[GRASS-CVS] moritz: grass6/lib/gis rename.c,2.4,2.5
grass at intevation.de grass at intevation.de
Fri Nov 23 15:51:15 EST 2007
Author: moritz
Update of /grassrepository/grass6/lib/gis
In directory doto:/tmp/cvs-serv24816
Modified Files:
	rename.c
Log Message:
add G_rename_file function for renaming files on file system
Index: rename.c
RCS file: /grassrepository/grass6/lib/gis/rename.c,v
retrieving revision 2.4
retrieving revision 2.5
diff -u -d -r2.4 -r2.5
--- rename.c	14 Apr 2007 23:02:00 -0000	2.4
+++ rename.c	23 Nov 2007 20:51:13 -0000	2.5
@@ -19,6 +19,30 @@
+ **\fn int G_rename_file (char *oldname, char *newname)
+ **\brief Rename a file in the filesystem.
+ **The file or directory <b>oldname</b> is renamed to <b>newname</b>.<br>
+ ** \param[in] oldname
+ ** \param[in] newname
+ ** \return 0 if successful
+ ** \return -1 on error
+int G_rename_file ( const char *oldname, const char *newname )
+    #ifdef __MINGW32__
+      remove(oldname);
+    #endif
+    return rename(oldname, newname);
  * \fn int G_rename (char *element, char *oldname, char *newname)
  * \brief Rename a database file.
@@ -60,5 +84,5 @@
     G__file_name (to, element, newname, mapset);
     /* return result of rename */
-    return rename(from, to) == 0 ? 1 : -1;
+    return G_rename_file(from, to) == 0 ? 1 : -1;
