 21 Sep 2007 22:12:49 -0000 1.13
+++ grasstcl_hi.po 23 Nov 2007 17:33:28 -0000 1.13.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasstcl_hi\n"
"PO-Revision-Date: 2006-09-19 22:49+0200\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_it.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_it.po,v
retrieving revision 1.19
retrieving revision 1.19.2.1
diff -u -d -r1.19 -r1.19.2.1
--- grasstcl_it.po 21 Sep 2007 22:12:49 -0000 1.19
+++ grasstcl_it.po 23 Nov 2007 17:33:28 -0000 1.19.2.1
@@ -9,10 +9,10 @@
msgstr ""
"Project-Id-Version: grasstcl_it\n"
"PO-Revision-Date: 2006-08-06 17:26+0200\n"
"Last-Translator: Luciano Montanaro <mikelima at cirulla.net>\n"
[...2148 lines suppressed...]
msgstr "Nome frame (opzionale): "
#, fuzzy
msgstr "Devi selezionare una mappa da interrogare\n"
#, fuzzy
msgstr "Nessuno Selezionato"
#, fuzzy
msgstr "Pannello Animazione"
Index: grasstcl_ja.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_ja.po,v
--- grasstcl_ja.po 21 Sep 2007 22:12:49 -0000 1.15
+++ grasstcl_ja.po 23 Nov 2007 17:33:28 -0000 1.15.2.1
@@ -8,10 +8,10 @@
msgstr ""
"Project-Id-Version: grasstcl_ja\n"
"PO-Revision-Date: 2006-06-29 11:49+0200\n"
[...2122 lines suppressed...]
msgstr ""
#, fuzzy
msgstr "鏿 ãã¡ã¤ã«"
#, fuzzy
msgstr "��"
msgstr ""
Index: grasstcl_ko.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_ko.po,v
--- grasstcl_ko.po 21 Sep 2007 22:12:49 -0000 1.7
+++ grasstcl_ko.po 23 Nov 2007 17:33:28 -0000 1.7.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasstcl_ko\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_lv.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_lv.po,v
--- grasstcl_lv.po 21 Sep 2007 22:12:49 -0000 1.13
+++ grasstcl_lv.po 23 Nov 2007 17:33:28 -0000 1.13.2.1
@@ -6,10 +6,10 @@
msgstr ""
"Project-Id-Version: grasstcl_lv\n"
"PO-Revision-Date: 2006-12-09 01:00+0200\n"
[...2020 lines suppressed...]
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_mr.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_mr.po,v
retrieving revision 1.8.2.1
diff -u -d -r1.8 -r1.8.2.1
--- grasstcl_mr.po 21 Sep 2007 22:12:49 -0000 1.8
+++ grasstcl_mr.po 23 Nov 2007 17:33:28 -0000 1.8.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasstcl_mr\n"
-"Language-Team: Marathi <translations at grass.itc.it>\n"
+"Language-Team: Marathi <translations at lists.osgeo.org>\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_pl.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_pl.po,v
retrieving revision 1.20
retrieving revision 1.20.2.1
diff -u -d -r1.20 -r1.20.2.1
--- grasstcl_pl.po 22 Sep 2007 09:08:39 -0000 1.20
+++ grasstcl_pl.po 23 Nov 2007 17:33:28 -0000 1.20.2.1
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grasstcl_pl\n"
"PO-Revision-Date: 2007-09-19 22:10+0100\n"
@@ -53,14 +53,14 @@
[...2135 lines suppressed...]
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_pt.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_pt.po,v
retrieving revision 1.10
retrieving revision 1.10.2.1
diff -u -d -r1.10 -r1.10.2.1
--- grasstcl_pt.po 21 Sep 2007 22:12:49 -0000 1.10
+++ grasstcl_pt.po 23 Nov 2007 17:33:28 -0000 1.10.2.1
@@ -9,10 +9,10 @@
msgstr ""
"Project-Id-Version: grasstcl_pt\n"
-"POT-Creation-Date: 2007-09-21 23:54+0200\n"
"PO-Revision-Date: 2007-06-18 20:35-0300\n"
"Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail dot com>\n"
[...2061 lines suppressed...]
