[GRASS-CVS] carlos: grass6/raster/r.out.vtk main.c,1.13,1.14
grass at intevation.de grass at intevation.de
Wed Nov 28 13:25:58 EST 2007
Author: carlos
Update of /grassrepository/grass6/raster/r.out.vtk
In directory doto:/tmp/cvs-serv1162/r.out.vtk
Modified Files:
	main.c
Log Message:
Message standardization
Index: main.c
RCS file: /grassrepository/grass6/raster/r.out.vtk/main.c,v
retrieving revision 1.13
retrieving revision 1.14
diff -u -d -r1.13 -r1.14
--- main.c	3 Jul 2007 17:35:52 -0000	1.13
+++ main.c	28 Nov 2007 18:25:56 -0000	1.14
@@ -44,7 +44,7 @@
 	mapset = G_find_cell2(param.elevationmap->answer, "");
 	if (mapset == NULL) {
-	    G_fatal_error(_("Cell file [%s] not found\n"),
+	    G_fatal_error(_("Raster map <%s not found"),
 			  param.elevationmap->answer);
 	    exit(EXIT_FAILURE);
@@ -57,7 +57,7 @@
 	    mapset = NULL;
 	    mapset = G_find_cell2(param.input->answers[i], "");
 			      param.input->answers[i]);
 		exit(EXIT_FAILURE);
@@ -76,7 +76,7 @@
 		mapset = NULL;
 		mapset = G_find_cell2(param.rgbmaps->answers[i], "");
-		    G_fatal_error(_("rgb cell map [%s] not found\n"),
+		    G_fatal_error(_("RGB raster map <%s> not found"),
 				  param.rgbmaps->answers[i]);
 		    exit(EXIT_FAILURE);
@@ -100,7 +100,7 @@
 		mapset = NULL;
 		mapset = G_find_cell2(param.vectmaps->answers[i], "");
-		    G_fatal_error(_("vector cell map [%s] not found\n"),
+		    G_fatal_error(_("Vector cell map <%s> not found"),
 				  param.vectmaps->answers[i]);
 		    exit(EXIT_FAILURE);
@@ -221,7 +221,7 @@
 	/* open raster map */
 	fd = G_open_cell_old(param.elevationmap->answer, mapset);
 	if (fd < 0)
-	    G_fatal_error(_("Could not open map %s"),
+	    G_fatal_error(_("Unable to open raster map <%s>"),
 	out_type = G_get_raster_map_type(fd);
@@ -283,7 +283,7 @@
 	    fd = G_open_cell_old(param.input->answers[i], mapset);
 	    if (fd < 0)
 	    /*Now write the data */
@@ -311,7 +311,7 @@
 		rgbfd[i] = G_open_cell_old(param.rgbmaps->answers[i], mapset);
 		if (rgbfd[i] < 0)
 		celltype[i] = G_get_raster_map_type(rgbfd[i]);
@@ -357,7 +357,7 @@
 		vectfd[i] = G_open_cell_old(param.vectmaps->answers[i], mapset);
 		if (vectfd[i] < 0)
 		celltype[i] =
 		    G_get_raster_map_type(vectfd[i]);
