[GRASS-CVS]
martinl: grass6/vector/v.in.ascii a2b.c, 1.17, 1.18 in.c,
1.50, 1.51
grass at intevation.de
Sun Nov 25 06:23:59 EST 2007
Author: martinl
Update of /grassrepository/grass6/vector/v.in.ascii
In directory doto:/tmp/cvs-serv22219
Modified Files:
a2b.c in.c
Log Message:
Run indent
Message standardization
Index: a2b.c
RCS file: /grassrepository/grass6/vector/v.in.ascii/a2b.c,v
retrieving revision 1.17
retrieving revision 1.18
diff -u -d -r1.17 -r1.18
--- a2b.c 6 Oct 2007 01:54:22 -0000 1.17
+++ a2b.c 25 Nov 2007 11:23:57 -0000 1.18
@@ -6,158 +6,164 @@
#define BUFFSIZE 128
-int asc_to_bin(
- FILE *ascii ,
- struct Map_info *Map)
+int asc_to_bin(FILE * ascii, struct Map_info *Map)
- char ctype ;
- char buff[BUFFSIZE];
- double *xarray ;
- double *yarray ;
- double *zarray ;
- double *x, *y, *z;
- int i, n_points, n_coors, n_cats ;
- int type;
- int alloc_points ;
- int end_of_file ;
- struct line_pnts *Points;
- struct line_cats *Cats;
- int catn;
- int cat;
+ char ctype;
+ char buff[BUFFSIZE];
+ double *xarray;
+ double *yarray;
+ double *zarray;
+ double *x, *y, *z;
+ int i, n_points, n_coors, n_cats;
+ int type;
+ int alloc_points;
+ int end_of_file;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ int catn;
+ int cat;
- /* Must always use this to create an initialized line_pnts structure */
- Points = Vect_new_line_struct ();
- Cats = Vect_new_cats_struct ();
+ /* Must always use this to create an initialized line_pnts structure */
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
- end_of_file = 0 ;
- /*alloc_points = 1000 ; */
- alloc_points = 1;
- xarray = (double *) G_calloc(alloc_points, sizeof(double)) ;
- yarray = (double *) G_calloc(alloc_points, sizeof(double)) ;
- zarray = (double *) G_calloc(alloc_points, sizeof(double)) ;
+ end_of_file = 0;
+ /*alloc_points = 1000 ; */
+ alloc_points = 1;
+ xarray = (double *)G_calloc(alloc_points, sizeof(double));
+ yarray = (double *)G_calloc(alloc_points, sizeof(double));
+ zarray = (double *)G_calloc(alloc_points, sizeof(double));
- while( G_getl2(buff,BUFFSIZE-1,ascii) != 0 )
- n_cats=0;
- if (buff[0] == '\0') {
- G_debug(3, "a2b: skipping blank line");
- continue;
+ while (G_getl2(buff, BUFFSIZE - 1, ascii) != 0) {
+ n_cats = 0;
+ if (buff[0] == '\0') {
+ G_debug(3, "a2b: skipping blank line");
+ continue;
- if ( sscanf(buff, "%1c%d%d", &ctype, &n_coors, &n_cats) < 2 || n_coors < 0 || n_cats < 0 ) {
- if (ctype == '#') {
- G_debug(2, "a2b: skipping commented line");
- continue;
- G_fatal_error(_("Error reading ASCII file: (bad type) [%s]"), buff);
+ if (sscanf(buff, "%1c%d%d", &ctype, &n_coors, &n_cats) < 2 ||
+ n_coors < 0 || n_cats < 0) {
if (ctype == '#') {
- G_debug(2, "a2b: Skipping commented line");
+ G_debug(2, "a2b: skipping commented line");
continue;
+ G_fatal_error(_("Error reading ASCII file: (bad type) [%s]"), buff);
+ if (ctype == '#') {
+ G_debug(2, "a2b: Skipping commented line");
+ continue;
- switch(ctype){
- case 'A':
- type = GV_BOUNDARY ;
- break ;
- case 'B':
- break ;
- case 'C':
- type = GV_CENTROID ;
- break ;
- case 'L':
- type = GV_LINE ;
- break ;
- case 'P':
- type = GV_POINT ;
- break ;
- case 'F':
- type = GV_FACE ;
- break ;
- case 'K':
- type = GV_KERNEL ;
- break ;
- case 'a':
- case 'b':
- case 'c':
- case 'l':
- case 'p':
- type = 0; /* dead -> ignore */
- break;
- default:
- G_fatal_error(_("Error reading ASCII file: (unknown type) [%s]"), buff);
- G_debug(5, "feature type = %d", type);
+ switch (ctype) {
+ case 'A':
+ type = GV_BOUNDARY;
+ break;
+ case 'B':
+ break;
+ case 'C':
+ type = GV_CENTROID;
+ break;
+ case 'L':
+ type = GV_LINE;
+ break;
+ case 'P':
+ type = GV_POINT;
+ break;
+ case 'F':
+ type = GV_FACE;
+ break;
+ case 'K':
+ type = GV_KERNEL;
+ break;
+ case 'a':
+ case 'b':
+ case 'c':
+ case 'l':
+ case 'p':
+ type = 0; /* dead -> ignore */
+ break;
+ default:
+ G_fatal_error(_("Error reading ASCII file: (unknown type) [%s]"),
+ buff);
+ G_debug(5, "feature type = %d", type);
