[GRASS-CVS] hamish: grass6/scripts/d.monsize d.monsize,1.11,1.12
grass at intevation.de grass at intevation.de
Sun Nov 25 23:03:12 EST 2007
Author: hamish
Update of /grassrepository/grass6/scripts/d.monsize
In directory doto:/tmp/cvs-serv17246
Modified Files:
	d.monsize
Log Message:
please drop or merge with d.resize for GRASS 7
Index: d.monsize
RCS file: /grassrepository/grass6/scripts/d.monsize/d.monsize,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- d.monsize	26 Nov 2007 03:37:11 -0000	1.11
+++ d.monsize	26 Nov 2007 04:03:09 -0000	1.12
@@ -20,7 +20,7 @@
 #### PLEASE REMOVE "SET" FROM OPTION NAMES FOR GRASS 7
-####  (if this module is even used there)
+####  (if this module is even used there; if so merge with d.resize)
 #%Module
 #%  description: Selects/starts specified monitor at specified size
@@ -83,6 +83,7 @@
     g.message -v "Monitor already running and selected"
     g.message "Restarting monitor $GIS_OPT_SETMONITORAT at ${GIS_OPT_SETWIDTH}X${GIS_OPT_SETHEIGHT} ..."
 # d.save > tmp file then source the tmp file to restore after the new mon is opened?
+# (just use d.resize instead)
     d.mon stop=$GIS_OPT_SETMONITOR
 # why the sleep?
     sleep 4
