[GRASS-CVS] glynn: grass6/raster/r.series main.c,2.18,2.19
grass at intevation.de
Wed Nov 28 19:52:40 EST 2007
Author: glynn
Update of /grassrepository/grass6/raster/r.series
In directory doto:/tmp/cvs-serv21754/raster/r.series
Modified Files:
main.c
Log Message:
Create integer maps where appropriate
Index: main.c
RCS file: /grassrepository/grass6/raster/r.series/main.c,v
retrieving revision 2.18
retrieving revision 2.19
diff -u -d -r2.18 -r2.19
--- main.c 23 Oct 2007 12:11:17 -0000 2.18
+++ main.c 29 Nov 2007 00:52:38 -0000 2.19
@@ -23,29 +23,30 @@
struct menu
stat_func *method; /* routine to compute new value */
+ int is_int; /* result is an integer */
char *name; /* method name */
char *text; /* menu display - full description */
} menu[] = {
- {c_ave, "average", "average value"},
- {c_count, "count", "count of non-NULL cells"},
- {c_median, "median", "median value"},
- {c_mode, "mode", "most frequently occuring value"},
- {c_min, "minimum", "lowest value"},
- {c_minx, "min_raster","raster with lowest value"},
- {c_max, "maximum", "highest value"},
- {c_maxx, "max_raster","raster with highest value"},
- {c_stddev, "stddev", "standard deviation"},
- {c_range, "range" , "range of values"},
- {c_sum, "sum", "sum of values"},
- {c_var, "variance", "statistical variance"},
- {c_divr, "diversity", "number of different values"},
- {c_reg_m, "slope", "linear regression slope"},
- {c_reg_c, "offset", "linear regression offset"},
- {c_reg_r2, "detcoeff", "linear regression coefficient of determination"},
- {c_quart1, "quart1", "first quartile"},
- {c_quart3, "quart3", "third quartile"},
- {c_perc90, "perc90", "ninetieth percentile"},
- {NULL, NULL, NULL}
+ {c_ave, 0, "average", "average value"},
+ {c_count, 1, "count", "count of non-NULL cells"},
+ {c_median, 0, "median", "median value"},
+ {c_mode, 0, "mode", "most frequently occuring value"},
+ {c_min, 0, "minimum", "lowest value"},
+ {c_minx, 1, "min_raster", "raster with lowest value"},
+ {c_max, 0, "maximum", "highest value"},
+ {c_maxx, 1, "max_raster", "raster with highest value"},
+ {c_stddev, 0, "stddev", "standard deviation"},
+ {c_range, 0, "range" , "range of values"},
+ {c_sum, 0, "sum", "sum of values"},
+ {c_var, 0, "variance", "statistical variance"},
+ {c_divr, 1, "diversity", "number of different values"},
+ {c_reg_m, 0, "slope", "linear regression slope"},
+ {c_reg_c, 0, "offset", "linear regression offset"},
+ {c_reg_r2, 0, "detcoeff", "linear regression coefficient of determination"},
+ {c_quart1, 0, "quart1", "first quartile"},
+ {c_quart3, 0, "quart3", "third quartile"},
+ {c_perc90, 0, "perc90", "ninetieth percentile"},
+ {NULL, 0, NULL, NULL}
struct input
@@ -179,7 +180,7 @@
/* process the output map */
out_name = parm.output->answer;
- out_fd = G_open_raster_new(out_name, DCELL_TYPE);
+ out_fd = G_open_raster_new(out_name, menu[method].is_int ? CELL_TYPE : DCELL_TYPE);
if (out_fd < 0)
G_fatal_error(_("Unable to create raster map <%s>"), out_name);