- n_points = 0 ;
- x = xarray ;
- y = yarray ;
- z = zarray ;
+ n_points = 0;
+ x = xarray;
+ y = yarray;
+ z = zarray;
- /* Collect the points */
- for( i=0; i<n_coors; i++)
- if ( G_getl2(buff,BUFFSIZE-1,ascii) == 0 )
- G_fatal_error(_("End of ASCII file reached before end of coordinates")) ;
+ /* Collect the points */
+ for (i = 0; i < n_coors; i++) {
+ if (G_getl2(buff, BUFFSIZE - 1, ascii) == 0)
+ G_fatal_error(_
+ ("End of ASCII file reached before end of coordinates"));
- G_debug(3, "a2b: skipping blank line while reading vertices");
- i--;
- continue;
+ G_debug(3, "a2b: skipping blank line while reading vertices");
+ i--;
+ continue;
- *z=0;
- if ( sscanf(buff, "%lf%lf%lf", x, y, z) < 2 )
- G_fatal_error(_("Error reading ASCII file: (bad point) [%s]"), buff);
+ *z = 0;
+ if (sscanf(buff, "%lf%lf%lf", x, y, z) < 2)
+ G_fatal_error(_("Error reading ASCII file: (bad point) [%s]"),
+ buff);
- G_debug( 5, "coor in: %s -> x = %f y = %f z = %f", G_chop(buff), *x, *y, *z);
- n_points++;
- x++;
- y++;
- z++;
- if (n_points >= alloc_points)
- alloc_points = n_points + 1000 ;
- xarray = (double *) G_realloc((void *)xarray, alloc_points * sizeof(double) );
- yarray = (double *) G_realloc((void *)yarray, alloc_points * sizeof(double) );
- zarray = (double *) G_realloc((void *)zarray, alloc_points * sizeof(double) );
- x = xarray + n_points ;
- y = yarray + n_points ;
- z = zarray + n_points ;
+ G_debug(5, "coor in: %s -> x = %f y = %f z = %f", G_chop(buff), *x,
+ *y, *z);
- /* Collect the cats */
- for( i=0; i<n_cats; i++)
- G_fatal_error(_("End of ASCII file reached before end of categories"));
+ n_points++;
+ x++;
+ y++;
+ z++;
- G_debug(3, "a2b: skipping blank line while reading category info");
- i--;
- continue;
+ if (n_points >= alloc_points) {
+ alloc_points = n_points + 1000;
+ xarray =
+ (double *)G_realloc((void *)xarray,
+ alloc_points * sizeof(double));
+ yarray =
+ (double *)G_realloc((void *)yarray,
+ zarray =
+ (double *)G_realloc((void *)zarray,
+ x = xarray + n_points;
+ y = yarray + n_points;
+ z = zarray + n_points;
- if ( sscanf(buff, "%u%u", &catn, &cat) != 2 )
- G_fatal_error(_("Error reading categories: [%s]"), buff);
+ /* Collect the cats */
+ for (i = 0; i < n_cats; i++) {
+ G_fatal_error(_
+ ("End of ASCII file reached before end of categories"));
- Vect_cat_set ( Cats, catn, cat );
+ G_debug(3,
+ "a2b: skipping blank line while reading category info");
+ i--;
+ continue;
- /* Allocation is handled for line_pnts */
- if (0 > Vect_copy_xyz_to_pnts (Points, xarray, yarray, zarray, n_points))
- G_fatal_error(_("Out of memory"));
+ if (sscanf(buff, "%u%u", &catn, &cat) != 2)
+ G_fatal_error(_("Error reading categories: [%s]"), buff);
- if ( type > 0 )
- Vect_write_line ( Map, type, Points, Cats );
- Vect_reset_cats ( Cats );
+ Vect_cat_set(Cats, catn, cat);
- return 0;
+ /* Allocation is handled for line_pnts */
+ if (0 > Vect_copy_xyz_to_pnts(Points, xarray, yarray, zarray, n_points))
+ G_fatal_error(_("Out of memory"));
+ if (type > 0)
+ Vect_write_line(Map, type, Points, Cats);
+ Vect_reset_cats(Cats);
+ return 0;
Index: in.c
RCS file: /grassrepository/grass6/vector/v.in.ascii/in.c,v
retrieving revision 1.50
retrieving revision 1.51
diff -u -d -r1.50 -r1.51
--- in.c 14 Oct 2007 16:43:29 -0000 1.50
+++ in.c 25 Nov 2007 11:23:57 -0000 1.51
@@ -1,3 +1,4 @@
* MODULE: v.in.ascii
@@ -26,474 +27,513 @@
#define A_DIR "dig_ascii"
-int
-main (int argc, char *argv[])
+int main(int argc, char *argv[])
- FILE *ascii;
- struct GModule *module;
- struct Option *old, *new, *delim_opt, *columns_opt, *xcol_opt,
- *ycol_opt, *zcol_opt, *catcol_opt, *format_opt, *skip_opt;
- int xcol, ycol, zcol, catcol, format, skip_lines;
- struct Flag *zcoorf, *t_flag, *e_flag, *noheader_flag, *notopol_flag, *region_flag;
- char *table;
- char *fs;
- int zcoor=WITHOUT_Z, make_table;
+ FILE *ascii;
+ struct GModule *module;
+ struct Option *old, *new, *delim_opt, *columns_opt, *xcol_opt,