msgstr "Nome do quadro (opcional)"
#, fuzzy
msgstr "Você deve selecionar um mapa para pesquisar\n"
#, fuzzy
msgstr "Nenhuma camada de mapa selecionada"
msgstr ""
Index: grasstcl_pt_br.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_pt_br.po,v
retrieving revision 1.25
retrieving revision 1.25.2.1
diff -u -d -r1.25 -r1.25.2.1
--- grasstcl_pt_br.po 21 Sep 2007 22:12:49 -0000 1.25
+++ grasstcl_pt_br.po 23 Nov 2007 17:33:28 -0000 1.25.2.1
@@ -11,11 +11,11 @@
msgstr ""
"Project-Id-Version: grasstcl_pt_br\n"
"PO-Revision-Date: 2007-06-16 18:27-0300\n"
"Last-Translator: Paulo Eduardo Pasquini Marcondes <paulomarcondes at gmail."
"com>\n"
-"Language-Team: Brazilian Portuguese <translations at grass.itc.it>\n"
+"Language-Team: Brazilian Portuguese <translations at lists.osgeo.org>\n"
#, fuzzy
msgstr "Voc? deve selecionar um mapa para pesquisar\n"
#, fuzzy
msgstr ""
Index: grasstcl_ru.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_ru.po,v
--- grasstcl_ru.po 21 Sep 2007 22:12:49 -0000 1.13
+++ grasstcl_ru.po 23 Nov 2007 17:33:28 -0000 1.13.2.1
@@ -6,10 +6,10 @@
msgstr ""
"Project-Id-Version: grasstcl_ru\n"
msgstr ""
msgstr ""
#, fuzzy
msgstr "÷ÅËÔÏÒÎÁÑ ËÁÒÔÁ:"
msgstr ""
Index: grasstcl_sl.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_sl.po,v
--- grasstcl_sl.po 21 Sep 2007 22:12:49 -0000 1.7
+++ grasstcl_sl.po 23 Nov 2007 17:33:28 -0000 1.7.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasstcl_sl\n"
"PO-Revision-Date: 007-03-16 21:31+0100\n"
-"Language-Team: Sloven�na <translations at grass.itc.it>\n"
+"Language-Team: Sloven�na <translations at lists.osgeo.org>\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
Index: grasstcl_tr.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_tr.po,v
retrieving revision 1.14
retrieving revision 1.14.2.1
diff -u -d -r1.14 -r1.14.2.1
--- grasstcl_tr.po 21 Sep 2007 22:12:49 -0000 1.14
+++ grasstcl_tr.po 23 Nov 2007 17:33:28 -0000 1.14.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasstcl_tr\n"
"PO-Revision-Date: 2006-06-20 16:04+0300\n"
"Last-Translator: Osman Yalçın YILMAZ\n"
[...2126 lines suppressed...]
msgstr ""
msgstr ""
#, fuzzy
msgstr "Hiçbiri seçilmedi"
#, fuzzy
msgstr "Canlandırma Paneli"
Index: grasstcl_vi.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_vi.po,v
--- grasstcl_vi.po 21 Sep 2007 22:12:49 -0000 1.15
+++ grasstcl_vi.po 23 Nov 2007 17:33:28 -0000 1.15.2.1
@@ -8,10 +8,10 @@
msgstr ""
"Project-Id-Version: grasstcl_vi\n"
"PO-Revision-Date: 2006-09-20 12:01+0200\n"
-"Language-Team: vietnamese <translations at grass.itc.it>\n"
+"Language-Team: vietnamese <translations at lists.osgeo.org>\n"
[...2146 lines suppressed...]
msgstr ""
#, fuzzy
msgstr "Chá»n bản Äá» raster Äá» tạo mặt cắt"
#, fuzzy
msgstr "Thá» tÃch thà nh các chuá»i bản Äá» raster"
msgstr ""
Index: grasstcl_zh.po
RCS file: /grassrepository/grass6/locale/po/grasstcl_zh.po,v
--- grasstcl_zh.po 21 Sep 2007 22:12:50 -0000 1.7
+++ grasstcl_zh.po 23 Nov 2007 17:33:28 -0000 1.7.2.1
@@ -7,10 +7,10 @@
msgstr ""
"Project-Id-Version: grasstcl_zh\n"
-"Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
+"Language-Team: Simplified Chinese <translations at lists.osgeo.org>\n"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
