[GRASS-CVS] markus: grass6/db/db.login main.c,1.3.4.1,1.3.4.2
grass at intevation.de
Thu Nov 29 05:23:57 EST 2007
Author: markus
Update of /grassrepository/grass6/db/db.login
In directory doto:/tmp/cvs-serv12859
Modified Files:
Tag: releasebranch_6_2
main.c
Log Message:
also interactively query PW (backported)
Index: main.c
RCS file: /grassrepository/grass6/db/db.login/main.c,v
retrieving revision 1.3.4.1
retrieving revision 1.3.4.2
diff -u -d -r1.3.4.1 -r1.3.4.2
--- main.c 23 Aug 2006 07:34:45 -0000 1.3.4.1
+++ main.c 29 Nov 2007 10:23:55 -0000 1.3.4.2
@@ -1,6 +1,26 @@
+ * MODULE: db.login
+ * AUTHOR(S): Radim Blazek <radim.blazek gmail.com> (original contributor)
+ * Glynn Clements <glynn gclements.plus.com>, Markus Neteler <neteler itc.it>
+ * PURPOSE:
+ * COPYRIGHT: (C) 2004-2006 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
#include <stdio.h>
#include <stdlib.h>
+#include <unistd.h>
#include <string.h>
+#include <grass/config.h>
+#ifdef HAVE_TERMIOS_H
+#include <termios.h>
+#endif
#include <grass/gis.h>
#include <grass/dbmi.h>
#include <grass/glocale.h>
@@ -10,13 +30,17 @@
struct Option *driver, *database, *user, *password;
struct GModule *module;
+ struct termios tios, tios2;
+#endif
+ char answer[200];
/* Initialize the GIS calls */
G_gisinit(argv[0]) ;
module = G_define_module();
- module->keywords = _("database, SQL");
- module->description = "Set user/password for driver/database.";
+ module->keywords = _("database, SQL");
+ module->description = _("Sets user/password for driver/database.");
driver = G_define_option() ;
driver->key = "driver" ;
@@ -35,31 +59,57 @@
database->description= "Database name" ;
database->answer = db_get_default_database_name();
- user = G_define_option() ;
+ user = G_define_option() ;
user->key = "user" ;
user->type = TYPE_STRING ;
user->required = NO ;
user->multiple = NO ;
- user->description= "User" ;
+ user->description= _("Username") ;
- password = G_define_option() ;
+ password = G_define_option() ;
password->key = "password" ;
password->type = TYPE_STRING ;
- password->required = NO ;
+ password->required = NO ;
password->multiple = NO ;
- password->description= "Password" ;
+ password->description= _("Password") ;
if(G_parser(argc, argv))
- exit(1);
+ exit(EXIT_FAILURE);
/* set connection */
+ if (!password->answer && isatty(fileno(stdin)) ){
+ for(;;) {
+ tcgetattr(STDIN_FILENO, &tios);
+ tios2 = tios;
+ tios2.c_lflag &= ~ECHO;
+ tcsetattr(STDIN_FILENO, TCSAFLUSH, &tios2);
+#endif
+ do {
+ fprintf (stderr,_("\nEnter database password for connection\n<%s:%s:user=%s>\n"), driver->answer, database->answer, user->answer);
+ fprintf (stderr, _("Hit RETURN to cancel request\n"));
+ fprintf (stderr,">");
+ } while(!G_gets(answer));
+ tcsetattr(STDIN_FILENO, TCSANOW, &tios);
+#endif
+ G_strip(answer);
+ if(strlen(answer)==0) {
+ G_message(_("Exiting. Not changing current settings"));
+ return -1;
+ } else {
+ G_message(_("New password set"));
+ password->answer = G_store(answer);
+ break;
if ( db_set_login ( driver->answer, database->answer, user->answer, password->answer ) == DB_FAILED ) {
- G_fatal_error ( _("Cannot set user/password") );
+ G_fatal_error ( _("Unable to set user/password") );
if ( password->answer )
- G_warning ( _("The password was stored in file.") );
+ G_warning ( _("The password was stored in file") );
- exit(0);
+ exit(EXIT_SUCCESS);