+ *ycol_opt, *zcol_opt, *catcol_opt, *format_opt, *skip_opt;
+ int xcol, ycol, zcol, catcol, format, skip_lines;
+ struct Flag *zcoorf, *t_flag, *e_flag, *noheader_flag, *notopol_flag,
+ *region_flag;
+ char *table;
+ char *fs;
+ int zcoor = WITHOUT_Z, make_table;
- struct Map_info Map;
+ struct Map_info Map;
- G_gisinit(argv[0]);
+ G_gisinit(argv[0]);
- module = G_define_module();
- module->keywords = _("vector, import");
- module->description =
- _("Creates a vector map from ASCII points file or ASCII vector file.");
+ module = G_define_module();
+ module->keywords = _("vector, import");
+ module->description =
+ _("Creates a vector map from ASCII points file or ASCII vector file.");
- /************************** Command Parser ************************************/
- old = G_define_standard_option (G_OPT_F_INPUT);
- old->required = NO;
- old->description =
- _("ASCII file to be imported, if not given reads from standard input");
+ /************************** Command Parser ************************************/
+ old = G_define_standard_option(G_OPT_F_INPUT);
+ old->required = NO;
+ old->description =
+ _("ASCII file to be imported, if not given reads from standard input");
- new = G_define_standard_option(G_OPT_V_OUTPUT);
+ new = G_define_standard_option(G_OPT_V_OUTPUT);
- format_opt = G_define_option();
- format_opt->key = "format";
- format_opt->type = TYPE_STRING;
- format_opt->required = NO;
- format_opt->multiple = NO;
- format_opt->options = "point,standard";
- format_opt->answer = "point";
- format_opt->description = _("Input file format");
+ format_opt = G_define_option();
+ format_opt->key = "format";
+ format_opt->type = TYPE_STRING;
+ format_opt->required = NO;
+ format_opt->multiple = NO;
+ format_opt->options = "point,standard";
+ format_opt->answer = "point";
+ format_opt->description = _("Input file format");
- delim_opt = G_define_option();
- delim_opt->key = "fs";
- delim_opt->type = TYPE_STRING;
- delim_opt->required = NO;
- delim_opt->description = _("Field separator");
- delim_opt->answer = "|";
+ delim_opt = G_define_standard_option(G_OPT_F_SEP);
- skip_opt = G_define_option();
- skip_opt->key = "skip";
- skip_opt->type = TYPE_INTEGER;
- skip_opt->required = NO;
- skip_opt->multiple = NO;
- skip_opt->answer = "0";
- skip_opt->description =
- _("Number of header lines to skip at top of input file (points mode)");
+ skip_opt = G_define_option();
+ skip_opt->key = "skip";
+ skip_opt->type = TYPE_INTEGER;
+ skip_opt->required = NO;
+ skip_opt->multiple = NO;
+ skip_opt->answer = "0";
+ skip_opt->description =
+ _("Number of header lines to skip at top of input file (points mode)");
- columns_opt = G_define_option();
- columns_opt->key = "columns";
- columns_opt->type = TYPE_STRING;
- columns_opt->required = NO;
- columns_opt->multiple = NO;
- columns_opt->guisection = _("Columns");
- columns_opt->label = _("Column definition in SQL style (points mode)");
- columns_opt->description = _("For example: "
- "'x double precision, y double precision, cat int, name varchar(10)'");
+ columns_opt = G_define_standard_option(G_OPT_COLUMNS);
+ columns_opt->multiple = NO;
+ columns_opt->guisection = _("Columns");
+ columns_opt->label = _("Column definition in SQL style (points mode)");
+ columns_opt->description = _("For example: "
+ "'x double precision, y double precision, cat int, "
+ "name varchar(10)'");
- xcol_opt = G_define_option();
- xcol_opt->key = "x";
- xcol_opt->type = TYPE_INTEGER;
- xcol_opt->required = NO;
- xcol_opt->multiple = NO;
- xcol_opt->answer = "1";
- xcol_opt->guisection = _("Columns");
- xcol_opt->description =
- _("Number of column used as x coordinate (first column is 1) for points mode");
+ xcol_opt = G_define_option();
+ xcol_opt->key = "x";
+ xcol_opt->type = TYPE_INTEGER;
+ xcol_opt->required = NO;
+ xcol_opt->multiple = NO;
+ xcol_opt->answer = "1";
+ xcol_opt->guisection = _("Columns");
+ xcol_opt->description =
+ _
+ ("Number of column used as x coordinate (first column is 1) for points mode");
