[GRASS-CVS] hamish: grass6/scripts/d.out.file d.out.file, 1.14, 1.15
grass at intevation.de grass at intevation.de
Mon Nov 26 23:17:18 EST 2007
Author: hamish
Update of /grassrepository/grass6/scripts/d.out.file
In directory doto:/tmp/cvs-serv988
Modified Files:
	d.out.file
Log Message:
support for cairo PS,PDF,SVG output
Index: d.out.file
RCS file: /grassrepository/grass6/scripts/d.out.file/d.out.file,v
retrieving revision 1.14
retrieving revision 1.15
diff -u -d -r1.14 -r1.15
--- d.out.file	22 Nov 2007 09:01:56 -0000	1.14
+++ d.out.file	27 Nov 2007 04:17:15 -0000	1.15
@@ -29,7 +29,7 @@
 #%option
 #% key: format
 #% type: string
-#% options: png,ppm,tif,jpg,bmp,ps,eps
+#% options: png,ppm,tif,jpg,bmp,ps,eps,svg,pdf
 #% answer: png
 #% description: Graphics file format
 #% required : yes
@@ -111,7 +111,7 @@
 #% end
 #%flag
 #% key: c
-#% description: Use the Cario driver instead of the PNG driver
+#% description: Use the Cario driver to render images
 #% guisection: Images
 #% end
 #%flag
@@ -156,6 +156,15 @@
    exit 1
 fi
+case "$GIS_OPT_FORMAT" in
+   pdf | svg)
+     if [ $GIS_FLAG_C -eq 0 ] ; then
+	g.message "Using the Cairo driver."
+	GIS_FLAG_C=1
+     fi
+esac
 if [ $GIS_FLAG_C -eq 1 ] &&  [ `d.mon -l | grep -c '^cairo'` -eq 0 ] ; then
    g.message -e "Cairo driver not present in this build of GRASS."
    exit 1
@@ -205,12 +214,19 @@
 #set output file name and format
-   png | ppm | ps | eps)
+   png | ppm | ps | eps | svg | pdf)
      output="${GIS_OPT_OUTPUT}.${GIS_OPT_FORMAT}"
-   tif | jpg | bmp)
+   tif | jpg)
      output="`g.tempfile pid=$$`.ppm"
+   bmp)
+     if [ $GIS_FLAG_C -eq 1 ] ; then
+	output="${GIS_OPT_OUTPUT}.${GIS_OPT_FORMAT}"
+     else
+	output="`g.tempfile pid=$$`.ppm"
+     fi
 esac
 outname="${GIS_OPT_OUTPUT}.${GIS_OPT_FORMAT}"
@@ -225,14 +241,19 @@
 if [ "$GIS_OPT_FORMAT" = "ps" ] || [ "$GIS_OPT_FORMAT" = "eps" ] ; then
-    if [ $GIS_FLAG_C -eq 1 ] ; then
-	g.message -e "Cairo driver is incompatible with the PostScript driver."
-	exit 1
+    if [ $GIS_FLAG_C -eq 1 ] && [ $GIS_FLAG_R -eq 1 ] ; then
+	g.message -w "Cairo driver doesn't know how to do landscape mode"
     fi
-    GRAPHICS_DRIVER=PS
-    GRASS_PSFILE="$output"
-    export GRASS_PSFILE
+	GRAPHICS_DRIVER=PS
+	GRASS_PSFILE="$output"
+	export GRASS_PSFILE
+    else
+	GRAPHICS_DRIVER=cairo
+	GRASS_CAIROFILE="$output"
+	export GRASS_CAIROFILE
+    fi
     if [ "$GIS_OPT_FORMAT" = "ps" ] ; then
 	GRASS_PAPER="$GIS_OPT_PAPER"
@@ -279,6 +300,7 @@
 g.message "Saving display from Monitor: [$curr_mon] to <$outname>."
+# what does the Cairo/PS driver do?
 if [ "$GIS_OPT_FORMAT" != "ps" ] ; then
     g.message "Image size [$out_width x $out_height]"
 else
@@ -299,14 +321,24 @@
 d.mon select="$curr_mon"
      g.message "Done."
      exit
-   tif | jpg | bmp)
+   tif | jpg)
      # delay not needed if using GRASS_PNG_AUTO_WRITE ?
      g.message "Waiting for file to write ..."
      sleep 5
+   bmp)
+	g.message "Done."
+	exit
+     else
+	# delay not needed if using GRASS_PNG_AUTO_WRITE ?
+	g.message "Waiting for file to write ..."
+	sleep 5
+     fi
 esac