- ycol_opt = G_define_option();
- ycol_opt->key = "y";
- ycol_opt->type = TYPE_INTEGER;
- ycol_opt->required = NO;
- ycol_opt->multiple = NO;
- ycol_opt->answer = "2";
- ycol_opt->guisection = _("Columns");
- ycol_opt->description =
- _("Number of column used as y coordinate (first column is 1) for points mode");
+ ycol_opt = G_define_option();
+ ycol_opt->key = "y";
+ ycol_opt->type = TYPE_INTEGER;
+ ycol_opt->required = NO;
+ ycol_opt->multiple = NO;
+ ycol_opt->answer = "2";
+ ycol_opt->guisection = _("Columns");
+ ycol_opt->description =
+ _
+ ("Number of column used as y coordinate (first column is 1) for points mode");
- zcol_opt = G_define_option();
- zcol_opt->key = "z";
- zcol_opt->type = TYPE_INTEGER;
- zcol_opt->required = NO;
- zcol_opt->multiple = NO;
- zcol_opt->answer = "0";
- zcol_opt->guisection = _("Columns");
- zcol_opt->label =
- _("Number of column used as z coordinate (first column is 1) for "
- "points mode");
- zcol_opt->description =
- _("If 0, z coordinate is not used");
+ zcol_opt = G_define_option();
+ zcol_opt->key = "z";
+ zcol_opt->type = TYPE_INTEGER;
+ zcol_opt->required = NO;
+ zcol_opt->multiple = NO;
+ zcol_opt->answer = "0";
+ zcol_opt->guisection = _("Columns");
+ zcol_opt->label =
+ _("Number of column used as z coordinate (first column is 1) for "
+ "points mode");
+ zcol_opt->description = _("If 0, z coordinate is not used");
- catcol_opt = G_define_option();
- catcol_opt->key = "cat";
- catcol_opt->type = TYPE_INTEGER;
- catcol_opt->required = NO;
- catcol_opt->multiple = NO;
- catcol_opt->answer = "0";
- catcol_opt->guisection = _("Columns");
- catcol_opt->label =
- _("Number of column used as category (first column is 1) for points mode");
- catcol_opt->description =
- _("If 0, unique category is assigned to each row and written to new column 'cat'");
+ catcol_opt = G_define_option();
+ catcol_opt->key = "cat";
+ catcol_opt->type = TYPE_INTEGER;
+ catcol_opt->required = NO;
+ catcol_opt->multiple = NO;
+ catcol_opt->answer = "0";
+ catcol_opt->guisection = _("Columns");
+ catcol_opt->label =
+ _
+ ("Number of column used as category (first column is 1) for points mode");
+ catcol_opt->description =
+ _
+ ("If 0, unique category is assigned to each row and written to new column 'cat'");
- zcoorf = G_define_flag ();
- zcoorf->key = 'z';
- zcoorf->description = _("Create 3D file");
+ zcoorf = G_define_flag();
+ zcoorf->key = 'z';
+ zcoorf->description = _("Create 3D file");
- e_flag = G_define_flag();
- e_flag->key = 'e';
- e_flag->description =
- _("Create a new empty map and exit. Nothing is read from input");
+ e_flag = G_define_flag();
+ e_flag->key = 'e';
+ e_flag->description =
+ _("Create a new empty map and exit. Nothing is read from input");
- noheader_flag = G_define_flag();
- noheader_flag->key = 'n';
- noheader_flag->description =
- _("Don't expect a header when reading in standard format");
+ noheader_flag = G_define_flag();
+ noheader_flag->key = 'n';
+ noheader_flag->description =
+ _("Don't expect a header when reading in standard format");
- t_flag = G_define_flag();
- t_flag->key = 't';
- t_flag->description = _("Do not create table in points mode");
+ t_flag = G_define_flag();
+ t_flag->key = 't';
+ t_flag->description = _("Do not create table in points mode");
- notopol_flag = G_define_flag();
- notopol_flag->key = 'b';
- notopol_flag->description = _("Do not build topology in points mode");
+ notopol_flag = G_define_flag();
+ notopol_flag->key = 'b';
+ notopol_flag->description = _("Do not build topology in points mode");
- region_flag = G_define_flag();
- region_flag->key = 'r';
- region_flag->description =
- _("Only import points falling within current region (points mode)");
+ region_flag = G_define_flag();
+ region_flag->key = 'r';
+ region_flag->description =
+ _("Only import points falling within current region (points mode)");
- if (G_parser (argc, argv))
- exit(EXIT_FAILURE);
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
- if ( format_opt->answer[0] == 'p' )
- format = FORMAT_POINT;
- else
- format = FORMAT_ALL;
+ if (format_opt->answer[0] == 'p')
+ format = FORMAT_POINT;
+ else
+ format = FORMAT_ALL;
- skip_lines = atoi(skip_opt->answer);
- if(skip_lines < 0)
- G_fatal_error(_("Please specify reasonable number of lines to skip"));
+ skip_lines = atoi(skip_opt->answer);
+ if (skip_lines < 0)
+ G_fatal_error(_("Please specify reasonable number of lines to skip"));
- if (zcoorf->answer && format == FORMAT_POINT && zcol_opt->answer == "0")
- G_fatal_error(_("Please specify z column"));
+ if (zcoorf->answer && format == FORMAT_POINT && !zcol_opt->answer)
+ G_fatal_error(_("Please specify z column"));
- xcol = atoi(xcol_opt->answer) - 1;
- ycol = atoi(ycol_opt->answer) - 1;
- zcol = atoi(zcol_opt->answer) - 1;
+ xcol = atoi(xcol_opt->answer) - 1;
+ ycol = atoi(ycol_opt->answer) - 1;
+ zcol = atoi(zcol_opt->answer) - 1;
- /* specifying zcol= implies that a 3D map is needed */
- if(zcol>=0 && !zcoorf->answer)
- zcoorf->answer = 1;
+ /* specifying zcol= implies that a 3D map is needed */
+ if (zcol >= 0 && !zcoorf->answer)
+ zcoorf->answer = 1;
- if (zcoorf->answer && format == FORMAT_POINT && zcol < 0)
- G_fatal_error(_("Please specify reasonable z column"));
+ if (zcoorf->answer && format == FORMAT_POINT && zcol < 0)
+ G_fatal_error(_("Please specify reasonable z column"));
- catcol = atoi(catcol_opt->answer) - 1;
+ catcol = atoi(catcol_opt->answer) - 1;
- if ( old->answer != NULL ) {
- if ( (ascii = fopen ( old->answer, "r" ) ) == NULL )
- G_fatal_error(_("Unable to open ASCII file <%s>"), old->answer);
- } else {
- ascii = stdin;
+ if (old->answer != NULL) {
+ if ((ascii = fopen(old->answer, "r")) == NULL) {
+ G_fatal_error(_("Unable to open ASCII file <%s>"), old->answer);
+ else {
+ ascii = stdin;
- fs = delim_opt->answer;
- if ( strcmp(fs,"\\t") == 0 ) fs = "\t";
- if ( strcmp(fs,"tab") == 0 ) fs = "\t";
- if ( strcmp(fs,"space") == 0 ) fs = " ";
+ fs = delim_opt->answer;
+ if (strcmp(fs, "\\t") == 0)
+ fs = "\t";
+ if (strcmp(fs, "tab") == 0)
+ fs = "\t";
+ if (strcmp(fs, "space") == 0)
+ fs = " ";
- /* check dimension */
- if (zcoorf->answer) {
- zcoor = 1;
+ /* check dimension */
+ if (zcoorf->answer) {
+ zcoor = 1;
- Vect_open_new (&Map, new->answer, zcoor);
- Vect_hist_command ( &Map );
+ Vect_open_new(&Map, new->answer, zcoor);
+ Vect_hist_command(&Map);
- if ( e_flag->answer ) {
- Vect_build ( &Map, stdout );
- Vect_close ( &Map );
- exit(EXIT_SUCCESS) ;
+ if (e_flag->answer) {
+ Vect_build(&Map, stdout);
+ Vect_close(&Map);
+ exit(EXIT_SUCCESS);
+ if (format == FORMAT_POINT) {
+ int i, rowlen, ncols, minncols, *coltype, *coltype2, *collen;
+ int n_int = 0, n_double = 0, n_string = 0;
+ char buf[1000];
+ struct field_info *Fi;
+ char *tmp, *key;
+ dbDriver *driver;
+ dbString sql;
+ FILE *tmpascii;
+ /* Open temporary file */
+ tmp = G_tempfile();
+ if (NULL == (tmpascii = fopen(tmp, "w+"))) {
+ G_fatal_error(_("Unable to open temporary file <%s>"), tmp);
+ unlink(tmp);
- if ( format == FORMAT_POINT ) {
- int i, rowlen, ncols, minncols, *coltype, *coltype2, *collen;
- int n_int = 0, n_double = 0, n_string = 0;
- char buf[1000];
- struct field_info *Fi;
- char *tmp, *key;
- dbDriver *driver;
- dbString sql;
- FILE *tmpascii;
+ points_analyse(ascii, tmpascii, fs, &rowlen, &ncols, &minncols,
+ &coltype, &collen, skip_lines, xcol, ycol,
+ region_flag->answer);
- /* Open temporary file */
- tmp = G_tempfile();
- if (NULL == (tmpascii = fopen(tmp, "w+"))) {
- G_fatal_error(_("Unable to open temporary file <%s>"), tmp);
- unlink(tmp);
+ G_message(_("Maximum input row length: %d"), rowlen);
+ G_message(_("Maximum number of columns: %d"), ncols);
+ G_message(_("Minimum number of columns: %d"), minncols);
- points_analyse ( ascii, tmpascii, fs, &rowlen, &ncols, &minncols,
- &coltype, &collen, skip_lines, xcol, ycol, region_flag->answer);
+ /* check column numbers */
+ if (xcol >= minncols) {
+ Vect_delete(new->answer);
+ G_fatal_error(_
+ ("x column number > minimum last column number\n(incorrect field separator?)"));
+ if (ycol >= minncols) {
+ G_fatal_error(_
+ ("y column number > minimum last column number\n(incorrect field separator?)"));
+ if (zcol >= minncols) {
+ G_fatal_error(_("z column number > minimum last column number "
+ "(incorrect field separator?)"));
+ if (catcol >= minncols) {
+ G_fatal_error(_("cat column number > minimum last column number "
- G_message(_("Maximum input row length: %d"), rowlen);
- G_message(_("Maximum number of columns: %d"), ncols);
- G_message(_("Minimum number of columns: %d"), minncols);
+ if (coltype[xcol] == DB_C_TYPE_STRING) {
+ G_fatal_error(_("x column is not of number type"));
+ if (coltype[ycol] == DB_C_TYPE_STRING) {
+ G_fatal_error(_("y column is not of number type"));
+ if (zcol >= 0 && coltype[zcol] == DB_C_TYPE_STRING) {
+ G_fatal_error(_("z column is not of number type"));
+ if (catcol >= 0 && coltype[catcol] == DB_C_TYPE_STRING) {
+ G_fatal_error(_("cat column is not of number type"));
- /* check column numbers */
- if ( xcol >= minncols ) {
- Vect_delete(new->answer);
- G_fatal_error(_("x column number > minimum last column number\n(incorrect field separator?)"));
- if ( ycol >= minncols ) {
- G_fatal_error(_("y column number > minimum last column number\n(incorrect field separator?)"));
- if ( zcol >= minncols ) {
- G_fatal_error(_("z column number > minimum last column number\n(incorrect field separator?)"));
+ /* Create table */
+ make_table = 0;
+ for (i = 0; i < ncols; i++) {
+ if (xcol != i && ycol != i && zcol != i && catcol != i) {
+ make_table = 1;
+ break;
- if ( catcol >= minncols ) {
+ if (t_flag->answer) {
+ make_table = 0;
+ if (make_table) {
+ Fi = Vect_default_field_info(&Map, 1, NULL, GV_1TABLE);
+ driver =
+ db_start_driver_open_database(Fi->driver,
+ Vect_subst_var(Fi->database,
+ &Map));
+ if (driver == NULL) {
- G_fatal_error(_("cat column number > minimum last column number\n(incorrect field separator?)"));
+ G_fatal_error(_("Unavle to open database <%s> by driver <%s>"),
+ Vect_subst_var(Fi->database, &Map), Fi->driver);
+ db_begin_transaction(driver);
- if ( coltype[xcol] == DB_C_TYPE_STRING ) {
- G_fatal_error(_("x column is not of number type"));
- if ( coltype[ycol] == DB_C_TYPE_STRING ) {
- G_fatal_error(_("y column is not of number type"));
- if ( zcol >= 0 && coltype[zcol] == DB_C_TYPE_STRING ) {
- G_fatal_error(_("z column is not of number type"));
+ db_init_string(&sql);
+ sprintf(buf, "create table %s ( ", Fi->table);
+ db_append_string(&sql, buf);
+ if (catcol < 0) {
+ db_append_string(&sql, "cat integer, ");
- if ( catcol >= 0 && coltype[catcol] == DB_C_TYPE_STRING ) {
+ if (i > 0 && !columns_opt->answer) {
+ db_append_string(&sql, ", ");
+ if (catcol == i && coltype[i] != DB_C_TYPE_INT) {
- G_fatal_error(_("cat column is not of number type"));
+ G_fatal_error(_("Category column is not of integer type"));
- /* Create table */
- make_table = 0;
- for ( i = 0 ; i < ncols; i++ ) {
- if ( xcol != i && ycol != i && zcol != i && catcol != i ) {
- make_table = 1;
+ switch (coltype[i]) {
+ case DB_C_TYPE_INT:
+ G_verbose_message("Column: %d type: integer", i + 1);
+ if (!columns_opt->answer) {
+ sprintf(buf, "int_%d integer", n_int + 1);
+ if (catcol == i) {
+ sprintf(buf, "int_%d", n_int + 1);
+ key = G_store(buf);
+ n_int++;
+ break;
+ case DB_C_TYPE_DOUBLE:
+ G_verbose_message("Column: %d type: double", i + 1);
+ sprintf(buf, "dbl_%d double precision", n_double + 1);
+ n_double++;
+ break;
+ case DB_C_TYPE_STRING:
+ G_verbose_message("Column: %d type: string length: %d",
+ i + 1, collen[i]);
+ sprintf(buf, "str_%d varchar(%d)", n_string + 1,
+ collen[i]);
+ n_string++;
break;
- if ( t_flag->answer ) {
- make_table = 0;
+ if (columns_opt->answer) {
+ db_append_string(&sql, columns_opt->answer);
+ db_append_string(&sql, " )");
- if ( make_table ) {
- Fi = Vect_default_field_info ( &Map, 1, NULL, GV_1TABLE );
- driver = db_start_driver_open_database ( Fi->driver, Vect_subst_var(Fi->database,&Map) );
- if ( driver == NULL ) {
- G_fatal_error(_("Cannot open database <%s> by driver <%s>"),
- Vect_subst_var(Fi->database,&Map), Fi->driver );
- db_begin_transaction ( driver );
+ /* this link is added with default 'cat' key, later deleted and replaced by true key name,
+ * otherwise if module crashes when the table exists but link is not written it makes troubles */
+ Vect_map_add_dblink(&Map, 1, NULL, Fi->table, "cat", Fi->database,
+ Fi->driver);
- db_init_string (&sql);
- sprintf ( buf, "create table %s ( ", Fi->table );
- db_append_string ( &sql, buf );
+ G_debug(3, db_get_string(&sql));
+ if (db_execute_immediate(driver, &sql) != DB_OK) {
+ G_fatal_error(_("Unable create table: %s"),
+ db_get_string(&sql));
- if ( catcol < 0 ) {
- db_append_string ( &sql, "cat integer, " );
+ /* Grant */
+ if (db_grant_on_table
+ (driver, Fi->table, DB_PRIV_SELECT,
+ DB_GROUP | DB_PUBLIC) != DB_OK) {
+ G_fatal_error(_("Unable to grant privileges on table <%s>"),
+ Fi->table);
- if ( i > 0 && !columns_opt->answer ) {
- db_append_string ( &sql, ", " );
- if ( catcol == i && coltype[i] != DB_C_TYPE_INT ) {
- G_fatal_error(_("Category column is not of integer type"));
+ /* Check column types */
+ int nc;
+ dbTable *table;
+ dbColumn *column;
- switch ( coltype[i] ) {
- case DB_C_TYPE_INT:
- G_verbose_message ("Column: %d type: integer", i+1);
- if ( !columns_opt->answer ) {
- sprintf ( buf, "int_%d integer", n_int+1);
- db_append_string ( &sql, buf);
- if ( catcol == i ) {
- sprintf ( buf, "int_%d", n_int+1);
- key = G_store( buf );
- n_int++;
- break;
- case DB_C_TYPE_DOUBLE:
- G_verbose_message ("Column: %d type: double", i+1);
- sprintf ( buf, "dbl_%d double precision", n_double+1);
- n_double++;
- break;
- case DB_C_TYPE_STRING:
- G_verbose_message ("Column: %d type: string length: %d", i+1, collen[i]);
- sprintf ( buf, "str_%d varchar(%d)", n_string+1, collen[i]);
- n_string++;
- break;
- if ( columns_opt->answer ) {
- db_append_string ( &sql, columns_opt->answer );
+ db_set_string(&sql, Fi->table);
+ if (db_describe_table(driver, &sql, &table) != DB_OK) {
+ G_fatal_error(_("Unable to describe table <%s>"),
+ Fi->table);
- db_append_string ( &sql, " )" );
- /* this link is added with default 'cat' key, later deleted and replaced by true key name,
- * otherwise if module crashes when the table exists but link is not written it makes troubles */
- Vect_map_add_dblink ( &Map, 1, NULL, Fi->table, "cat", Fi->database, Fi->driver);
+ nc = db_get_table_number_of_columns(table);
- G_debug ( 3, db_get_string ( &sql ) );
- if (db_execute_immediate (driver, &sql) != DB_OK ) {
+ if ((catcol >= 0 && nc != ncols) ||
+ (catcol < 0 && (nc - 1) != ncols)) {
- G_fatal_error(_("Cannot create table: %s"), db_get_string ( &sql ) );
+ G_fatal_error(_
+ ("Number of columns defined (%d) does not match number "
+ "of columns (%d) in input"),
+ catcol < 0 ? nc - 1 : nc, ncols);
- /* Grant */
- if (db_grant_on_table (driver, Fi->table, DB_PRIV_SELECT, DB_GROUP|DB_PUBLIC ) != DB_OK ) {
- G_fatal_error(_("Cannot grant privileges on table <%s>"), Fi->table );
+ coltype2 = (int *)G_malloc(ncols * sizeof(int));
- /* Check column types */
- int nc;
- dbTable *table;
- dbColumn *column;
- db_set_string ( &sql, Fi->table );
- if(db_describe_table (driver, &sql, &table) != DB_OK) {
- G_fatal_error(_("Cannot describe table <%s>"), Fi->table);
- nc = db_get_table_number_of_columns(table);
+ int dbcol, ctype, length;
- if ( (catcol >= 0 && nc != ncols) || (catcol < 0 && (nc-1) != ncols) ) {
- G_fatal_error(_("Number of columns defined (%d) does not match number "
- "of columns (%d) in input"), catcol < 0 ? nc-1 : nc, ncols);
+ if (catcol < 0)
+ dbcol = i + 1; /* first is category */
+ else
+ dbcol = i;
- coltype2 = (int *) G_malloc ( ncols * sizeof(int) );
+ column = db_get_table_column(table, dbcol);
+ ctype = db_sqltype_to_Ctype(db_get_column_sqltype(column));
+ length = db_get_column_length(column);
+ coltype2[i] = ctype;
- for ( i = 0; i < ncols; i++ ) {
- int dbcol, ctype, length;
+ if (catcol == i) { /* if catcol == -1 it cannot be tru */
+ key = G_store(db_get_column_name(column));
- if ( catcol < 0 ) dbcol = i+1; /* first is category */
- else dbcol = i;
- column = db_get_table_column ( table, dbcol );
- ctype = db_sqltype_to_Ctype ( db_get_column_sqltype(column) );
- length = db_get_column_length ( column );
- coltype2[i] = ctype;
- if ( catcol == i ) { /* if catcol == -1 it cannot be tru */
- key = G_store(db_get_column_name(column));
+ if (ctype == DB_C_TYPE_DOUBLE) {
+ G_warning(_("Column number %d defined as double "
+ "has only integer values"), i + 1);
- if ( ctype == DB_C_TYPE_DOUBLE ) {
- G_warning(_("Column number [%d] defined as double has only integer values"), i+1);
- } else if ( ctype == DB_C_TYPE_STRING ) {
- G_warning(_("Column number [%d] defined as string has only integer values"), i+1);
- break;
- if ( ctype == DB_C_TYPE_INT ) {
- G_fatal_error(_("Column number [%d] defined as integer has double values"), i+1);
- G_warning(_("Column number [%d] defined as string has double values"), i+1);
- break;
- G_fatal_error(_("Column number [%d] defined as integer has string values"), i+1);
- } else if ( ctype == DB_C_TYPE_DOUBLE ) {
- G_fatal_error(_("Column number [%d] defined as double has string values"), i+1);
- if ( length < collen[i] ) {
- G_fatal_error(_("Length of column [%d] (%d) is less than maximum value "
- "length (%d)"), i+1, length, collen[i]);
- break;
+ else if (ctype == DB_C_TYPE_STRING) {
+ G_warning(_("Column number %d defined as string "
+ break;
+ if (ctype == DB_C_TYPE_INT) {
+ G_fatal_error(_
+ ("Column number %d defined as integer "
+ "has double values"), i + 1);
+ break;
+ G_fatal_error(_
+ "has string values"), i + 1);
+ else if (ctype == DB_C_TYPE_DOUBLE) {
+ G_fatal_error(_
+ ("Column number %d defined as double "
+ if (length < collen[i]) {
+ G_fatal_error(_
+ ("Length of column %d (%d) is less than "
+ "maximum value " "length (%d)"),
+ i + 1, length, collen[i]);
+ break;
- } else {
- coltype2 = coltype;
- key = "cat";
- } else if ( !columns_opt->answer ) {
+ else {
+ coltype2 = coltype;
- if ( db_create_index2(driver, Fi->table, key ) != DB_OK )
- G_warning(_("Cannot create index"));
+ if (catcol < 0) {
+ key = "cat";
+ else if (!columns_opt->answer) {
- Vect_map_del_dblink ( &Map, 1 );
- Vect_map_add_dblink ( &Map, 1, NULL, Fi->table, key, Fi->database, Fi->driver);
- table = Fi->table;
- } else {
- driver = NULL;
- table = NULL;
- points_to_bin ( tmpascii, rowlen, &Map, driver, table, fs, ncols,
- coltype2, xcol, ycol, zcol, catcol, skip_lines );
+ if (db_create_index2(driver, Fi->table, key) != DB_OK)
+ G_warning(_("Unable to create index for table <%s>, key <%s>"),
+ Fi->table, key);
- if ( driver ) {
- G_message(_("Populating table..."));
- db_commit_transaction ( driver );
- db_close_database_shutdown_driver ( driver );
- fclose (tmpascii);
+ Vect_map_del_dblink(&Map, 1);
+ Vect_map_add_dblink(&Map, 1, NULL, Fi->table, key, Fi->database,
+ Fi->driver);
+ table = Fi->table;
+ else {
+ driver = NULL;
+ table = NULL;
- else { /* FORMAT_ALL (standard mode) */
- if ( ! noheader_flag->answer )
- read_head(ascii, &Map);
+ points_to_bin(tmpascii, rowlen, &Map, driver, table, fs, ncols,
+ coltype2, xcol, ycol, zcol, catcol, skip_lines);
- asc_to_bin(ascii, &Map) ;
+ if (driver) {
+ G_message(_("Populating table..."));
+ db_commit_transaction(driver);
+ db_close_database_shutdown_driver(driver);
+ fclose(tmpascii);
- fclose(ascii);
+ else { /* FORMAT_ALL (standard mode) */
+ if (!noheader_flag->answer)
+ read_head(ascii, &Map);
- if ( notopol_flag->answer ) {
- else {
+ asc_to_bin(ascii, &Map);
- G_done_msg("");
+ fclose(ascii);
- exit(EXIT_SUCCESS);
+ if (notopol_flag->answer) {
+ Vect_close(&Map);
+ else {
+ Vect_close(&Map);
+ G_done_msg(" ");
